  3. Einsteigerfragen
  4. Installation
  5. Multihost - Slave tut nix...
26 Beiträge 4 Kommentatoren 2.7k Aufrufe 5 Beobachtet
  • B Bluehannover
    @glasfaser
    So, dann mal hier der Master:
    			v.2023-10-10
     Static hostname: iobrokermaster
           Icon name: computer-vm
             Chassis: vm
      Virtualization: kvm
    Operating System: Ubuntu 22.04.3 LTS
              Kernel: Linux 6.2.0-36-generic
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Installation: 		kvm
    Kernel: 		x86_64
    Userland: 		amd64
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    X-Server: 		false
    Boot Target: 		graphical.target
    Pending OS-Updates: 	0
    Pending iob updates: 	1
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
    			/usr/bin/node 		v18.18.2
    			/usr/bin/npm 		9.8.1
    			/usr/bin/npx 		9.8.1
    			/usr/bin/corepack 	0.19.0
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    MEMORY:
    Mem:            3.9G        1.0G        1.6G         34M        1.3G        2.6G
    Swap:           3.4G          0B        3.4G
    Total:          7.3G        1.0G        5.0G
    Active iob-Instances: 	4
    Active repo(s): stable
    ioBroker Core: 		js-controller 		5.0.12
    			admin 			6.10.1
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iobrokermaster                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    Objects: 		145
    States: 		103
    Size of iob-Database:
    3.9M	/opt/iobroker/iobroker-data/objects.jsonl
    3.8M	/opt/iobroker/iobroker-data/objects.json.migrated
    3.8M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    52K	/opt/iobroker/iobroker-data/states.jsonl
    16K	/opt/iobroker/iobroker-data/states.json.migrated
    16K	/opt/iobroker/iobroker-data/states.json.bak.migrated
    und hier der Client:
    			v.2023-10-10
     Static hostname: iobrokerclient
           Icon name: computer-desktop
             Chassis: desktop
    Installation: 		native
    Kernel: 		x86_64
    Userland: 		amd64
    User-ID: 		1000
    X-Server: 		true
    			/usr/bin/npm 		9.8.1
    			/usr/bin/npx 		9.8.1
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:            7.8G        977M        5.3G        195M        1.5G        6.4G
    Swap:           2.0G          0B        2.0G
    Total:          9.9G        977M        7.4G
    			admin 			6.10.1
    At least one iobroker host is running.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		173
    States: 		126
    220K	/opt/iobroker/iobroker-data/states.jsonl
    interessant dabei ist das der Client jetzt im Master zu sehen ist, ich habe alles nochmal neu aufgesetzt. im Client iobroker multihost connect bleibt aber wie vorher ohne weitere Meldung, der Promt wandert eine Zeil tiefer und blinkt dort nur noch vor sich hin, somit auch keine Möglichkeit den Master auszuwählen, geschweige denn ein Passwort einzugeben. Womit sich jetzt die Frage stellt wie er sich mit dem Master verbinden konnte (die Systempasswörter und für den Connect wären aber alle Identisch).
    das einzige was jetzt anders gemacht wurde - ich habe noch keine updates im iobroker gemacht...
    @bahnuhr lass es Bitte
    @bluehannover sagte in Multihost - Slave tut nix...:
    Der macht mit Multihost-Neueinrichtungen Probleme.
      GlasfaserG Offline
      GlasfaserG Offline
      deshalb mein Link schon dazu ... da ich nicht wußte was er hat :
      @glasfaser sagte in Multihost - Slave tut nix...:
      blinkt munter vor sich hin..
      da hier nichts von deiner Systemumgebung angegeben ist ... kann man nur raten !
      dieses war mal hier so :
      https://forum.iobroker.net/post/1055387
      https://forum.iobroker.net/topic/68802/gelöst-hilfe-bei-multihost
      • GlasfaserG Glasfaser
        SUMMARY
        bitte die Full Ausgabe !
