  4. Rasperry 5 im anrollen
raspberryraspberry 5raspy
55 Beiträge 16 Kommentatoren 10.4k Aufrufe 11 Beobachtet
    @bibo-13
    iob stop
    iob fix
    iob nodejs-update
    Wenn dann ein aktuelles nodejs installiert wurde
    iob diag
    Bibo*13
    #41
    @thomas-braun Das ist das Summary; sieht irgendwie nicht gesund aus.
                            v.2023-10-10
       Static hostname: iobrokermaster
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Installation:           native
    Kernel:                 armv7l
    Userland:               armhf
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    node:internal/modules/cjs/loader:1080
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        at Module._load (node:internal/modules/cjs/loader:922:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12)
        at node:internal/main/run_main_module:23:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v18.18.2
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                            /usr/bin/node           v18.18.2
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            /usr/bin/corepack       0.19.0
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:            7.9G         86M        6.7G        0.0K        1.1G        7.5G
    Swap:            99M          0B         99M
    Total:          8.0G         86M        6.8G
      throw err;
      requireStack: []
    Node.js v18.18.2
    Active iob-Instances:   0
      throw err;
      requireStack: []
    Node.js v18.18.2
      throw err;
      requireStack: []
    Node.js v18.18.2
    ioBroker Core:          js-controller
      throw err;
      requireStack: []
    Node.js v18.18.2
                            admin
      throw err;
      requireStack: []
    Node.js v18.18.2
    ioBroker Status:
      throw err;
      requireStack: []
    Node.js v18.18.2
    Objects:                0
    States:                 0
    Size of iob-Database:
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/objects.json.migrated
    19M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    12K     /opt/iobroker/iobroker-data/objects.json.old
    0       /opt/iobroker/iobroker-data/objects.json.broken
    8.0K    /opt/iobroker/iobroker-data/states.json.old
    8.0K    /opt/iobroker/iobroker-data/states.json.bak
    • WinniW Offline
      WinniW Offline
      Winni
      #42
      Ich konnte leider noch keinen Raspberry pi 5 ergattern, bleibt im Moment nur das lesen von Testberichten. Hier ein Test bezüglich der Tauglichkeit als Alltagsrechner von Heise.de (externer Link)
      Es gibt nicht Gutes. Außer man tut es. Erich Kästner
      • CluniC Offline
        CluniC Offline
        Cluni
        schrieb am zuletzt editiert von Cluni
        #43
        @homoran said in Rasperry 5 im anrollen:
        ja, und die RTC ist wohl ein Steckmodul
        aber ich hab noch nichts genaueres gefunden
        Wo ist das Problem? Ich betreibe ein kleines RTC-Modul seit Ewigkeiten mit einem RPi 3, da wir den Raspberry in Tests unserer Geräte als CAN-Logger in Umgebungen einsetzen, wo es weder WLAN noch LAN gibt. Kostet pro Modul auch nur ein paar Euronen. z.B.: https://www.amazon.de/AZDelivery-DS3231-Batterie-Inklusive-Arduino/dp/B077XN4LL4?th=1
        Und wenn es eh nur ein optionales Steckmodul sein wird, dann kann man ja auch weiterhin auf dieses Modul zurückgreifen...
        Hier ein Link, wie man es ins System einbindet: https://www.raspberry-pi-geek.de/ausgaben/rpg/2015/03/echtzeituhr-modul-ds3231-sorgt-fuer-genaue-zeitangaben/
        EDIT: Weil es mich interessiert hat, habe ich nochmal nachgesehen. Und der Pi 5 hat anscheinend doch eine fest verbaute RTC: https://www.raspberrypi.com/documentation/computers/raspberry-pi-5.html#real-time-clock-rtc
        EDIT2: Oh Asche über mein Haupt - das hatte @paul53 schon geschrieben. 🙈
        • WinniW Offline
          WinniW Offline
          Winni
          schrieb am zuletzt editiert von Winni
          #44
          Falls noch jemand auf der Suche ist, bei Reichelt (externer Link) gibt es aktuell eine begrenzte Stückzahl. Hab mal zugeschlagen, schau mer mal ob auch was kommt 😉
          • WinniW Offline
            WinniW Offline
            Winni
            #45
            So, jetzt ist der Raspi5-8gb angekommen. Das Betriebssystem und iobroker waren schnell installiert.Backitup Sicherung eingespielt. Hat alles prima funktioniert. Auch der Zigbee Stick nur umgesteckt. Ich lass ihn jetzt noch nicht "produktiv" laufen, weil ich erst noch ein paar Sachen ausprobieren will. Ich habe auch das orginal 27w Netzteil. Als "Gehäuse" verwende ich mein vorhandene GeeekPi Raspberry Pi 4 Cluster Gehäuse. Das passt wunderbar. Da sind jetzt 2 pi4 und der neue pi5 drin. Der Stromverbrauch scheint laut der avm dect200 Dosen ziemlich gleich zu sein. Und der kleine Lüfter vom GeeekPi hat auch keine Probleme die Wärme wegzubringen, beim Restore waren es mal knapp 50 Grad, jetzt gerade unter 40.
            • WinniW Winni
              HomoranH Offline
              HomoranH Offline
              #46
              @winni sagte in Rasperry 5 im anrollen:
              hab mich gerade auch nicht mehr bremsen können und sowas
              bestellt.
