  4. keine Geräte im Zigbee Adapter [gelöst - Vielen Dank]
zigbee-adapter
61 Beiträge 2 Kommentatoren 6.5k Aufrufe 2 Beobachtet
    @wolkenloser
    Ich seh nix. Text auch als Text in CodeTags eingebettet hier rein.
    W Offline
    W Offline
    wolkenloser
    schrieb am zuletzt editiert von wolkenloser
    #41
    /opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
    (#####⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠸ idealTree:@root/greenlock: sill placeDep ROOT @root/keypairs@0.9.0 OK for: greenlock@4.0.(#####⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠸ idealTree:@root/greenlock: sill placeDep ROOT @root/keypairs@0.9.0 OK for: greenlock@4.0.npm WARN skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
    npm WARN deprecated string-similarity@4.0.4: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
    npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
    npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in 0.5.0
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated phantomjs-prebuilt@2.1.16: this package is now deprecated
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
    npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
    added 6 packages, and changed 1963 packages in 15m
    176 packages are looking for funding
      run `npm fund` for details
    iobroker@iobroker:/opt/iobroker$ npm fund
    iobroker.inst@2.0.3
    ├── https://github.com/sponsors/jaredhanson
    │   └── passport@0.5.3
    ├── https://github.com/sponsors/RubenVerborgh
    │   └── follow-redirects@1.15.3
    ├── https://github.com/sponsors/ljharb
    │   └── qs@6.11.0, side-channel@1.0.4, call-bind@1.0.5, function-bind@1.1.2, gopd@1.0.1, has-property-descriptors@1.0.1, get-intrinsic@1.2.2, has-proto@1.0.1, has-symbols@1.0.3, object-inspect@1.13.1, is-arguments@1.1.1, has-tostringtag@1.0.0, is-generator-function@1.0.10, is-typed-array@1.1.12, which-typed-array@1.1.13, available-typed-arrays@1.0.5, is-callable@1.2.7, resolve@1.22.8, is-core-module@2.13.1, supports-preserve-symlinks-flag@1.0.0, minimist@1.2.8, is-nan@1.3.2, define-properties@1.2.1, object-is@1.1.5, traverse@0.6.7, is-object@1.0.2, deep-equal@1.1.2, is-date-object@1.0.5, is-regex@1.1.4, regexp.prototype.flags@1.5.1, functions-have-names@1.2.3, object.assign@4.1.4
    ├── https://github.com/sponsors/feross
    │   └── safe-buffer@5.2.1, base64-js@1.5.1, ieee754@1.2.1, simple-concat@1.0.1, buffer@6.0.3, run-parallel@1.2.0, queue-microtask@1.2.3
    ├── https://github.com/sponsors/broofa
    │   └── uuid@9.0.1
    ├── https://github.com/sponsors/sindresorhus
    │   └── is-stream@2.0.1, responselike@2.0.1, clone-response@1.0.3, get-stream@5.2.0, normalize-url@6.1.0, component-emitter@1.3.1, make-dir@3.1.0, mimic-response@2.1.0, onetime@5.1.2, multimatch@5.0.0, throttleit@1.0.1, sort-keys@4.2.0, p-limit@2.3.0, p-queue@6.6.2, any-observable@0.5.1, del@6.1.1, globby@11.1.0, p-map@4.0.0, escape-goat@3.0.0, escape-string-regexp@4.0.0, import-local@3.1.0, is-installed-globally@0.3.2, global-dirs@2.1.0, log-symbols@4.1.0, is-unicode-supported@0.1.0, meow@8.1.2, camelcase-keys@6.2.2, map-obj@4.3.0, decamelize-keys@1.1.1, type-fest@0.18.1, npm-name@6.0.1, p-event@4.2.0, type-fest@0.10.0, is-url-superb@4.0.0, open@7.4.2, is-docker@2.2.1, ow@0.21.0, dot-prop@6.0.1, type-fest@0.20.2, p-settle@4.1.1, read-pkg-up@7.0.1, terminal-link@2.1.1, boxen@5.1.2, camelcase@6.3.0, cli-boxes@2.2.1, is-installed-globally@0.4.0, global-dirs@3.0.1, is-npm@5.0.0, import-fresh@3.3.0, parse-json@5.2.0, ansi-escapes@4.3.2, type-fest@0.21.3, figures@3.2.0, find-up@5.0.0, locate-path@6.0.0, p-locate@5.0.0, p-limit@3.1.0, yocto-queue@0.1.0, hex-rgb@4.3.0
    ├─┬ https://github.com/sindresorhus/got?sponsor=1
