  4. Modbus Probleme
Modbus Probleme
4 Beiträge 3 Kommentatoren 494 Aufrufe 1 Beobachtet
    mpl1338
    ich habe nun seit einigen Tagen einige Modbus Geräte am laufen und einen Fehler den ich nicht finden kann.
    Im moment sind es 2 Stromzähler und 4 Sensoren
    modbus.2
    2024-04-03 21:30:59.828	info	Disconnected from slave 192.168.178.168
    modbus.2
    2024-04-03 21:30:59.827	debug	Closing client on purpose.
    modbus.2
    2024-04-03 21:30:58.879	debug	[DevID_20/inputRegs] Poll address 0 - 18 registers
    modbus.2
    2024-04-03 21:30:58.879	debug	[DevID_20] Poll start ---------------------
    modbus.2
    2024-04-03 21:30:58.829	debug	Cleaning up request fifo.
    modbus.2
    2024-04-03 21:30:58.829	debug	Clearing timeout of the current request.
    modbus.2
    2024-04-03 21:30:58.829	debug	Socket closed with error
    modbus.2
    2024-04-03 21:30:58.828	warn	Poll error count: 1 code: {"err":"timeout","timeout":12000}
    modbus.2
    2024-04-03 21:30:58.828	error	Client in error state.
    modbus.2
    2024-04-03 21:30:58.828	error	Request timed out.
    modbus.2
    2024-04-03 21:30:58.827	warn	Error: undefined
    modbus.2
    2024-04-03 21:30:46.826	debug	[DevID_10/inputRegs] Poll address 290 - 2 registers
    modbus.2
    2024-04-03 21:30:46.826	debug	[DevID_10] Poll start ---------------------
    modbus.2
    2024-04-03 21:32:38.364	info	Disconnected from slave 192.168.178.168
    modbus.2
    2024-04-03 21:32:38.363	debug	Closing client on purpose.
    modbus.2
    2024-04-03 21:32:37.362	debug	Cleaning up request fifo.
    modbus.2
    2024-04-03 21:32:37.362	debug	Clearing timeout of the current request.
    modbus.2
    2024-04-03 21:32:37.362	debug	Socket closed with error
    modbus.2
    2024-04-03 21:32:37.362	warn	Poll error count: 1 code: {"err":"timeout","timeout":12000}
    modbus.2
    2024-04-03 21:32:37.361	error	Client in error state.
    modbus.2
    2024-04-03 21:32:37.361	error	Request timed out.
    modbus.2
    2024-04-03 21:32:37.361	warn	Error: undefined
    modbus.2
    2024-04-03 21:32:25.359	debug	[DevID_40/inputRegs] Poll address 1 - 2 registers
    modbus.2
    2024-04-03 21:32:25.359	debug	[DevID_40] Poll start ---------------------
    Mal steigt er bei einem Zähler aus, mal bei einem Sensor.
    Als Gateway nutze ich dieses hier:
    https://de.aliexpress.com/item/1005006035644415.html?spm=a2g0o.productlist.main.11.1160ZXsRZXsRcf&algo_pvid=ae14b8f0-525e-47a0-ada2-e3ffa9182576&algo_exp_id=ae14b8f0-525e-47a0-ada2-e3ffa9182576-5&pdp_npi=4%40dis!EUR!21.53!21.53!!!22.65!22.65!%40210386d117121728178691045ebc5f!12000035422512783!sea!DE!134662450!&curPageLogUid=LJMIVraIbJdf&utparam-url=scene%3Asearch|query_from%3A
    Abschlusswiderstände sind gesetzt, schirm der Leitungen verbunden, Bias wurde auch mal getestet, keine Änderung.
    Geräte einzeln laufen ohne Probleme.
    Bin am Ende :/ kann mir jemand weiterhelfen?
    Ist das Gateway eventuell schrott?
    S W 2 Antworten Letzte Antwort
    • M mpl1338
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      modbus.2
      SuFra
      @mpl1338 Schonmal den Timeout fürs Pollen hochgestellt?
      Ich habe bei mir glaube ich 60000 drin stehen.
      Ab und zu hakt die Abfrage, habe aber ein anderes Setup.
      HA-Cluster 1x NUC11TNHI50L00, 2x NUC11TNHI30L00, 1x BSi3, 1x BSi5
      LXC's: PiHole, Grafana, MariaDB, TasmoAdmin, NTP Server, PeaNUT, ESPHome, paperless-ai, ollama
      VM's: PBS, ioBroker, frigate, paperless, trueNAS (Plex)
      • M mpl1338
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        modbus.2
        W Offline
        W Offline
        warp735
        @mpl1338
        Ich hab die "old Version" von dem Ding und läuft einwandfrei
        • S SuFra
          mpl1338
          @sufra
          habe verschiedene Pollzeiten versucht, keine änderung.
