  4. Oilfox adapter aktualisiert nicht mehr *HILFE*
    6.4k
26 Beiträge 5 Kommentatoren 3.3k Aufrufe 5 Beobachtet
    driftkingisback
    schrieb am zuletzt editiert von driftkingisback
    Hallo, was mache ich falsch das dieser Adapter nicht mehr aktausliert.
    Diese Meldung bekomme ich:
    host.buanet-iobroker1
    2023-10-06 10:40:04.045	warn	instance system.adapter.oilfox.0 already running with pid 8264
    2023-10-06 10:30:04.056	warn	instance system.adapter.oilfox.0 already running with pid 8264
    2023-10-06 10:20:04.045	warn	instance system.adapter.oilfox.0 already running with pid 8264
    2023-10-06 10:10:04.041	warn	instance system.adapter.oilfox.0 already running with pid 8264
    2023-10-06 10:00:04.062	warn	instance system.adapter.oilfox.0 already running with pid 8264
    2023-10-06 09:50:04.041	warn	instance system.adapter.oilfox.0 already running with pid 8264
    2023-10-06 09:40:04.043	warn	instance system.adapter.oilfox.0 already running with pid 8264
    2023-10-06 09:30:04.064	warn	instance system.adapter.oilfox.0 already running with pid 8264
    2023-10-06 09:20:04.041	warn	instance system.adapter.oilfox.0 already running with pid 8264
    2023-10-06 09:10:04.042	warn	instance system.adapter.oilfox.0 already running with pid 8264
    2023-10-06 09:00:04.059	warn	instance system.adapter.oilfox.0 already running with pid 8264
    2023-10-06 08:50:04.041	warn	instance system.adapter.oilfox.0 already running with pid 8264
    2023-10-06 08:40:04.044	warn	instance system.adapter.oilfox.0 already running with pid 8264
    2023-10-06 08:30:04.056	warn	instance system.adapter.oilfox.0 already running with pid 8264
    Das ist mein Stand:
    Plattform: docker
    Betriebssystem: linux
    Architektur: x64
    CPUs: 4
    Geschwindigkeit: 2001 MHz
    Modell: Intel(R) Celeron(R) J4125 CPU @ 2.00GHz
    RAM: 3.6 GB
    System-Betriebszeit: 178 T. 20:56:26
    Node.js: v18.16.1
    time: 1696579879997
    timeOffset: -120
    Adapter-Anzahl: 504
    NPM: 9.5.1
    Datenträgergröße: 7149.5 GB
    Freier Festplattenspeicher: 5366.7 GB
    Betriebszeit: 86 T. 10:37:06
    Aktive Instanzen: 13
    Pfad: /opt/iobroker/
    • D driftkingisback
      Das ist mein Stand:
      Plattform: docker
      Architektur: x64
      CPUs: 4
      RAM: 3.6 GB
      Node.js: v18.16.1
      time: 1696579879997
      timeOffset: -120
      Adapter-Anzahl: 504
      NPM: 9.5.1
      @driftkingisback
      Starte den Docker mal durch.
        @driftkingisback
        driftkingisback
        @thomas-braun hab ich gemacht als neustart, keine abhilfe...woran kann es noch liegen? Gibt es welche die das gleiche Problem haben?
        • D driftkingisback
          @driftkingisback
          iob diag
          in der Langfassung sagt?
            @driftkingisback
            iob diag
            driftkingisback
            @thomas-braun was genau meinst du?
            • D driftkingisback
              @driftkingisback
              Du möchstest bitte
              iob diag
              in dein bevorzugtes Terminal hacken und die dann ausgespuckte Langfassung der Diagnose hier bekannt machen.
                @driftkingisback
                Du möchstest bitte
                iob diag
                mcm1957M Online
                mcm1957M Online
                mcm1957
                Dies ist ein Problem des Adapters:
                https://github.com/iobroker-community-adapters/ioBroker.oilfox/issues/122
                Ich hab zwar schon eine Vermutung wie das passiert ('Exception während der http Kommunication die nicht richtig abgefangen wird') weiß aber leider noch nicht wann ich dazu komme eine Testversion zu machen.
