  3. Einsteigerfragen
  4. Backup einspielen
Backup einspielen
4 Beiträge 3 Kommentatoren 268 Aufrufe 3 Beobachtet
  • O Offline
    O Offline
    Oebler
    ich habe über backitup ein Backup meiner ioBroker Installation gemacht.
    Nun habe ich mit Portainer einen Container mit der aktuellen Version (buanet) erstellt.
    Leider kann ich darin nicht mein Backup installieren (weder über Google Drive noch durch hochladen.
    Die Fehlermeldung sieht folgendermaßen aus:
    2024-01-13 21:11:01.619 - error: backitup.0 (62738) uncaught exception: listen EADDRINUSE: address already in use :::9081
    2024-01-13 21:11:01.631 - error: backitup.0 (62738) Error: listen EADDRINUSE: address already in use :::9081
    at Server.setupListenHandle [as _listen2] (node:net:1817:16)
    at listenInCluster (node:net:1865:12)
    at Server.listen (node:net:1953:7)
    at Function.listen (/opt/iobroker/node_modules/express/lib/application.js:635:24)
    at dlFileServer (/opt/iobroker/node_modules/iobroker.backitup/main.js:1703:39)
    at AdapterClass. (/opt/iobroker/node_modules/iobroker.backitup/main.js:311:29)
    at AdapterClass.emit (node:events:517:28)
    at AdapterClass.emit (node:domain:489:12)
    at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11143:34)
    at Immediate. (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:379:37)
    2024-01-13 21:11:01.632 - error: backitup.0 (62738) Exception-Code: EADDRINUSE: listen EADDRINUSE: address already in use :::9081
    2024-01-13 21:11:01.709 - info: backitup.0 (62738) cleaned everything up...
    2024-01-13 21:11:01.711 - info: backitup.0 (62738) terminating
    2024-01-13 21:11:01.717 - warn: backitup.0 (62738) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-01-13 21:11:02.221 - error: host.427605deb40c Caught by controller[0]: Error: listen EADDRINUSE: address already in use :::9081
    2024-01-13 21:11:02.224 - error: host.427605deb40c Caught by controller[0]: at Server.setupListenHandle [as _listen2] (node:net:1817:16)
    2024-01-13 21:11:02.225 - error: host.427605deb40c Caught by controller[0]: at listenInCluster (node:net:1865:12)
    2024-01-13 21:11:02.225 - error: host.427605deb40c Caught by controller[0]: at Server.listen (node:net:1953:7)
    2024-01-13 21:11:02.226 - error: host.427605deb40c Caught by controller[0]: at Function.listen (/opt/iobroker/node_modules/express/lib/application.js:635:24)
    2024-01-13 21:11:02.226 - error: host.427605deb40c Caught by controller[0]: at dlFileServer (/opt/iobroker/node_modules/iobroker.backitup/main.js:1703:39)
    2024-01-13 21:11:02.227 - error: host.427605deb40c Caught by controller[0]: at AdapterClass. (/opt/iobroker/node_modules/iobroker.backitup/main.js:311:29)
    2024-01-13 21:11:02.228 - error: host.427605deb40c Caught by controller[0]: at AdapterClass.emit (node:events:517:28)
    2024-01-13 21:11:02.228 - error: host.427605deb40c Caught by controller[0]: at AdapterClass.emit (node:domain:489:12)
    2024-01-13 21:11:02.228 - error: host.427605deb40c Caught by controller[0]: at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11143:34)
    2024-01-13 21:11:02.229 - error: host.427605deb40c Caught by controller[0]: at Immediate. (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:379:37) {
    2024-01-13 21:11:02.229 - error: host.427605deb40c Caught by controller[0]: code: 'EADDRINUSE',
    2024-01-13 21:11:02.230 - error: host.427605deb40c Caught by controller[0]: errno: -98,
    2024-01-13 21:11:02.230 - error: host.427605deb40c Caught by controller[0]: syscall: 'listen',
    2024-01-13 21:11:02.230 - error: host.427605deb40c Caught by controller[0]: address: '::',
    2024-01-13 21:11:02.230 - error: host.427605deb40c Caught by controller[0]: port: 9081
    2024-01-13 21:11:02.231 - error: host.427605deb40c Caught by controller[0]: }
    2024-01-13 21:11:02.231 - error: host.427605deb40c instance system.adapter.backitup.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    Kann man hieraus erkennen, worin das Problem liegt?
    Vielenn Dank für eure Hilfe!
    Grüße
    Oebler
    • O Oebler
      Grüße
      Oebler
      crunchipC Offline
      crunchipC Offline
      @oebler sagte in Backup einspielen:
      ansonsten
      https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch
      O 1 Antwort Letzte Antwort
        ansonsten
        O Offline
        O Offline
        Oebler
        @crunchip
        Super, danke dir - habe einen neuen Container erstellt, wo ich diesen Port 1:1 weiterleite, damit läuft das Backup aktuell erst mal los :)
        • O Oebler
          @crunchip
          simatecS Offline
          simatecS Offline
          simatec
          @oebler Installiere die neuste Version von Backitup aus der latest Repo. Aktuell die v2.10.1
          Bitte in deinem Docker die Ports laut Doku mappen.
          Dann läuft der Restore auch... Leider ist das mappen bei Docker nötig... oder du baust dir für den iobroker ein Macvlan. Damit entfallen die Mapping Ports.
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
