  4. fritzbox dect update 2.5.9 - Fehler im log
    6.1k
fritzdecterrorlog
12 Beiträge 5 Kommentatoren 1.7k Aufrufe 6 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    Habe eben update auf 2.5.9 gemacht.
    kennwort neu eingegeben.
    Instanz wird grün.
    Aber im log kommt:
    fritzdect.0
    2023-12-10 10:33:45.773	error	API err => {"msg":"AHA request error","function":"fritzAHA_Request","error":400,"status":400}
    fritzdect.0
    2023-12-10 10:33:45.773	error	no response part in returned error message
    fritzdect.0
    2023-12-10 10:33:45.772	error	API funct => executeCommand2
    fritzdect.0
    2023-12-10 10:33:45.772	error	API msg => relogin failed, or status400/500
    fritzdect.0
    2023-12-10 10:33:45.772	error	--------------- error calling the fritzbox -----------
    Jemand eine Idee ?
    Danke.
    K 1 Antwort Letzte Antwort
    • bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      Hier mal das komplette log beim Start der Instanz:
      fritzdect.0
      2023-12-10 10:39:03.570	info	finished initial updating devices/groups
      fritzdect.0
      2023-12-10 10:39:02.944	info	start initial updating devices/groups
      fritzdect.0
      2023-12-10 10:39:02.944	info	finished creating routines (if any)
      fritzdect.0
      2023-12-10 10:39:02.944	error	API err => {"msg":"AHA request error","function":"fritzAHA_Request","error":400,"status":400}
      fritzdect.0
      2023-12-10 10:39:02.943	error	no response part in returned error message
      fritzdect.0
      2023-12-10 10:39:02.943	error	API funct => executeCommand2
      fritzdect.0
      2023-12-10 10:39:02.943	error	API msg => relogin failed, or status400/500
      fritzdect.0
      2023-12-10 10:39:02.943	error	--------------- error calling the fritzbox -----------
      fritzdect.0
      2023-12-10 10:39:01.946	info	start creating routines
      fritzdect.0
      2023-12-10 10:39:01.946	info	routines are used(false)
      fritzdect.0
      2023-12-10 10:39:01.946	info	finished creating templates (if any)
      fritzdect.0
      2023-12-10 10:39:01.298	info	start creating templates
      fritzdect.0
      2023-12-10 10:39:01.298	info	templates are used(false)
      fritzdect.0
      2023-12-10 10:39:01.297	info	finished creating devices/groups (if any)
      fritzdect.0
      2023-12-10 10:39:01.217	info	create Main object DECT_ 087610949675 FRITZ!DECT Rep 100 #2 thermo
      fritzdect.0
      2023-12-10 10:39:01.217	info	____________________________________________
      fritzdect.0
      2023-12-10 10:39:01.216	info	CREATE Devices 1
      fritzdect.0
      2023-12-10 10:39:00.329	info	start creating devices/groups
      fritzdect.0
      2023-12-10 10:39:00.329	info	finished creating global values
      fritzdect.0
      2023-12-10 10:39:00.319	info	create Main object global channel list
      fritzdect.0
      2023-12-10 10:39:00.319	info	____________________________________________
      fritzdect.0
      2023-12-10 10:39:00.319	info	start creating global values
      fritzdect.0
      2023-12-10 10:39:00.318	info	the rights are : {"Rights":{"Name":["Dial","App","HomeAuto","BoxAdmin","Phone","NAS"],"Access":["2","2","2","2","2","2"]}}
      fritzdect.0
      2023-12-10 10:38:59.852	info	checking user permissions
      fritzdect.0
      2023-12-10 10:38:56.213	info	fritzdect uses USER: didi-m
      fritzdect.0
      2023-12-10 10:38:56.191	info	fritzdect entered ready
      fritzdect.0
      2023-12-10 10:38:56.173	info	starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v18.18.2, js-controller: 5.0.16
      Danke.
      • bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        So, dieser Fehler kommt alle 5 Minuten.
        fritzdect.0
        2023-12-10 12:29:08.725	error	API err => {"msg":"AHA request error","function":"fritzAHA_Request","error":400,"status":400}
        fritzdect.0
        2023-12-10 12:29:08.725	error	no response part in returned error message
        fritzdect.0
        2023-12-10 12:29:08.724	error	API funct => executeCommand2
        fritzdect.0
        2023-12-10 12:29:08.724	error	API msg => relogin failed, or status400/500
        fritzdect.0
        2023-12-10 12:29:08.724	error	--------------- error calling the fritzbox -----------
        Und da ich offenbar der Einzige bin damit, gehe ich wieder zurück.
        Danke.
        • bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          So, alte V ging nicht installieren.
          Dann Instanz und Adapter komplett gelöscht.
          Und über npm wieder die 2.5.9 installiert.
          Daten eingegeben.
          Fehler bleibt.
          Schlecht.
          Danke.
          • bahnuhrB bahnuhr
            Daten eingegeben.
            Fehler bleibt.
            Schlecht.
            @bahnuhr sagte in fritzbox dect update 2.5.9 - Fehler im log:
            Fehler bleibt.
            Schlecht.
            Und wo findet man dein Issue dazu?
            So bleibt der Fehler mit Sicherheit bestehen...
            Hier ist jedenfalls nix zu finden:
            https://github.com/foxthefox/ioBroker.fritzdect/issues
              Fehler bleibt.
              Schlecht.
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              @thomas-braun sagte in fritzbox dect update 2.5.9 - Fehler im log:
              Nicht schlimm. Habe den Adapter deinstalliert. Fertig.
              Wenn du magst kannst du gerne ein issue eröffnen.
              Danke.
              • bahnuhrB bahnuhr
                Warum sollte ich für DEINE Probleme ein Issue eröffnen?
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  DEINE Probleme
                  Ich habe keine Probleme.
                  Adapter ist weg.
                  Danke.
                  • bahnuhrB bahnuhr
                    Instanz wird grün.
                    Aber im log kommt:
                    fritzdect.0
                    fritzdect.0
                    fritzdect.0
                    fritzdect.0
                    fritzdect.0
                    Jemand eine Idee ?
                    KiloByte
                    schrieb am zuletzt editiert von KiloByte
                    Seit dem Update auf 2.5.9 habe ich die gleichen Fehlermeldungen in den Logs.
                    In der Zwischenzeit habe ich:
                    • einen neuen ioBroker User in der Fritzbox eingerichtet
                    • den Adapter downgegraded auf die Version 2.5.7
                    • das Polling-Intervall mal auf 300 Sek. erhöht
                    • die Fritzbox und den ioBroker rebootet
                    alles ohne Erfolg.
                    Vielleicht gibt es hier noch weitere Ideen?
                    ioBroker auf Raspberry Pi4 8GB
                    Node.js v22.22.0 // js-controller 7.2.2 // NPM 10.9.4
                    W 1 Antwort Letzte Antwort
                    • K KiloByte
                      alles ohne Erfolg.
                      W Offline
                      W Offline
                      wg
                      @kilobyte Neuer User in der Fritzbox hat mir geholfen: Sonderzeichen raus aus dem Passwort (und möglicherweise nicht länger als 13 Zeichen machen). Polling ist bei mir auf 10s. Adapteroptionen alle an (also exclude aktiviert). Damit läuft 2.5.9 bei mir (2 Instanzen, Fritzen sind 7590er).
                      • W wg
                        KiloByte
                        @wg Bingo!! Die "Adapter Options" waren es. Ich habe bei allen ein Häkchen gesetzt und nun scheint es OK zu sein. Danke.
                        • K KiloByte
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          Und nochmal die Frage an alle die hier von Problemen berichten:
                          Warum eröffnet ihr kein Issue beim Adapter?
                          Wie denkt ihr dass das Maintainer von einem Problem erfährt?
                          Also BITTE eröffnet doch ein Issue wenn ihr ein Problem habt. (Ok deinstallieren ist auch ein Weg erinnert mich aber - nicht bös sein - ein wenig an das Verhalten meines trotzigen Enkerls...)
                          Support Repositoryverwaltung.
                          LESEN - gute Forenbeitrage
