  4. Ältere ioBroker Instanz updaten?
    5.1k
31 Beiträge 5 Kommentatoren 3.4k Aufrufe 3 Beobachtet
    @tolkin
    iob diag
    sagt?
    Im simpelsten Fall hilft
    iob start admin
    TolkinT Offline
    TolkinT Offline
    Tolkin
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.1.0-rpi4-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     21:37:29 up 15 min,  2 users,  load average: 0.04, 0.22, 0.19
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2023-10-24 21:37:30 CEST
               Universal time: Tue 2023-10-24 19:37:30 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            8.2G        268M        7.5G        1.2M        565M        7.9G
    Swap:           104M          0B        104M
    Total:          8.3G        268M        7.6G
             7811 M total memory
              256 M used memory
              220 M active memory
              343 M inactive memory
             7138 M free memory
               30 M buffer memory
              509 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     782M  1.1M  781M   1% /run
    /dev/mmcblk0p2 ext4       59G  2.7G   53G   5% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
    tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
    [Tue Oct 24 21:22:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:49:6E:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c509a9ba-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Oct 24 21:22:19 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Oct 24 21:22:21 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    492M    /var/
    201M    /var/cache
    195M    /var/cache/apt
    159M    /var/lib
    130M    /var/lib/apt/lists
    Archived and active journals take up 32.0M in the file system.
    /opt/iobroker/backups:
    5.0M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    19M     /opt/iobroker/iobroker-data/
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    3.8M    /opt/iobroker/iobroker-data/objects.jsonl
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    No connection to states 127.0.0.1:6379[redis]
    Core adapters versions
    js-controller:  5.0.12
    admin:          "admin" not found
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    ioBroker-Repositories
    Installed ioBroker-Instances
    Objects and States
    Objects:        1
    States:         1
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       29953      4445/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3990       681/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          3992       681/sshd: /usr/sbin
    udp        0      0 0.0.0.0:50025           0.0.0.0:*                           104        13702      531/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13700      531/avahi-daemon: r
    udp6       0      0 :::47411                :::*                                104        13703      531/avahi-daemon: r
    udp6       0      0 fe80::573c:9b67:23c:546 :::*                                0          16494      601/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        13701      531/avahi-daemon: r
    2023-10-24 21:36:54.637  - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d
    2023-10-24 21:37:24.657  - error: host.raspberrypi No connection to databases possible, restart
    2023-10-24 21:37:24.673  - info: host.raspberrypi iobroker _restart
    2023-10-24 21:37:30.540  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
    2023-10-24 21:37:30.546  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-10-24 21:37:30.548  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.2
    2023-10-24 21:37:30.550  - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d
    2023-10-24 21:38:00.571  - error: host.raspberrypi No connection to databases possible, restart
    2023-10-24 21:38:00.578  - info: host.raspberrypi iobroker _restart
    2023-10-24 21:38:06.332  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
    2023-10-24 21:38:06.337  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-10-24 21:38:06.338  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.2
    2023-10-24 21:38:06.340  - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d
    2023-10-24 21:38:36.359  - error: host.raspberrypi No connection to databases possible, restart
    2023-10-24 21:38:36.366  - info: host.raspberrypi iobroker _restart
    2023-10-24 21:38:42.122  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
    2023-10-24 21:38:42.128  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-10-24 21:38:42.129  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.2
    2023-10-24 21:38:42.130  - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d
    2023-10-24 21:39:12.149  - error: host.raspberrypi No connection to databases possible, restart
    2023-10-24 21:39:12.166  - info: host.raspberrypi iobroker _restart
    2023-10-24 21:39:18.223  - info: host.raspberrypi iobroker.js-controller version 5.0.12 js-controller starting
    2023-10-24 21:39:18.230  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2023-10-24 21:39:18.232  - info: host.raspberrypi hostname: raspberrypi, node: v18.18.2
    2023-10-24 21:39:18.234  - info: host.raspberrypi ip addresses: 192.168.178.150 2a00:6020:a18c:bb00:d4a2:dc11:99f6:b2cb fe80::573c:9b67:23cc:366d
    • TolkinT Tolkin
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           104M          0B        104M
               7811 M total memory
                256 M used memory
                220 M active memory
               7138 M free memory
                 30 M buffer memory
                509 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      492M    /var/
      201M    /var/cache
      195M    /var/cache/apt
      159M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Adapter State
      Objects and States
      Objects:        1
      States:         1
      Pending Updates: 0
      @tolkin sagte in Ältere ioBroker Instanz updaten?:
      War das ein redis-Setup? Dann muss redis noch nachinstalliert werden.
