  3. Einsteigerfragen
  4. Installation
  5. Backup IOBroker but cannot find admin.js
18 Beiträge 4 Kommentatoren 856 Aufrufe 3 Beobachtet
      system.adapter.admin.2                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
    + system.adapter.broadlink2.1             : broadlink2            : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.loxone.0                 : loxone                : raspberrypi                              -  enabled, port: 80
    + system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
      system.adapter.rickshaw.0               : rickshaw              : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
      system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
    + system.adapter.tvprogram.0              : tvprogram             : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
      system.adapter.web.1                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
      system.adapter.windows-control.0        : windows-control       : raspberrypi                              -  enabled
    + instance is alive
    pi@raspberrypi:~ $ node node_modules/iobroker.admin/admin.js --logs
    node:internal/modules/cjs/loader:1137
      throw err;
    Error: Cannot find module '/home/pi/node_modules/iobroker.admin/admin.js'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
        at Module._load (node:internal/modules/cjs/loader:975:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
        at node:internal/main/run_main_module:28:49 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v18.19.0
    HomoranH Offline
    HomoranH Offline
    @marvin thanks!
    don't use the iobroker commands with sudo! never!
    please try iob start admin.2 --debug
    but the full output of iob diag should reveal more infos
      @marvin thanks!
      @homoran said in Backup IOBroker but cannot find admin.js:
      this is my iob diag output:
      			v.2023-10-10
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Installation: 		native
      Kernel: 		aarch64
      Userland: 		arm64
      Timezone: 		Europe/Berlin (CET, +0100)
      User-ID: 		1000
      X-Server: 		true
      Boot Target: 		graphical.target
      Pending OS-Updates: 	73
      Pending iob updates: 	28
      Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
      			/usr/bin/node 		v18.19.0
      			/usr/bin/npm 		10.2.3
      			/usr/bin/npx 		10.2.3
      			/usr/bin/corepack 	0.22.0
      Recommended versions are nodejs  and npm
      MEMORY:
      Mem:            4.0G        2.2G        691M        161M        1.3G        1.8G
      Swap:           104M        4.2M        100M
      Total:          4.1G        2.2G        792M
      Active iob-Instances: 	19
      Active repo(s): stable
      ioBroker Core: 		js-controller 		5.0.17
      			admin 			6.2.20
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Objects: 		7891
      States: 		6317
      Size of iob-Database:
      16M	/opt/iobroker/iobroker-data/objects.jsonl
      8.8M	/opt/iobroker/iobroker-data/objects.json.migrated
      8.8M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
      12M	/opt/iobroker/iobroker-data/states.jsonl
      5.1M	/opt/iobroker/iobroker-data/states.json.migrated
      5.1M	/opt/iobroker/iobroker-data/states.json.bak.migrated
      HomoranH DJMarc75D 3 Antworten Letzte Antwort
        			v.2023-10-10
               Icon name: computer
            Architecture: arm64
        Kernel: 		aarch64
        Userland: 		arm64
        User-ID: 		1000
        X-Server: 		true
        			/usr/bin/npm 		10.2.3
        			/usr/bin/npx 		10.2.3
        MEMORY:
        			admin 			6.2.20
        Objects type: jsonl
        States  type: jsonl
        Objects: 		7891
        States: 		6317
        HomoranH Offline
        HomoranH Offline
        @marvin sagte in Backup IOBroker but cannot find admin.js:
        unfortunately just the summary
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
            			v.2023-10-10
                   Icon name: computer
                Architecture: arm64
            Kernel: 		aarch64
            Userland: 		arm64
            User-ID: 		1000
            X-Server: 		true
            			/usr/bin/npm 		10.2.3
            			/usr/bin/npx 		10.2.3
            MEMORY:
            			admin 			6.2.20
            Objects type: jsonl
            States  type: jsonl
            Objects: 		7891
            States: 		6317
            HomoranH Offline
            HomoranH Offline
            in combination with
            leads me to me guess that you restored an old version with controller v4.
            did you?
              in combination with
              did you?
              @homoran i dont know the exact version but not the newest for sure...
              • DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @Homoran please postpone to english category ;)
                Lehrling seit 1975 !!!
                • DJMarc75D DJMarc75
                  HomoranH Offline
                  HomoranH Offline
                  @djmarc75 sagte in Backup IOBroker but cannot find admin.js:
                  there is no beginners forum
                    HomoranH Offline
                    HomoranH Offline
                    you cannot restore a backup of v4 in a new installation with controller v5.
                    @thomas-braun tried this at another user
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller
                    iob update
                    iob upgrade all -y
                    I recommend to stop iob first iob stop
                    Good luck!
                      			v.2023-10-10
                             Icon name: computer
                          Architecture: arm64
                      Kernel: 		aarch64
                      Userland: 		arm64
                      User-ID: 		1000
                      X-Server: 		true
                      			/usr/bin/npm 		10.2.3
                      			/usr/bin/npx 		10.2.3
                      MEMORY:
                      			admin 			6.2.20
                      Objects type: jsonl
                      States  type: jsonl
                      Objects: 		7891
                      States: 		6317
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      Really ?
                      X-Server: true
                      Desktop: LXDE-pi
                      Terminal: x11
                      Pending Updates: 73
                        cd /opt/iobroker
                        iob update
                        iob upgrade all -y
                        Good luck!
                        @homoran thank you so much for your help and time. fixed it :)
                          HomoranH Offline
                          HomoranH Offline
                          glad to hear!
                          but fix also all old stuff!
                          And what already was said by @DJMarc75 :
                          a Server will not have an graphical interface!
                          and do you really live in German time-zone?
                          • Samson71S Offline
                            Samson71S Offline
                            Samson71
                            @Marvin
                            Deutscher Forumsteil, deutsche IP (bei mir um die Ecke im Norden), warum dann nicht auf Deutsch?
                            EDIT
                            So kann man es natürlich auch machen. Anstatt zu reagieren einfach abmelden und wieder verschwinden.
                            Markus
                            Bitte beachten:
