  4. trashschedule widget verschwindet immer wieder
28 Beiträge 7 Kommentatoren 4.0k Aufrufe 5 Beobachtet
  • K Kellerkind-86
    danke für die ausführliche Hilfe..
    hier nochmal die ausgabe
    ======== Start marking the full check here =========
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
            Machine ID: b741ae0544da421d9f11987d7b02c49f
               Boot ID: e3faddb809704a889c43abc284b4824f
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.15.61-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     20:00:00 up 14 days, 4 min,  3 users,  load average: 0.77, 0.90, 0.83
    CPU threads: 4
    Raspberry only:
    throttled=0x80000
    Other values than 0x0 hint to temperature/voltage problems
    temp=70.1'C
    volt=0.8688V
    The systems needs to be REBOOTED!
    *** Time and Time Zones ***
                   Local time: Thu 2023-09-28 20:00:00 CEST
               Universal time: Thu 2023-09-28 18:00:00 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        2.9G        223M         34M        641M        755M
    Swap:            99M         99M          0B
    Total:          3.9G        3.0G        223M
             3794 M total memory
             2929 M used memory
              475 M active memory
             2865 M inactive memory
              223 M free memory
               42 M buffer memory
              599 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FILESYSTEM ***
    /dev/root      ext4      117G   39G   74G  35% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
    Show mounted filesystems (real ones only):
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    33G     /var/
    31G     /var/lib/influxdb/engine/data/ef99e5411b8859ab/autogen
    Archived and active journals take up 1.3G in the file system.
    /opt/iobroker/backups:
    43M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    603M    /opt/iobroker/iobroker-data/
    493M    /opt/iobroker/iobroker-data/files
    134M    /opt/iobroker/iobroker-data/files/vis-2
    83M     /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.c6771b2d.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : raspberrypi                              -  enabled
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
    + system.adapter.bluelink.0               : bluelink              : raspberrypi                              -  enabled
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
      system.adapter.enigma2.0                : enigma2               : raspberrypi                              - disabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
    + system.adapter.onkyo.0                  : onkyo                 : raspberrypi                              -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
    + system.adapter.renacidc.0               : renacidc              : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
    + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.unifi.0                  : unifi                 : raspberrypi                              - disabled
    + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
      system.adapter.web.1                    : web                   : raspberrypi                              - disabled, port: 20002, bind: 0.0.0.0, run as: admin
    + system.adapter.wiffi-wz.0               : wiffi-wz              : raspberrypi                              -  enabled
    + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2659215-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alexa-shoppinglist": 0.1.5, installed 0.1.5
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
    Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
    Adapter    "cul"          : 2.2.0    , installed 2.2.0
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "synology"     : 3.0.0    , installed 3.0.0
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        15736
    States:         13224
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 https://repos.influxdata.com/debian stable InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye InRelease
    Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.74:8181     0.0.0.0:*               LISTEN      1001       15485983   352601/io.wiffi-wz.
