  3. Einsteigerfragen
  4. Installation
  5. Backup IOBroker but cannot find admin.js
Geplant Angeheftet Gesperrt Verschoben Installation
18 Beiträge 4 Kommentatoren 856 Aufrufe 3 Beobachtet
  • ? Offline
    Hello i restored an old version of my IOBroker installation but the webinterface wont start :(
      @marvin diese schwarze Briefmarke ist nur sehr schwer zu entziffern,.
      Bitte als Text in code-tags posten!
      ? 1 Antwort Letzte Antwort
        @marvin please provide the full output of iob diag
            system.adapter.admin.2                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
          + system.adapter.broadlink2.1             : broadlink2            : raspberrypi                              -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
          + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.loxone.0                 : loxone                : raspberrypi                              -  enabled, port: 80
          + system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
            system.adapter.rickshaw.0               : rickshaw              : raspberrypi                              -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
          + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
          + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
            system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
          + system.adapter.tvprogram.0              : tvprogram             : raspberrypi                              -  enabled
            system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
            system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
            system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              -  enabled
            system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
            system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
            system.adapter.web.1                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
            system.adapter.windows-control.0        : windows-control       : raspberrypi                              -  enabled
          + instance is alive
          pi@raspberrypi:~ $ node node_modules/iobroker.admin/admin.js --logs
          node:internal/modules/cjs/loader:1137
            throw err;
          Error: Cannot find module '/home/pi/node_modules/iobroker.admin/admin.js'
              at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
              at Module._load (node:internal/modules/cjs/loader:975:27)
              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
              at node:internal/main/run_main_module:28:49 {
            code: 'MODULE_NOT_FOUND',
            requireStack: []
          Node.js v18.19.0
          ? HomoranH 2 Antworten Letzte Antwort
            + instance is alive
              throw err;
              requireStack: []
            Node.js v18.19.0
            i tried following but i didnt help:
            cd /opt/iobroker
            npm i iobroker.admin --production
            iobroker upload admin
            iobroker restart admin.2
              + instance is alive
                throw err;
                requireStack: []
              Node.js v18.19.0
              @marvin thanks!
              don't use the iobroker commands with sudo! never!
              please try iob start admin.2 --debug
              but the full output of iob diag should reveal more infos
                @marvin thanks!
                @homoran said in Backup IOBroker but cannot find admin.js:
                this is my iob diag output:
                			v.2023-10-10
                 Static hostname: raspberrypi
                       Icon name: computer
                          Kernel: Linux 6.1.0-rpi7-rpi-v8
                    Architecture: arm64
                Installation: 		native
                Kernel: 		aarch64
                Userland: 		arm64
                Timezone: 		Europe/Berlin (CET, +0100)
                User-ID: 		1000
                X-Server: 		true
                Boot Target: 		graphical.target
                Pending OS-Updates: 	73
                Pending iob updates: 	28
                Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
                			/usr/bin/node 		v18.19.0
                			/usr/bin/npm 		10.2.3
                			/usr/bin/npx 		10.2.3
                			/usr/bin/corepack 	0.22.0
                Recommended versions are nodejs  and npm
                MEMORY:
                Mem:            4.0G        2.2G        691M        161M        1.3G        1.8G
                Swap:           104M        4.2M        100M
                Total:          4.1G        2.2G        792M
                Active iob-Instances: 	19
                Active repo(s): stable
                ioBroker Core: 		js-controller 		5.0.17
                			admin 			6.2.20
                ioBroker Status: 	iobroker is running on this host.
                Objects type: jsonl
                States  type: jsonl
                Objects: 		7891
                States: 		6317
                Size of iob-Database:
                16M	/opt/iobroker/iobroker-data/objects.jsonl
                8.8M	/opt/iobroker/iobroker-data/objects.json.migrated
                8.8M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                12M	/opt/iobroker/iobroker-data/states.jsonl
                5.1M	/opt/iobroker/iobroker-data/states.json.migrated
                5.1M	/opt/iobroker/iobroker-data/states.json.bak.migrated
                HomoranH DJMarc75D 3 Antworten Letzte Antwort
                  			v.2023-10-10
                         Icon name: computer
                      Architecture: arm64
                  Kernel: 		aarch64
                  Userland: 		arm64
                  User-ID: 		1000
                  X-Server: 		true
                  			/usr/bin/npm 		10.2.3
                  			/usr/bin/npx 		10.2.3
                  MEMORY:
                  			admin 			6.2.20
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		7891
                  States: 		6317
                  @marvin sagte in Backup IOBroker but cannot find admin.js:
                  unfortunately just the summary
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                      			v.2023-10-10
                             Icon name: computer
                          Architecture: arm64
                      Kernel: 		aarch64
                      Userland: 		arm64
                      User-ID: 		1000
                      X-Server: 		true
                      			/usr/bin/npm 		10.2.3
                      			/usr/bin/npx 		10.2.3
                      MEMORY:
                      			admin 			6.2.20
                      Objects type: jsonl
                      States  type: jsonl
                      Objects: 		7891
                      States: 		6317
                      in combination with
                      leads me to me guess that you restored an old version with controller v4.
                      did you?
                        in combination with
                        did you?
                        @homoran i dont know the exact version but not the newest for sure...
                        • DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          @Homoran please postpone to english category ;)
                          Lehrling seit 1975 !!!
                          • DJMarc75D DJMarc75
                            @djmarc75 sagte in Backup IOBroker but cannot find admin.js:
                            there is no beginners forum
                              you cannot restore a backup of v4 in a new installation with controller v5.
                              @thomas-braun tried this at another user
                              cd /opt/iobroker
                              sudo -H -u iobroker npm install iobroker.js-controller
                              iob update
                              iob upgrade all -y
                              I recommend to stop iob first iob stop
                              Good luck!
                                			v.2023-10-10
                                       Icon name: computer
                                    Architecture: arm64
                                Kernel: 		aarch64
                                Userland: 		arm64
                                User-ID: 		1000
                                X-Server: 		true
                                			/usr/bin/npm 		10.2.3
                                			/usr/bin/npx 		10.2.3
                                MEMORY:
                                			admin 			6.2.20
                                Objects type: jsonl
                                States  type: jsonl
                                Objects: 		7891
                                States: 		6317
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                Really ?
                                X-Server: true
                                Desktop: LXDE-pi
                                Terminal: x11
                                Pending Updates: 73
                                  cd /opt/iobroker
                                  iob update
                                  iob upgrade all -y
                                  Good luck!
                                  @homoran thank you so much for your help and time. fixed it :)
                                    glad to hear!
                                    but fix also all old stuff!
                                    And what already was said by @DJMarc75 :
                                    a Server will not have an graphical interface!
                                    and do you really live in German time-zone?
                                    • Samson71S Offline
                                      Samson71S Offline
                                      Samson71
                                      @Marvin
                                      Deutscher Forumsteil, deutsche IP (bei mir um die Ecke im Norden), warum dann nicht auf Deutsch?
                                      EDIT
                                      So kann man es natürlich auch machen. Anstatt zu reagieren einfach abmelden und wieder verschwinden.
                                      Markus
                                      Bitte beachten:
