  4. Gelöst ESPHome (kann gelöscht werden)
1 Beiträge 1 Kommentatoren 250 Aufrufe 1 Beobachtet
  • TbsJahT Offline
    TbsJahT Offline
    TbsJah
    schrieb am zuletzt editiert von TbsJah
    Scheinbar bin ich zu blöd oder unwissend ESPHome zu laufen zu bekommen.
    Neu aufgesetzter Rasp 5 8GB
    ESPHome wie gewohnt installiert aber bei dem Start das Dashboards erhalte ich diese Fehlermeldung
    (venv) pi@raspberrypi:~/esphome $ esphome dashboard config/
    2024-03-06 09:43:56,684 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir config/...
    Traceback (most recent call last):
     File "/home/pi/esphome/venv/bin/esphome", line 8, in <module>
       sys.exit(main())
     File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/__main__.py", line 1041, in main
       return run_esphome(sys.argv)
     File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/__main__.py", line 1004, in run_esphome
       return PRE_CONFIG_ACTIONS[args.command](args)
     File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/__main__.py", line 518, in command_dashboard
       return dashboard.start_dashboard(args)
     File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/dashboard/dashboard.py", line 129, in start_dashboard
       asyncio.run(async_start(args))
     File "/usr/lib/python3.11/asyncio/runners.py", line 190, in run
       return runner.run(main)
     File "/usr/lib/python3.11/asyncio/runners.py", line 118, in run
       return self._loop.run_until_complete(task)
     File "/usr/lib/python3.11/asyncio/base_events.py", line 653, in run_until_complete
       return future.result()
     File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/dashboard/dashboard.py", line 150, in async_start
       await dashboard.async_run()
     File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/dashboard/core.py", line 104, in async_run
       await self.entries.async_update_entries()
     File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/dashboard/entries.py", line 144, in async_update_entries
       await self._async_update_entries()
     File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/dashboard/entries.py", line 163, in _async_update_entries
       path_to_cache_key = await self._loop.run_in_executor(
     File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
       result = self.fn(*self.args, **self.kwargs)
     File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/dashboard/entries.py", line 220, in _get_path_to_cache_key
       for file in util.list_yaml_files([self._config_dir]):
     File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/util.py", line 266, in list_yaml_files
       [os.path.join(folder, p) for folder in folders for p in os.listdir(folder)]
     File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/util.py", line 266, in <listcomp>
    FileNotFoundError: [Errno 2] No such file or directory: 'config/'
    Ich check es nicht - vielleicht habt ihr eine Idee woran es liegen könnte
    (venv) pi@raspberrypi:~/esphome $ python3 --version
    Python 3.11.2
    (venv) pi@raspberrypi:~/esphome $ node -v
    v18.19.1
    (venv) pi@raspberrypi:~/esphome $ npm -v
    10.2.4
    (venv) pi@raspberrypi:~/esphome $ lsb_release -a
    No LSB modules are available.
    Distributor ID: Debian
    Description:    Debian GNU/Linux 12 (bookworm)
    Release:        12
    Codename:       bookworm
    (venv) pi@raspberrypi:~/esphome $ esphome version
    Version: 2024.2.2
