  3. Einsteigerfragen
  4. Installation
  5. Multihost - Slave tut nix...
Geplant Angeheftet Gesperrt Verschoben Installation
26 Beiträge 4 Kommentatoren 2.7k Aufrufe 5 Beobachtet
  • B Bluehannover
    @glasfaser Sorry, dachte falsch verstanden:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobrokermaster
           Icon name: computer-vm
             Chassis: vm
      Virtualization: kvm
    Operating System: Ubuntu 22.04.3 LTS
              Kernel: Linux 6.2.0-36-generic
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    model name	: QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     18:25:40 up 32 min,  2 users,  load average: 0.46, 0.15, 0.09
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Sat 2023-11-11 18:25:40 CET
               Universal time: Sat 2023-11-11 17:25:40 UTC
                     RTC time: Sat 2023-11-11 17:25:40
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    master
    /home/master
    master adm cdrom sudo dip plugdev lpadmin lxd sambashare iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop: 	ubuntu
    Terminal: 	wayland
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            3.9G        1.7G        270M         38M        1.9G        1.9G
    Swap:           3.4G        5.0M        3.4G
    Total:          7.3G        1.7G        3.7G
             3907 M total memory
             1729 M used memory
              942 M active memory
             2394 M inactive memory
              270 M free memory
               57 M buffer memory
             1850 M swap cache
             3429 M total swap
                5 M used swap
             3424 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem     Type     Size  Used Avail Use% Mounted on
    tmpfs          tmpfs    391M  1.6M  390M   1% /run
    /dev/sda3      ext4      31G   15G   15G  51% /
    tmpfs          tmpfs    2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs    5.0M     0  5.0M   0% /run/lock
    /dev/sda2      vfat     512M  6.1M  506M   2% /boot/efi
    tmpfs          tmpfs    391M  104K  391M   1% /run/user/1000
    /dev/sr0       iso9660  4.7G  4.7G     0 100% /media/master/Ubuntu 22.04.3 LTS amd64
    [Sat Nov 11 17:53:41 2023] EXT4-fs (sda3): mounted filesystem 91234521-1cf2-4a18-9713-9ac651eb2267 with ordered data mode. Quota mode: none.
    [Sat Nov 11 17:53:42 2023] EXT4-fs (sda3): re-mounted 91234521-1cf2-4a18-9713-9ac651eb2267. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET                                   SOURCE                         FSTYPE      OPTIONS
    /                                        /dev/sda3                      ext4        rw,relatime,errors=remount-ro
    |-/run/user/1000/doc                     portal                         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |-/snap/bare/5                           /dev/loop0                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core22/858                       /dev/loop1                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core20/1974                      /dev/loop2                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/firefox/2987                     /dev/loop3                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/gnome-42-2204/120                /dev/loop5                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/gnome-3-38-2004/143              /dev/loop4                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/curl/1754                        /dev/loop6                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/snapd-desktop-integration/83     /dev/loop7                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/var/snap/firefox/common/host-hunspell /dev/sda3[/usr/share/hunspell] ext4        ro,noexec,noatime,errors=remount-ro
    |-/snap/snapd/19457                      /dev/loop9                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/gtk-common-themes/1535           /dev/loop10                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/snap-store/959                   /dev/loop8                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/boot/efi                              /dev/sda2                      vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
    `-/media/master/Ubuntu 22.04.3 LTS amd64 /dev/sr0                       iso9660     ro,nosuid,nodev,relatime,nojoliet,check=s,map=n,blocksize=2048,uid=1000,gid=1000,dmode=500,fmode=400,iocharset=utf8
    /var:
    3.9G	/var/
    3.1G	/var/lib
    2.7G	/var/lib/snapd
    1.4G	/var/lib/snapd/snaps
    1.4G	/var/lib/snapd/seed/snaps
    Archived and active journals take up 32.0M in the file system.
