  4. MQTT ack=false forcieren?
    5.1k
17 Beiträge 5 Kommentatoren 1.9k Aufrufe 5 Beobachtet
  • H Offline
    Highpressure
    Hi zusammen
    Ich habe aktuell den MQTT adapter in version 4.1.1 auf meiner QNAP basierenden ioBroker instanz laufen.
    Der Adapter verbindet sich als Client/Subscriber via IP zu meinem SolarAssistant MQTT Server um die Wechselrichter und Batteriewerte zu subscriben
    das Funktioniert soweit auch:
    mqtt-packet:writeToStream generate called +7ms
    mqtt-packet:writeToStream generate: packet.cmd: publish +0ms
    mqtt-packet:writeToStream publish: packet: { cmd: 'publish', topic: 'PVGrid/battery_1/state_of_charge/state', payload: '46', qos: 0, retain: false, messageId: 0, dup: false } +0ms
    mqtt-packet:writeToStream writeVarByteInt: writing to stream: <Buffer 2a> +0ms
    mqtt-packet:writeToStream writeNumberCached: number: 38 +1ms
    mqtt-packet:writeToStream writeNumberCached: <Buffer 00 26> +0ms
    mqtt-packet:writeToStream publish: payload: '46' +0ms
    2023-10-11 12:20:38.128 - debug: mqtt.0 (7442) stateChange mqtt.0.PVGrid.inverter_2.ac_output_voltage.state: {"val":229,"ack":true,"ts":1697019638104,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697019638104}
    2023-10-11 12:20:38.129 - debug: mqtt.0 (7442) stateChange mqtt.0.PVGrid.inverter_2.load_power.state: {"val":1396,"ack":true,"ts":1697019638104,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697019638104}
    2023-10-11 12:20:38.129 - debug: mqtt.0 (7442) stateChange mqtt.0.PVGrid.battery_1.power.state: {"val":1078,"ack":true,"ts":1697019638104,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697019638104}
    2023-10-11 12:20:38.130 - debug: mqtt.0 (7442) stateChange mqtt.0.PVGrid.battery_1.state_of_charge.state: {"val":46,"ack":true,"ts":1697019638104,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697019494681}
    2023-10-11 12:20:38.131 - debug: mqtt.0 (7442) stateChange mqtt.0.PVGrid.battery_1.voltage.state: {"val":53.9,"ack":true,"ts":1697019638104,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697019638104}
    2023-10-11 12:20:38.132 - debug: mqtt.0 (7442) stateChange mqtt.0.PVGrid.total.battery_power.state: {"val":1078,"ack":true,"ts":1697019638112,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697019638112}
    2023-10-11 12:20:38.132 - debug: mqtt.0 (7442) stateChange mqtt.0.PVGrid.total.load_percentage.state: {"val":26,"ack":true,"ts":1697019638112,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697019604919}
    Mein Problem ist allerdings das ack:true welches ich abstellen muss, da mein Go-E Adapter damit nicht umgehen kann.
    Die MQTT Einstellungen habe ich soweit alle standard gelassen.
    Sprich "Nur bei Änderungen publizieren" und "Eigene States beim Verbinden publizieren" ist gewählt.
    Wie bekomme ich es hin das ack:false ist?
    Auf der SolarAssistant Seite gibt es nichts einzustellen, was den wert ändert.
    Vielen lieben Dank!
    arteckA haus-automatisierungH 2 Antworten Letzte Antwort
    • H Highpressure
      Hi zusammen
      Vielen lieben Dank!
      arteckA Offline
      arteckA Offline
      arteck
      @highpressure sagte in MQTT ack=false forcieren?:
      verstehe ich nicht ??
      H 1 Antwort Letzte Antwort
      • H Highpressure
        Hi zusammen
        Vielen lieben Dank!
        haus-automatisierungH Offline
        Das wird ja auch nicht von der anderen Seite per MQTT mitgesendet, sondern so wird der State vom MQTT-Adapter geschrieben. Und da der Wert von extern so reinkam, ist er logischerweise auch bestätigt.
        Was genau ist denn die Problemstellung?
