  5. komplettes Script zB. von November bis Januar aktivieren
    6.3k
43 Beiträge 5 Kommentatoren 3.3k Aufrufe 2 Beobachtet
  • H Offline
    Hicki
    schrieb am zuletzt editiert von Hicki
    ich möchte dieses Script von November bis Januar aktivieren. Ist das möglich?
      <variables>
        <variable id="aL_X)*sBl03%NEW0`$16">licht</variable>
      </variables>
      <block type="variables_set" id="nAb*8A.{e9B7yRo7Vp4$" x="-312" y="-13">
        <field name="VAR" id="aL_X)*sBl03%NEW0`$16">licht</field>
        <value name="VALUE">
          <block type="get_value" id="5osR!02k6g`HA4bCFFc3">
            <field name="OID">meross.0.2103167712159190845648e1e962ef89.2</field>
          </block>
        </value>
        <next>
          <block type="on_ext" id="{C!-q#5L0R;9f?kYAsry">
            <value name="OID0">
              <shadow type="field_oid" id="E`(8h#e|S}7v|r5d0.Mc">
                <field name="oid">hm-rpc.0.PEQ1447187.1.LUX</field>
              </shadow>
            </value>
            <statement name="STATEMENT">
              <block type="controls_if" id=";}+3f,3x_YBFZFD~i@.Y">
                <value name="IF0">
                  <block type="time_compare" id="b^e@Rw{#Wsk;K#:VY3;#">
                    <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true"></mutation>
                    <field name="OPTION">between</field>
                    <field name="START_TIME">6:00</field>
                    <field name="END_TIME">23:00</field>
                  </block>
                </value>
                <statement name="DO0">
                  <block type="variables_set" id="VbB+lbG|FS58Fk3H5vcH">
                      <block type="logic_compare" id="_#buL5doh#t/okTN*!a6">
                        <field name="OP">LT</field>
                        <value name="A">
                          <block type="on_source" id="VEtoDSob:sF14%jmnXr[">
                          </block>
                        </value>
                        <value name="B">
                          <block type="math_number" id="V!?+lG#2|7VQ-dgnn?4|">
                            <field name="NUM">300</field>
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </statement>
                <value name="IF1">
                  <block type="logic_operation" id="IC)`}jgNen5F1N#Qjb:~" inline="false">
                    <field name="OP">AND</field>
                    <value name="A">
                      <block type="time_compare" id="qhQ*DY~ZoD9U*WJiSE.8">
                        <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="false"></mutation>
                        <field name="OPTION">&gt;</field>
                        <field name="START_TIME">23:00</field>
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_compare" id="FeHt$8yMCXvUq$5ye-RE">
                        <value name="A">
                          <block type="on_source" id="wr/psQ*vKTIf+8y}gg4R">
                          </block>
                        </value>
                        <value name="B">
                          <block type="math_number" id="lIx1BP/VE)`}t!k!U4r|">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <statement name="DO1">
                  <block type="variables_set" id="L+4Ku-/v|69KE0nD7Pb7">
                      <block type="logic_boolean" id="W,a2FN}d^%PaI]hyCYkK">
                      </block>
                    </value>
                  </block>
                </statement>
                <next>
                  <block type="controls_if" id="_qgWF*jdZ/QKfr9POs0L">
                    <value name="IF0">
                      <block type="logic_compare" id="X7KYR)Q6|-QL@=*ZWTBD">
                        <field name="OP">NEQ</field>
                        <value name="A">
                          <block type="variables_get" id="[-Bv!#,hV:Yz8I53N2Y~">
                          </block>
                        </value>
                        <value name="B">
                          <block type="get_value" id="kD~ukn|f|d@uo5#GX.y}">
                          </block>
                        </value>
                      </block>
                    </value>
                      <block type="control" id="fT~xYZ|F)+1p)_rAB}a,">
                          <block type="variables_get" id="y8rYr_L_eWEvAR[d$pG_">
                          </block>
                        </value>
                      </block>
                    </statement>
                    <next>
                      <block type="debug" id=":;07tr72fVw{?`HNic(q">
                        <value name="TEXT">
                          <shadow type="text" id="3P6x:CGgrB2V^fsr0hn0">
                          </shadow>
                          <block type="text_join" id="!E[?o{_K5c3tfHgAa+6O">
                            <mutation items="4"></mutation>
                            <value name="ADD0">
                              <block type="text" id=":,psL={k/UsAtc1$,U=1">
                                <field name="TEXT">Außenbeleuchtung:</field>
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="variables_get" id="(ybtL.qIEg()hW:uHkyH">
                              </block>
                            </value>
                            <value name="ADD2">
                              <block type="text" id="gmO[[Owfys^]w}t]IQTL">
                                <field name="TEXT"> und Helligkeit:</field>
                              </block>
                            </value>
                            <value name="ADD3">
                              <block type="get_value" id="~7fMP8j.GBv_e,jA{XD[">
                                <field name="OID">hm-rpc.0.PEQ1447187.1.LUX</field>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
            <next>
              <block type="schedule" id="EF?3)TIqPV%Jq)SG/g|P">
                <field name="SCHEDULE">0 3 * * *</field>
                  <block type="control" id="$s!n*t`o@*j$ZrYUGcZx">
                      <block type="logic_boolean" id="d*lQAX^al7xdtMDpqP%A">
                      </block>
                    </value>
                    <next>
                      <block type="debug" id="4TuibwT/7=lXyJ+V*Rte">