              Kenn ich noch nicht sah aber edel und funktionell aus
              https://www.welectron.com/Raspberry-Pi-5-8-GB-Flirc-Kit
              WinniW D 2 Antworten Letzte Antwort
                bestellt.
                WinniW Offline
                WinniW Offline
                Winni
                #47
                @homoran sehr schön, richtig schick 👍
                  bestellt.
                  darkiop
                  #48
                  @homoran sagte in Rasperry 5 im anrollen:
                  Ging mir auch so. Über die Feiertage dann mal Testen ;)
                  • WinniW Offline
                    WinniW Offline
                    Winni
                    #49
                    Bei Barrybase ist im Moment das Raspberry Pi 5, 8GB RAM, Light Starter Kit (externer Link) für 120,90 € lieferbar.
                    • D darkiop
                      darkiop
                      #50
                      @darkiop sagte in Rasperry 5 im anrollen:
                      @Homoran Habe den ersten Test mit dem RPI5 + Flirc Kit hinter mir.
                      Nach guten 30min Stress Test pendelt sich die Temp bei 80°C ein. Das Gehäuse hat so um die 50-55°C.
                      Könnte etwas kühler sein - aber im Normal Betrieb wird diese Last auch selten erreicht.
                      • D darkiop
                        HomoranH Offline
                        HomoranH Offline
                        #51
                        @darkiop So!
                        bin endlich dazu gekommen meinen FLIRC Kit in Betrieb zu nehmen.
                        mit dem Raspi Imager die Karte beschrieben (64Bit lite) rein gesteckt und vom PC versucht zu administrieren.
                        Hab nen Riesen Schreck bekommen, es klemmte.
                        Am Pi mit Tastatur und Monitor lief alles Spitze.
                        Durch Zufall sah ich dass die LED vom NIC regelmäßig aus und wieder angingen.
                        Musste ja sein, Netzwerkkarte / Treiber defekt, und das über Weihnachten 😢
                        Nach Wechsel des Netzwerkkabels und des Ports am Switch lief es aber wieder!
                        Weihnachten ist gerettet 🎄
                        Noch schnell die .m2 ins externe Gehäuse gebastelt und angeklemmt.
                        Jetzt sitze ich seit heute nachmittag, lese mich durch manpages und ubuntu help, und schaffe es nicht diese Platte einzubinden.
                        aber der Pi5 schnurrt vor sich hin, das Alugehäuse ist gut handwarm und die CPU Temperatur liegt bei 41-45°C.
                        Der Stromverbrauch liegt bei ca. 7 Watt im idle bei einer jungfräulichen ioBroker Installation und dem Gebastel mit parted.
                        ohne externe SSD etwa bei 6W.
                        WinniW 1 Antwort Letzte Antwort
                          @darkiop So!
                          WinniW Offline
                          WinniW Offline
                          Winni
                          #52
                          @homoran viel Spaß mit dem 5er. Der Stromverbrauch wundert mich aber ein wenig. Bei mir läuft er mit einer 2tb Ssd, dem SONOFF Zigbee 3.0 USB Dongle Plus und iobroker mit immerhin 45 Prozesse sowie pihole, zwischen 5 und knapp 6 W, sagt zumindest die dect 200 Dose. Mit was hast du gemessen?
                          • WinniW Winni
                            HomoranH Offline
                            HomoranH Offline
                            #53
                            mit einer Homematic Dose die an meinem Basteltisch sowieso läuft.
                            Das ist der grobe Mehrverbrauch zum sonstigen Verbrauch.
                            5-6W könnte auch sein, aber es wurden ja 10W und mehr in den Raum geworfen.
                            Da liegt es aber deutlich drunter.
                            Hab jetzt erstmal den neuen NUC mit 12W in die SBC Vitrine gestellt 😁
                            EDIT:
                            ich kann jetzt die ca. 5W incl SSD bestätigen.
                            Da die HM Dose kleine Schwankungen nicht immer meldet habe ich jetzt einen weiteren Verbraucher mit und ohne pi5 ein und ausgeschaltet. Die Differenz liegt bei 5W
                            • WinniW Offline
                              WinniW Offline
                              Winni
                              #54
                              Raspberry Pi 5: Produktion fährt auf 90.000 Einplatinencomputer pro Woche hoch.
                              Die Raspberry Pi Ltd. und Sony fahren die Produktion des Raspi 5 weiter hoch. Ab Februar sollen es mehr als 360.000 pro Monat werden..
                              Hier die ganze Meldung: https://www.heise.de/news/Raspberry-Pi-5-Bald-90-000-Einplatinencomputer-pro-Woche-9597843.html
                              • WinniW Offline
                                WinniW Offline
                                Winni
                                #55
                                Es gibt nun auch eine 2 GB Version vom Raspberry Pi 5 zum Preis von 50$. Wird hierzulande wahrscheinlich auch unter 60€ zu haben sein.
                                Interessant die Aussage zur CPU.
                                https://www.raspberrypi.com/news/2gb-raspberry-pi-5-on-sale-now-at-50/
                                Edit: Hier dazu der Bericht auf Caschys Blog:
                                https://stadt-bremerhaven.de/raspberry-pi-neue-version-vorgestellt/
