  3. Entwicklung
  4. Neuer Adapter:::milight-smart-light
    5.3k
422 Beiträge 46 Kommentatoren 153.7k Aufrufe 17 Beobachtet
    Ritter
    #401
    Hab jetzt npm erhöht. Beim installieren von milight kommen Fehler auch wenn ich z.B. 0.1.8 nehme:
    $ ./iobroker url "https://github.com/Steiger04/ioBroker.milight-smart-light/tarball/master" milight-smart-light
    install https://github.com/Steiger04/ioBroker.milight-smart-light/tarball/master
    npm install https://github.com/Steiger04/ioBroker.milight-smart-light/tarball/master --production --save --prefix "C:/Program Files/ioBroker" (System call)
    npm
    WARN
    rollback
    Rolling back iobroker.milight-smart-light@0.2.4 failed (this is probably harmless): EBUSY: resource busy or locked, rmdir 'C:\Program Files\ioBroker\node_modules\iobroker.milight-smart-light\mslfe-ibr'
    npm
    ERR!
    path
    npm ERR! code EPERM
    npm
    ERR! errno -4048
    npm
    ERR!
    syscall rename
    npm
    ERR!
    Error: EPERM: operation not permitted, rename 'C:\Program Files\ioBroker\node_modules\iobroker.milight-smart-light' -> 'C:\Program Files\ioBroker\node_modules.iobroker.milight-smart-light.DELETE'
    npm
    ERR! { [Error: EPERM: operation not permitted, rename 'C:\Program Files\ioBroker\node_modules\iobroker.milight-smart-light' -> 'C:\Program Files\ioBroker\node_modules.iobroker.milight-smart-light.DELETE']
    npm
    ERR! cause:
    npm
    ERR! { Error: EPERM: operation not permitted, rename 'C:\Program Files\ioBroker\node_modules\iobroker.milight-smart-light' -> 'C:\Program Files\ioBroker\node_modules.iobroker.milight-smart-light.DELETE'
    npm
    ERR! errno: -4048,
    npm
    ERR! code: 'EPERM',
    npm
    ERR! syscall: 'rename',
    npm
    ERR! path:
    npm
    ERR! 'C:\Program Files\ioBroker\node_modules\iobroker.milight-smart-light',
    npm
    ERR! dest:
    npm
    ERR! 'C:\Program Files\ioBroker\node_modules\.iobroker.milight-smart-light.DELETE' },
    npm
    ERR! stack:
    npm
    ERR! 'Error: EPERM: operation not permitted, rename 'C:\Program Files\ioBroker\node_modules\iobroker.milight-smart-light' -> 'C:\Program Files\ioBroker\node_modules\.iobroker.milight-smart-light.DELETE'',
    npm
    ERR! errno: -4048,
    npm
    ERR! code: 'EPERM',
    npm
    npm
    ERR! path:npm ERR! 'C:\Program Files\ioBroker\node_modules\iobroker.milight-smart-light',
    npm ERR! dest:
    npm ERR! 'C:\Program Files\ioBroker\node_modules\.iobroker.milight-smart-light.DELETE',
    npm ERR! parent: 'iobroker.core' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It's possible that the file was already in use (by a text editor or antivirus),
    npm ERR! or that you lack permissions to access it.
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm
    ERR! A complete log of this run can be found in:npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-03-06T16_31_58_773Z-debug.log
    ERROR: host.NUC Cannot install https://github.com/Steiger04/ioBroker.milight-smart-light/tarball/master: 4294963248
    J 1 Antwort Letzte Antwort
    • R Ritter
      npm
      WARN
      rollback
      npm
      ERR!
      path
      npm ERR! code EPERM
      npm
      ERR! errno -4048
      npm
      ERR!
      syscall rename
      npm
      ERR!
      npm
      npm
      ERR! cause:
      npm
      npm
      ERR! errno: -4048,
      npm
      ERR! code: 'EPERM',
      npm
      npm
      ERR! path:
      npm
      npm
      ERR! dest:
      npm
      npm
      ERR! stack:
      npm
      npm
      ERR! errno: -4048,
      npm
      ERR! code: 'EPERM',
      npm
      npm
      npm ERR! dest:
      npm ERR!
      npm ERR!
      npm
      Jan1
      #402
      @Ritter
      hast auch ein NPM reload gemacht?