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15479269   351869/iobroker.js-
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15479276   351869/iobroker.js-
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14516      588/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15582248   353986/cupsd
    tcp        0      0 192.168.178.74:42001    0.0.0.0:*               LISTEN      1001       15481971   352019/io.hm-rpc.0
    tcp        0      0 192.168.178.74:42010    0.0.0.0:*               LISTEN      1001       15479421   352030/io.hm-rpc.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       15480128   352075/io.mqtt.0
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       15480436   352296/io.harmony.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12898      588/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15582247   353986/cupsd
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        16515      453/influxd
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       15480678   352483/io.ws.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15482709   352468/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15479307   351887/io.admin.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15450      489/dhcpcd
    udp        0      0 0.0.0.0:57487           0.0.0.0:*                           1001       16519862   352105/io.shelly.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       15480437   352296/io.harmony.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16545813   380276/cups-browsed
    udp        0      0 0.0.0.0:56484           0.0.0.0:*                           108        16543369   380398/avahi-daemon
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16543367   380398/avahi-daemon
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15482055   352105/io.shelly.0
    udp6       0      0 :::47230                :::*                                108        16543370   380398/avahi-daemon
    udp6       0      0 :::546                  :::*                                0          18552      489/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        16543368   380398/avahi-daemon
    2023-09-28 19:58:17.237  - info: javascript.0 (351921) script.js.Logik.Anwesenheit_.Niemand_da: Occupancyfalse
    2023-09-28 19:59:13.447  - info: renacidc.0 (352514) Adapter tries to retrieve data from the cloud
    2023-09-28 20:00:00.142  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 387550
    2023-09-28 20:00:04.208  - info: host.raspberrypi instance system.adapter.luftdaten.0 started with pid 387612
    2023-09-28 20:00:04.349  - info: dwd.0 (387550) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
    2023-09-28 20:00:05.565  - info: dwd.0 (387550) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-28 20:00:06.235  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-28 20:00:08.283  - info: host.raspberrypi instance system.adapter.ical.1 started with pid 387667
    2023-09-28 20:00:08.502  - info: luftdaten.0 (387612) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.17.1, js-controller: 5.0.12
    2023-09-28 20:00:12.154  - info: ical.1 (387667) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
    2023-09-28 20:00:12.380  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 387696
    2023-09-28 20:00:13.166  - info: ical.1 (387667) processing URL: Geburtstagskalender https://calendar.google.com/calendar/ical/0relf9ud5521k366kksf6jqer8%40group.calendar.google.com/private-39d3a6ac59f696c380df0beea146709c/basic.ics
    2023-09-28 20:00:13.336  - info: ical.1 (387667) processing URL: GemeinsamerKalender https://calendar.google.com/calendar/ical/d67eaeb54c441780c19711dd394e1fb33093a6e3aa9359195df53e0c386d9873%40group.calendar.google.com/private-92ad164037a768ce8af455f5fad6f0fd/basic.ics
    2023-09-28 20:00:13.358  - info: ical.1 (387667) processing URL: Schichtkalender https://calendar.google.com/calendar/ical/b21c0ab72df170809a006055dbbc18c132d9ec8262b9742728726592e3db51b8%40group.calendar.google.com/private-732ab3c9db0ea0398941bae0db042c91/basic.ics
    2023-09-28 20:00:13.439  - info: ical.1 (387667) processing URL: Alexa https://calendar.google.com/calendar/ical/t64uq8ll5c13qvss54ju3n5e9s%40group.calendar.google.com/private-7a66af3a8f4d0f93006f5417934756aa/basic.ics
    2023-09-28 20:00:13.448  - info: renacidc.0 (352514) Adapter tries to retrieve data from the cloud
    2023-09-28 20:00:16.845  - info: ical.0 (387696) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
    2023-09-28 20:00:17.680  - info: ical.0 (387696) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/tiggercomuth1986%40gmail.com/private-8284d4d318c30ee5229502c24de84492/basic.ics
    2023-09-28 20:00:18.710  - info: ical.1 (387667) Terminated (NO_ERROR): Without reason
    2023-09-28 20:00:19.274  - info: host.raspberrypi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
    2023-09-28 20:00:19.394  - info: luftdaten.0 (387612) Terminated (NO_ERROR): Without reason
    2023-09-28 20:00:19.946  - info: host.raspberrypi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2023-09-28 20:00:22.987  - info: ical.0 (387696) Terminated (NO_ERROR): Without reason
    2023-09-28 20:00:23.572  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-09-28 20:01:13.448  - info: renacidc.0 (352514) Adapter tries to retrieve data from the cloud
    @kellerkind-86 sagte in trashschedule widget verschwindet immer wieder:
    Tu das, der Text erscheint nicht, weil da noch Platz war.
    Und schalt den Desktop AUS!