        Bluehannover
        @glasfaser Sorry, dachte falsch verstanden:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Chassis: vm
          Virtualization: kvm
        model name	: QEMU Virtual CPU version 2.5+
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         18:25:40 up 32 min,  2 users,  load average: 0.46, 0.15, 0.09
        CPU threads: 2
        *** Time and Time Zones ***
                       Local time: Sat 2023-11-11 18:25:40 CET
                   Universal time: Sat 2023-11-11 17:25:40 UTC
                         RTC time: Sat 2023-11-11 17:25:40
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        master
        /home/master
        master adm cdrom sudo dip plugdev lpadmin lxd sambashare iobroker
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop: 	ubuntu
        Terminal: 	wayland
        *** MEMORY ***
        Mem:            3.9G        1.7G        270M         38M        1.9G        1.9G
        Swap:           3.4G        5.0M        3.4G
        Total:          7.3G        1.7G        3.7G
                 3907 M total memory
                 1729 M used memory
                  942 M active memory
                 2394 M inactive memory
                  270 M free memory
                   57 M buffer memory
                 1850 M swap cache
                 3429 M total swap
                    5 M used swap
                 3424 M free swap
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        Filesystem     Type     Size  Used Avail Use% Mounted on
        tmpfs          tmpfs    391M  1.6M  390M   1% /run
        /dev/sda3      ext4      31G   15G   15G  51% /
        tmpfs          tmpfs    2.0G     0  2.0G   0% /dev/shm
        tmpfs          tmpfs    5.0M     0  5.0M   0% /run/lock
        /dev/sda2      vfat     512M  6.1M  506M   2% /boot/efi
        tmpfs          tmpfs    391M  104K  391M   1% /run/user/1000
        /dev/sr0       iso9660  4.7G  4.7G     0 100% /media/master/Ubuntu 22.04.3 LTS amd64
        [Sat Nov 11 17:53:41 2023] EXT4-fs (sda3): mounted filesystem 91234521-1cf2-4a18-9713-9ac651eb2267 with ordered data mode. Quota mode: none.
        [Sat Nov 11 17:53:42 2023] EXT4-fs (sda3): re-mounted 91234521-1cf2-4a18-9713-9ac651eb2267. Quota mode: none.
        TARGET                                   SOURCE                         FSTYPE      OPTIONS
        /                                        /dev/sda3                      ext4        rw,relatime,errors=remount-ro
        |-/run/user/1000/doc                     portal                         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        |-/snap/bare/5                           /dev/loop0                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/core22/858                       /dev/loop1                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/core20/1974                      /dev/loop2                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/firefox/2987                     /dev/loop3                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gnome-42-2204/120                /dev/loop5                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gnome-3-38-2004/143              /dev/loop4                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/curl/1754                        /dev/loop6                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/snapd-desktop-integration/83     /dev/loop7                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/var/snap/firefox/common/host-hunspell /dev/sda3[/usr/share/hunspell] ext4        ro,noexec,noatime,errors=remount-ro
        |-/snap/snapd/19457                      /dev/loop9                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gtk-common-themes/1535           /dev/loop10                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/snap-store/959                   /dev/loop8                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/boot/efi                              /dev/sda2                      vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
        `-/media/master/Ubuntu 22.04.3 LTS amd64 /dev/sr0                       iso9660     ro,nosuid,nodev,relatime,nojoliet,check=s,map=n,blocksize=2048,uid=1000,gid=1000,dmode=500,fmode=400,iocharset=utf8
        /var:
        3.9G	/var/
        3.1G	/var/lib
        2.7G	/var/lib/snapd
        1.4G	/var/lib/snapd/snaps
        1.4G	/var/lib/snapd/seed/snaps
        Archived and active journals take up 32.0M in the file system.