                        <value name="TEXT">
                          </shadow>
                          <block type="text_join" id="7B0j;l)a9WQg@)h.=hI-">
                            <value name="ADD0">
                              <block type="text" id="*VT-YVw1K_Zh-,fd672c">
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="variables_get" id="Y*gQg{ue5OwAgVo9y(3-">
                              </block>
                            </value>
                            <value name="ADD2">
                              <block type="text" id="pu^|1])3KW9TXT1@^~cp">
                              </block>
                            </value>
                            <value name="ADD3">
                              <block type="get_value" id="?!r3#E$%_zTY[]7iQJB]">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
                <next>
                  <block type="schedule" id="=1HK,tlY!FMQ?IZ%RF0,">
                    <field name="SCHEDULE">0 6 * * *</field>
                      <block type="controls_if" id="U`8u9o:Am{Eun=MmoPK_">
                        <value name="IF0">
                          <block type="logic_compare" id="i)kldwDoimFLu5k8ox0_">
                            <value name="A">
                              <block type="get_value" id="_-:}|R08h~[Uj:eeFG#K">
                              </block>
                            </value>
                            <value name="B">
                              <block type="math_number" id="0k|EA=5[YYT5]j0{|g^.">
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="control" id="+[YWQ7voD;9Qs3X;#A_B">
                              <block type="logic_boolean" id="erKj+5,3/9=gp~|T#k$}">
                              </block>
                            </value>
                          </block>
                        </statement>
                        <next>
                          <block type="debug" id="Ibr7L|o{Y0M!~}qe~+Hv">
                            <value name="TEXT">
                              </shadow>
                              <block type="text_join" id="17qImrEo}nAik]AXmpn.">
                                <value name="ADD0">
                                  <block type="text" id="%Qw]s~){^9?VHjBu9nB[">
                                  </block>
                                </value>
                                <value name="ADD1">
                                  <block type="variables_get" id="rb3|1b-pT)K1#8TL7mRF">
                                  </block>
                                </value>
                                <value name="ADD2">
                                  <block type="text" id="UDH{#Warhxuiaw4#.5sf">
                                  </block>
                                </value>
                                <value name="ADD3">
                                  <block type="get_value" id="m=/Hc)PQ9y7D48KB#pQ-">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </next>
      </block>
    </xml>
    Gruß Hicki
    mickymM paul53P 2 Antworten Letzte Antwort
    • H Hicki
        <variables>
        </variables>
            </block>
          </value>
          <next>
              <value name="OID0">
                </shadow>
              </value>
                  <value name="IF0">
                    </block>
                  </value>
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </statement>
                  <value name="IF1">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                    </block>
                  </statement>
                  <next>
                      <value name="IF0">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                      <next>
                          <value name="TEXT">
                            </shadow>
                              <value name="ADD0">
                                </block>
                              </value>
                              <value name="ADD1">
                                </block>
                              </value>
                              <value name="ADD2">
                                </block>
                              </value>
                              <value name="ADD3">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </statement>
              <next>
                        </block>
                      </value>
                      <next>
                          <value name="TEXT">
                            </shadow>
                              <value name="ADD0">
                                </block>
                              </value>
                              <value name="ADD1">
                                </block>
                              </value>
                              <value name="ADD2">
                                </block>
                              </value>
                              <value name="ADD3">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </statement>
                  <next>
                          <value name="IF0">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                                </block>
                              </value>
                            </block>
                          </statement>
                          <next>
                              <value name="TEXT">
                                </shadow>
                                  <value name="ADD0">
                                    </block>
                                  </value>
                                  <value name="ADD1">
                                    </block>
                                  </value>
                                  <value name="ADD2">
                                    </block>
                                  </value>
                                  <value name="ADD3">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </statement>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
      </xml>
      Gruß Hicki
      mickymM Offline
      mickymM Offline
      mickym
      @hicki Du machst einfach einen Block - der in der übrigen Zeit das Script vorzeitig beendet.