    K 1 Antwort Letzte Antwort
      Kellerkind-86
      @thomas-braun sorry...👼
      so..nochmal
      Skript v.2023-06-20
      *** BASE SYSTEM ***
               Icon name: computer
                 Boot ID: 2983b1ca5478481b997749a0bf7fa9d3
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
       20:13:32 up 4 min,  1 user,  load average: 3.07, 2.13, 0.91
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=77.4'C
      volt=0.8563V
                     Local time: Thu 2023-09-28 20:13:33 CEST
                 Universal time: Thu 2023-09-28 18:13:33 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            3.8G        2.3G        838M        1.0M        684M        1.4G
      Swap:            99M          0B         99M
      Total:          3.9G        2.3G        938M
               3794 M total memory
               2270 M used memory
               2582 M active memory
                230 M inactive memory
                838 M free memory
                 53 M buffer memory
                631 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
      [Thu Sep 28 20:09:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:50:A2:FD vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=596adcb1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Thu Sep 28 20:09:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Thu Sep 28 20:09:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Thu Sep 28 20:09:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      /var:
      33G     /var/
      623M    /opt/iobroker/iobroker-data/
      28M     /opt/iobroker/iobroker-data/objects.jsonl
      19M     /opt/iobroker/iobroker-data/states.jsonl
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.10.1
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        15736
      States:         13238
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Pending Updates: 0
      tcp        0      0 192.168.178.74:42001    0.0.0.0:*               LISTEN      1001       16665      1094/io.hm-rpc.0
      tcp        0      0 192.168.178.74:42010    0.0.0.0:*               LISTEN      1001       15660      1117/io.hm-rpc.1
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13132      573/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15368      877/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2017       877/iobroker.js-con
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1840       541/cupsd
      tcp        0      0 192.168.178.74:8181     0.0.0.0:*               LISTEN      1001       19319      1681/io.wiffi-wz.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       15334      1162/io.mqtt.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13134      573/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1839       541/cupsd
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       18161      1407/io.harmony.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15079      908/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18427      1572/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       19913      1587/io.ws.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        13261      445/influxd
      udp        0      0 0.0.0.0:56988           0.0.0.0:*                           108        13094      400/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14848      498/dhcpcd
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       18162      1407/io.harmony.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1846       594/cups-browsed
      udp        0      0 0.0.0.0:47951           0.0.0.0:*                           1001       17826      1192/io.shelly.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13092      400/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       16767      1192/io.shelly.0
      udp6       0      0 :::51527                :::*                                108        13095      400/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          3872       498/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        13093      400/avahi-daemon: r
      2023-09-28 20:13:49.113  - info: mqtt.0 (1162) Client [DVES_0D944D] connected with secret 1695924829109_1760
      2023-09-28 20:13:49.177  - info: mqtt.0 (1162) Client [DVES_0D944D] subscribes on "Smarthome/OG/LaurenzLaurenz/cmnd/#" with regex /^Smarthome\.OG\.LaurenzLaurenz\.cmnd\..*/
      2023-09-28 20:13:49.178  - info: mqtt.0 (1162) Client [DVES_0D944D] subscribes on "Smarthome/OG/LaurenzLaurenz/cmnd/#"  with regex /^mqtt\.0\.Smarthome\.OG\.LaurenzLaurenz\.cmnd\..*/
      2023-09-28 20:13:49.179  - info: mqtt.0 (1162) Client [DVES_0D944D] subscribes on "Smarthome/OG/Laurenzsonoffs/cmnd/#" with regex /^Smarthome\.OG\.Laurenzsonoffs\.cmnd\..*/
      2023-09-28 20:13:49.180  - info: mqtt.0 (1162) Client [DVES_0D944D] subscribes on "Smarthome/OG/Laurenzsonoffs/cmnd/#"  with regex /^mqtt\.0\.Smarthome\.OG\.Laurenzsonoffs\.cmnd\..*/
      2023-09-28 20:13:49.182  - info: mqtt.0 (1162) Client [DVES_0D944D] subscribes on "cmnd/DVES_0D944D_fb/#" with regex /^cmnd\.DVES_0D944D_fb\..*/
      2023-09-28 20:13:49.183  - info: mqtt.0 (1162) Client [DVES_0D944D] subscribes on "cmnd/DVES_0D944D_fb/#"  with regex /^mqtt\.0\.cmnd\.DVES_0D944D_fb\..*/
      2023-09-28 20:13:49.378  - info: mqtt.0 (1162) Client [DVES_0D944D] publishOnSubscribe send all known states
      2023-09-28 20:13:49.382  - info: mqtt.0 (1162) Client [DVES_0D944D] publishOnSubscribe send all known states
      2023-09-28 20:13:49.384  - info: mqtt.0 (1162) Client [DVES_0D944D] publishOnSubscribe send all known states
      2023-09-28 20:13:53.603  - info: renacidc.0 (1617) Adapter tries to retrieve data from the cloud
      2023-09-28 20:13:56.773  - info: web.0 (1572) <== Disconnect system.user.admin from ::ffff:192.168.178.133
      2023-09-28 20:13:56.867  - info: web.0 (1572) <== Disconnect system.user.admin from ::ffff:192.168.178.133 vis-2
      2023-09-28 20:14:01.913  - info: web.0 (1572) ==> Connected system.user.admin from ::ffff:192.168.178.133
      2023-09-28 20:14:02.132  - info: alexa2.0 (1087) No smart home devices to query
      2023-09-28 20:14:06.739  - info: alexa2.0 (1087) Subscribing to states...
