  3. Einsteigerfragen
  4. Installationsprobleme iobroker
11 Beiträge 5 Kommentatoren 1.4k Aufrufe 5 Beobachtet
    andi_grafa
    ich habe bereits iobroker auf einem Raspi laufen und wollte iob jetzt auf einem neuen Raspi mit Bookworm installieren.
    leider bekomme ich mehrmal immer den gleichen fehler:
    npm ERR! code 6
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c node iobroker.js setup first
    npm ERR! Could not determine dns resolution order, fallback to "ipv4first": /opt/iobroker/iobroker-data/iobroker.json: Unexpected end of JSON input
    npm ERR! Cannot check config file: /opt/iobroker/iobroker-data/iobroker.json: Unexpected end of JSON input
    npm ERR! Uncaught Rejection: SyntaxError: /opt/iobroker/iobroker-data/iobroker.json: Unexpected end of JSON input
    npm ERR!     at JSON.parse (<anonymous>)
    npm ERR!     at Object.readFileSync (/opt/iobroker/node_modules/jsonfile/index.js:52:17)
    npm ERR!     at dbConnect (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/dbConnection.js:63:39)
    npm ERR!     at /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/dbConnection.js:321:35
    npm ERR!     at new Promise (<anonymous>)
    npm ERR!     at dbConnectAsync (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/dbConnection.js:321:12)
    npm ERR!     at Setup.setupObjects (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupSetup.js:271:96)
    npm ERR!     at Setup.setup (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupSetup.js:1035:18)
    npm ERR!     at processCommand (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:536:19)
    npm ERR!     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    npm ERR! A complete log of this run can be found in: /home/ip/.npm/_logs/2023-11-26T19_31_05_578Z-debug-0.log
    Der Fehlerlog zeigt folgendes:
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@9.8.1
    2 info using node@v18.18.2
    3 timing npm:load:whichnode Completed in 8ms
    4 timing config:load:defaults Completed in 14ms
    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 5ms
    6 timing config:load:builtin Completed in 8ms
    7 warn config production Use `--omit=dev` instead.
    8 timing config:load:cli Completed in 29ms
    9 timing config:load:env Completed in 3ms
    10 timing config:load:file:/opt/iobroker/.npmrc Completed in 11ms
    11 timing config:load:project Completed in 35ms
    12 timing config:load:file:/home/ip/.npmrc Completed in 2ms
    13 timing config:load:user Completed in 3ms
    14 timing config:load:file:/usr/etc/npmrc Completed in 1ms
    15 timing config:load:global Completed in 2ms
    16 timing config:load:setEnvs Completed in 8ms
    17 timing config:load Completed in 109ms
    18 timing npm:load:configload Completed in 110ms
    19 timing config:load:flatten Completed in 22ms
    20 timing npm:load:mkdirpcache Completed in 6ms
    21 timing npm:load:mkdirplogs Completed in 2ms
    22 verbose title npm i
    23 verbose argv "i" "--production" "--loglevel" "error" "--unsafe-perm"
    24 timing npm:load:setTitle Completed in 10ms
    25 timing npm:load:display Completed in 6ms
    26 verbose logfile logs-max:10 dir:/home/ip/.npm/_logs/2023-11-26T19_31_05_578Z-
    27 verbose logfile /home/ip/.npm/_logs/2023-11-26T19_31_05_578Z-debug-0.log
    28 timing npm:load:logFile Completed in 77ms
    29 timing npm:load:timers Completed in 0ms
    30 timing npm:load:configScope Completed in 1ms
    31 timing npm:load Completed in 360ms
    32 timing arborist:ctor Completed in 5ms
    33 timing arborist:ctor Completed in 1ms
    34 silly logfile start cleaning logs, removing 2 files
    35 silly logfile done cleaning log files
    36 timing idealTree:init Completed in 8124ms
    37 timing idealTree:userRequests Completed in 1ms
    38 silly idealTree buildDeps
    39 silly fetch manifest iobroker.js-controller@stable
    40 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 1767ms (cache revalidated)
    41 silly fetch manifest iobroker.admin@stable
    42 http fetch GET 200 https://registry.npmjs.org/iobroker.admin 909ms (cache revalidated)
    43 silly fetch manifest iobroker.discovery@stable
