  4. OpenMQTTGateway reagiert nicht
2 Beiträge 2 Kommentatoren 573 Aufrufe 2 Beobachtet
    RichieXX
    Hallo.
    Ich bin zugegebener Maßen Einsteiger beim Thema 433MHz und hatte mir das eigentlich einfacher vorgestellt. Ich scheitere schon beim Empfangen der Signale mit einem ESP32dev1 (habe auch schon andere ESP32 und ESP8266 probiert) und einem C1101. Das OMG ist geflasht und läuft,
    N: OpenMQTTGateway URL: http://192.168.253.12/
    N: ZwebUI setup done
    N: Config frequency changed: false
    N: RF Receive mhz: 433.92
    N: RF receiver active: 3
    N: Config active changed: false
    N: C1101 spi Connection OK
    N: Enable RF Receiver: 433.92Mhz
    N: RF_EMITTER_GPIO: 12
    N: RF_RECEIVER_GPIO: 27
    N: RF Config loaded
    N: ZgatewayRTL_433 setup done
    N: OpenMQTTGateway modules: ["WebUI","RF","RF2","RTL_433"]
    N: ************** Setup OpenMQTTGateway end **************
    W: MQTT connection...
    N: Connected to broker
    N: Send on /RFtoMQTT msg {"active":2,"frequency":433.92}
    N: Update check, free heap: 171972N: Update check done, free heap: 128872N: Send on /SYStoMQTT msg {"uptime":3,"version":"v1.7.0","disc":true,"ohdisc":false,"env":"esp32dev-multi_receiver","freemem":173716,"mqttp":"1883","mqtts":false,"msgprc":0,"msgblck":0,"maxq":0,"minmem":170556,"tempc":55,"freestck":4560,"eth":false,"rssi":-87,"SSID":"BLUELAN","BSSID":"BC:CF:4F:CD:AA:05","ip":"192.168.253.12","mac":"CC:50:E3:99:DB:F8","modules":["WebUI","RF","RF2","RTL_433"]}
    N: Send on /WebUItoMQTT msg {"displayMetric":true,"webUISecure":true,"displayQueue":0}
    N: Send on /RLStoMQTT msg {"latest_version":"v1.7.0","title":"OpenMQTTGateway","release_url":"https://github.com/1technophile/OpenMQTTGateway/releases/tag/v1.7.0","installed_version":"v1.7.0","entity_picture":"https://github.com/1technophile/OpenMQTTGateway/raw/development/docs/img/Openmqttgateway_logo_mini_margins.png","release_summary":""}
    N: [ MQTT->OMG ]: {"value":1023,"protocol":29,"length":9,"delay":270,"tre_state":"0000","binary":"000000000","raw":"12436,211,347,316,350,138,350,625,348,361,373,362,338,363,366,364,386,361"}
    N: Send on /SYStoMQTT msg {"uptime":123,"version":"v1.7.0","disc":true,"ohdisc":false,"env":"esp32dev-multi_receiver","freemem":178460,"mqttp":"1883","mqtts":false,"msgprc":3,"msgblck":0,"maxq":3,"minmem":110452,"tempc":53.89,"freestck":2332,"eth":false,"rssi":-85,"SSID":"BLUELAN","BSSID":"BC:CF:4F:CD:AA:05","ip":"192.168.253.12","mac":"CC:50:E3:99:DB:F8","modules":["WebUI","RF","RF2","RTL_433"]}
    empfängt aber keinerlei Signale von einer Steckdosenfernbedienung (schon ziemlich alt) und auch von einer Motorsteuerung (das ist das Ziel des Projekts). Verwendet habe ich schon mehrere Images ohne irgendwelche Erfolge. Mit dem Image "esp32dev-multi_receiver" reagiert der ESP32 zumindest mit dem Blinken der blauen LED sobald eine Taste an einer FB gedrückt wird. Jedoch keinerlei Reaktion in der Konsole des OMG. Wo könnte mein (Denk-)Fehler liegen?
    alkA 1 Antwort Letzte Antwort
    • R RichieXX
      Hallo.
      N: RF Config loaded
      alkA Offline
      alkA Offline
      alk
      @richiexx hallo, ist das Thema noch relevant ?
      • DIY Electronics that do their job
      • EV, WB, PV + Battery and optimized charging ;-)
