  4. trashschedule widget verschwindet immer wieder
28 Beiträge 7 Kommentatoren 4.0k Aufrufe 5 Beobachtet
    @kellerkind-86
    wget -q https://repos.influxdata.com/influxdata-archive_compat.key
    echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
    echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
    rm influxdata-archive_compat.key
    Und dann
    sudo apt update
    sudo apt full-upgrade
    Kellerkind-86
    pi@raspberrypi:~ $ sudo apt update
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 https://repos.influxdata.com/debian stable InRelease
    Hit:4 http://deb.debian.org/debian bullseye InRelease
    Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,040 B]
    Hit:6 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:7 https://deb.nodesource.com/node_18.x bullseye InRelease
    Err:5 https://repos.influxdata.com/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Fetched 7,040 B in 2s (3,972 B/s)
    Reading package lists... Done
    2 packages can be upgraded. Run 'apt list --upgradable' to see them.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    leider immer noch..sorry
    Gruß Marcell
    • K Kellerkind-86
      @kellerkind-86 sagte in trashschedule widget verschwindet immer wieder:
      Du hast für influx zwei Quellen aktiv.
      ls -lAh /etc/apt/sources.list.d/
      K Thomas BraunT 2 Antworten Letzte Antwort
        Kellerkind-86
        pi@raspberrypi:~ $ ls -lAh /etc/apt/sources.list.d/
        total 16K
        -rw-r--r-- 1 root root 114 Sep 28 19:39 influxdata.list
        -rw-r--r-- 1 root root 101 Sep 28 19:28 influxdb.list
        -rw-r--r-- 1 root root 208 Sep 14 21:57 nodesource.list
        -rw-r--r-- 1 root root 191 Sep 22  2022 raspi.list
        Gruß Marcell
          Lösch die Datei, die NICHT influxdata.list heißt.
          • K Kellerkind-86
            total 16K
            sudo rm /etc/apt/sources.list.d/influxdb.list
            sudo apt update
              sudo apt update
              Kellerkind-86
              danke für die ausführliche Hilfe..
              hier nochmal die ausgabe
              Skript v.2023-06-20
              *** BASE SYSTEM ***
                 Static hostname: raspberrypi
                       Icon name: computer
                      Machine ID: b741ae0544da421d9f11987d7b02c49f
                         Boot ID: e3faddb809704a889c43abc284b4824f
                Operating System: Debian GNU/Linux 11 (bullseye)
                          Kernel: Linux 5.15.61-v8+
                    Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.1
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : arm64
              Systemuptime and Load:
               20:00:00 up 14 days, 4 min,  3 users,  load average: 0.77, 0.90, 0.83
              CPU threads: 4
              Raspberry only:
              throttled=0x80000
              Other values than 0x0 hint to temperature/voltage problems
              temp=70.1'C
              volt=0.8688V
              The systems needs to be REBOOTED!
              *** Time and Time Zones ***
                             Local time: Thu 2023-09-28 20:00:00 CEST
                         Universal time: Thu 2023-09-28 18:00:00 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       true
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            3.8G        2.9G        223M         34M        641M        755M
              Swap:            99M         99M          0B
              Total:          3.9G        3.0G        223M
                       3794 M total memory
                       2929 M used memory
                        475 M active memory
                       2865 M inactive memory
                        223 M free memory
                         42 M buffer memory
                        599 M swap cache
                         99 M total swap
                         99 M used swap
                          0 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /dev/root      ext4      117G   39G   74G  35% /
              devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
              tmpfs          tmpfs     759M  1.2M  758M   1% /run
              /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
              tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
              TARGET  SOURCE         FSTYPE OPTIONS
              /       /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              33G     /var/
              31G     /var/lib/influxdb/engine/data/ef99e5411b8859ab/autogen
              Archived and active journals take up 1.3G in the file system.
              /opt/iobroker/backups:
              43M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              603M    /opt/iobroker/iobroker-data/
              493M    /opt/iobroker/iobroker-data/files
              134M    /opt/iobroker/iobroker-data/files/vis-2
              83M     /opt/iobroker/iobroker-data/backup-objects
              72M     /opt/iobroker/iobroker-data/files/telegram.admin
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
              19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.c6771b2d.js.map
              19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
              18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.17.1
              /usr/bin/node           v18.17.1
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              nodejs:
                Installed: 18.17.1-deb-1nodesource1
                Candidate: 18.17.1-deb-1nodesource1
                Version table:
               *** 18.17.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                   12.22.12~dfsg-1~deb11u3 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              No configuration change needed.