    /opt/iobroker/backups:
    1.3M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    28M	/opt/iobroker/iobroker-data/
    15M	/opt/iobroker/iobroker-data/files
    13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    find: '/dev/serial/by-id/': No such file or directory
    6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    3.9M	/opt/iobroker/iobroker-data/objects.jsonl
    3.8M	/opt/iobroker/iobroker-data/objects.json.migrated
    3.8M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.18.2
    /usr/bin/node 		v18.18.2
    /usr/bin/npm 		9.8.1
    /usr/bin/npx 		9.8.1
    /usr/bin/corepack 	0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.9~dfsg-1ubuntu3.1 500
            500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
            500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.12
    admin: 		6.12.0
    javascript: 	"javascript" not found
    Adapters from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobrokermaster                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobrokermaster                           -  enabled
    + system.adapter.discovery.0              : discovery             : iobrokermaster                           -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Objects and States
    Objects: 	174
    States: 	127
    Hit:1 https://linux.teamviewer.com/deb stable InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Hit:5 http://security.ubuntu.com/ubuntu jammy-security InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1803       1/init
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        18173      366/systemd-resolve
    tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          46859      5027/teamviewerd
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       22788      510/iobroker.js-con
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       22796      510/iobroker.js-con
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          20818      507/cupsd
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1805       1/init
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          20817      507/cupsd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       48970      5514/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           114        19821      416/avahi-daemon: r
    udp        0      0 0.0.0.0:48998           0.0.0.0:*                           0          50397      5027/teamviewerd
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        18172      366/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1804       1/init
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          21184      581/cups-browsed
    udp        0      0 0.0.0.0:58293           0.0.0.0:*                           114        19823      416/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                114        19822      416/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          1806       1/init
    udp6       0      0 :::60348                :::*                                114        19824      416/avahi-daemon: r
    2023-11-11 18:09:57.828  - info: admin.0 (915) ==> Connected system.user.admin from ::ffff:192.168.20.224
    2023-11-11 18:21:53.042  - info: host.iobrokermaster "system.adapter.admin.0" disabled
    2023-11-11 18:21:53.043  - info: host.iobrokermaster stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-11-11 18:21:53.045  - info: admin.0 (915) Got terminate signal TERMINATE_YOURSELF
    2023-11-11 18:21:53.047  - info: admin.0 (915) terminating http server on port 8081
    2023-11-11 18:21:53.048  - info: admin.0 (915) terminating
    2023-11-11 18:21:53.048  - info: admin.0 (915) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-11-11 18:21:53.087  - info: host.iobrokermaster stopInstance system.adapter.admin.0 send kill signal
    2023-11-11 18:21:53.550  - info: admin.0 (915) terminating
    2023-11-11 18:21:53.569  - info: host.iobrokermaster instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-11 18:21:56.048  - info: host.iobrokermaster [WEBSERVER_UPGRADE] (admin) Server is running on http://localhost:8081
    2023-11-11 18:22:00.291  - info: host.iobrokermaster [WEBSERVER_UPGRADE] (admin) Successfully upgraded admin to version 6.12.0
    2023-11-11 18:22:01.393  - info: host.iobrokermaster [WEBSERVER_UPGRADE] (admin) Final information delivered
    2023-11-11 18:22:01.397  - info: host.iobrokermaster "system.adapter.admin.0" enabled
    2023-11-11 18:22:01.398  - info: host.iobrokermaster [WEBSERVER_UPGRADE] (admin) Successfully started adapter
    2023-11-11 18:22:01.461  - info: host.iobrokermaster instance system.adapter.admin.0 started with pid 5514
    2023-11-11 18:22:02.217  - info: admin.0 (5514) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
    2023-11-11 18:22:02.236  - info: admin.0 (5514) requesting all objects
    2023-11-11 18:22:02.401  - info: admin.0 (5514) received all objects
    2023-11-11 18:22:02.516  - info: admin.0 (5514) socket.io server listening on port 8081
    2023-11-11 18:22:02.517  - info: admin.0 (5514) http server listening on port 8081
    2023-11-11 18:22:02.517  - info: admin.0 (5514) Use link "http://127.0.0.1:8081" to configure.