    │ │ └── got@11.8.6, got@10.7.0
    │ └── https://github.com/sindresorhus/is?sponsor=1
    │     └── @sindresorhus/is@4.6.0, @sindresorhus/is@2.1.1
    ├── https://github.com/sponsors/epoberezkin
    │   └── ajv@6.12.6
    ├── https://github.com/sponsors/NaturalIntelligence
    │   └── fast-xml-parser@4.3.2
    ├── https://github.com/sponsors/isaacs
    │   └── minimatch@9.0.3, rimraf@3.0.2, glob@7.2.3
    ├─┬ https://opencollective.com/node-fetch
    │ │ └── node-fetch@3.3.2
    │ └── https://github.com/sponsors/jimmywarting
    │     └── fetch-blob@3.2.0, node-domexception@1.0.0
    ├── https://opencollective.com/serialport/donate
    │   └── serialport@10.5.0, @serialport/bindings-cpp@10.8.0, @serialport/parser-byte-length@10.5.0, @serialport/parser-cctalk@10.5.0, @serialport/parser-delimiter@10.5.0, @serialport/parser-inter-byte-timeout@10.5.0, @serialport/parser-readline@10.5.0, @serialport/parser-ready@10.5.0, @serialport/parser-regex@10.5.0, @serialport/parser-slip-encoder@10.5.0, @serialport/parser-spacepacket@10.5.0, @serialport/stream@10.5.0, @serialport/bindings-cpp@12.0.1, @serialport/parser-delimiter@12.0.0, @serialport/stream@12.0.0
    ├── https://www.buymeacoffee.com/systeminfo
    │   └── systeminformation@5.21.17
    ├── https://opencollective.com/date-fns
    │   └── date-fns@2.30.0
    ├── https://opencollective.com/ioredis
    │   └── ioredis@4.28.5
    ├── https://github.com/sindresorhus/execa?sponsor=1
    │   └── execa@5.1.1
    ├─┬ https://paulmillr.com/funding/
    │ │ └── chokidar@3.5.3
    │ └── https://github.com/sponsors/jonschlinkert
    │     └── picomatch@2.3.1, set-value@4.1.0
    ├── https://github.com/sponsors/sibiraj-s
    │   └── ci-info@3.9.0
    ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
    │ │ └── wrap-ansi@7.0.0
    │ └── https://github.com/chalk/ansi-styles?sponsor=1
    │     └── ansi-styles@4.3.0
    ├── https://opencollective.com/browserslist
    │   └── browserslist@4.22.1, caniuse-lite@1.0.30001563, update-browserslist-db@1.0.13
    ├── https://opencollective.com/core-js
    │   └── core-js@3.33.3, core-js-compat@3.33.3
    ├─┬ https://opencollective.com/javascript-obfuscator
    │ │ └── javascript-obfuscator@3.2.7
    │ └── https://github.com/chalk/chalk?sponsor=1
    │     └── chalk@4.1.2
    ├── https://github.com/sponsors/wooorm
    │   └── levenshtein-edit-distance@2.0.5
    ├── https://opencollective.com/js-sdsl
    │   └── js-sdsl@4.3.0
    └─┬ https://github.com/sindresorhus/np?sponsor=1
      │ └── np@7.7.0
      ├── https://github.com/sindresorhus/p-memoize?sponsor=1
      │   └── p-memoize@4.0.4
      └── https://github.com/yeoman/update-notifier?sponsor=1
          └── update-notifier@5.1.0
    W 1 Antwort Letzte Antwort
    • W wolkenloser
      iobroker.inst@2.0.3
      │   └── uuid@9.0.1
      │   └── ajv@6.12.6
      │   └── execa@5.1.1
      │   └── ci-info@3.9.0
      │     └── chalk@4.1.2
      │   └── js-sdsl@4.3.0
        │ └── np@7.7.0
      W Offline
      W Offline
      wolkenloser
      #42
      Die Web Oberfläche klappt wieder , ENERGIEFLUSS läßt sich deinstallieren.
      Dann bleibt noch der fronius
      • W wolkenloser
        W Offline
        W Offline
        wolkenloser
        #43
        Kurzes Status Update.
        Ich update gerade 30 Adapter, pro Adapter dauert es anscheinend mehr als 5 Minuten.
        • W wolkenloser
          #44
          @wolkenloser
          Ja, das ist möglich.
            @wolkenloser
            W Offline
            W Offline
            wolkenloser
            #45
            das Updaten der Adapter dauert leider sehr lange.
            Es gibt bei einigen Adaptern Fehlermeldungen sowohl beim Updaten, als auch beim löschen wie z.B. hier bei Openweather Map.