              Multihost discovery server: disabled
              Discovery authentication:   enabled
              Persistent activation:      disabled
              Objects:                    jsonl on 127.0.0.1
              States:                     jsonl on 127.0.0.1
              Core adapters versions
              js-controller:  5.0.12
              admin:          6.10.1
              javascript:     7.1.4
              Adapters from github:   3
              Adapter State
              + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : raspberrypi                              -  enabled
                system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
              + system.adapter.bluelink.0               : bluelink              : raspberrypi                              -  enabled
                system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
              + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
              + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                system.adapter.enigma2.0                : enigma2               : raspberrypi                              - disabled
                system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
              + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
              + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
              + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
              + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
              + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
              + system.adapter.onkyo.0                  : onkyo                 : raspberrypi                              -  enabled
              + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
              + system.adapter.renacidc.0               : renacidc              : raspberrypi                              -  enabled
              + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
                system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
              + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
              + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
              + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
              + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                system.adapter.unifi.0                  : unifi                 : raspberrypi                              - disabled
              + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
                system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                system.adapter.web.1                    : web                   : raspberrypi                              - disabled, port: 20002, bind: 0.0.0.0, run as: admin
              + system.adapter.wiffi-wz.0               : wiffi-wz              : raspberrypi                              -  enabled
              + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                system.adapter.yr.0                     : yr                    : raspberrypi                              -  enabled
              + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2659215-if00
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.10.1   , installed 6.10.1
              Adapter    "alexa-shoppinglist": 0.1.5, installed 0.1.5
              Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
              Adapter    "backitup"     : 2.8.1    , installed 2.8.1
              Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
              Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
              Adapter    "cul"          : 2.2.0    , installed 2.2.0
              Adapter    "devices"      : 1.1.5    , installed 1.1.5
              Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
              Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
              Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
              Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
              Adapter    "harmony"      : 1.2.2    , installed 1.2.2
              Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
              Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
              Adapter    "ical"         : 1.13.3   , installed 1.13.3
              Adapter    "iot"          : 1.14.5   , installed 1.14.5
              Adapter    "javascript"   : 7.1.4    , installed 7.1.4
              Controller "js-controller": 5.0.12   , installed 5.0.12
              Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
              Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
              Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
              Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
              Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
              Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
              Adapter    "shelly"       : 6.4.1    , installed 6.4.1
              Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
              Adapter    "socketio"     : 6.5.5    , installed 6.5.5
              Adapter    "synology"     : 3.0.0    , installed 3.0.0
              Adapter    "telegram"     : 1.16.0   , installed 1.16.0
              Adapter    "text2command" : 3.0.2    , installed 3.0.2
              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
              Adapter    "unifi"        : 0.6.6    , installed 0.6.6
              Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
              Adapter    "web"          : 6.1.2    , installed 6.1.2
              Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
              Adapter    "ws"           : 2.5.5    , installed 2.5.5
              Adapter    "yr"           : 5.3.0    , installed 5.3.0
              Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
              Objects and States
              Objects:        15736
              States:         13224
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 https://repos.influxdata.com/debian stable InRelease
              Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:6 https://deb.nodesource.com/node_18.x bullseye InRelease
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 192.168.178.74:8181     0.0.0.0:*               LISTEN      1001       15485983   352601/io.wiffi-wz.