        /opt/iobroker/backups:
        1.3M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        28M	/opt/iobroker/iobroker-data/
        15M	/opt/iobroker/iobroker-data/files
        13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
        find: '/dev/serial/by-id/': No such file or directory
        6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/npm 		9.8.1
        /usr/bin/npx 		9.8.1
        nodejs:
          Installed: 18.18.2-1nodesource1
          Candidate: 18.18.2-1nodesource1
          Version table:
         *** 18.18.2-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             12.22.9~dfsg-1ubuntu3.1 500
                500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	5.0.12
        admin: 		6.12.0
        javascript: 	"javascript" not found
        Adapters from github: 	0
        Adapter State
        + system.adapter.backitup.0               : backitup              : iobrokermaster                           -  enabled
        + system.adapter.discovery.0              : discovery             : iobrokermaster                           -  enabled
        + instance is alive
        ioBroker-Repositories
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Objects and States
        Objects: 	174
        States: 	127
        Hit:1 https://linux.teamviewer.com/deb stable InRelease
        Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
        Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
        Hit:5 http://security.ubuntu.com/ubuntu jammy-security InRelease
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1803       1/init
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        18173      366/systemd-resolve
        tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          46859      5027/teamviewerd
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       22788      510/iobroker.js-con
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       22796      510/iobroker.js-con
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          20818      507/cupsd
        tcp6       0      0 :::111                  :::*                    LISTEN      0          1805       1/init
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          20817      507/cupsd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       48970      5514/io.admin.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           114        19821      416/avahi-daemon: r
        udp        0      0 0.0.0.0:48998           0.0.0.0:*                           0          50397      5027/teamviewerd
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        18172      366/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1804       1/init
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          21184      581/cups-browsed
        udp        0      0 0.0.0.0:58293           0.0.0.0:*                           114        19823      416/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                114        19822      416/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          1806       1/init
        udp6       0      0 :::60348                :::*                                114        19824      416/avahi-daemon: r
        2023-11-11 18:09:57.828  - info: admin.0 (915) ==> Connected system.user.admin from ::ffff:192.168.20.224
        2023-11-11 18:21:53.042  - info: host.iobrokermaster "system.adapter.admin.0" disabled
        2023-11-11 18:21:53.043  - info: host.iobrokermaster stopInstance system.adapter.admin.0 (force=false, process=true)
        2023-11-11 18:21:53.045  - info: admin.0 (915) Got terminate signal TERMINATE_YOURSELF
        2023-11-11 18:21:53.047  - info: admin.0 (915) terminating http server on port 8081
        2023-11-11 18:21:53.048  - info: admin.0 (915) terminating
        2023-11-11 18:21:53.048  - info: admin.0 (915) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-11-11 18:21:53.087  - info: host.iobrokermaster stopInstance system.adapter.admin.0 send kill signal
        2023-11-11 18:21:53.550  - info: admin.0 (915) terminating
        2023-11-11 18:21:53.569  - info: host.iobrokermaster instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-11-11 18:21:56.048  - info: host.iobrokermaster [WEBSERVER_UPGRADE] (admin) Server is running on http://localhost:8081
        2023-11-11 18:22:00.291  - info: host.iobrokermaster [WEBSERVER_UPGRADE] (admin) Successfully upgraded admin to version 6.12.0
        2023-11-11 18:22:01.393  - info: host.iobrokermaster [WEBSERVER_UPGRADE] (admin) Final information delivered
        2023-11-11 18:22:01.397  - info: host.iobrokermaster "system.adapter.admin.0" enabled
        2023-11-11 18:22:01.398  - info: host.iobrokermaster [WEBSERVER_UPGRADE] (admin) Successfully started adapter
        2023-11-11 18:22:01.461  - info: host.iobrokermaster instance system.adapter.admin.0 started with pid 5514
        2023-11-11 18:22:02.217  - info: admin.0 (5514) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
        2023-11-11 18:22:02.236  - info: admin.0 (5514) requesting all objects
        2023-11-11 18:22:02.401  - info: admin.0 (5514) received all objects
        2023-11-11 18:22:02.516  - info: admin.0 (5514) socket.io server listening on port 8081
        2023-11-11 18:22:02.517  - info: admin.0 (5514) http server listening on port 8081
        2023-11-11 18:22:02.517  - info: admin.0 (5514) Use link "http://127.0.0.1:8081" to configure.
