  3. Einsteigerfragen
  4. Installation
  5. Buanet ioBroker Docker Aktualisierung
Geplant Angeheftet Gesperrt Verschoben Installation
9 Beiträge 3 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • C Offline
    CoComp
    schrieb am zuletzt editiert von CoComp
    Moin,
    nachdem ihr mir schon einmal so toll geholfen habet, habe ich eine Frage.
    Ich habe auf meiner Synology DS218+ in Dockercontainer meine InfluxDB und den ioBroker laufen. Letzteren habe ich 07/2022 erstellt.
       "CapAdd" : null,
       "CapDrop" : null,
       "cmd" : "",
       "cpu_priority" : 50,
       "enable_publish_all_ports" : false,
       "enable_restart_policy" : true,
       "enable_service_portal" : false,
       "enabled" : false,
       "entrypoint_default" : "/bin/bash -c /opt/scripts/iobroker_startup.sh",
       "env_variables" : [
             "key" : "PATH",
             "value" : "/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
             "key" : "DEBIAN_FRONTEND",
             "value" : "teletype"
             "key" : "LANG",
             "value" : "de_DE.UTF-8"
             "key" : "LANGUAGE",
             "value" : "de_DE:de"
             "key" : "LC_ALL",
             "key" : "SETGID",
             "value" : "1000"
             "key" : "SETUID",
             "value" : "1000"
             "key" : "TZ",
             "value" : "Europe/Berlin"
       "exporting" : false,
       "id" : "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
       "image" : "buanet/iobroker:latest",
       "is_ddsm" : false,
       "is_package" : false,
       "labels" : {
          "org.opencontainers.image.authors" : "André Germann <info@buanet.de>",
          "org.opencontainers.image.base.name" : "docker.io/library/debian:bullseye-slim",
          "org.opencontainers.image.created" : "2022-07-05T18:51:52+00:00",
          "org.opencontainers.image.description" : "Officical Docker image for ioBroker smarthome software (https://www.iobroker.net)",
          "org.opencontainers.image.documentation" : "https://github.com/buanet/ioBroker.docker#readme",
          "org.opencontainers.image.source" : "https://github.com/buanet/ioBroker.docker",
          "org.opencontainers.image.title" : "Official ioBroker Docker Image",
          "org.opencontainers.image.url" : "https://github.com/buanet/ioBroker.docker",
          "org.opencontainers.image.version" : "v7.0.1"
       "links" : [],
       "memory_limit" : 0,
       "name" : "buanet-iobroker",
       "network" : [
             "driver" : "bridge",
             "name" : "bridge"
       "network_mode" : "bridge",
       "port_bindings" : [
             "container_port" : 8081,
             "host_port" : 56666,
             "type" : "tcp"
             "container_port" : 8082,
             "host_port" : 56667,
             "type" : "tcp"
       "privileged" : false,
       "shortcut" : {
          "enable_shortcut" : false
       "use_host_network" : false,
       "version" : 2,
       "volume_bindings" : [
             "host_volume_file" : "/docker/iobroker",
             "is_directory" : true,
             "mount_point" : "/opt/iobroker",
             "type" : "rw"
    In der Containerverwaltung von meinem NAS wird mir aber nicht die Möglichkeit angezeigt, den Container auf eine aktuelle Version zu bringen, so, wie in der Anleitung von Marius https://mariushosting.com/synology-how-to-update-containers-in-container-manager/ zu sehen.
    Liegt das daran, dass meine Installation aus der Zeit vor dem Containermanager kommt?
    Ich würde jetzt
    • list itemmanuell die Adapter im Container so weit wie möglich updaten,
    • list item dann im ioBroker ein Backup machen,
    • list item den Container stoppen und umbenennen.
    • list itemDann einen neuen Container mit dem aktuellen Buanet erstellen und an das bestehende Verzeichnis mounten.
    Oder ist das falsch oder zu umständlich?
    CodierknechtC GlasfaserG 3 Antworten Letzte Antwort
    • C CoComp
      Moin,
         "CapAdd" : null,
         "CapDrop" : null,
         "cmd" : "",
         "enabled" : false,
         "env_variables" : [
               "key" : "PATH",
               "key" : "LANG",
               "key" : "LANGUAGE",
               "key" : "LC_ALL",
               "key" : "SETGID",
               "value" : "1000"
               "key" : "SETUID",
               "value" : "1000"
               "key" : "TZ",
         "is_ddsm" : false,
         "labels" : {
         "links" : [],
         "memory_limit" : 0,
         "network" : [
               "name" : "bridge"
         "port_bindings" : [
               "type" : "tcp"
               "type" : "tcp"
         "shortcut" : {
         "version" : 2,
               "type" : "rw"
      Ich würde jetzt
      CodierknechtC Offline
      Codierknecht
      @cocomp sagte in Buanet ioBroker Docker Aktualisierung:
      Nö. Passt im Prinzip schon.
