  4. [gelöst] Logitech Harmony-Adapter
3 Beiträge 2 Kommentatoren 1.4k Aufrufe
  • K Offline
    Kueppert
    Hallo in die Runde der Wissenden,
    wollte jetzt mal den Harmony-Adapter ausprobieren, da bei mir der Samsung-Adapter nicht funktioniert (TV wird nicht unterstützt), um eine Fernbedienung in VIS zu basteln…aber scheitere leider bei der Installation vom Harmony-Adapter:
    iobroker	2017-08-09 18:10:19.452	info	exit 13
    iobroker	2017-08-09 18:10:19.421	error	host.raspberrypi3 Cannot install harmony
    iobroker	2017-08-09 18:10:19.419	info	host.raspberrypi3 install adapter harmony
    iobroker	2017-08-09 18:10:19.400	info	npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
    iobroker	2017-08-09 18:10:19.398	info
    iobroker	2017-08-09 18:10:19.206	info	Please check if you have git installed and in your PATH.
    iobroker	2017-08-09 18:10:19.204	info	npm ERR!
    iobroker	2017-08-09 18:10:19.204	info	npm ERR! This is most likely not a problem with npm itself.
    iobroker	2017-08-09 18:10:19.204	info	npm ERR! Failed using git.
    iobroker	2017-08-09 18:10:19.204	info	ERR! not found: gitnpm ERR!
    iobroker	2017-08-09 18:10:19.201	info	npm
    iobroker	2017-08-09 18:10:19.199	info
    iobroker	2017-08-09 18:10:19.193	info	npm ERR! code ENOGIT
    iobroker	2017-08-09 18:10:19.191	info	npm ERR! npm v2.15.11
    iobroker	2017-08-09 18:10:19.191	info	npm ERR! node v4.8.3
    iobroker	2017-08-09 18:10:19.191	info	ERR! Linux 4.9.30-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"
    iobroker	2017-08-09 18:10:19.189	info	npm
    iobroker	2017-08-09 18:10:18.832	info	npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! g
    iobroker	2017-08-09 18:10:18.728	info	npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
    iobroker	2017-08-09 18:10:18.700	info	npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: no
    iobroker	2017-08-09 18:10:18.700	info	npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
    iobroker	2017-08-09 18:10:18.700	info	addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.j
    iobroker	2017-08-09 18:10:18.696	info	WARN
    iobroker	2017-08-09 18:10:18.694	info	npm
    iobroker	2017-08-09 18:10:18.694	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    iobroker	2017-08-09 18:10:18.694	info	npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    iobroker	2017-08-09 18:10:18.694	info	npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
    iobroker	2017-08-09 18:10:18.688	info	npm WARN addRemoteGit Error: not found: git
    iobroker	2017-08-09 18:10:17.818	info	WARN engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.8.3","npm":"2.15.11"})
    iobroker	2017-08-09 18:10:17.815	info	npm
    iobroker	2017-08-09 18:10:13.945	info	npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
    iobroker	2017-08-09 18:10:13.517	info	host.raspberrypi3 install adapter harmony
    iobroker	2017-08-09 18:10:13.501	info	npm ERR! /opt/npm-debug.log
    iobroker	2017-08-09 18:10:13.501	info	npm ERR! Please include the following file with any support request:
    iobroker	2017-08-09 18:10:13.336	info	Please check if you have git installed and in your PATH.
    iobroker	2017-08-09 18:10:13.328	info	ERR! This is most likely not a problem with npm itself.npm ERR!
    iobroker	2017-08-09 18:10:13.325	info	npm
    iobroker	2017-08-09 18:10:13.325	info	npm ERR! Failed using git.
    iobroker	2017-08-09 18:10:13.325	info	not found: gitnpm ERR!
    iobroker	2017-08-09 18:10:13.323	info	npm ERR!