        2023-11-11 18:22:04.227  - info: admin.0 (5514) ==> Connected system.user.admin from ::ffff:192.168.20.224
        2023-11-11 18:22:04.859  - info: admin.0 (5514) <== Disconnect system.user.admin from ::ffff:192.168.20.224 admin
        2023-11-11 18:22:10.688  - info: admin.0 (5514) ==> Connected system.user.admin from ::ffff:192.168.20.224
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Chassis: desktop
        model name	: Intel(R) Core(TM) i3-4010U CPU @ 1.70GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : amd64
         18:28:55 up 21 min,  2 users,  load average: 0.34, 0.27, 0.29
        CPU threads: 4
                       Local time: Sat 2023-11-11 18:28:55 CET
                   Universal time: Sat 2023-11-11 17:28:55 UTC
                         RTC time: Sat 2023-11-11 17:28:55
                      NTP service: active
                  RTC in local TZ: no
        client
        /home/client
        client adm cdrom sudo dip plugdev lpadmin lxd sambashare iobroker
        X-Server: 	true
        Desktop: 	ubuntu-xorg
        Terminal: 	x11
        *** MEMORY ***
        Mem:            7.8G        1.0G        5.3G        212M        1.6G        6.4G
        Swap:           2.0G          0B        2.0G
        Total:          9.9G        1.0G        7.3G
                 7829 M total memory
                 1006 M used memory
                  621 M active memory
                 1453 M inactive memory
                 5270 M free memory
                   54 M buffer memory
                 1498 M swap cache
                 2047 M total swap
                    0 M used swap
                 2047 M free swap
        *** FILESYSTEM ***
        tmpfs          tmpfs  783M  1.8M  782M   1% /run
        /dev/sda2      ext4    55G   14G   39G  26% /
        tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs  5.0M  4.0K  5.0M   1% /run/lock
        /dev/sda1      vfat   511M  6.1M  505M   2% /boot/efi
        tmpfs          tmpfs  783M  104K  783M   1% /run/user/1000
        [Sat Nov 11 18:07:13 2023] EXT4-fs (sda2): mounted filesystem 406be6a0-17ec-4dbb-b69a-8cd7f490e14f with ordered data mode. Quota mode: none.
        [Sat Nov 11 18:07:13 2023] EXT4-fs (sda2): re-mounted 406be6a0-17ec-4dbb-b69a-8cd7f490e14f. Quota mode: none.
        /                                        /dev/sda2                      ext4        rw,relatime,errors=remount-ro
        |-/snap/bare/5                           /dev/loop1                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/core20/1974                      /dev/loop0                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/core22/858                       /dev/loop2                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/curl/1754                        /dev/loop4                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gnome-3-38-2004/143              /dev/loop5                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gnome-42-2204/120                /dev/loop6                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gtk-common-themes/1535           /dev/loop7                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/var/snap/firefox/common/host-hunspell /dev/sda2[/usr/share/hunspell] ext4        ro,noexec,noatime,errors=remount-ro
        |-/snap/snapd-desktop-integration/83     /dev/loop10                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        `-/boot/efi                              /dev/sda1                      vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
        /var:
        3.9G	/var/
        3.1G	/var/lib
        2.7G	/var/lib/snapd
        Archived and active journals take up 40.0M in the file system.
        4.0K	/opt/iobroker/backups/
        19M	/opt/iobroker/iobroker-data/
        1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
        652K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
        USB-Devices by-id:
        /usr/bin/npm 		9.8.1
        /usr/bin/npx 		9.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin: 		6.10.1
        Adapter State
        + instance is alive
        Adapter    "admin"        : 6.12.0   , installed 6.10.1 [Updatable]
        Objects and States
        Objects: 	174
        States: 	127
        Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
        Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:3 https://linux.teamviewer.com/deb stable InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:6 http://security.ubuntu.com/ubuntu jammy-security InRelease
        Pending Updates: 0
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        23098      468/systemd-resolve
        tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          29980      1565/teamviewerd
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          24143      670/cupsd
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          16964      1/init
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          24142      670/cupsd
        tcp6       0      0 :::111                  :::*                    LISTEN      0          16966      1/init
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        23097      468/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          16965      1/init
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          30824      1544/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           114        27154      574/avahi-daemon: r
        udp        0      0 0.0.0.0:50463           0.0.0.0:*                           114        27156      574/avahi-daemon: r
        udp        0      0 0.0.0.0:39577           0.0.0.0:*                           0          40199      1565/teamviewerd
        udp6       0      0 :::111                  :::*                                0          16967      1/init
        udp6       0      0 :::45934                :::*                                114        27157      574/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                114        27155      574/avahi-daemon: r
        2023-11-11 18:06:54.687  - info: host.iobrokerclient instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
        2023-11-11 18:06:54.688  - info: host.iobrokerclient All instances are stopped.
