  4. Nach update - Yeelight geht im ganzen Haus nicht mehr!
    5.1k
19 Beiträge 5 Kommentatoren 1.4k Aufrufe 4 Beobachtet
  • L Offline
    LaBamba
    schrieb am zuletzt editiert von LaBamba
    Hallo heute ein paar updates erneuert und plötzlich geht wieder einmal einiges nicht.
    Vorallem die Lichtsteuerung regt gerade richtig auf. Hier verwende ich im ganzen Haus Yeelights.
    host.raspberrypi
    	2023-10-25 21:48:23.205	error	instance system.adapter.yeelight-2.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.raspberrypi
    	2023-10-25 21:48:23.204	error	Caught by controller[1]: at TCP.<anonymous> (node:net:323:12)
    host.raspberrypi
    	2023-10-25 21:48:23.204	error	Caught by controller[1]: at Socket.emit (node:domain:489:12)
    host.raspberrypi
    	2023-10-25 21:48:23.204	error	Caught by controller[1]: at Socket.emit (node:events:526:35)
    host.raspberrypi
    	2023-10-25 21:48:23.204	error	Caught by controller[1]: at Object.onceWrapper (node:events:629:26)
    host.raspberrypi
    	2023-10-25 21:48:23.204	error	Caught by controller[1]: at Socket.onClose (node:net:912:10)
    host.raspberrypi
    	2023-10-25 21:48:23.204	error	Caught by controller[1]: at new NodeError (node:internal/errors:405:5)
    host.raspberrypi
    	2023-10-25 21:48:23.203	error	Caught by controller[1]: Error: Socket closed before the connection was established
    host.raspberrypi
    	2023-10-25 21:48:23.203	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    yeelight-2.1
    	2023-10-25 21:48:22.405	error	Exception-Code: ERR_SOCKET_CLOSED_BEFORE_CONNECTION: Socket closed before the connection was established
    yeelight-2.1
    	2023-10-25 21:48:22.403	error	Error: Socket closed before the connection was established at new NodeError (node:internal/errors:405:5) at Socket.onClose (node:net:912:10) at Object.onceWrapper (node:events:629:26) at Socket.emit (node:events:526:35) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:323:12)
    yeelight-2.1
    	2023-10-25 21:48:22.402	error	unhandled promise rejection: Socket closed before the connection was established
    yeelight-2.1
    	2023-10-25 21:48:22.401	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Weiß zufällig jemand an was das liegen könnte?
    Geupdatet habe ich die Adapter admin, history und zwei die ich nicht mehr weiss.
    Yeelight war aber nicht dabei. Gibt es irgendwo die Möglichkeit das nachzuschauen.
    @arteck
    @Feuersturm
    @Glasfaser
    @apollon77
    • L LaBamba
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      yeelight-2.1
      yeelight-2.1
      yeelight-2.1
      yeelight-2.1
      @arteck
      @Feuersturm
      @Glasfaser
      @apollon77
      @labamba
      Und wie sieht deine Installation im Gesamten aus?
      iob diag
      anschauen.
      Könnte aber das sein:
      https://github.com/iobroker-community-adapters/ioBroker.yeelight-2/issues/222
      L GlasfaserG 2 Antworten Letzte Antwort
        @labamba
        iob diag
        anschauen.
        LaBamba
        Verwende node.js18
        Thomas BraunT haselchenH 2 Antworten Letzte Antwort
        • L LaBamba
          Verwende node.js18
          @labamba
          iob diag
          sagt?
            @labamba
            iob diag
            anschauen.
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            @LaBamba
            sowas ähnliches war schonmal ... mit der gleichen Meldung
            #>Caught by controller ... at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:323:12)
            usw.
            aber da war mehr !
            https://forum.iobroker.net/topic/68891/iobroker-problem-js-controller-stürtzt-ab
            aber versuche erstmal
            iob fix
            • L LaBamba
              Verwende node.js18
              haselchenH Offline
              haselchenH Offline
              haselchen
              @labamba
              Habe auch den Adapter.
              Funktioniert mit Node 16 und jetzt mit Node 18.
              Anhand deines Logs kann ich leider nicht erkennen, welche Adapter Version Du hast.
              mcm1957M L 2 Antworten Letzte Antwort
              • haselchenH haselchen
                @labamba
                mcm1957M Offline
                mcm1957M Offline
                mcm1957
                @haselchen
                Das o.a. Issue beim Adapter bezieht sich lt. log auf 1.2.1 was auch die letzte Version in latest / stable ist.