                Bis dahin bleibt nix anderes übrig, als den hängenden Prozess abzuschießen. @thomas-braun kann sicher sagen wie das am sichersten im ioBroker Umfeld geht.
                DANKE und SORRY
                P.S: Oilfox ist nicht von mir und ich habe auch kein passended Gerät / keine Testmöglichkeit. SOllte es daher Freiwillige geben, die den Adapter warten können vermittle ich gerne.
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                • mcm1957M mcm1957
                  DANKE und SORRY
                  @mcm57 @driftkingisback
                  sudo -u iobroker kill `pgrep oilfox`
                    driftkingisback
                    @thomas-braun also kann ich garnichts machen , dachte der fehler liegt bei mir
                    • D driftkingisback
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      @driftkingisback
                      Kannst bei dir nicht wirklcihw as tun. Außer du hast eine besonders instabile Internetanbindung die das Problem ev. verschärft.
                      Bitte schau aber einmal in dein Log ob da irgendeine (Fehler-)Meldung vom oilfox VOR den already running drinnen steht und gib hier oder noch besser im Issue ein Feedback dazu.
                      FriedhofsblondF 1 Antwort Letzte Antwort
                      • mcm1957M mcm1957
                        @driftkingisback
                        FriedhofsblondF Offline
                        Friedhofsblond
                        @mcm57
                        Moin,
                        ich habe auch irgendein Problem mit dem Oilfox.
                        Der Fox scannt jeden Tag um 11:55 den Tankstand und läd den in die Cloud hoch.
                        Ab 12:00 stehen dann die Werte aktuell in der App zur Ansicht.
                        Habe also die Abfrage auf täglich 12:00 gestellt - was auch getan wird.
                        Aber die Abfrage wird dann trotzdem jede Minute neu gemacht. Das wird wohl in der "Fox-Cloud" als Angriff gewertet und man wird temporär gesperrt.
                        Ich bin letztens schon rausgeflogen und mußte mein Passwort neu setzen und ein paar Stunden warten.
                        So denke ich jedenfalls.
                        Der Abfrageprozess wird nicht gestoppt.
                        Was kann man tun?
                        • FriedhofsblondF Friedhofsblond
                          @mcm57
                          Moin,
                          Was kann man tun?
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          @friedhofsblond
                          Bitte zeig mal, welche Config du eingestellt hast (auf Uhr in den Instanzen stellen):
                          Bzw die Zeitplungsansicht:
                          -> Bleistift
                          Beispiel ist von anderem Adapter - aber bei Oilfox sollte es prinzipiell genauso aussehen,
                          • mcm1957M mcm1957
                            @friedhofsblond
                            -> Bleistift
                            Friedhofsblond
                            schrieb am zuletzt editiert von Friedhofsblond
                            @mcm57
                            so habe ich es:
                            Abfrage ist 12:00 gestartet und hab ich nach 5min manuell gestoppt.