    44 http fetch GET 200 https://registry.npmjs.org/iobroker.discovery 880ms (cache revalidated)
    45 silly fetch manifest iobroker.backitup@stable
    46 http fetch GET 200 https://registry.npmjs.org/iobroker.backitup 164ms (cache revalidated)
    47 silly placeDep ROOT iobroker.admin@6.10.1 REPLACE for: iobroker.inst@3.0.0 want: stable
    48 silly placeDep ROOT iobroker.backitup@2.8.7 REPLACE for: iobroker.inst@3.0.0 want: stable
    49 silly placeDep ROOT iobroker.discovery@4.2.0 REPLACE for: iobroker.inst@3.0.0 want: stable
    50 silly placeDep ROOT iobroker.js-controller@5.0.16 REPLACE for: iobroker.inst@3.0.0 want: stable
    51 timing idealTree:#root Completed in 4172ms
    52 silly fetch manifest fsevents@~2.3.2
    53 http fetch GET 200 https://registry.npmjs.org/fsevents 136ms (cache revalidated)
    54 silly placeDep node_modules/chokidar fsevents@2.3.3 OK for: chokidar@3.5.3 want: ~2.3.2
    55 timing idealTree:node_modules/chokidar Completed in 156ms
    56 timing idealTree:node_modules/iobroker.admin Completed in 1ms
    57 timing idealTree:node_modules/iobroker.backitup Completed in 0ms
    58 timing idealTree:node_modules/iobroker.discovery Completed in 0ms
    59 timing idealTree:node_modules/iobroker.js-controller Completed in 1ms
    60 timing idealTree:node_modules/chokidar/node_modules/fsevents Completed in 0ms
    61 timing idealTree:buildDeps Completed in 4341ms
    62 timing idealTree:fixDepFlags Completed in 58ms
    63 timing idealTree Completed in 12588ms
    64 timing reify:loadTrees Completed in 12594ms
    65 timing reify:diffTrees Completed in 51ms
    66 silly reify mark retired [ '/opt/iobroker/node_modules/fsevents' ]
    67 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.admin' ]
    68 silly reify mark retired [
    68 silly reify   '/opt/iobroker/node_modules/iobroker.js-controller',
    68 silly reify   '/opt/iobroker/node_modules/.bin/iobroker'
    68 silly reify ]
    69 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.backitup' ]
    70 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.discovery' ]
    71 silly reify moves {
    71 silly reify   '/opt/iobroker/node_modules/fsevents': '/opt/iobroker/node_modules/.fsevents-yNYMVUiI',
    71 silly reify   '/opt/iobroker/node_modules/iobroker.admin': '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk',
    71 silly reify   '/opt/iobroker/node_modules/iobroker.js-controller': '/opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba',
    71 silly reify   '/opt/iobroker/node_modules/.bin/iobroker': '/opt/iobroker/node_modules/.bin/.iobroker-dBRdrK4k',
    71 silly reify   '/opt/iobroker/node_modules/iobroker.backitup': '/opt/iobroker/node_modules/.iobroker.backitup-ZZHwpo6A',
    71 silly reify   '/opt/iobroker/node_modules/iobroker.discovery': '/opt/iobroker/node_modules/.iobroker.discovery-Domn1CAP'
    71 silly reify }
    72 timing reify:retireShallow Completed in 34ms
    73 timing reify:createSparse Completed in 5ms
    74 timing reify:trashOmits Completed in 8ms
    75 timing reify:loadBundles Completed in 0ms
    76 verbose reify failed optional dependency /opt/iobroker/node_modules/chokidar/node_modules/fsevents
    77 silly reify mark deleted [ '/opt/iobroker/node_modules/chokidar/node_modules/fsevents' ]
    78 timing reifyNode:node_modules/chokidar/node_modules/fsevents Completed in 27ms
    79 timing reifyNode:node_modules/iobroker.js-controller Completed in 1198ms
    80 timing reifyNode:node_modules/iobroker.discovery Completed in 1314ms
    81 timing reifyNode:node_modules/iobroker.backitup Completed in 3852ms
    82 timing reifyNode:node_modules/iobroker.admin Completed in 8553ms
    83 timing reify:unpack Completed in 8558ms
    84 timing reify:unretire Completed in 26ms
    85 timing build:queue Completed in 10ms
    86 info run iobroker.js-controller@5.0.16 preinstall node_modules/iobroker.js-controller node build/lib/preinstallCheck.js
    87 info run iobroker.js-controller@5.0.16 preinstall { code: 0, signal: null }
    88 timing build:run:preinstall:node_modules/iobroker.js-controller Completed in 2949ms
    89 timing build:run:preinstall Completed in 2953ms
