  4. Mysensors
Mysensors
Geplant Angeheftet Gesperrt Verschoben Gelöst ioBroker Allgemein
mysensors
4 Beiträge 2 Kommentatoren 1.5k Aufrufe 1 Beobachtet
  • W Offline
    W Offline
    winny1900
    Ich bekomme immer eine Fehlermeldung im Log
    mysensors.0 2017-08-22 23:34:14.440 warn ID not found. Inclusion mode OFF: {"id":"0","childId":"255","type":"presentation","ack":false,"payload":"2.1.0","subType":"S_ARDUINO_RELAY"}
    mysensors.0 2017-08-22 23:34:14.425 warn ID not found. Inclusion mode OFF: {"id":"0","childId":"255","type":"presentation","ack":false,"payload":"2.1.0","subType":"S_ARDUINO_RELAY"}
    Das ist der Sketch fürs Gateway
    * The MySensors Arduino library handles the wireless radio link and protocol
    * between your home built sensors/actuators and HA controller of choice.
    * The sensors forms a self healing radio network with optional repeaters. Each
    * repeater and gateway builds a routing tables in EEPROM which keeps track of the
    * network topology allowing messages to be routed to nodes.
    * Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
    * Copyright (C) 2013-2015 Sensnology AB
    * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
    * Documentation: http://www.mysensors.org
    * Support Forum: http://forum.mysensors.org
    * This program is free software; you can redistribute it and/or
    * modify it under the terms of the GNU General Public License
    * version 2 as published by the Free Software Foundation.
    * DESCRIPTION
    * The ArduinoGateway prints data received from sensors on the serial link.
    * The gateway accepts input on seral which will be sent out on radio network.
    * The GW code is designed for Arduino Nano 328p / 16MHz
    * Wire connections (OPTIONAL):
    * - Inclusion button should be connected between digital pin 3 and GND
    * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
    * LEDs (OPTIONAL):
    * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
    * - RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
    * - TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
    * - ERR (red) - fast blink on error during transmission error or recieve crc error
    // Enable debug prints to serial monitor
    #define MY_DEBUG
    // Enable and select radio type attached
    #define MY_RADIO_NRF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM69
    //#define MY_RADIO_RFM95
    // Set LOW transmit power level as default, if you have an amplified NRF-module and
    // power your radio separately with a good regulator you can turn up PA level.
    #define MY_RF24_PA_LEVEL RF24_PA_LOW
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    #endif
    // Enable inclusion mode
    #define MY_INCLUSION_MODE_FEATURE
    // Enable Inclusion mode button on gateway
    //#define MY_INCLUSION_BUTTON_FEATURE
    // Inverses behavior of inclusion button (if using external pullup)
    //#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
    // Set inclusion mode duration (in seconds)
    #define MY_INCLUSION_MODE_DURATION 60
    // Digital pin used for inclusion mode button
    //#define MY_INCLUSION_MODE_BUTTON_PIN  3
    // Set blinking period
    #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Inverses the behavior of leds
    //#define MY_WITH_LEDS_BLINKING_INVERSE
    // Flash leds on rx/tx/err
    // Uncomment to override default HW configurations
    //#define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  6  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  5  // the PCB, on board LED
    #include <mysensors.h>
    void setup()
        // Setup locally attached sensors
    void presentation()
        // Present locally attached sensors
    void loop()
        // Send locally attached sensor data here
    }</mysensors.h></henrik.ekblad@mysensors.org>
    Das GAteway läuft auf einem Nano
    • W Offline
      W Offline
      winny1900
      • W Offline
        W Offline
        winny1900
        Hat sich erledigt läuft
        • W winny1900
          D3rr1ck
          @winny1900
          Hallo winny1900, ich habe das gleiche Problem wie in Deinem Screenshot. Die Verbindung zum raspberry-Gateway will nicht gelingen.
          Wie hast Du das Problem lösen können?