      H 1 Antwort Letzte Antwort
      • mickymM mickym
        Hicki
        @mickym Kannst Du mir da bitte helfen?
        • H Hicki
            <variables>
            </variables>
                </block>
              </value>
              <next>
                  <value name="OID0">
                    </shadow>
                  </value>
                      <value name="IF0">
                        </block>
                      </value>
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                      <value name="IF1">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                      <next>
                          <value name="IF0">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                                </block>
                              </value>
                            </block>
                          </statement>
                          <next>
                              <value name="TEXT">
                                </shadow>
                                  <value name="ADD0">
                                    </block>
                                  </value>
                                  <value name="ADD1">
                                    </block>
                                  </value>
                                  <value name="ADD2">
                                    </block>
                                  </value>
                                  <value name="ADD3">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                  <next>
                            </block>
                          </value>
                          <next>
                              <value name="TEXT">
                                </shadow>
                                  <value name="ADD0">
                                    </block>
                                  </value>
                                  <value name="ADD1">
                                    </block>
                                  </value>
                                  <value name="ADD2">
                                    </block>
                                  </value>
                                  <value name="ADD3">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </statement>
                      <next>
                              <value name="IF0">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                    </block>
                                  </value>
                                </block>
                              </value>
                                    </block>
                                  </value>
                                </block>
                              </statement>
                              <next>
                                  <value name="TEXT">
                                    </shadow>
                                      <value name="ADD0">
                                        </block>
                                      </value>
                                      <value name="ADD1">
                                        </block>
                                      </value>
                                      <value name="ADD2">
                                        </block>
                                      </value>
                                      <value name="ADD3">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </xml>
          Gruß Hicki
          @hicki sagte: von November bis Januar aktivieren.
          Im Datenpunkt-Trigger:
          In den Zeitplänen mit CRON:
          • H Offline
            Hicki
            Ich danke Dir.
            Hier mal meine Lösung. Würde es funktionieren?
              <variables>
              </variables>
              <block type="variables_set" id="nAb*8A.{e9B7yRo7Vp4$" x="-255" y="7">
                  </block>
                </value>
                <next>
                    <value name="OID0">
                      </shadow>
                    </value>
                      <block type="controls_if" id="G^5|WqVzjvmK,U%fMdMq">
                        <value name="IF0">
                          <block type="logic_operation" id="0!U[bEw56oGuFc_yfZqy" inline="false">
                            <field name="OP">OR</field>
                            <value name="A">
                              <block type="logic_compare" id="47YF}hPY)Nx(JS!4Y~td">
                                <field name="OP">GTE</field>
                                <value name="A">
                                  <block type="time_get" id="z}:J)6`L7;6o}JW~sJ`u">
                                    <field name="OPTION">MM.DD</field>
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="text" id="kPaw)1bj?}#e*j7(+OuX">
                                    <field name="TEXT">12/01</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                              <block type="logic_compare" id="dWU^lD%(7ac*e$PKNrhF">
                                <field name="OP">LTE</field>
                                <value name="A">
                                  <block type="time_get" id="d(3^$vsg3DKf@7wn(_9s">
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="text" id="=L^_)Og/Pb#z58x$Ks0;">
                                    <field name="TEXT">01/31</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                            <value name="IF0">
                              </block>
                            </value>
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </statement>
                            <value name="IF1">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                                  </block>
                                </value>
                              </block>
                            </statement>
                            <next>
                                <value name="IF0">
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                                <next>
                                    <value name="TEXT">