            Da steht man soll den Adapter von Hand löschen, aber trotz intensiver suche weiss ich nicht wo die Dateien liegen. Da brauch ich noch einmal Hilfe:
            ERROR: Process exited with code 25
            weniger
            mehr
            $ iobroker upgrade openweathermap@0.4.5
            Update openweathermap from @0.3.11 to @0.4.5
            NPM version: 9.8.1
            Installing iobroker.openweathermap@0.4.5... (System call)
            host.iobroker Cannot install iobroker.openweathermap@0.4.5: 217
            Ich hab die meisten Module hier gefunden, aber nicht openweathermap
            /opt/iobroker/iobroker-data/files$ ls
            admin.admin                        javascript.admin          vis-2-beta
            alias-manager.admin                knx.admin                 vis-2-beta.0
            backitup.admin                     lg-thinq.admin            vis-2-beta.admin
            bydbatt.admin                      lgtv.admin                vis.admin
            bydhvs.admin                       midea.admin               vis-bars.admin
            cloud.admin                        mihome.admin              vis-canvas-gauges.admin
            daswetter.admin                    mihome-vacuum.admin       vis-colorpicker.admin
            device-reminder.admin              mobile                    vis-fancyswitch.admin
            discovery.admin                    mobile.admin              vis-google-fonts.admin
            dwd.admin                          moma.admin                vis-history.admin
            easee.admin                        onkyo.admin               vis-hqwidgets.admin
            echarts                            parser.admin              vis-icontwo
            echarts.admin                      phantomjs.admin           vis-icontwo.admin
            fakeroku.admin                     pi-hole.admin             vis-inventwo.admin
            feiertage.admin                    ping.admin                vis-jqui-mfd.admin
            flot                               pvforecast.admin          vis-justgage.admin
            flot.admin                         sayit.0                   vis-keyboard.admin
            fronius.admin                      sayit.admin               vis-lcars.admin
            fronius-solarweb.admin             scenes.admin              vis-map.admin
            habpanel                           schwoerer-ventcube.admin  vis-material.admin
            habpanel.admin                     shelly.0                  vis-material-advanced.admin
            harmony.admin                      shelly.admin              vis-metro.admin
            history.admin                      shuttercontrol.admin      vis-players.admin
            ical.admin                         simple-api.admin          vis-plumb.admin
            icons-addictive-flavour-png        socketio.admin            vis-rgraph.admin
            icons-addictive-flavour-png.admin  sonoff.admin              vis-timeandweather.admin
            icons-mfd-svg                      sourceanalytix.admin      vis-weather.admin
            icons-mfd-svg.admin                tado.admin                web
            icons-open-icon-library-png        tankerkoenig.admin        web.admin
            icons-open-icon-library-png.admin  tr-064.admin              web-speedy.admin
            influxdb.admin                     trashschedule.admin       wifilight.admin
            info.admin                         tuya.admin                wled.admin
            iqontrol.meta                      unifi.admin               zigbee.admin
            jarvis                             vis
            jarvis.admin                       vis.0
            • W wolkenloser
              weniger
              mehr
              NPM version: 9.8.1
              jarvis                             vis
              jarvis.admin                       vis.0
              #46
              @wolkenloser
              Du kannst auch immer mal ein
              iob fix
              einschieben.
                @wolkenloser
                iob fix
                einschieben.
                W Offline
                W Offline
                wolkenloser
                #47
                Ok, mach ich.
                Ich hab da ganz viel Meldungen vom Tpy
                chown: changing ownership of '/opt/iobroker/backups/sqlite_2023_09_26-02_01_42_backupiobroker.sql': Permission denied
                chown: changing ownership of '/opt/iobroker/backups/influxDB_2023_10_30-02_01_00_backupiobroker.tar.gz': Permission denied
                chown: changing ownership of '/opt/iobroker/backups/influxDB_2023_09_13-02_00_24_backupiobroker.tar.gz': Permission denied
                chown: changing ownership of '/opt/iobroker/backups/iobroker_2023_03_08-02_00_21_backupiobroker.tar.gz': Permission denied
                chown: changing ownership of '/opt/iobroker/backups/iobroker_2023_10_04-02_00_22_backupiobroker.tar.gz': Permission denied
                chown: changing ownership of '/opt/iobroker/backups/sqlite_2023_09_18-02_01_41_backupiobroker.sql': Permission denied
                chown: changing ownership of '/opt/iobroker/backups/iobroker_2023_10_02-02_00_22_backupiobroker.tar.gz': Permission denied
                chown: changing ownership of '/opt/iobroker/backups/zigbee.0_2023_03_05-02_01_29_backupiobroker.tar.gz': Permission denied
                chown: changing ownership of '/opt/iobroker/backups/influxDB_2023_10_21-02_00_43_backupiobroker.tar.gz': Permission denied
                chown: changing ownership of '/opt/iobroker/backups/iobroker_2023_09_28-02_00_22_backupiobroker.tar.gz': Permission denied
                chown: changing ownership of '/opt/iobroker/backups/sqlite_2023_11_09-02_01_14_backupiobroker.sql': Permission denied
                chown: changing ownership of '/opt/iobroker/backups/influxDB_2023_09_29-02_00_45_backupiobroker.tar.gz': Permission denied
                chown: changing ownership of '/opt/iobroker/backups': Permission denied
                This system does not support setting default permissions.