    90 timing build:link:node_modules/iobroker.js-controller Completed in 35ms
    91 timing build:link Completed in 36ms
    92 info run iobroker.js-controller@5.0.16 install node_modules/iobroker.js-controller node iobroker.js setup first
    93 info run iobroker.js-controller@5.0.16 install { code: 6, signal: null }
    94 timing reify:rollback:createSparse Completed in 655ms
    95 timing reify:rollback:retireShallow Completed in 5ms
    96 timing command:i Completed in 28976ms
    97 verbose stack Error: command failed
    97 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
    97 verbose stack     at ChildProcess.emit (node:events:517:28)
    97 verbose stack     at maybeClose (node:internal/child_process:1098:16)
    97 verbose stack     at ChildProcess._handle.onexit (node:internal/child_process:303:5)
    98 verbose pkgid iobroker.js-controller@5.0.16
    99 verbose cwd /opt/iobroker
    100 verbose Linux 6.1.0-rpi6-rpi-v8
    101 verbose node v18.18.2
    102 verbose npm  v9.8.1
    103 error code 6
    104 error path /opt/iobroker/node_modules/iobroker.js-controller
    105 error command failed
    106 error command sh -c node iobroker.js setup first
    107 error Could not determine dns resolution order, fallback to "ipv4first": /opt/iobroker/iobroker-data/iobroker.json: Unexpected end of JSON input
    107 error Cannot check config file: /opt/iobroker/iobroker-data/iobroker.json: Unexpected end of JSON input
    107 error Uncaught Rejection: SyntaxError: /opt/iobroker/iobroker-data/iobroker.json: Unexpected end of JSON input
    107 error     at JSON.parse (<anonymous>)
    107 error     at Object.readFileSync (/opt/iobroker/node_modules/jsonfile/index.js:52:17)
    107 error     at dbConnect (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/dbConnection.js:63:39)
    107 error     at /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/dbConnection.js:321:35
    107 error     at new Promise (<anonymous>)
    107 error     at dbConnectAsync (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/dbConnection.js:321:12)
    107 error     at Setup.setupObjects (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupSetup.js:271:96)
    107 error     at Setup.setup (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupSetup.js:1035:18)
    107 error     at processCommand (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:536:19)
    107 error     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    108 verbose exit 6
    109 timing npm Completed in 31091ms
    110 verbose unfinished npm timer reify 1701027067668
    111 verbose unfinished npm timer reify:build 1701027088977
    112 verbose unfinished npm timer build 1701027088982
    113 verbose unfinished npm timer build:deps 1701027088984
    114 verbose unfinished npm timer build:run:install 1701027091986
    115 verbose unfinished npm timer build:run:install:node_modules/iobroker.js-controller 1701027091986
    116 verbose code 6
    117 error A complete log of this run can be found in: /home/ip/.npm/_logs/2023-11-26T19_31_05_578Z-debug-0.log
    Leider komme ich nicht weiter in der Ursachenfindung für die wiederholten Probleme.
    Andreas
    DJMarc75D crunchipC 2 Antworten Letzte Antwort
    • A andi_grafa
      npm ERR! code 6
      68 silly reify ]
      71 silly reify }
      103 error code 6
      108 verbose exit 6
      116 verbose code 6
      Andreas
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @andi_grafa sagte in Installationsprobleme iobroker:
      und nach welcher Anleitung gemacht ?
      Lehrling seit 1975 !!!
        andi_grafa
        @djmarc75 , sorry, das habe ich vergessen
        curl -sLf https://iobroker.net/install.sh | bash -
        • A andi_grafa
          CodierknechtC Offline
          Codierknecht
          @andi_grafa
          Was hast Du da an OS installiert?
          Hast Du da "von Hand" schon ein Node draufgepackt?
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
          A 1 Antwort Letzte Antwort
          • CodierknechtC Codierknecht
            @andi_grafa
            andi_grafa
            @codierknecht
            Ich habe bookworm neu installiert.