    iobroker	2017-08-09 18:10:13.318	info	npm ERR! code ENOGIT
    iobroker	2017-08-09 18:10:13.318	info	npm ERR! npm v2.15.11
    iobroker	2017-08-09 18:10:13.318	info	npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.8.3
    iobroker	2017-08-09 18:10:13.314	info	ERR! Linux 4.9.30-v7+
    iobroker	2017-08-09 18:10:13.312	info	npm
    iobroker	2017-08-09 18:10:13.059	info	ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! git
    iobroker	2017-08-09 18:10:13.057	info	npm
    iobroker	2017-08-09 18:10:13.028	info	npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: no
    iobroker	2017-08-09 18:10:13.028	info	npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
    iobroker	2017-08-09 18:10:13.028	info	WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/acc
    iobroker	2017-08-09 18:10:13.023	info	npm
    iobroker	2017-08-09 18:10:13.023	info	WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    iobroker	2017-08-09 18:10:13.018	info	at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm
    iobroker	2017-08-09 18:10:13.016	info	npm WARN addRemoteGit
    iobroker	2017-08-09 18:10:13.016	info	WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    iobroker	2017-08-09 18:10:13.012	info	npm
    iobroker	2017-08-09 18:10:12.812	info	npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
    iobroker	2017-08-09 18:10:12.081	info	WARN engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.8.3","npm":"2.15.11"})
    iobroker	2017-08-09 18:10:12.078	info	npm
    iobroker	2017-08-09 18:10:08.971	info	npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
    iobroker	2017-08-09 18:10:08.503	info	host.raspberrypi3 install adapter harmony
    iobroker	2017-08-09 18:10:08.442	info	npm ERR! /opt/npm-debug.log
    iobroker	2017-08-09 18:10:08.437	info	ERR! Please include the following file with any support request:
    iobroker	2017-08-09 18:10:08.435	info	npm
    iobroker	2017-08-09 18:10:08.434	info
    iobroker	2017-08-09 18:10:08.255	info	npm ERR! Please check if you have git installed and in your PATH.
    iobroker	2017-08-09 18:10:08.255	info	npm ERR! This is most likely not a problem with npm itself.
    iobroker	2017-08-09 18:10:08.255	info	npm ERR! Failed using git.
    iobroker	2017-08-09 18:10:08.255	info	npm ERR! not found: git
    iobroker	2017-08-09 18:10:08.242	info	npm ERR! npm v2.15.11npm ERR! code ENOGIT
    iobroker	2017-08-09 18:10:08.239	info	npm ERR! node v4.8.3
    iobroker	2017-08-09 18:10:08.239	info	npm ERR! Linux 4.9.30-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"
    iobroker	2017-08-09 18:10:07.810	info	npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! g
    iobroker	2017-08-09 18:10:07.721	info	npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
    iobroker	2017-08-09 18:10:07.684	info	npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: no
    iobroker	2017-08-09 18:10:07.684	info	npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
    iobroker	2017-08-09 18:10:07.684	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    iobroker	2017-08-09 18:10:07.684	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    iobroker	2017-08-09 18:10:07.684	info	WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    iobroker	2017-08-09 18:10:07.673	info	npm
    iobroker	2017-08-09 18:10:07.673	info	npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
    iobroker	2017-08-09 18:10:07.670	info	npm WARN addRemoteGit Error: not found: git
    iobroker	2017-08-09 18:10:06.808	info	engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.8.3","npm":"2.15.11"})
    iobroker	2017-08-09 18:10:06.804	info	WARN
    iobroker	2017-08-09 18:10:06.800	info	npm
    iobroker	2017-08-09 18:10:02.694	info	npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
    iobroker	2017-08-09 18:10:00.530	info	add harmony
    Sehr schade…habe js-controller 1.1.2 installiert.
    Hat jemand eine Idee, ob und wenn ja, wie ich den Adapter installiert bekomme?
    Alternative wäre: Adapter geht halt nicht dann baue deine Fernbedienung für TV, Verstärker usw. mit...???
    Danke euch und Grüße, Thorsten
    • eric2905E Offline
      eric2905E Offline
      eric2905
      In der 7. oder 8. Zeile von unten steht „Not found: git“.
      Installiere das mal in der Konsole mit „apt-get install git“ nach (sofern Du einen Pi oder Linux-Maschine als Basis hast) - falls Du Dich nicht als Root anmeldest, setze noch ein „sudo“ davor.
      Gruß,
      Eric
      Von unterwegs getippert
      • K Offline
        Kueppert
        Hey Eric,
        hab einen Pi3 mit Jessy Lite. Mit deinem Befehl hat es geklappt, danke :)
        PS: bin immer als root unterwegs ;)