                                      </shadow>
                                        <value name="ADD0">
                                          </block>
                                        </value>
                                        <value name="ADD1">
                                          </block>
                                        </value>
                                        <value name="ADD2">
                                          </block>
                                        </value>
                                        <value name="ADD3">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </statement>
                    <next>
                      <block type="schedule" id="ak~y9Iwu#Cup^J),=;v@">
                          <block type="control" id="oZj+MJkM;{]VnsEg.;A^">
                              <block type="logic_boolean" id="cV3]LAPIrt2tIOX-)d|t">
                              </block>
                            </value>
                            <next>
                              <block type="debug" id="7^r40|R30Z}3Kv)r|f8f">
                                <value name="TEXT">
                                  </shadow>
                                  <block type="text_join" id="y/kf?#2~+Z[c#pQjx#Z)">
                                    <value name="ADD0">
                                      <block type="text" id="]u=J_0w=vHN{zR/[yPoZ">
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      <block type="variables_get" id="W^;Ww~TaenQB+RO$hkHN">
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                      <block type="text" id="h6f=xZOU[Zo.](Qcl+v)">
                                      </block>
                                    </value>
                                    <value name="ADD3">
                                      <block type="get_value" id=",=-.E{00d*V[KQse*.GF">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </statement>
                        <next>
                          <block type="schedule" id=",ECUIntEI0QA|h_h+kct">
                              <block type="controls_if" id=",}pMxq4a7bGFzlZ^GWVf">
                                <value name="IF0">
                                  <block type="logic_compare" id="uqgMXHv#IWDH6P9bzJ7w">
                                    <value name="A">
                                      <block type="get_value" id="U;u.tz;2xslL9g4SO8qx">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="math_number" id="}NM^dhdqr7^?*`h`R4t0">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                  <block type="control" id="fBR6ceNE|aLkv?~u_*sn">
                                      <block type="logic_boolean" id="~9g-D.r!~]S;KRZ10Z6,">
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                                <next>
                                  <block type="debug" id="[k9j)X3_5#kaEq`l,o]*">
                                    <value name="TEXT">
                                      </shadow>
                                      <block type="text_join" id="l--#7]:HfKX$u94:lwEl">
                                        <value name="ADD0">
                                          <block type="text" id="yD*h{N`o+]^xO|xUX^ZC">
                                          </block>
                                        </value>
                                        <value name="ADD1">
                                          <block type="variables_get" id="TN-#Gu]hUM+${?$|}Z7r">
                                          </block>
                                        </value>
                                        <value name="ADD2">
                                          <block type="text" id="(.q3YL3bmfx4IpU$_z4r">
                                          </block>
                                        </value>
                                        <value name="ADD3">
                                          <block type="get_value" id="KR/ZhBngvcuN5{7fcU{;">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </statement>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </xml>
              Hicki
              @paul53 sagte in komplettes Script zB. von November bis Januar aktivieren:
              ich habe es geändert, so wie es Paul53 geschrieben hat. Es funktioniert aber nicht.
                <variables>
                  <variable id="h9D`_bjnh7+zfds1apYJ">monat</variable>
                </variables>
                    </block>
                  </value>
                  <next>
                      <value name="OID0">
                        </shadow>
                      </value>
                        <block type="variables_set" id="+C=!uRkGaZV+@fwXn(^-">
                          <field name="VAR" id="h9D`_bjnh7+zfds1apYJ">monat</field>
                            <block type="time_get" id="SP54U[1N:+(T*JZQ35wy">
                              <field name="OPTION">M</field>
                            </block>
                          </value>
                          <next>
                              <value name="IF0">
                                <block type="logic_operation" id="2+e?:^M.*R-ZIHgD];C,">
                                  <value name="A">
                                    <block type="logic_compare" id="i.rk`1TXp!JYA42Sew%U">
                                      <value name="A">
                                        <block type="variables_get" id="vMq!pTewS+y1_IO8Bk6B">
                                        </block>
                                      </value>
                                      <value name="B">
                                        <block type="math_number" id="$#|ns76)0ik=DuJX^0zN">
                                          <field name="NUM">11</field>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="logic_compare" id="th?,9uz!uBdsFyN|jn:5">
                                      <field name="OP">EQ</field>
                                      <value name="A">
                                        <block type="variables_get" id="@K=3Ujd]%!-{yW{Btq9S">