        Ritter
        #403
        Danke für deine Hilfe,
        hatte ich nicht gemacht, aber jetzt. NPM reload kennt er nicht, er schlägt dann repo vor. Hier kommen viele errors.
          Ritter
          #404
          Hab jetzt mal sämtliche Versionen von milight Adapter probiert zu installieren, mit der Version 0.1.9 funktioniert er jetzt wieder.
          • tripperT Offline
            tripperT Offline
            tripper
            #405
            Habt ihr auch das Problem das sich der Adapter über den backitup Adapter nicht wiederherstellen lässt? Bekomme immer "File index_m.html not found", auch nach längere Wartezeit.
            Das laden der Konfigurationsdatei über die Instanz Einstellungen geht bei mir nicht immer rund.
            Wäre praktisch wenn das reibungslos funktionieren würde.
            Ich habe nun doch schon einige male alles wieder neu einstellen müssen und kenne die Einstellungen, die Scripts funktionieren deshalb auch noch alle, wenn in Zukunft noch mehr als 4 Zonen dazu kommen (ich möchte bald den esp8266_milight_hub zum laufen bringen, hab da noch Probleme mit dem flashen) wird es dann aber eher mühsam
            • carsten04C Online
              carsten04C Online
              carsten04
              #406
              Die index_m.html ist genau da wo sie sein sollte ☺, von daher scheint das Problem hier noch irgendwo anders bei Dir zu liegen. Bei der Konfigurationsdatei gab es noch Probleme, die in v0.2.3 behoben wurden. Aktuell ist v0.2.5. Falls bei Dir noch eine ältere Version läuft bitte upgraden.
                anglemandw
                #407
                Hallo an alle,
                großartige Arbeit und vielen Dank an die Entwickler.
                Ich habe folgendes Problem mit milight-smart-light in Verbindung mit Alexa.
                Kurze Vorgeschichte
                Ich habe mein Wohnzimmer in vier (vier Zonen) Bereiche geteilt um sie per Milight
                unterschiedlich anzusteuern.
                1 Zone eine RGB CCT Stripe 10m
                2 Zone Stehlampe mit MiLight e27 RGB CCT Birne
                3 Zone 6xGU10 MiLight RGBCCT
                4 Zone 7xGU10 MiLight RGBCCT
                Soweit so gut. Einbindung im Cloud Adapter hat funktioniert. In der Alexa APP auch
                alles drin und die Sprachsteuerung:
                Helligkeit, Farbe, Ein, Aus sowie Gruppensteuerung
                funktionieren.
                Das eigentliche `Problem besteht nur bei den GU10 Spots.
                Wenn ich z.B. sage Alexa "Zone4" aus schalten sich häufig ein bis zwei Spots nicht mit aus.
                Gleiches bein Farbwechsel oder Helligkeits Ändereungen.
                Habt ihr da ein Tip für mich, welche Einstellung ich da Optimieren kann ?
                Grüße an alle
                carsten04C 1 Antwort Letzte Antwort
                • A anglemandw
                  Hallo an alle,
                  Kurze Vorgeschichte
                  funktionieren.
                  Grüße an alle
                  carsten04C Online
                  carsten04C Online
                  carsten04
                  schrieb am zuletzt editiert von carsten04
                  #408
                  @anglemandw setze mal im Controller Tab die Befehlswiederholungen auf 2.
                    anglemandw
                    #409
                    @carsten04
                    ich Rindvieh... Warum hab ich das nicht gesehen.
                    Klappt Super jetzt.
                    Vielen Vielen Dank an dich.
                      Alex1984
                      #410
                      Moin, kann ich mit dem Adapter auch Geräte welche als App die Milight Cloud brauchen ansteuern? Konkret geht es um den Milight YL5 - ist ein 5in1 Wifi RBG Controller welcher direkt, ohne eine Bridge ins WLAN eingebunden und auch per Alexa gesteuert werden kann...