                Do not use npm to manually install adapters unless you know what you are doing!
                Ich hatte mal gelesen das man IOB mit SUDO nicht machen sollte.
                Gilt das auch für IOB FIX ?
                • W wolkenloser
                  Ok, mach ich.
                  #48
                  @wolkenloser sagte in keine Geräte im Zigbee Adapter - funktioniert aber.:
                  Das gilt FÜR ALLES was mit iob / iobroker zu tun hat...
                  Nie, nie, niemals sudo vor iob / iobroker-Kommandos setzen. NIE!
                  Das führt nämlich genau zu solch krummen Kisten wie bei dir gerade.
                    W Offline
                    W Offline
                    wolkenloser
                    #49
                    ok, hast Du trotzdem eine Idee wie ich den Backupordner wieder grade ziehen kann ?
                    /opt/iobroker$ ls -l
                    total 344
                    drwxrwxr-x+    2 iobroker iobroker   4096 Sep 11  2022 backups
                    drwxrwxr-x+    2 iobroker iobroker   4096 Jan 11  2020 cache
                    -rwxrwxrwx+    1 iobroker iobroker   1049 Okt 19  2019 CHANGELOG_FIXER_LINUX.md
                    -rwxrwxrwx+    1 iobroker iobroker   3556 Okt 19  2019 CHANGELOG_INSTALLER_LINUX.md
                    -rwxrwxrwx+    1 iobroker iobroker  23988 Okt 19  2019 fix_installation.sh
                    drwxrwxrwx+    3 iobroker iobroker   4096 Okt 19  2019 install
                    -rwxrwxrwx+    1 iobroker iobroker   1938 Nov 21 10:50 INSTALLER_INFO.txt
                    lrwxrwxrwx     1 iobroker iobroker     22 Nov 21 10:50 iob -> /opt/iobroker/iobroker
                    -rwxr-xr-x+    1 iobroker iobroker    677 Nov 21 10:50 iobroker
                    drwxrwxrwx+   15 iobroker iobroker   4096 Nov 21 10:54 iobroker-data
                    drwxrwxrwx+    2 iobroker iobroker   4096 Okt 19  2019 lib
                    -rwxrwxrwx+    1 iobroker iobroker   1137 Okt 19  2019 LICENSE
                    drwxrwxrwx+    2 iobroker iobroker   4096 Nov 21 11:08 log
                    drwxrwxr-x+ 2293 iobroker iobroker  86016 Nov 21 11:02 node_modules
                    -rwxrwxrwx+    1 iobroker iobroker   3889 Nov 20 19:58 package.json
                    -rwxrwxrwx+    1 iobroker iobroker 169201 Okt 19  2019 package-lock.json
                    -rwxrwxrwx+    1 iobroker iobroker   6101 Okt 19  2019 README.md
                    -rwxrwxrwx+    1 iobroker iobroker   5693 Aug 11  2021 reinstall.js
                    • W wolkenloser
                      total 344
                      #50
                      @wolkenloser
                      Mit
                      iob fix
                        @wolkenloser
                        Mit
                        iob fix
                        W Offline
                        W Offline
                        wolkenloser
                        #51
                        hat geholfen
                        Process exited with code 0
                        weniger
                        mehr
                        $ iobroker del openweathermap --custom
                        Delete adapter "openweathermap"
                        host.iobroker object openweathermap deleted
                        host.iobroker object openweathermap.admin deleted
                        added 5 packages, removed 843 packages, and changed 2303 packages in 13m263 packages are looking for funding run `npm fund` for details
                        Adapter "system.adapter.vis.0" restarted.
                        Adapter "system.adapter.vis-2-beta.0" restarted.
                        • W wolkenloser
                          hat geholfen
                          weniger
                          mehr
                          #52
                          hat geholfen
                          Natürlich. Wenn man mit dem iobroker richtig umgeht funktioniert das auch.
                            hat geholfen
                            W Offline
                            W Offline
                            wolkenloser
                            #53
                            @thomas-braun sagte in keine Geräte im Zigbee Adapter - funktioniert aber.:
                            hat geholfen
                            Der ursprüngliche Fehler besteht auch immer noch.
                            Keine Geräte im Zigbee Adapter.