        2023-11-11 18:06:54.899  - info: host.iobrokerclient terminated
        2023-11-11 18:07:19.924  - info: host.iobrokerclient iobroker.js-controller version 5.0.12 js-controller starting
        2023-11-11 18:07:19.928  - info: host.iobrokerclient Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
        2023-11-11 18:07:19.929  - info: host.iobrokerclient hostname: iobrokerclient, node: v18.18.2
        2023-11-11 18:07:19.930  - info: host.iobrokerclient ip addresses:
        2023-11-11 18:07:49.956  - error: host.iobrokerclient No connection to databases possible, restart
        2023-11-11 18:07:49.960  - info: host.iobrokerclient iobroker _restart
        2023-11-11 18:07:50.601  - info: host.iobrokerclient iobroker Starting node restart.js
        2023-11-11 18:07:50.607  - error: host.iobrokerclient [sendTo] Could not push message "{
          command: 'cmdStdout',
          message: { id: undefined, data: 'Starting node restart.js' },
        }" to "system.host.iobrokerclient": Cannot read properties of null (reading 'pushMessage')
        2023-11-11 18:07:55.054  - info: host.iobrokerclient iobroker.js-controller version 5.0.12 js-controller starting
        2023-11-11 18:07:55.058  - info: host.iobrokerclient Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
        2023-11-11 18:07:55.058  - info: host.iobrokerclient hostname: iobrokerclient, node: v18.18.2
        2023-11-11 18:07:55.059  - info: host.iobrokerclient ip addresses: 192.168.20.115 fe80::3a77:89f:66f8:985
        2023-11-11 18:07:55.204  - info: host.iobrokerclient connected to Objects and States
        2023-11-11 18:07:55.218  - info: host.iobrokerclient Node.js version has changed from unknown to 18.18.2
        2023-11-11 18:07:55.243  - info: host.iobrokerclient added notifications configuration of host
        2023-11-11 18:07:55.265  - info: host.iobrokerclient Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
        2023-11-11 18:07:55.546  - info: host.iobrokerclient 3 instances found
        2023-11-11 18:07:55.548  - warn: host.iobrokerclient does not start any instances on this host
        GlasfaserG Thomas BraunT 3 Antworten Letzte Antwort
        • B Bluehannover
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Chassis: vm
            Virtualization: kvm
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 2
                        NTP service: active
                    RTC in local TZ: no
          master
          /home/master
          X-Server: 	false
          Desktop: 	ubuntu
          Terminal: 	wayland
          *** MEMORY ***
                   3907 M total memory
                   1729 M used memory
                    942 M active memory
                    270 M free memory
                     57 M buffer memory
                   1850 M swap cache
                   3429 M total swap
                      5 M used swap
                   3424 M free swap
          *** FILESYSTEM ***
          /var:
          3.9G	/var/
          3.1G	/var/lib
          2.7G	/var/lib/snapd
          USB-Devices by-id:
          /usr/bin/npm 		9.8.1
          /usr/bin/npx 		9.8.1
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin: 		6.12.0
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	174
          States: 	127
          Pending Updates: 0
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Chassis: desktop
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          client
          /home/client
          X-Server: 	true
          Terminal: 	x11
          *** MEMORY ***
          Swap:           2.0G          0B        2.0G
                   7829 M total memory
                   1006 M used memory
                    621 M active memory
                   5270 M free memory
                     54 M buffer memory
                   1498 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          *** FILESYSTEM ***
          /var:
          3.9G	/var/
          3.1G	/var/lib
          2.7G	/var/lib/snapd
          USB-Devices by-id:
          /usr/bin/npm 		9.8.1
          /usr/bin/npx 		9.8.1
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin: 		6.10.1
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	174
          States: 	127
          Pending Updates: 0
          GlasfaserG Offline
          GlasfaserG Offline
          @bluehannover
          die Lösung dazu , habe ich dir schon geschrieben !