      sudo apt install redis
      TolkinT 1 Antwort Letzte Antwort
        TolkinT Offline
        TolkinT Offline
        Tolkin
        Habe ich nachinstalliert, aber die Weboberfläsche funktioniert nicht. Irgendwas ist noch faul.
        • TolkinT Tolkin
          @tolkin
          iobroker (oder den Server) neugestartet?
          systemctl status redis
          sagt?
            @tolkin
            sagt?
            TolkinT Offline
            TolkinT Offline
            Tolkin
            @thomas-braun sagte in Ältere ioBroker Instanz updaten?:
            pi@raspberrypi:~ $ systemctl status redis
            ● redis-server.service - Advanced key-value store
            Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; preset:>
            Active: active (running) since Tue 2023-10-24 21:45:50 CEST; 5min ago
            Docs: http://redis.io/documentation,
            man:redis-server(1)
            Main PID: 672 (redis-server)
            Status: "Ready to accept connections"
            Tasks: 5 (limit: 8741)
            CPU: 1.485s
            CGroup: /system.slice/redis-server.service
            └─672 "/usr/bin/redis-server 127.0.0.1:6379"
            Oct 24 21:45:50 raspberrypi systemd[1]: Starting redis-server.service - Advance>
            Oct 24 21:45:50 raspberrypi systemd[1]: Started redis-server.service - Advanced>
            lines 1-14/14 (END)...skipping...
            Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; preset: enabled)
            man:redis-server(1)
            CPU: 1.485s
            Oct 24 21:45:50 raspberrypi systemd[1]: Starting redis-server.service - Advanced key-value store...
            Oct 24 21:45:50 raspberrypi systemd[1]: Started redis-server.service - Advanced key-value store.
            • TolkinT Tolkin
              man:redis-server(1)
              CPU: 1.485s
              man:redis-server(1)
              CPU: 1.485s
              @tolkin
              iob restart
              Und dann
              iob list adapters
                @tolkin
                iob restart
                Und dann
                iob list adapters
                TolkinT Offline
                TolkinT Offline
                Tolkin
                iob list adapters
                pi@raspberrypi:~ $ iob list adapters
                system.adapter.admin : admin - v6.10.1
                system.adapter.backitup : backitup - v2.8.1
                system.adapter.discovery : discovery - v3.1.0
                • TolkinT Tolkin
                  iob list adapters
                  @tolkin
                  iob list instances
                  Besser statt Spoiler die CodeTags verwenden. Oder beides...
                    @tolkin
                    iob list instances
                    TolkinT Offline
                    TolkinT Offline
                    Tolkin
                    iob list instances
                    pi@raspberrypi:~ $ iob list instances
                    + system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                    + instance is alive
                    pi@raspberrypi:~ $
                    • TolkinT Tolkin
                      iob list instances
                      + instance is alive
                      pi@raspberrypi:~ $
                      @tolkin
                      disabled...
                      Hatte ich lange nicht mehr. Weiß gerade nicht wie man den wieder 'enabled'.
                      iob restart admin
                      vielleicht.
                        @tolkin
                        disabled...
                        iob restart admin
                        vielleicht.
                        TolkinT Offline
                        TolkinT Offline
                        Tolkin
                        iob restart admin
                        Das hat geholfen, vielen Dank ;)