                            2023-10-08 12:00:00.086 - info: host.ioserver instance system.adapter.oilfox.0 started with pid 1735
                            2023-10-08 12:00:01.272 - info: oilfox.0 (1735) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v18.17.1, js-controller: 5.0.12
                            2023-10-08 12:00:26.977 - info: oilfox.0 (1735) Terminated (NO_ERROR): Without reason
                            2023-10-08 12:00:27.594 - info: host.ioserver instance system.adapter.oilfox.0 terminated with code 0 (NO_ERROR)
                            2023-10-08 12:01:00.054 - info: host.ioserver instance system.adapter.oilfox.0 started with pid 1750
                            2023-10-08 12:01:01.154 - info: oilfox.0 (1750) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v18.17.1, js-controller: 5.0.12
                            2023-10-08 12:01:10.868 - info: oilfox.0 (1750) Terminated (NO_ERROR): Without reason
                            2023-10-08 12:01:11.413 - info: host.ioserver instance system.adapter.oilfox.0 terminated with code 0 (NO_ERROR)
                            2023-10-08 12:02:00.052 - info: host.ioserver instance system.adapter.oilfox.0 started with pid 1766
                            2023-10-08 12:02:01.309 - info: oilfox.0 (1766) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v18.17.1, js-controller: 5.0.12
                            2023-10-08 12:02:03.933 - info: oilfox.0 (1766) Terminated (NO_ERROR): Without reason
                            2023-10-08 12:02:04.476 - info: host.ioserver instance system.adapter.oilfox.0 terminated with code 0 (NO_ERROR)
                            2023-10-08 12:03:00.061 - info: host.ioserver instance system.adapter.oilfox.0 started with pid 1784
                            2023-10-08 12:03:01.269 - info: oilfox.0 (1784) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v18.17.1, js-controller: 5.0.12
                            2023-10-08 12:03:08.493 - info: oilfox.0 (1784) Terminated (NO_ERROR): Without reason
                            2023-10-08 12:03:09.034 - info: host.ioserver instance system.adapter.oilfox.0 terminated with code 0 (NO_ERROR)
                            2023-10-08 12:04:00.056 - info: host.ioserver instance system.adapter.oilfox.0 started with pid 1799
                            2023-10-08 12:04:01.307 - info: oilfox.0 (1799) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v18.17.1, js-controller: 5.0.12
                            2023-10-08 12:04:04.091 - info: oilfox.0 (1799) Terminated (NO_ERROR): Without reason
                            2023-10-08 12:04:04.628 - info: host.ioserver instance system.adapter.oilfox.0 terminated with code 0 (NO_ERROR)
                            2023-10-08 12:05:00.057 - info: host.ioserver instance system.adapter.oilfox.0 started with pid 1814
                            2023-10-08 12:05:01.239 - info: oilfox.0 (1814) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v18.17.1, js-controller: 5.0.12
                            2023-10-08 12:05:10.269 - info: oilfox.0 (1814) Terminated (NO_ERROR): Without reason
                            2023-10-08 12:05:10.810 - info: host.ioserver instance system.adapter.oilfox.0 terminated with code 0 (NO_ERROR)
                            2023-10-08 12:06:00.053 - info: host.ioserver instance system.adapter.oilfox.0 started with pid 1829
                            2023-10-08 12:06:01.315 - info: oilfox.0 (1829) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v18.17.1, js-controller: 5.0.12
                            2023-10-08 12:06:04.837 - info: oilfox.0 (1829) Terminated (NO_ERROR): Without reason
                            2023-10-08 12:06:05.376 - info: host.ioserver instance system.adapter.oilfox.0 terminated with code 0 (NO_ERROR)
                            2023-10-08 12:06:05.407 - info: host.ioserver "system.adapter.oilfox.0" disabled
                            2023-10-08 12:06:05.408 - info: host.ioserver stopInstance system.adapter.oilfox.0 (force=false, process=false)
                            2023-10-08 12:06:05.408 - info: host.ioserver stopInstance canceled schedule system.adapter.oilfox.0
                            2023-10-08 12:18:55.593 - info: admin.0 (1000) <== Disconnect system.user.admin from ::ffff:192.168.115.175 admin
                            2023-10-08 12:18:55.928 - info: opendtu.0 (1111) Connect to OpenDTU over websocket connection.
                            2023-10-08 12:19:20.605 - info: opendtu.0 (1111) Connect to OpenDTU over websocket connection.
                            2023-10-08 12:19:32.395 - info: opendtu.0 (1111) Connect to OpenDTU over websocket connection.
                            2023-10-08 13:18:07.739 - info: admin.0 (1000) ==> Connected system.user.admin from ::ffff:192.168.115.175
                            2023-10-08 13:18:07.798 - info: admin.0 (1000) <== Disconnect system.user.admin from ::ffff:192.168.115.175 admin
                            2023-10-08 13:36:04.183 - info: opendtu.0 (1111) Connect to OpenDTU over websocket connection.