                            Ich habe aber noch 5 Adapter die sich derzeit micht Updaten lassen.
                            Meistens nach IOB FIX geht es wiieder für ein paar Adapter.
                            Das versuche ich erstmal sauber zu bekommen.
                            Und dann steht da immer noch das HOST Update im IOBROKER....
                            Beim Zigbee hab ich die Befürchtung, wenn ich den gelöscht bekomme und dann neu installiere muß ich alle Datenpunkte in meinen Scripten neu zuordnen, Oder ?
                            Ich habe mehrere Bewegungsmelder, Türkontakte und Thermometer im Einsatz
                            • W wolkenloser
                              hat geholfen
                              W Offline
                              W Offline
                              wolkenloser
                              #54
                              noch 3 :-)
                                Pending iob updates: 27
                                Wassen da los?
                                Ran da!
                                W Offline
                                W Offline
                                wolkenloser
                                #55
                                Ich habe es jetzt endlich geschafft.
                                Alle Adapter sind up to Date.
                                Ich bin jetzt an der Stelle wo ich den Host updaten kann.
                                In der Anweisung stehen folgende Befehle.
                                Ist das jetzt anzuraten oder lieber nicht ?
                                Beim letzen Versuch lief bei mir der IOBROKER nicht mehr
                                iobroker stop
                                iobroker update
                                iobroker fix
                                iobroker upgrade self
                                iobroker start
                                • W wolkenloser
                                  iobroker stop
                                  iobroker update
                                  iobroker fix
                                  iobroker start
                                  W Offline
                                  W Offline
                                  wolkenloser
                                  #56
                                  Aktueller stand ist derzeit
                                  ======== Start marking the full check here =========
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                     Static hostname: iobroker
                                           Icon name: computer-vm
                                             Chassis: vm
                                      Virtualization: microsoft
                                    Operating System: Ubuntu 20.04.6 LTS
                                              Kernel: Linux 5.4.0-167-generic
                                        Architecture: x86-64
                                  model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                                  Docker          : false
                                  Virtualization  : microsoft
                                  Kernel          : x86_64
                                  Userland        : amd64
                                  Systemuptime and Load:
                                   10:47:12 up  1:35,  1 user,  load average: 0.16, 0.26, 0.52
                                  CPU threads: 4
                                  *** Time and Time Zones ***
                                                 Local time: Wed 2023-11-22 10:47:12 CET
                                             Universal time: Wed 2023-11-22 09:47:12 UTC
                                                   RTC time: Wed 2023-11-22 09:47:13
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** User and Groups ***
                                  iobroker
                                  /home/iobroker
                                  iobroker adm tty dialout cdrom sudo audio dip video plugdev lxd
                                  *** X-Server-Setup ***
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:           5.9G        497M        3.4G        1.0M        2.0G        5.2G
                                  Swap:          2.0G         15M        2.0G
                                  Total:         7.9G        512M        5.4G
                                           5929 M total memory
                                            497 M used memory
                                            975 M active memory
                                            910 M inactive memory
                                           3409 M free memory
                                            378 M buffer memory
                                           1643 M swap cache
                                           1969 M total swap
                                             15 M used swap
                                           1954 M free swap
                                  *** FAILED SERVICES ***
                                    UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                                  * iobroker.service loaded failed failed ioBroker Server
                                  1 loaded units listed.
                                  *** FILESYSTEM ***
                                  udev           devtmpfs  2.9G     0  2.9G   0% /dev
                                  tmpfs          tmpfs     593M  1.2M  592M   1% /run
                                  /dev/sda2      ext4       50G   34G   13G  73% /
                                  tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
                                  tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                  tmpfs          tmpfs     2.9G     0  2.9G   0% /sys/fs/cgroup
                                  /dev/loop3     squashfs   56M   56M     0 100% /snap/core18/2796
                                  /dev/loop0     squashfs  106M  106M     0 100% /snap/core/16202
                                  /dev/loop2     squashfs   56M   56M     0 100% /snap/core18/2790
                                  /dev/loop5     squashfs   64M   64M     0 100% /snap/core20/2015
                                  /dev/loop1     squashfs  106M  106M     0 100% /snap/core/16091
                                  /dev/loop4     squashfs   64M   64M     0 100% /snap/core20/1974
                                  /dev/loop6     squashfs   92M   92M     0 100% /snap/lxd/23991
                                  /dev/loop8     squashfs  128K  128K     0 100% /snap/ncdu/62
                                  /dev/loop7     squashfs   92M   92M     0 100% /snap/lxd/24061