                                        </block>
                                      </value>
                                      <value name="B">
                                        <block type="math_number" id="6u%uJ.L,f[{xNNP88$9n">
                                          <field name="NUM">1</field>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </value>
                                <block type="controls_if" id="ah9bdqk^?`(F?iRu9K0E">
                                  <value name="IF0">
                                    </block>
                                  </value>
                                          <value name="A">
                                            </block>
                                          </value>
                                          <value name="B">
                                              <field name="NUM">350</field>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                </block>
                              </statement>
                              <value name="IF1">
                                  <value name="A">
                                      <field name="START_TIME">23:30</field>
                                    </block>
                                  </value>
                                  <value name="B">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </value>
                                    </block>
                                  </value>
                                </block>
                              </statement>
                              <next>
                                  <value name="IF0">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                    <block type="control" id="w.%$^mNIRkE/BvQ_kibz">
                                        <block type="variables_get" id="_b]p1k!)%d}f%ykWXd=4">
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                  <next>
                                      <value name="TEXT">
                                        </shadow>
                                          <value name="ADD0">
                                            </block>
                                          </value>
                                          <value name="ADD1">
                                            </block>
                                          </value>
                                          <value name="ADD2">
                                            </block>
                                          </value>
                                          <value name="ADD3">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </statement>
                      <next>
                          <field name="SCHEDULE">0 2 * 1,11,12 *</field>
                            <block type="control" id="e$Hyu9Sa.Sz9/5=Ma4TE">
                                <block type="logic_boolean" id="Y9SG.fNG@^=%Y+$@ow|)">
                                </block>
                              </value>
                              <next>
                                <block type="debug" id="=e7HUvXBE%fz)WI8HLUD">
                                  <value name="TEXT">
                                    </shadow>
                                    <block type="text_join" id="3q=r},YXe!pv`V[ma!,4">
                                      <value name="ADD0">
                                        <block type="text" id="q`mw%gyq)T$lgE)rqzm5">
                                        </block>
                                      </value>
                                      <value name="ADD1">
                                        <block type="variables_get" id="p2svWA!S`R4*pV0%9e0?">
                                        </block>
                                      </value>
                                      <value name="ADD2">
                                        <block type="text" id="8GP6#MJ5^K`b?`g~f2*9">
                                        </block>
                                      </value>
                                      <value name="ADD3">
                                        <block type="get_value" id="NAU_RnF6{6U?#-{_rOqv">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </statement>
                          <next>
                              <field name="SCHEDULE">0 6 * 1,11,12 *</field>
                                  <value name="IF0">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                    <block type="control" id="KXd3@lXse#4s[gt=zm@Z">
                                        <block type="logic_boolean" id="BN-5gr7sNQ?R^8E|3*m+">
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                  <next>
                                    <block type="debug" id="Vx}Nv%]Bt_k9]N^RakQS">
                                      <value name="TEXT">
                                        </shadow>
                                        <block type="text_join" id="p8.wQe+)UP~?43;ljchF">
                                          <value name="ADD0">
                                            <block type="text" id="F7*Cv|^vdR#Ii(6B#S|o">
                                            </block>
                                          </value>
                                          <value name="ADD1">
                                            <block type="variables_get" id="H~:(r8Vn#tJIH5kFM|u=">
                                            </block>
                                          </value>
                                          <value name="ADD2">
                                            <block type="text" id="*+C:ANSOjYY~O8=l?U0=">
                                            </block>
                                          </value>
                                          <value name="ADD3">
                                            <block type="get_value" id="C,R}00?Q0*-VlVaY([+[">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </xml>
              Was habe ich falsch gemacht?