      2023-09-28 20:14:06.751  - info: alexa2.0 (1087) Deleting the following states: ["Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84","Smart-Home-Devices.64ce6c05-678e-45c4-85e2-abdce053ca5d","Smart-Home-Devices.b6da0ecd-a0a0-4c77-a62c-850b5e6063ff","Smart-Home-Devices.db1f5767-8a29-4fb2-a89a-623c67fadb73","Smart-Home-Devices.74b879fd-8067-4ca9-b75b-36ed5d8b22b6","Smart-Home-Devices.be77b0e0-71d1-46e9-a9a1-7309c65b2373","Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c.#delete","Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c.#enabled","Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c.#query","Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c.Yeedi-Mode-mode","Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c.powerState","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84.#delete","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84.#enabled","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84.#query","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84.Blinds-Position-rangeValue","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84.connectivity","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84.connectivity-reason","Smart-Home-Devices.64ce6c05-678e-45c4-85e2-abdce053ca5d.#delete","Smart-Home-Devices.64ce6c05-678e-45c4-85e2-abdce053ca5d.#enabled","Smart-Home-Devices.64ce6c05-678e-45c4-85e2-abdce053ca5d.#query","Smart-Home-Devices.64ce6c05-678e-45c4-85e2-abdce053ca5d.Blinds-Position-rangeValue","Smart-Home-Devices.64ce6c05-678e-45c4-85e2-abdce053ca5d.connectivity","Smart-Home-Devices.64ce6c05-678e-45c4-85e2-abdce053ca5d.connectivity-reason","Smart-Home-Devices.b6da0ecd-a0a0-4c77-a62c-850b5e6063ff.#delete","Smart-Home-Devices.b6da0ecd-a0a0-4c77-a62c-850b5e6063ff.#enabled","Smart-Home-Devices.b6da0ecd-a0a0-4c77-a62c-850b5e6063ff.#query","Smart-Home-Devices.b6da0ecd-a0a0-4c77-a62c-850b5e6063ff.Blinds-Position-rangeValue","Smart-Home-Devices.b6da0ecd-a0a0-4c77-a62c-850b5e6063ff.connectivity","Smart-Home-Devices.b6da0ecd-a0a0-4c77-a62c-850b5e6063ff.connectivity-reason","Smart-Home-Devices.db1f5767-8a29-4fb2-a89a-623c67fadb73.#delete","Smart-Home-Devices.db1f5767-8a29-4fb2-a89a-623c67fadb73.#enabled","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84.#includeInAllQuery","Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c.VacuumCleaner-Charge-mode","Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c.#includeInAllQuery","Smart-Home-Devices.74b879fd-8067-4ca9-b75b-36ed5d8b22b6.#enabled","Smart-Home-Devices.74b879fd-8067-4ca9-b75b-36ed5d8b22b6.#delete","Smart-Home-Devices.be77b0e0-71d1-46e9-a9a1-7309c65b2373.#enabled","Smart-Home-Devices.be77b0e0-71d1-46e9-a9a1-7309c65b2373.#delete","Smart-Home-Devices.be77b0e0-71d1-46e9-a9a1-7309c65b2373.VacuumCleaner-Charge-mode","Smart-Home-Devices.be77b0e0-71d1-46e9-a9a1-7309c65b2373.powerState","Smart-Home-Devices.be77b0e0-71d1-46e9-a9a1-7309c65b2373.#query","Smart-Home-Devices.be77b0e0-71d1-46e9-a9a1-7309c65b2373.#includeInAllQuery"]
      2023-09-28 20:14:06.785  - info: web.0 (1572) ==> Connected system.user.admin from ::ffff:192.168.178.133
      2023-09-28 20:14:08.830  - info: alexa2.0 (1087) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2023-09-28 20:14:22.873  - info: alexa2.0 (1087) Initialization Done ...
