  4. gelöst: node.js macht Probleme
2 Beiträge 2 Kommentatoren 573 Aufrufe 2 Beobachtet
  • K Offline
    Karacho
    schrieb am zuletzt editiert von Karacho
    beim Update von node.js ist was schief gelaufen...
    instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    Caught by controller[1]: Node.js v18.19.0
    Caught by controller[1]: at node:internal/main/run_main_module:28:49
    Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:1013:12)
    Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1197:32)
    Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
    Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
    Caught by controller[1]: at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
    Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
    Caught by controller[1]: ^
    Caught by controller[1]: adapter.log.error("Could not check npm version: " + e);
    Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
    Caught by controller[0]: /bin/sh: 1: npm: not found
    iob diag
    sagt:
                            v.2023-10-10
     Static hostname: iobroker20
           Icon name: computer
              Kernel: Linux 6.1.0-rpi7-rpi-v8
        Architecture: arm64
    Installation:           native
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                            /usr/bin/node           v18.19.0
    /home/iobroker/.diag.sh: line 488: npm: command not found
    /home/iobroker/.diag.sh: line 489: npx: command not found
    /home/iobroker/.diag.sh: line 490: corepack: command not found
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please check
    for more information on how to fix these errors.
    MEMORY:
    Mem:            4.0G        2.5G        993M         16K        511M        1.4G
    Swap:           104M         33M         71M
    Total:          4.1G        2.6G        1.1G
    Active iob-Instances:   32
    ioBroker Core:          js-controller           5.0.16
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iobroker20                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : iobroker20                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                16191
    States:                 14127
    Size of iob-Database:
    16M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/states.jsonl
    Eduard77E 1 Antwort Letzte Antwort
    • K Karacho
      iob diag
      sagt:
                              v.2023-10-10
             Icon name: computer
          Architecture: arm64
      Kernel:                 aarch64
      Userland:               arm64
      User-ID:                1000
      X-Server:               false
      Please check
      MEMORY:
      Swap:           104M         33M         71M
                              admin                   6.12.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                16191
      States:                 14127
      Eduard77E Online
      Eduard77E Online
      Eduard77
      @karacho sagte in node.js macht Probleme:
      Guten Morgen,
      https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