                            2023-10-08 13:36:18.301 - info: opendtu.0 (1111) Connect to OpenDTU over websocket connection.
                            2023-10-08 14:13:31.248 - info: admin.0 (1000) ==> Connected system.user.admin from ::ffff:192.168.115.175
                            2023-10-08 14:14:54.176 - info: admin.0 (1000) <== Disconnect system.user.admin from ::ffff:192.168.115.175 admin
                            2023-10-08 14:58:54.606 - info: admin.0 (1000) ==> Connected system.user.admin from ::ffff:192.168.115.175
                            2023-10-08 14:59:57.295 - info: host.ioserver "system.adapter.oilfox.0" enabled
                            2023-10-08 14:59:57.297 - info: host.ioserver stopInstance system.adapter.oilfox.0 (force=false, process=false)
                            2023-10-08 15:00:00.399 - info: host.ioserver instance scheduled system.adapter.oilfox.0 * 12 * * *
                              @mcm57
                              so habe ich es:
                              Friedhofsblond
                              @friedhofsblond
                              Ah, hab schon gesehen:
                              ... aber wie stelle ich 12:00 Uhr ein?
                              Da ich den IOBroker 1x in der nacht reboote würde ja auch nicht alle 24H passen ??
                                @friedhofsblond
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                @friedhofsblond
                                0 12 * * * *
                                Das da könnte dir helfen
                                https://crontab.guru/
                                Übrigengds - stell besser '3 12 * * *' (12:03 oder irgendwas zwischen 12:00 und 12:15 ein wenn du damit leben kannst. Wenn zig ioBroker installationen alle pünktlich um 12:00 (wqeil das halt so eine schöne Zahl ist :-) die Webseite aufrufen, ist Oilfox ev. "genervt" sprich überlastet.
                                Das gilt übrigends für ALLE scheduled Adapter mit Cloud Zugriff !
                                • mcm1957M mcm1957
                                  @friedhofsblond
                                  0 12 * * * *
                                  Friedhofsblond
                                  @mcm57
                                  Ah super, vielen Dank - ja immer dieses Crontabzeugs ..... :D 👌
                                  So passt es:
                                  Sorry, da ist ein Stern zu Viel - ist doch kein Cognac 🙄 (Klugscheissermodus OFF)
                                    @mcm57
                                    So passt es:
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    @friedhofsblond
                                    Sorry - sternchenzählen ist nicht meine Stärke :-)
                                    Hauptsache der Adapter läuft jetzt wieder.
                                    Das weiter oben gemeldeten Problem des Hängenbleibens ist in Evidenz wobei ich nach wie vor um die Info von Betroffenen bitte ob es VOR dem Hängenbelleiben irgendeien Fehlermeldung / Warning des Oilfuches im Log gegeben hat.
                                    • mcm1957M mcm1957
                                      @friedhofsblond
                                      driftkingisback
                                      @mcm57 ich habe jetzt ein Update des Oilfox adapter gemacht und die gleiche Uhrzeit wie bei dir eingestellt...läuft der Adapter bei dir jetzt?
                                      Ich muss jetzt erstmal bis morgen um 12.05 warten :)
                                      • D driftkingisback
                                        mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        @driftkingisback
                                        Nehme an die Frage geht an @Friedhofsblond
                                        Ich (mcm1957) habe keine Oilfox Installation. Ich versuche nur den Adapter soweit das ohne HW geht zu fixen bzw. zu releasen :-)
                                        • mcm1957M mcm1957
                                          @driftkingisback
                                          driftkingisback
                                          @mcm57 said in Oilfox adapter aktualisiert nicht mehr *HILFE*:
                                          @driftkingisback
                                          @Friedhofsblond geht bei dir der Adapter?
                                          FriedhofsblondF 2 Antworten Letzte Antwort