                                  /dev/loop9     squashfs  128K  128K     0 100% /snap/ncdu/64
                                  /dev/loop10    squashfs  4.3M  4.3M     0 100% /snap/tree/18
                                  tmpfs          tmpfs     593M     0  593M   0% /run/user/1000
                                  [Wed Nov 22 09:11:55 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                                  [Wed Nov 22 09:12:02 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
                                  Show mounted filesystems \(real ones only\):
                                  TARGET                SOURCE      FSTYPE   OPTIONS
                                  /                     /dev/sda2   ext4     rw,relatime
                                  |-/sys/kernel/tracing tracefs     tracefs  rw,nosuid,nodev,noexec,relatime
                                  |-/snap/core18/2796   /dev/loop3  squashfs ro,nodev,relatime
                                  |-/snap/core/16202    /dev/loop0  squashfs ro,nodev,relatime
                                  |-/snap/core18/2790   /dev/loop2  squashfs ro,nodev,relatime
                                  |-/snap/core20/2015   /dev/loop5  squashfs ro,nodev,relatime
                                  |-/snap/core/16091    /dev/loop1  squashfs ro,nodev,relatime
                                  |-/snap/core20/1974   /dev/loop4  squashfs ro,nodev,relatime
                                  |-/snap/lxd/23991     /dev/loop6  squashfs ro,nodev,relatime
                                  |-/snap/ncdu/62       /dev/loop8  squashfs ro,nodev,relatime
                                  |-/snap/lxd/24061     /dev/loop7  squashfs ro,nodev,relatime
                                  |-/snap/ncdu/64       /dev/loop9  squashfs ro,nodev,relatime
                                  `-/snap/tree/18       /dev/loop10 squashfs ro,nodev,relatime
                                  /var:
                                  5.6G    /var/
                                  4.0G    /var/log/journal/4c4f1c196fd742fb8ea78816d6e03b15
                                  4.0G    /var/log
                                  1.5G    /var/lib
                                  Archived and active journals take up 3.9G in the file system.
                                  /opt/iobroker/backups:
                                  12M     /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  17G     /opt/iobroker/iobroker-data/
                                  16G     /opt/iobroker/iobroker-data/history
                                  668M    /opt/iobroker/iobroker-data/files
                                  155M    /opt/iobroker/iobroker-data/backup-objects
                                  113M    /opt/iobroker/iobroker-data/files/vis-2-beta
                                  24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
                                  24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
                                  24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
                                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                                  17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.f79fb97a.js.map
                                  USB-Devices by-id:
                                  USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                                  /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs         v18.18.2
                                  /usr/bin/node           v18.18.2
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  /usr/bin/corepack       0.19.0
                                  nodejs:
                                    Installed: 18.18.2-1nodesource1
                                    Candidate: 18.18.2-1nodesource1
                                    Version table:
                                   *** 18.18.2-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                          100 /var/lib/dpkg/status
                                       18.18.1-1nodesource1 1001
                                       18.18.0-1nodesource1 1001
                                       18.17.1-1nodesource1 1001
                                       18.17.0-1nodesource1 1001
                                       18.16.1-1nodesource1 1001
                                       18.16.0-1nodesource1 1001
                                       18.15.0-1nodesource1 1001
                                       18.14.2-1nodesource1 1001
                                       18.14.1-1nodesource1 1001
                                       18.14.0-1nodesource1 1001
                                       18.13.0-1nodesource1 1001
                                       18.12.0-1nodesource1 1001
                                       18.11.0-1nodesource1 1001
                                       18.10.0-1nodesource1 1001
                                       18.9.1-1nodesource1 1001
                                       18.9.0-1nodesource1 1001
                                       18.8.0-1nodesource1 1001
                                       18.7.0-1nodesource1 1001
                                       18.6.0-1nodesource1 1001
                                       18.5.0-1nodesource1 1001
                                       18.4.0-1nodesource1 1001
                                       18.3.0-1nodesource1 1001
                                       18.2.0-1nodesource1 1001
                                       18.1.0-1nodesource1 1001
                                       18.0.0-1nodesource1 1001
                                       10.19.0~dfsg-3ubuntu1.3 500
                                          500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
                                          500 http://de.archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
                                       10.19.0~dfsg-3ubuntu1 500
                                          500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
                                  No problems detected
                                  Errors in npm tree:
                                  npm ERR! code ELSPROBLEMS
                                  npm ERR! invalid: iobroker.fronius@2.0.2 /opt/iobroker/node_modules/iobroker.fronius
                                  npm ERR! invalid: iobroker.labcom@0.1.1 /opt/iobroker/node_modules/iobroker.labcom
                                  npm ERR! invalid: eiscp@0.0.1 /opt/iobroker/node_modules/eiscp
                                  npm ERR! invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-22T09_47_33_666Z-debug-0.log
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  iobroker is not running on this host.