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15479269   351869/iobroker.js-
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15479276   351869/iobroker.js-
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14516      588/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15582248   353986/cupsd
              tcp        0      0 192.168.178.74:42001    0.0.0.0:*               LISTEN      1001       15481971   352019/io.hm-rpc.0
              tcp        0      0 192.168.178.74:42010    0.0.0.0:*               LISTEN      1001       15479421   352030/io.hm-rpc.1
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       15480128   352075/io.mqtt.0
              tcp6       0      0 :::61991                :::*                    LISTEN      1001       15480436   352296/io.harmony.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          12898      588/sshd: /usr/sbin
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15582247   353986/cupsd
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        16515      453/influxd
              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       15480678   352483/io.ws.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15482709   352468/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15479307   351887/io.admin.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15450      489/dhcpcd
              udp        0      0 0.0.0.0:57487           0.0.0.0:*                           1001       16519862   352105/io.shelly.0
              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       15480437   352296/io.harmony.0
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16545813   380276/cups-browsed
              udp        0      0 0.0.0.0:56484           0.0.0.0:*                           108        16543369   380398/avahi-daemon
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16543367   380398/avahi-daemon
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15482055   352105/io.shelly.0
              udp6       0      0 :::47230                :::*                                108        16543370   380398/avahi-daemon
              udp6       0      0 :::546                  :::*                                0          18552      489/dhcpcd
              udp6       0      0 :::5353                 :::*                                108        16543368   380398/avahi-daemon
              2023-09-28 19:58:17.237  - info: javascript.0 (351921) script.js.Logik.Anwesenheit_.Niemand_da: Occupancyfalse
              2023-09-28 19:59:13.447  - info: renacidc.0 (352514) Adapter tries to retrieve data from the cloud
              2023-09-28 20:00:00.142  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 387550
              2023-09-28 20:00:04.208  - info: host.raspberrypi instance system.adapter.luftdaten.0 started with pid 387612
              2023-09-28 20:00:04.349  - info: dwd.0 (387550) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
              2023-09-28 20:00:05.565  - info: dwd.0 (387550) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-09-28 20:00:06.235  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-09-28 20:00:08.283  - info: host.raspberrypi instance system.adapter.ical.1 started with pid 387667
              2023-09-28 20:00:08.502  - info: luftdaten.0 (387612) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.17.1, js-controller: 5.0.12
              2023-09-28 20:00:12.154  - info: ical.1 (387667) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
              2023-09-28 20:00:12.380  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 387696
              2023-09-28 20:00:13.166  - info: ical.1 (387667) processing URL: Geburtstagskalender https://calendar.google.com/calendar/ical/0relf9ud5521k366kksf6jqer8%40group.calendar.google.com/private-39d3a6ac59f696c380df0beea146709c/basic.ics
              2023-09-28 20:00:13.336  - info: ical.1 (387667) processing URL: GemeinsamerKalender https://calendar.google.com/calendar/ical/d67eaeb54c441780c19711dd394e1fb33093a6e3aa9359195df53e0c386d9873%40group.calendar.google.com/private-92ad164037a768ce8af455f5fad6f0fd/basic.ics
              2023-09-28 20:00:13.358  - info: ical.1 (387667) processing URL: Schichtkalender https://calendar.google.com/calendar/ical/b21c0ab72df170809a006055dbbc18c132d9ec8262b9742728726592e3db51b8%40group.calendar.google.com/private-732ab3c9db0ea0398941bae0db042c91/basic.ics
              2023-09-28 20:00:13.439  - info: ical.1 (387667) processing URL: Alexa https://calendar.google.com/calendar/ical/t64uq8ll5c13qvss54ju3n5e9s%40group.calendar.google.com/private-7a66af3a8f4d0f93006f5417934756aa/basic.ics
              2023-09-28 20:00:13.448  - info: renacidc.0 (352514) Adapter tries to retrieve data from the cloud
              2023-09-28 20:00:16.845  - info: ical.0 (387696) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 5.0.12
              2023-09-28 20:00:17.680  - info: ical.0 (387696) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/tiggercomuth1986%40gmail.com/private-8284d4d318c30ee5229502c24de84492/basic.ics
              2023-09-28 20:00:18.710  - info: ical.1 (387667) Terminated (NO_ERROR): Without reason
              2023-09-28 20:00:19.274  - info: host.raspberrypi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
              2023-09-28 20:00:19.394  - info: luftdaten.0 (387612) Terminated (NO_ERROR): Without reason
              2023-09-28 20:00:19.946  - info: host.raspberrypi instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
              2023-09-28 20:00:22.987  - info: ical.0 (387696) Terminated (NO_ERROR): Without reason
              2023-09-28 20:00:23.572  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2023-09-28 20:01:13.448  - info: renacidc.0 (352514) Adapter tries to retrieve data from the cloud
              Gruß Marcell
              • K Kellerkind-86
                Skript v.2023-06-20
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Raspberry only:
                throttled=0x80000
                temp=70.1'C
                volt=0.8688V
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       true
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M         99M          0B
                         3794 M total memory
                         2929 M used memory
                          475 M active memory
                          223 M free memory
                           42 M buffer memory
                          599 M swap cache
                           99 M total swap
                           99 M used swap
                            0 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                33G     /var/
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.10.1
                javascript:     7.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        15736
                States:         13224
                Pending Updates: 0
                Tu das, der Text erscheint nicht, weil da noch Platz war.