          • B Bluehannover
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Chassis: vm
              Virtualization: kvm
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 2
                          NTP service: active
                      RTC in local TZ: no
            master
            /home/master
            X-Server: 	false
            Desktop: 	ubuntu
            Terminal: 	wayland
            *** MEMORY ***
                     3907 M total memory
                     1729 M used memory
                      942 M active memory
                      270 M free memory
                       57 M buffer memory
                     1850 M swap cache
                     3429 M total swap
                        5 M used swap
                     3424 M free swap
            *** FILESYSTEM ***
            /var:
            3.9G	/var/
            3.1G	/var/lib
            2.7G	/var/lib/snapd
            USB-Devices by-id:
            /usr/bin/npm 		9.8.1
            /usr/bin/npx 		9.8.1
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin: 		6.12.0
            Adapter State
            + instance is alive
            Objects and States
            Objects: 	174
            States: 	127
            Pending Updates: 0
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Chassis: desktop
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 4
                          NTP service: active
                      RTC in local TZ: no
            client
            /home/client
            X-Server: 	true
            Terminal: 	x11
            *** MEMORY ***
            Swap:           2.0G          0B        2.0G
                     7829 M total memory
                     1006 M used memory
                      621 M active memory
                     5270 M free memory
                       54 M buffer memory
                     1498 M swap cache
                     2047 M total swap
                        0 M used swap
                     2047 M free swap
            *** FILESYSTEM ***
            /var:
            3.9G	/var/
            3.1G	/var/lib
            2.7G	/var/lib/snapd
            USB-Devices by-id:
            /usr/bin/npm 		9.8.1
            /usr/bin/npx 		9.8.1
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin: 		6.10.1
            Adapter State
            + instance is alive
            Objects and States
            Objects: 	174
            States: 	127
            Pending Updates: 0
            Schalt die Desktops auf den beiden Kisten aus.
            • B Bluehannover
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Chassis: vm
                Virtualization: kvm
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
              CPU threads: 2
                            NTP service: active
                        RTC in local TZ: no
              master
              /home/master
              X-Server: 	false
              Desktop: 	ubuntu
              Terminal: 	wayland
              *** MEMORY ***
                       3907 M total memory
                       1729 M used memory
                        942 M active memory
                        270 M free memory
                         57 M buffer memory
                       1850 M swap cache
                       3429 M total swap
                          5 M used swap
                       3424 M free swap
              *** FILESYSTEM ***
              /var:
              3.9G	/var/
              3.1G	/var/lib
              2.7G	/var/lib/snapd
              USB-Devices by-id:
              /usr/bin/npm 		9.8.1
              /usr/bin/npx 		9.8.1
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 		6.12.0
              Adapter State
              + instance is alive
              Objects and States
              Objects: 	174
              States: 	127
              Pending Updates: 0
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Chassis: desktop
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
              CPU threads: 4
                            NTP service: active
                        RTC in local TZ: no
              client
              /home/client
              X-Server: 	true
              Terminal: 	x11
              *** MEMORY ***
              Swap:           2.0G          0B        2.0G
                       7829 M total memory
                       1006 M used memory
                        621 M active memory
                       5270 M free memory
                         54 M buffer memory
                       1498 M swap cache
                       2047 M total swap
                          0 M used swap
                       2047 M free swap
              *** FILESYSTEM ***
              /var:
              3.9G	/var/
              3.1G	/var/lib
              2.7G	/var/lib/snapd
              USB-Devices by-id:
              /usr/bin/npm 		9.8.1
              /usr/bin/npx 		9.8.1
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 		6.10.1
              Adapter State
              + instance is alive
              Objects and States
              Objects: 	174
              States: 	127
              Pending Updates: 0
              GlasfaserG Offline
              GlasfaserG Offline
              teamviewerd
              ... wofür das !?
                teamviewerd
                ... wofür das !?
                ... wofür das !?
                Damit man auf den unnötigen Desktops auch was zu klicken hat...
                  ... wofür das !?
                  Bluehannover
                  @thomas-braun das ist damit auch mal jemand von aussen helfen kann..
                  aber ausser Ressourcen doch jetzt kein Problem, oder?
                  • B Bluehannover
                    Das 'von außen über eine GUI' ist genau das Problem.
                    Auf Servern läuft KEINE GUI.
                    Aus 1000 Gründen.
                      Aus 1000 Gründen.
                      Bluehannover
                      schrieb am zuletzt editiert von Bluehannover
                      @thomas-braun So ein Windowsserver hat auch ne GUI... aber wir sind ja im Einsteigerbereich, ich lerne also noch.
                      Und die 1000 Gründe werden die Sicherheit sein, also müsste man auch klären wie sich der client jetzt ohne Passwort verbinden konnte 🤔
                      • B Bluehannover
                        Auch.
                        Neben Ressourcen des GUI, der Stabilität des GUI, der höheren Komplexität des GUI usw...
                        Die gleichen Gründe sprechen aber auch unter Windows gegen eine GUI.
                        Dann kannste ja als erste Lektion lernen: Kein Desktop mit allem Zipp und Zapp auf einem Server.