                Achtung in Github wird 1.1.2 angezeigt - da wurde wohl nicht immer eine GH Version agelegt :-(.
                Aber gut zu wissen, dass der Adapter 'auch' funktioniert.
                Leider gibt es derzeit niemand der die Zeit und die Möglichkeit hat sich den Adapter mal anzushen. Sorry. Aber neue Mitstreiter sind immer gern gesehen.
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                  @labamba
                  LaBamba
                  @haselchen
                  Yeelight Version 1.8.24
                  Meine Vermutung ist es liegt am update vom Javascript Adapter auf 7.1.6.
                  Keine Änderung wenn ich zurück auf eine ältere Version gehe.
                  Thomas BraunT mcm1957M haselchenH 3 Antworten Letzte Antwort
                  • L LaBamba
                    @haselchen
                    @labamba
                    Nochmal...
                    iob diag
                    sagt?
                    • L LaBamba
                      @haselchen
                      mcm1957M Offline
                      mcm1957M Offline
                      mcm1957
                      @labamba said in Nach update - Yeelight geht im ganzen Haus nicht mehr!:
                      @haselchen
                      Welchen Adapter benutzt du ???
                      Auf npm gibts nur iobroker.yeelight-2 mit Version 1.2.1. Eine Version 1.8.24 gibts da und auf Github nicht.
                      Und dass javascript einen Adapter Abstürzen läßt kann ich mir kaum vorstellen.
                      • mcm1957M mcm1957
                        @haselchen
                        @mcm57 sagte in Nach update - Yeelight geht im ganzen Haus nicht mehr!:
                        Aber vom zigbee-Adapter. Der steht alphabetisch in der Nähe von yeelight. Vermutlich in der Zeile verrutscht. Aber mit Nacherzählungen kann man leider nicht viel anfangen.
                        • L LaBamba
                          @haselchen
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @labamba
                          Kann ich @mcm57 nur zustimmen.
                          Diese Version habe ich auch.
                          Der Script Adapter macht bei mir keine Probleme diesbezüglich.
                            @labamba
                            Nochmal...
                            iob diag
                            sagt?
                            LaBamba
                            Würde ich ja gerne machen.
                            Mir hat jemand bei der Neuinstallation den Rat gegeben das Desktop auszustellen. Jetzt kann ich aber nicht mehr per RemoteDesktopverbindung auf die Befehlszeile zugreifen.
                            Per Filezilla kann ich aber zugreifen. Jedoch kenne ich mich da nicht aus.
                            Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                            • L LaBamba
                              @labamba sagte in Nach update - Yeelight geht im ganzen Haus nicht mehr!:
                              Deswegen macht man sowas ja auch per SSH in einem Terminal. Da brauchts keinen Desktop, erst recht keinen Remote-Desktop.
                              • L LaBamba
                                mcm1957M Offline
                                mcm1957M Offline
                                mcm1957
                                @labamba
                                ssh zugriff sollte z.B. so gehen
                                Windows - Eingabeaufforderung öffnen
                                ssh <username>@<rechnername>
                                Also z.B.
                                ssh maxi@mypi
                                ggF Frage bei ssh key bestätigen und Passwort eintippen
                                Und ne dumme Frage: -
                                Wie hast du in letzter Zeit bzw. seit der Installation updates des Betriebssystem gemacht ohne einzuloggen ?
                                  @labamba
                                  Nochmal...
                                  iob diag
                                  sagt?
                                  LaBamba
                                  @haselchen
                                  @mcm57
                                  @Glasfaser
                                  Das Problem ist gelöst.
                                  Beim Yeelight Adapter müssen alle Lichtquellen aktiv sein. Also Strom haben!
                                  Wird dieser aus irgendwelchen Gründen neu gestartet und eine Lampe in der Adapter-Liste hat keinen Strom, zeigt er den Fehler an.
                                  Meine Tochter hat anscheinend eine Lampe über den Schalter stromlos gemacht.
                                  Danke an alle für die Unterstützung.
                                  P.S. Hatte damals Zugriff über Putty
                                  • L LaBamba
                                    @haselchen
                                    @mcm57
                                    @Glasfaser
                                    Und warum heute nicht mehr? puTTY ist ein SSH-fähiges Terminal-Programm.
                                    • L LaBamba
                                      @haselchen
                                      @mcm57
                                      @Glasfaser
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @labamba
                                      Und schon zur Adoption freigegeben...... 😝
                                      L 1 Antwort Letzte Antwort
                                        @labamba
                                        LaBamba
                                        @haselchen
                                        Haha, deswegen doch nicht ;-)