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Core adapters versions
                                  js-controller:  4.0.24
                                  admin:          6.12.0
                                  javascript:     7.1.4
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-22T09_48_06_617Z-debug-0.log
                                  Adapters from github:   2
                                  Adapter State
                                    system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                                    system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                    system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                                    system.adapter.easee.0                  : easee                 : iobroker                                 - disabled
                                    system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                                    system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
                                    system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                                    system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
                                    system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                                    system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
                                    system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                                    system.adapter.history.0                : history               : iobroker                                 -  enabled
                                    system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
                                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                                    system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                    system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                    system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                                    system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                    system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.8.67
                                    system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
                                    system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                                    system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                                    system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
                                    system.adapter.onkyo.0                  : onkyo                 : iobroker                                 -  enabled
                                    system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                                    system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                                    system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
                                    system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                    system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                    system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
                                    system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                                    system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                                    system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                    system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                    system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                    system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                    system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
                                    system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                                    system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
                                    system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                    system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                                    system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                                    system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                                    system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
                                    system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
                                    system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
                                    system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                                    system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
                                    system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                                    system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                                    system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
                                    system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                    system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                    system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
                                    system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                                    system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
                                  + instance is alive
                                  ioBroker-Repositories
                                  Active repo(s): stable
                                  Installed ioBroker-Instances
                                  Used repository: stable
                                  Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                  Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                                  Adapter    "backitup"     : 2.8.7    , installed 2.9.4
                                  Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
                                  Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
                                  Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                                  Adapter    "daswetter"    : 3.1.10   , installed 3.1.11
                                  Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                                  Adapter    "easee"        : 1.0.10   , installed 1.0.10
                                  Adapter    "echarts"      : 1.5.4    , installed 1.5.4
                                  Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
                                  Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                                  Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                                  Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                                  Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                  Adapter    "harmony"      : 1.2.2    , installed 1.3.0
                                  Adapter    "ical"         : 1.13.3   , installed 1.13.3
                                  Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
                                  Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
                                  Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                                  Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                                  Adapter    "info"         : 2.0.0    , installed 2.0.0
                                  Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                  Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                  Controller "js-controller": 5.0.16   , installed 4.0.24 [Updatable]
                                  Adapter    "knx"          : 2.0.23   , installed 2.0.23
                                  Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
                                  Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
                                  Adapter    "midea"        : 0.0.7    , installed 0.0.7
                                  Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                  Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                                  Adapter    "moma"         : 1.2.9    , installed 1.2.9
                                  Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                                  Adapter    "openweathermap": 0.4.5   , installed 0.4.5
                                  Adapter    "parser"       : 2.0.7    , installed 2.0.7
                                  Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
                                  Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                                  Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
                                  Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                                  Adapter    "scenes"       : 2.3.9    , installed 2.3.9
                                  Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                  Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
                                  Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                                  Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                  Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
                                  Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
                                  Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                                  Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                                  Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                                  Adapter    "vis"          : 1.4.16   , installed 1.5.1
                                  Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
                                  Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
                                  Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
                                  Adapter    "vis-icontwo"  : 0.97.1   , installed 0.97.1
                                  Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
                                  Adapter    "vis-justgage" : 2.0.0    , installed 2.0.0
                                  Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                  Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                                  Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                  Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                                  Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                  Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
                                  Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
                                  Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                  Adapter    "web"          : 6.1.10   , installed 6.1.10
                                  Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                                  Adapter    "wled"         : 0.7.1    , installed 0.7.1
                                  Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                  Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                                  Objects and States
                                  Objects:        11401
                                  States:         10304
                                  Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
                                  Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
                                  Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
                                  Hit:4 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
                                  Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Reading package lists...