        • arteckA arteck
          Highpressure
          ich muss ack=false - warum auch immer - dem go-e bereitstellen, da der - warum auch immer - nicht damit umgehen kann.
          Ich hatte eigentlich nicht vor den erst in history oder sonst wo nochmals unnötig zu schreiben.
          Gibt es da keinen anderen Weg?
          • H Highpressure
            @highpressure Wie hast Du denn MQTT und den anderen Adapter miteinander verknüpft?
              Highpressure
              via einstellungen des go-e adapter
              haus-automatisierungH mcm1957M 2 Antworten Letzte Antwort
              • H Highpressure
                schrieb am zuletzt editiert von haus-automatisierung
                Und wenn Du only Ack anhakst? Dann sollte doch genau das gewünschte Verhalten erreicht werden (oder ich verstehe die Option in den Einstellungen falsch).
                Ist auch hier erklärt: https://github.com/MK-2001/ioBroker.go-e/issues/168#issuecomment-1639802038
                Normalerweise sollten von einem System immer nur bestätigte Werte geliefert werden. Unbestätigte werden zu steuern verwendet und dann vom Zielgerät nachträglich bestätigt.
                Je nachdem welchen Adapter du verwendest, kommen ggf. auch unbestätigte werte aus dem Adapter zurück, dann muss der Haken bei OnlyAck raus.
                • H Highpressure
                  mcm1957M Offline
                  mcm1957M Offline
                  mcm1957
                  @highpressure
                  Adapter setzen ihre AUSGANGS-State, d.h. jene States die einen Wert VOM Gerät liefern IMMER mit ack=true. Alles andere wäre falsch.
                  Schau mal in die go-e Dokumentation, dort gibts ein Beispiel für Fronius
                  https://github.com/MK-2001/ioBroker.go-e/blob/main/docs/Readme.md#foreign-objects
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                    Highpressure
                    schrieb am zuletzt editiert von Highpressure
                    @haus-automatisierung
                    hab ich schon alles durch :(
                    Die Beschreibung im screenshot sagt auch: "This Adapter is currently consuming only ack = false states."
                    Wenn ich onlyAck wähle habe ich im log einen error:
                    wähle ich gar nichts von beiden - verhalten wie vorher
                    ich hab eben ins github repo geschaut und die main.js geöffnet:
                    EDIT sorry, screenshot ist ein paar zeilen zu hoch, weiter unte ist quasi derselbe text nochmals für die ack=true in Zeile 284
                    https://github.com/MK-2001/ioBroker.go-e/blob/main/main.js![11-10-2023_14-04-22.png](/assets/uploads/files/1697025881093-11-10-2023_14-04-22.png)
                    scheinbar wird nur die house consumption geprüft, wie ich das sehe, oder?
                    mcm1957M haus-automatisierungH 2 Antworten Letzte Antwort
                    • H Highpressure
                      mcm1957M Offline
                      mcm1957M Offline
                      mcm1957
                      @highpressure said in MQTT ack=false forcieren?:
                      Dann poste das Problem entweder im go-e Wartungstopic (so es das gibt) und / oder mach ein Issue beim Adapter auf.
                      Wie oben geschrieben, States die der Adapter xyz mit Werten aus dem Gerät befüllt werden IMMER ack=true haben.
                      Nur States die DU als Input in den Adapter schreibts müssen ack=false haben. Das kann dann aber nur States des GO-E betreffen, die DU (z.b. via script) beschreibts.
                      • mcm1957M mcm1957
                        Highpressure
                        @mcm57
                        Vielen Dank, dann werde ich das im GitHub so tun :)
                        DANKE EUCH FÜR DIE HILFE!
                        PS: habe ChatGPT4 den link zur main.js gegeben und um erklärung gebeten weshalb das so ist:
                        In the code, checking for ack = false is crucial as it helps ensure that only state changes initiated by external inputs are processed further in the onStateChange method. When ack is false, it indicates that the state change is new or unacknowledged, prompting action to handle this change. If ack were true, it would signify an acknowledged or system-generated state change, which doesn't require further action in this context​1.