    2023-11-11 18:22:04.227  - info: admin.0 (5514) ==> Connected system.user.admin from ::ffff:192.168.20.224
    2023-11-11 18:22:04.859  - info: admin.0 (5514) <== Disconnect system.user.admin from ::ffff:192.168.20.224 admin
    2023-11-11 18:22:10.688  - info: admin.0 (5514) ==> Connected system.user.admin from ::ffff:192.168.20.224
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobrokerclient
           Icon name: computer-desktop
             Chassis: desktop
    model name	: Intel(R) Core(TM) i3-4010U CPU @ 1.70GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : amd64
     18:28:55 up 21 min,  2 users,  load average: 0.34, 0.27, 0.29
    CPU threads: 4
                   Local time: Sat 2023-11-11 18:28:55 CET
               Universal time: Sat 2023-11-11 17:28:55 UTC
                     RTC time: Sat 2023-11-11 17:28:55
                  NTP service: active
              RTC in local TZ: no
    client
    /home/client
    client adm cdrom sudo dip plugdev lpadmin lxd sambashare iobroker
    X-Server: 	true
    Desktop: 	ubuntu-xorg
    Terminal: 	x11
    *** MEMORY ***
    Mem:            7.8G        1.0G        5.3G        212M        1.6G        6.4G
    Swap:           2.0G          0B        2.0G
    Total:          9.9G        1.0G        7.3G
             7829 M total memory
             1006 M used memory
              621 M active memory
             1453 M inactive memory
             5270 M free memory
               54 M buffer memory
             1498 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    *** FILESYSTEM ***
    tmpfs          tmpfs  783M  1.8M  782M   1% /run
    /dev/sda2      ext4    55G   14G   39G  26% /
    tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs  5.0M  4.0K  5.0M   1% /run/lock
    /dev/sda1      vfat   511M  6.1M  505M   2% /boot/efi
    tmpfs          tmpfs  783M  104K  783M   1% /run/user/1000
    [Sat Nov 11 18:07:13 2023] EXT4-fs (sda2): mounted filesystem 406be6a0-17ec-4dbb-b69a-8cd7f490e14f with ordered data mode. Quota mode: none.
    [Sat Nov 11 18:07:13 2023] EXT4-fs (sda2): re-mounted 406be6a0-17ec-4dbb-b69a-8cd7f490e14f. Quota mode: none.
    /                                        /dev/sda2                      ext4        rw,relatime,errors=remount-ro
    |-/snap/bare/5                           /dev/loop1                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core20/1974                      /dev/loop0                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core22/858                       /dev/loop2                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/curl/1754                        /dev/loop4                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/gnome-3-38-2004/143              /dev/loop5                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/gnome-42-2204/120                /dev/loop6                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/gtk-common-themes/1535           /dev/loop7                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/var/snap/firefox/common/host-hunspell /dev/sda2[/usr/share/hunspell] ext4        ro,noexec,noatime,errors=remount-ro
    |-/snap/snapd-desktop-integration/83     /dev/loop10                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    `-/boot/efi                              /dev/sda1                      vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
    /var:
    3.9G	/var/
    3.1G	/var/lib
    2.7G	/var/lib/snapd
    Archived and active journals take up 40.0M in the file system.
    4.0K	/opt/iobroker/backups/
    19M	/opt/iobroker/iobroker-data/
    1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    USB-Devices by-id:
    /usr/bin/npm 		9.8.1
    /usr/bin/npx 		9.8.1
    nodejs:
      Version table:
    Errors in npm tree:
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    admin: 		6.10.1
    Adapter State
    + instance is alive
    Adapter    "admin"        : 6.12.0   , installed 6.10.1 [Updatable]
    Objects and States
    Objects: 	174
    States: 	127
    Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 https://linux.teamviewer.com/deb stable InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:6 http://security.ubuntu.com/ubuntu jammy-security InRelease
    Pending Updates: 0
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        23098      468/systemd-resolve
    tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          29980      1565/teamviewerd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          24143      670/cupsd
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          16964      1/init
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          24142      670/cupsd
    tcp6       0      0 :::111                  :::*                    LISTEN      0          16966      1/init
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        23097      468/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          16965      1/init
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          30824      1544/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           114        27154      574/avahi-daemon: r
    udp        0      0 0.0.0.0:50463           0.0.0.0:*                           114        27156      574/avahi-daemon: r
    udp        0      0 0.0.0.0:39577           0.0.0.0:*                           0          40199      1565/teamviewerd
    udp6       0      0 :::111                  :::*                                0          16967      1/init
    udp6       0      0 :::45934                :::*                                114        27157      574/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                114        27155      574/avahi-daemon: r
    2023-11-11 18:06:54.687  - info: host.iobrokerclient instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2023-11-11 18:06:54.688  - info: host.iobrokerclient All instances are stopped.