                      • A Alex1984
                        Jan1
                        #411
                        @Alex1984
                        Ich vermute mal nicht, da im Adapter die Bridge angegeben werden muss und ohne müsste man das Device direkt angeben.
                        Probiere es einfach aus, oder warte was Carsten dazu sagt.
                        • carsten04C Online
                          carsten04C Online
                          carsten04
                          #412
                          Tja, gute Frage. Ich vermute mal nein, aber ganz ausschließen möchte ich es nicht. Hintergrund: mit dem YL5 können wohl die üblichen Fernbedienungen und Wandschalter von Milight verwendet werden, von daher scheint sich die Funkkomponente zumindest nicht geändert zu haben. Es käme jetzt auf einen Versuch an, also YL5 ins heimische WLAN bringen, IP-Adresse und Port in den Adapter eintragen, die angelernte Zone in den Adapter eintragen, schauen was passiert und dann hiert berichten ☺ . Mehr kann ich dazu auch nicht sagen, da ich keinen YL5 besitze.
                            Alex1984
                            #413
                            Werde ich heute Abend mal machen, hab inzwischen 3 von den Dingern zuhause liegen
                              ReverZ
                              #414
                              Was haben denn die Tests mit den YL5 ergeben? Lassen die sich irgendwie entweder per Funk oder WLAN ohne die Milight Cloud App ansteuern?
                              • J Offline
                                jodie77
                                #415
                                Hallo ,
                                jemand bei meinem Problem helfen. Mein Adapter läuft und ist verbunden mein Gateway ist die v2.
                                Über die App Schnittstelle lassen sich die LEDs problemlos ansteuern und geben auch Rückmeldung über Status true/false etc.
                                Mache ich das selbe mit der Handyapp oder der Fernbedienung ändert sich zwar die LED wie sie soll, aber im Adapter ändern sich die Werte nicht. Woran kann das liegen? Vielen Dank schonmal im vorraus für eure Unterstützung.
                                Lg
                                • C Offline
                                  cactus-online
                                  #416
                                  Mi-Light kennt keinen Status. Daher spiegeln die Angaben im ioBroker nicht den realen Status wieder.
                                  • J jodie77
                                    Hallo ,
                                    Lg
                                    carsten04C Online
                                    carsten04C Online
                                    carsten04
                                    #417
                                    @jodie77 Das Milight-System ist nicht Rückkanal fähig, d.h. Änderungen der Einstellungen die Du außerhalb des ioBrokers durchführst (z.B. via Fernbedienung oder original Milight-App bekommt der Adapter nicht mit). Deshalb habe ich auch die "App" geschrieben, damit man die Möglichkeit hat via Smartphone oder Tablet die Milights zu schalten und ioBroker es trotzdem "merkt" (dann wird z.B. auch eine vis-Darstellung oder irgendeine andere auf den ID's basierende Darstellung korrekt aktualisiert).
                                    • J Offline
                                      jodie77
                                      #418
                                      Hallo Carsten,
                                      super :) Danke für die Info und klasse Arbeit die du da abgeliefert hast... Der Adapter läuft perfekt!
                                      • J Offline
                                        JesusC
                                        #419
                                        An dieser Stelle eine Frage von mir. Ich habe den Adapter in Version 0.2.7 installiert (restliches System: JS Controller 1.5.14, Node.js: v10.16.3, NPM: 6.9.0, Cloud-Adapter 2.6.2). Adapter selbst läuft auch, Zonen wurden angelegt und Räume/Funktionen wurden zugewiesen. Zone lässt sich ansprechen, bis dahin also alles gut. Es wird jedoch kein Smartdevice im Cloud-Adapter angelegt. Hab ich einfach einen Zwischenschritt überlesen? Wie kann ich mich da am schlausten auf die Fehlersuche begeben?
                                        Grüße
                                        jC
                                        • J JesusC
                                          Grüße
                                          jC
                                          carsten04C Online
                                          carsten04C Online
                                          carsten04
                                          #420
                                          @JesusC Du musst im cloud-Adapter unter Smart Aufzählungen die verwendeten Räume und Funktionen aktivieren.