                        mcm1957M M 2 Antworten Letzte Antwort
                        • H Highpressure
                          @mcm57
                          mcm1957M Offline
                          mcm1957M Offline
                          mcm1957
                          @highpressure
                          Möglicherweise hat der Adapzter den (in meinen Augen falschen Ansatz) dass hier ein vom User beschreibarer State in der Config eingetragen wird, z.B. 0_userdate.xxxxx. Wenn du diesen eigenen State per Skript beschreibts kann da natürlich ack=false stehen.
                          Der Ansatz ist aber m.E. falsch, da für das Bearbeiten des States als Input bei einem Adapter gilt:
                          • Input State === eigener State der Instanz -> ack=false
                          • Input State === foreign State einer fremden Instanz -> ack=true
                          Es mag Ausnahmen geben - hier seh ich aber keine.
                          • H Highpressure
                            Gerade nochmal den Code genauer angeschaut. Wenn state.ack = true, dann geht es ja hier weiter:
                            https://github.com/MK-2001/ioBroker.go-e/blob/fe2afea205c73c870473201012e9755ba9fc23a6/main.js#L285-L296
                            Und dann wird geprüft, ob onlyAck auch auf true steht. Sollte also funktionieren.
                            Nein, werden alle geprüft. Siehe 3x case da drüber. Code passt aus meiner Sicht.
                            Teil doch am besten nochmal ein Log, wenn Du überall onlyAck angehakt hast.
                            @mcm57 sagte in MQTT ack=false forcieren?:
                            Der Adapter bietet doch in den Instanzeinstellungen die Option, ob man jeweils ack: true oder ack: false verarbeiten möchte. Mehr Optionen braucht man ja nicht. Damit ist alles abgedeckt. Auch dieser MQTT-Fall hier.
                              mcm1957M Offline
                              mcm1957M Offline
                              mcm1957
                              @haus-automatisierung said in MQTT ack=false forcieren?:
                              Wenn er das tut ist das voll in Ordnung.
                              Ich hatte nur - ohne den Code zu analysieren - nach dem hier geschriebenen einen anderen Einsruck.
                              • H Highpressure
                                @mcm57
                                mk2001
                                schrieb am zuletzt editiert von mk2001
                                @highpressure
                                Die gezeigt Fehlermeldung erscheint, wenn eines der auszulesenden Objekte keinen Wert, bzw. Keinen numerischen Wert beinhaltet.
                                Bitte stelle sicher, dass alle Objekte eingetragen sind. Und in deren Values auch reale Werte eingetragen sind. Welche Werte bei der Berechnung berücksichtigt werden ist in der Formel bei den Einstellungen ersichtlich.
                                M.E. Hat die Fehlermeldung nichts mit ack zu tun.
                                • M mk2001
                                  @highpressure
                                  Highpressure
                                  @mk2001
                                  go-e.0
                                  12309 2023-10-11 14:03:26.539 silly States user redis pmessage io.mqtt.0.PVGrid.total.pv_power.state/io.mqtt.0.PVGrid.total.pv_power.state:{"val":5288,"ack":true,"ts":1697025806536,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697025806536}
                                  go-e.0
                                  12309 2023-10-11 14:03:26.537 silly States user redis pmessage io.mqtt.0.PVGrid.total.load_power.state/io.mqtt.0.PVGrid.total.load_power.state:{"val":5770,"ack":true,"ts":1697025806536,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697025806536}
                                  go-e.0
                                  12309 2023-10-11 14:03:26.529 silly States user redis pmessage io.mqtt.0.PVGrid.total.battery_power.state/io.mqtt.0.PVGrid.total.battery_power.state:{"val":-208,"ack":true,"ts":1697025806528,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1697025806528}
                                  Das sind auch die Foreign Objects aus dem Setup, die liest er ja scheinbar auch aus und wie im silly log zu lesen sind sie nicht 0.
                                  • H Highpressure
                                    @mk2001
                                    go-e.0
                                    go-e.0
                                    go-e.0
                                    @highpressure Du hast onlyAck ja immernoch nicht angehakt :)