            Node ist nicht installiert, node -v brachte "Befehl nicht gefunden"
            • A andi_grafa
              npm ERR! code 6
              68 silly reify ]
              71 silly reify }
              103 error code 6
              108 verbose exit 6
              116 verbose code 6
              Andreas
              crunchipC Offline
              crunchipC Offline
              liegt da möglicherweise ein Netzwerkproblem vor?
                andi_grafa
                schrieb am zuletzt editiert von andi_grafa
                @crunchip
                Netzwerproblem in welcher Hinsicht?
                Das Raspi kann auf das Internet zugreifen, er wird remote bedient und hat somit Zugriff in das WWW.
                Vielleicht kannst du noch etwas schreiben, wie du es genau meinst!?
                Falls du die IPV4 Meldung meinst, wie könnte ich es überprüfen? Updates gehen, homematic konnte ich installieren und updaten...ein Zugriff sollte eigentlich möglich sein
                • A andi_grafa
                  @crunchip
                  amg_666A Offline
                  amg_666A Offline
                  amg_666
                  @andi_grafa was sagt denn ifconfig ?
                  • amg_666A amg_666
                    andi_grafa
                    Mir ist leider ein Fehler unterlaufen, ich habe bezüglich npm auf dem falschen Raspi nachgesehen.
                    Auf dem betreffenden iobroker-Raspi ist npm 9.8.1 bereits installiert. ebenso wie node 18.18.2. iobroker ist momentan deinstalliert und alle iob Verzeichnisse wurden gelöscht.
                    @amg_666
                    es existiert wegen homematic bereits eine bridge, diese konfiguration hatte bisher (nur mit wlan) bereits auf dem alten Raspi funktioniert
                    ip@raspi-MUG:~ $ ifconfig
                    br0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
                    inet 192.168.178.34 netmask 255.255.255.0 broadcast 192.168.178.255
                    inet6 fe80::ba27:ebff:fefa:f8d prefixlen 64 scopeid 0x20<link>
                    ether b8:27:eb:fa:0f:8d txqueuelen 1000 (Ethernet)
                    RX packets 142731 bytes 8191143 (7.8 MiB)
                    RX errors 0 dropped 0 overruns 0 frame 0
                    TX packets 11736 bytes 2480981 (2.3 MiB)
                    TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
                    eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
                    RX packets 281382 bytes 18308181 (17.4 MiB)
                    RX errors 0 dropped 1680 overruns 0 frame 0
                    TX packets 112629 bytes 24380603 (23.2 MiB)
                    lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
                    inet 127.0.0.1 netmask 255.0.0.0
                    inet6 ::1 prefixlen 128 scopeid 0x10<host>
                    loop txqueuelen 1000 (Lokale Schleife)
                    RX packets 38 bytes 3586 (3.5 KiB)
                    TX packets 38 bytes 3586 (3.5 KiB)
                    lxcbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
                    inet 10.0.3.1 netmask 255.255.255.0 broadcast 10.0.3.255
                    ether 00:16:3e:00:00:00 txqueuelen 1000 (Ethernet)
                    RX packets 0 bytes 0 (0.0 B)
                    TX packets 0 bytes 0 (0.0 B)
                    vethpivccu: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
                    inet6 fe80::fcc0:6cff:fe51:c5 prefixlen 64 scopeid 0x20<link>
                    ether fe:c0:6c:51:00:c5 txqueuelen 1000 (Ethernet)
                    RX packets 81845 bytes 19689550 (18.7 MiB)
                    TX packets 269974 bytes 20867680 (19.9 MiB)
                    wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
                    ether b8:27:eb:af:5a:d8 txqueuelen 1000 (Ethernet)
                    wlan1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
                    ether 00:0c:43:00:b5:8d txqueuelen 1000 (Ethernet)
                    • A andi_grafa
                      @amg_666
                      andi_grafa
                      hat niemand eine Idee, über einige Ideen würde ich mich freuen.
                      Andreas
                      • A andi_grafa
                        Andreas
                        crunchipC Offline
                        crunchipC Offline
                        dann setz neu auf, anschließend iobroker installieren.
                        nodejs kommt automatisch mit der iobroker Installation