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          28932      1063/perl
                                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        20806      663/systemd-resolve
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          26317      818/sshd: /usr/sbin
                                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        26362      810/influxd
                                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        29471      810/influxd
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          26319      818/sshd: /usr/sbin
                                  tcp6       0      0 :::3000                 :::*                    LISTEN      111        28897      784/grafana-server
                                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        20805      663/systemd-resolve
                                  udp        0      0 192.168.8.67:68         0.0.0.0:*                           100        22851      661/systemd-network
                                  udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          28933      1063/perl
                                  udp6       0      0 fe80::11:32ff:fe2d::546 :::*                                100        24053      661/systemd-network
                                  2023-11-22 10:36:45.421  - info: host.iobroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2023-11-22 10:36:45.422  - info: host.iobroker instance system.adapter.info.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2023-11-22 10:36:45.455  - info: host.iobroker instance system.adapter.lgtv.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2023-11-22 10:36:45.507  - info: tuya.0 (1832) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                  2023-11-22 10:36:45.506  - info: host.iobroker instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2023-11-22 10:36:45.507  - info: host.iobroker instance system.adapter.wled.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2023-11-22 10:36:45.985  - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGTERM
                                  2023-11-22 10:36:45.986  - info: host.iobroker instance system.adapter.javascript.0 terminated with code null ()
                                  2023-11-22 10:36:46.048  - warn: host.iobroker instance system.adapter.ping.0 terminated due to SIGTERM
                                  2023-11-22 10:36:46.049  - info: host.iobroker instance system.adapter.ping.0 terminated with code null ()
                                  2023-11-22 10:36:46.050  - warn: host.iobroker instance system.adapter.sonoff.0 terminated due to SIGTERM
                                  2023-11-22 10:36:46.050  - info: host.iobroker instance system.adapter.sonoff.0 terminated with code null ()
                                  2023-11-22 10:36:46.122  - warn: host.iobroker instance system.adapter.zigbee.0 terminated due to SIGTERM
                                  2023-11-22 10:36:46.123  - info: host.iobroker instance system.adapter.zigbee.0 terminated with code null ()
                                  2023-11-22 10:36:46.123  - warn: host.iobroker instance system.adapter.fronius.0 terminated due to SIGTERM
                                  2023-11-22 10:36:46.123  - info: host.iobroker instance system.adapter.fronius.0 terminated with code null ()
                                  2023-11-22 10:36:46.203  - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGTERM
                                  2023-11-22 10:36:46.204  - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
                                  2023-11-22 10:36:46.205  - warn: host.iobroker instance system.adapter.echarts.0 terminated due to SIGTERM
                                  2023-11-22 10:36:46.205  - info: host.iobroker instance system.adapter.echarts.0 terminated with code null ()
                                  2023-11-22 10:36:46.232  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2023-11-22 10:36:46.438  - info: host.iobroker instance system.adapter.history.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2023-11-22 10:36:46.463  - info: host.iobroker instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2023-11-22 10:36:46.463  - info: host.iobroker All instances are stopped.
                                  2023-11-22 10:36:46.878  - info: host.iobroker terminated
                                  iob diag has finished.
                                  • W wolkenloser
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                               Chassis: vm
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : amd64
                                    CPU threads: 4
                                                  NTP service: active
                                              RTC in local TZ: no
                                    iobroker
                                    /home/iobroker
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:          2.0G         15M        2.0G
                                             5929 M total memory
                                              497 M used memory
                                              975 M active memory
                                             3409 M free memory
                                              378 M buffer memory
                                             1643 M swap cache
                                             1969 M total swap
                                               15 M used swap
                                             1954 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    5.6G    /var/
                                    4.0G    /var/log
                                    1.5G    /var/lib
                                    USB-Devices by-id:
                                    /usr/bin/npm            9.8.1
                                    /usr/bin/npx            9.8.1
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.12.0
                                    javascript:     7.1.4
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        11401
                                    States:         10304
                                    Pending Updates: 0
                                    W Offline
                                    W Offline
                                    wolkenloser
                                    #57
                                    Den Fronius Adapter hab ich noch nicht angepackt....
                                    Den Labcom Adapter hatte ich gelöscht, anscheinen sidn noch Reste vorhanden....
                                    • W wolkenloser
                                      #58
                                      Installier den nochmal drüber.
                                      iob update
                                      iob upgrade fronius@2.0.2 --debug
                                      Zu labcom
                                      iob del iobroker.labcom --debug
                                        iob update
                                        Zu labcom
                                        W Offline
                                        W Offline
                                        wolkenloser
                                        #59
                                        ich hatte den Fronius adapter jetzt schon im Webinterface gelöscht und wieder hinzugefügt.
                                        Das hat geklappt.
                                        Mit IOB DIAG kommt jetzt nur noch das
                                        Errors in npm tree:
                                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-22T13_06_05_339Z-debug-0.log
                                        Bekomme ich das auch weg ?
                                        • W wolkenloser
                                          Das hat geklappt.
                                          Errors in npm tree:
                                          W Offline
                                          W Offline
                                          wolkenloser
                                          #60
                                          Ich habe jetzt alles geupdatet.
                                          Alle Adapter sind aktuell, und das Hostupdate hat am Ende auch funktioniert.
                                          Soweit erstmal alles Gut.
                                          Nun kann ich ja auf den Ersten Eintrag in diesem Threat kommen...
                                          genau das hat sich nicht verändert.
                                          Ich habe keine Geräte im Zigbee Adapter, angezeigt wird dort Version 1.75
                                          Installiert sein soll aber 1.8.24 ?
                                          Nach der ganzen Update Orgie würde ich ja sagen, Adapter entfernen nund neu installieren, aber bei Zigbee hab ich viele Sensoren in Scripten benutzt.
                                          Kann ich das auch so upgraden ?
                                          iob upgrade zigbee@1.8.24 --debug