      ... und hoffentlich seitdem einigermaßen aktuell gehalten?
      Nimm mal die "list item" da raus. Kann man kaum lesen ;-)
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • C CoComp
        Moin,
           "CapAdd" : null,
           "CapDrop" : null,
           "cmd" : "",
           "enabled" : false,
           "env_variables" : [
                 "key" : "PATH",
                 "key" : "LANG",
                 "key" : "LANGUAGE",
                 "key" : "LC_ALL",
                 "key" : "SETGID",
                 "value" : "1000"
                 "key" : "SETUID",
                 "value" : "1000"
                 "key" : "TZ",
           "is_ddsm" : false,
           "labels" : {
           "links" : [],
           "memory_limit" : 0,
           "network" : [
                 "name" : "bridge"
           "port_bindings" : [
                 "type" : "tcp"
                 "type" : "tcp"
           "shortcut" : {
           "version" : 2,
                 "type" : "rw"
        Ich würde jetzt
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        "v7.0.1"
        ... das sieht man ... ist schon sehr alt .
        wie alt ist denn sonst noch alles , hast du noch JS-Controller "4.x" !?
        C 1 Antwort Letzte Antwort
        • C CoComp
          Moin,
             "CapAdd" : null,
             "CapDrop" : null,
             "cmd" : "",
             "enabled" : false,
             "env_variables" : [
                   "key" : "PATH",
                   "key" : "LANG",
                   "key" : "LANGUAGE",
                   "key" : "LC_ALL",
                   "key" : "SETGID",
                   "value" : "1000"
                   "key" : "SETUID",
                   "value" : "1000"
                   "key" : "TZ",
             "is_ddsm" : false,
             "labels" : {
             "links" : [],
             "memory_limit" : 0,
             "network" : [
                   "name" : "bridge"
             "port_bindings" : [
                   "type" : "tcp"
                   "type" : "tcp"
             "shortcut" : {
             "version" : 2,
                   "type" : "rw"
          Ich würde jetzt
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          Ich würde jetzt
          würde dann bei einem " Versionssprung " von 7.x auf 9.x
          diese nicht machen :
          sondern einen leeren neuen Mount Ordner nehmen und das Backup im neuen IoBroker einspielen !
          • GlasfaserG Glasfaser
            "v7.0.1"
            CoComp
            @glasfaser said in Buanet ioBroker Docker Aktualisierung:
            "v7.0.1"
            Ja, läuft noch mit js-controller 4.0.23.
            Bis jetzt läuft bei mir fast alles über Loxone und der IoBroker war nur Datensammler und Schnittstelle zu meiner InfluxDB2. Ich wollte das ganze ein aber bisschen straffen und damit den ioBroker stärker nutzen.
            Daher die Überlegung, alles was geht, im Container auf den aktuellst möglichen Stand zu bringen, dann Backup, neuer Container und Backup zurück. Der js-controller wird mir unter "Host" ja auch zum Update auf 5.0.17 angeboten
            CodierknechtC GlasfaserG 2 Antworten Letzte Antwort
            • C CoComp
              "v7.0.1"
              Codierknecht
              Dann mach's so wie @Glasfaser es vorgeschlagen hat. Und kümmere Dich künftig regelmäßiger um die Aktualisierung des Systems.
              Ob die dann langfristig genügend Power hat, steht auf einem anderen Blatt.
              • C CoComp
                "v7.0.1"
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                und Backup zurück.
                Im neuen Image ist schon der js-controller 5.x.x vorhanden und der passt dann nicht mit einem Backup von js-controller 4 . ( kann man einspielen , aber mit Umwege )
                ... aber alles eine richtige Überlegung von dir ... 👍
                dann auch noch so wie ich beschrieben habe , dann ist alles sauber !
                  und Backup zurück.
                  CoComp
                  @glasfaser
                  Moin, ich habe jetzt alle Adapter im aktuellen Container aktualisiert und würde jetzt auf der Konsole
                  • iobroker stop
                  • iobroker update
                  • iobroker fix
                  • iobroker upgrade self
                  • iobroker start
                  durchführen, dann BackUp, dann neuen Container mit neuem Verzeichnis mounten und das BackUp zurückspielen,
                  Richtig?
                  • C CoComp
                    @glasfaser
                    • iobroker stop
                    • iobroker update
                    • iobroker fix
                    • iobroker start
                    Richtig?
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    @cocomp
                    So
                    pkill -u iobroker
                    iobroker update
                    iobroker fix
                    Container neu starten
                    dann