      2023-09-28 20:14:53.603  - info: renacidc.0 (1617) Adapter tries to retrieve data from the cloud
      2023-09-28 20:15:00.079  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 2132
      2023-09-28 20:15:04.418  - info: dwd.0 (2132) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-28 20:15:05.355  - info: dwd.0 (2132) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-28 20:15:05.902  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      Gruß Marcell
      • K Kellerkind-86
        so..nochmal
        Skript v.2023-06-20
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=77.4'C
        volt=0.8563V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 3794 M total memory
                 2270 M used memory
                  838 M free memory
                   53 M buffer memory
                  631 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        33G     /var/
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.10.1
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        15736
        States:         13238
        Pending Updates: 0
        @kellerkind-86
        Ja, passt. Das nodesource-Repository musst du noch umstellen. Geht mit dem Skript aus meiner Signatur.
          @kellerkind-86
          Kellerkind-86
          perfekt.. danke für die hilfe..
          Nothing to do - Your installation is using the correct paths.
          Nothing to do - Your version is the recommended one.
          was könnte ich jetzt noch gegen das eigentliche problem tun ?
          oder liegt es vielleicht an der hardware ?
          hab mir was neues bestellt und wird morgen ankommen.
          vielleicht behebt das ganze dann das eigentliche Problem.
          muss mich jetzt nur noch schlau machen wie ich das ganze umziehen lasse, welches betriebsystem und welches containersystem ich nutzen soll....😕
          danke für die unterstützung bis hier hin
          Gruß Marcell
          • O Offline
            O Offline
            Ostpower
            schrieb am zuletzt editiert von Ostpower
            Hallo Zusammen,
            ich möchte mich mal hier auch dran hängen, da ich seit der vis-2.0 das selbe Problem mit Trashshedule widget habe.
            Das Widget kann ich im Vis2 Editor bearbeiten und es wird mir auch angezeigt. Starte ich den Runtime ist das Widget mal da oder auch nicht. Es kommt oft wieder, wenn ich im Editor es nur kurz bewege. Das ganze hat in der VIS 1 ohne Probleme funktioniert.
            Screenshot 2023-10-18 165020.pngRuntime oder Panel, sichtbar für ein paar Minuten
            Screenshot 2023-10-18 164941.png Runtime oder Panel, nicht mehr sichtbar
            Screenshot 2023-10-18 164900.png Vis-Editor.
            Das selbe Problem habe ich mit dem "materialdesign Table widget", auch da kann ich z.B. die Json Tabelle vom Tankkönig einbinden, aber es verschwindet oft auf der Visu (Runtime bzw. Panel)
            Hat jemand da vielleicht Eine Idee, was das sein könnte.
            LG
            • O Ostpower
              Hallo Zusammen,
              LG
              schneidy76
              @ostpower das Problem kann ich bestätigen, eine Lösung habe ich aber auch nicht
              Raspberry Matic (RP3), LIVE PV Monitoring mit Smartmeter, Poolsteuerung mit NodeRed, KNX Ausbau (ersetzt stückweise HM & klassische Installation), ioBroker Multihost (RP4 &RP2), Visu mit VIS
              • NegaleinN Offline
                NegaleinN Offline
                Negalein
                dazu hat Mathias in GIT was geschrieben.
                Er wird für VIS 2 ein neues Widget entwickeln.
                https://github.com/klein0r/ioBroker.trashschedule/issues/193#issuecomment-1822283836
                ° Fixer ---> iob fix
                • NegaleinN Negalein
                  schneidy76
                  @negalein Ja, habe ein issue auf gemacht. Bin leider dazwischen nicht mehr ins Forum gekommen - die liebe Zeit.... ;-)