    2023-11-11 18:06:54.899  - info: host.iobrokerclient terminated
    2023-11-11 18:07:19.924  - info: host.iobrokerclient iobroker.js-controller version 5.0.12 js-controller starting
    2023-11-11 18:07:19.928  - info: host.iobrokerclient Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-11-11 18:07:19.929  - info: host.iobrokerclient hostname: iobrokerclient, node: v18.18.2
    2023-11-11 18:07:19.930  - info: host.iobrokerclient ip addresses:
    2023-11-11 18:07:49.956  - error: host.iobrokerclient No connection to databases possible, restart
    2023-11-11 18:07:49.960  - info: host.iobrokerclient iobroker _restart
    2023-11-11 18:07:50.601  - info: host.iobrokerclient iobroker Starting node restart.js
    2023-11-11 18:07:50.607  - error: host.iobrokerclient [sendTo] Could not push message "{
      command: 'cmdStdout',
      message: { id: undefined, data: 'Starting node restart.js' },
    }" to "system.host.iobrokerclient": Cannot read properties of null (reading 'pushMessage')
    2023-11-11 18:07:55.054  - info: host.iobrokerclient iobroker.js-controller version 5.0.12 js-controller starting
    2023-11-11 18:07:55.058  - info: host.iobrokerclient Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-11-11 18:07:55.058  - info: host.iobrokerclient hostname: iobrokerclient, node: v18.18.2
    2023-11-11 18:07:55.059  - info: host.iobrokerclient ip addresses: 192.168.20.115 fe80::3a77:89f:66f8:985
    2023-11-11 18:07:55.204  - info: host.iobrokerclient connected to Objects and States
    2023-11-11 18:07:55.218  - info: host.iobrokerclient Node.js version has changed from unknown to 18.18.2
    2023-11-11 18:07:55.243  - info: host.iobrokerclient added notifications configuration of host
    2023-11-11 18:07:55.265  - info: host.iobrokerclient Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2023-11-11 18:07:55.546  - info: host.iobrokerclient 3 instances found
    2023-11-11 18:07:55.548  - warn: host.iobrokerclient does not start any instances on this host
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    @bluehannover sagte in Multihost - Slave tut nix...:
    teamviewerd
    ... wofür das !?
    • GlasfaserG Glasfaser
      teamviewerd
      ... wofür das !?
      @glasfaser sagte in Multihost - Slave tut nix...:
      ... wofür das !?
      Damit man auf den unnötigen Desktops auch was zu klicken hat...
      B 1 Antwort Letzte Antwort
        ... wofür das !?
        Bluehannover
        @thomas-braun das ist damit auch mal jemand von aussen helfen kann..
        aber ausser Ressourcen doch jetzt kein Problem, oder?
        • B Bluehannover
          Das 'von außen über eine GUI' ist genau das Problem.
          Auf Servern läuft KEINE GUI.
          Aus 1000 Gründen.
            Aus 1000 Gründen.
            Bluehannover
            schrieb am zuletzt editiert von Bluehannover
            @thomas-braun So ein Windowsserver hat auch ne GUI... aber wir sind ja im Einsteigerbereich, ich lerne also noch.
            Und die 1000 Gründe werden die Sicherheit sein, also müsste man auch klären wie sich der client jetzt ohne Passwort verbinden konnte 🤔
            • B Bluehannover
              Auch.
              Neben Ressourcen des GUI, der Stabilität des GUI, der höheren Komplexität des GUI usw...
              Die gleichen Gründe sprechen aber auch unter Windows gegen eine GUI.
              Dann kannste ja als erste Lektion lernen: Kein Desktop mit allem Zipp und Zapp auf einem Server.