              besser dargestellt
              • H Hicki
                  <variables>
                  </variables>
                      </block>
                    </value>
                    <next>
                        <value name="OID0">
                          </shadow>
                        </value>
                              </block>
                            </value>
                            <next>
                                <value name="IF0">
                                    <value name="A">
                                        <value name="A">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="B">
                                        <value name="A">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                    <value name="IF0">
                                      </block>
                                    </value>
                                            <value name="A">
                                              </block>
                                            </value>
                                            <value name="B">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </statement>
                                  </block>
                                </statement>
                                <value name="IF1">
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                        <value name="A">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                                <next>
                                    <value name="IF0">
                                        <value name="A">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                          </block>
                                        </value>
                                      </block>
                                    </statement>
                                    <next>
                                        <value name="TEXT">
                                          </shadow>
                                            <value name="ADD0">
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                              </block>
                                            </value>
                                            <value name="ADD2">
                                              </block>
                                            </value>
                                            <value name="ADD3">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </statement>
                        <next>
                                  </block>
                                </value>
                                <next>
                                    <value name="TEXT">
                                      </shadow>
                                        <value name="ADD0">
                                          </block>
                                        </value>
                                        <value name="ADD1">
                                          </block>
                                        </value>
                                        <value name="ADD2">
                                          </block>
                                        </value>
                                        <value name="ADD3">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </statement>
                            <next>
                                    <value name="IF0">
                                        <value name="A">
                                          </block>
                                        </value>
                                        <value name="B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                          </block>
                                        </value>
                                      </block>
                                    </statement>
                                    <next>
                                        <value name="TEXT">
                                          </shadow>
                                            <value name="ADD0">
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                              </block>
                                            </value>
                                            <value name="ADD2">
                                              </block>
                                            </value>
                                            <value name="ADD3">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </xml>
                besser dargestellt
                @hicki sagte in komplettes Script zB. von November bis Januar aktivieren:
                besser dargestellt
                dein falls mit den Zeitabfragen umschliesst nicht alles!
                ist das gewollt?
                ...ist keine Fehlerbeschreibung!
                was passiert?
                was erwartest du?
                  besser dargestellt
                  ist das gewollt?
                  was passiert?
                  was erwartest du?
                  Hicki
                  @homoran Hallo,
                  ich erkläre noch einmal was ich genau mit dem Script erreichen will.
                  Lichtsensor - Terrasse.LUX ist der Lichtsensor
                  Objekt ID Switch2 ist schaltbare Steckdose
                  Von November bis Januar soll das Script aktiv sein, dass heißt,
                  von 6 - 23Uhr soll bei weniger als 350Lux die Steckdose an gehen
                  ab 23.30Uhr Steckdose aus
                  ab 6Uhr Steckdose wieder an bei weniger als 350Lux
                  bei allen Uhrzeiten bei mehr als 350Lux Steckdose aus
                  Ich hoffe es verständlich erklärt zu haben.
                  Gruß Hicki
                  paul53P HomoranH 3 Antworten Letzte Antwort
                  • H Hicki
                    @homoran Hallo,
                    Gruß Hicki
                    @hicki sagte: ab 23.30Uhr Steckdose aus
                    Weshalb dann per Zeitplan erst um 2:00 Uhr? Der Lux-Wert wird sich nach 23:00 Uhr nicht mehr ändern.
                    Versuche es mal einfacher:
                    • H Hicki
                      @homoran Hallo,
                      Gruß Hicki
                      @hicki sagte: bei allen Uhrzeiten bei mehr als 350Lux Steckdose aus
                      Wenn der Wert um 350 Lux schwankt, geht das Licht ein und aus. Besser ist es, am Vormittag das Licht bei erster Überschreitung nur auszuschalten und abends bei erster Unterschreitung nur einzuschalten.
                      • H Hicki
                        @homoran Hallo,
                        Gruß Hicki
                        nicht wirklich!
                        also nochmal:
                        heisst was?
                          Hicki
                          weil 2Uhr das Licht ausgeschalten werden soll.
                          • H Hicki
                            und nicht wird?
                            aber die Systemzeit ist richtig?
                              Hicki
                              Abend geht das Licht nicht an.
                              • H Hicki
                                Hicki
                                @hicki Ich war jetzt lange Krank, deshalb melde ich mich jetzt erst.
                                Es haut immer noch nicht hin. Wer kann mir bitte helfen.
                                Vielen Dank -
                                Hicki
                                • H Hicki
                                  Vielen Dank -
                                  Hicki
                                  Michi_Pi
                                  @hicki was genau funktioniert denn jetzt und was nicht? Dann wäre es auch einfacher dir zu helfen.
                                  • M Michi_Pi
                                    Hicki
                                    @michi_pi Hallo,
                                    das Licht geht nicht an.
                                    • H Hicki
                                      @michi_pi Hallo,
                                      @michi_pi Hallo,
                                      und wie hell ist es?
                                        @michi_pi Hallo,
                                        Hicki
                                        @homoran Wenn es unter 350Lux ist, bleibt es dunkel
                                        • H Hicki
                                          ja! deshalb die Frage