                Und schalt den Desktop AUS!
                  Kellerkind-86
                  @thomas-braun sorry...👼
                  so..nochmal
                  Skript v.2023-06-20
                  *** BASE SYSTEM ***
                           Icon name: computer
                             Boot ID: 2983b1ca5478481b997749a0bf7fa9d3
                              Kernel: Linux 6.1.21-v8+
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                   20:13:32 up 4 min,  1 user,  load average: 3.07, 2.13, 0.91
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  temp=77.4'C
                  volt=0.8563V
                                 Local time: Thu 2023-09-28 20:13:33 CEST
                             Universal time: Thu 2023-09-28 18:13:33 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            3.8G        2.3G        838M        1.0M        684M        1.4G
                  Swap:            99M          0B         99M
                  Total:          3.9G        2.3G        938M
                           3794 M total memory
                           2270 M used memory
                           2582 M active memory
                            230 M inactive memory
                            838 M free memory
                             53 M buffer memory
                            631 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                  [Thu Sep 28 20:09:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:50:A2:FD vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=596adcb1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                  [Thu Sep 28 20:09:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Thu Sep 28 20:09:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Thu Sep 28 20:09:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  /var:
                  33G     /var/
                  623M    /opt/iobroker/iobroker-data/
                  28M     /opt/iobroker/iobroker-data/objects.jsonl
                  19M     /opt/iobroker/iobroker-data/states.jsonl
                  /usr/bin/npm            9.6.7
                  /usr/bin/npx            9.6.7
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.10.1
                  javascript:     7.1.4
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        15736
                  States:         13238
                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:5 https://repos.influxdata.com/debian stable InRelease
                  Pending Updates: 0
                  tcp        0      0 192.168.178.74:42001    0.0.0.0:*               LISTEN      1001       16665      1094/io.hm-rpc.0
                  tcp        0      0 192.168.178.74:42010    0.0.0.0:*               LISTEN      1001       15660      1117/io.hm-rpc.1
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13132      573/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15368      877/iobroker.js-con
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2017       877/iobroker.js-con
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1840       541/cupsd
                  tcp        0      0 192.168.178.74:8181     0.0.0.0:*               LISTEN      1001       19319      1681/io.wiffi-wz.0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       15334      1162/io.mqtt.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          13134      573/sshd: /usr/sbin
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1839       541/cupsd
                  tcp6       0      0 :::61991                :::*                    LISTEN      1001       18161      1407/io.harmony.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15079      908/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18427      1572/io.web.0
                  tcp6       0      0 :::8084                 :::*                    LISTEN      1001       19913      1587/io.ws.0
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        13261      445/influxd
                  udp        0      0 0.0.0.0:56988           0.0.0.0:*                           108        13094      400/avahi-daemon: r
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14848      498/dhcpcd
                  udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       18162      1407/io.harmony.0
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1846       594/cups-browsed
                  udp        0      0 0.0.0.0:47951           0.0.0.0:*                           1001       17826      1192/io.shelly.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13092      400/avahi-daemon: r
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       16767      1192/io.shelly.0
                  udp6       0      0 :::51527                :::*                                108        13095      400/avahi-daemon: r
                  udp6       0      0 :::546                  :::*                                0          3872       498/dhcpcd
                  udp6       0      0 :::5353                 :::*                                108        13093      400/avahi-daemon: r
                  2023-09-28 20:13:49.113  - info: mqtt.0 (1162) Client [DVES_0D944D] connected with secret 1695924829109_1760
                  2023-09-28 20:13:49.177  - info: mqtt.0 (1162) Client [DVES_0D944D] subscribes on "Smarthome/OG/LaurenzLaurenz/cmnd/#" with regex /^Smarthome\.OG\.LaurenzLaurenz\.cmnd\..*/
                  2023-09-28 20:13:49.178  - info: mqtt.0 (1162) Client [DVES_0D944D] subscribes on "Smarthome/OG/LaurenzLaurenz/cmnd/#"  with regex /^mqtt\.0\.Smarthome\.OG\.LaurenzLaurenz\.cmnd\..*/
                  2023-09-28 20:13:49.179  - info: mqtt.0 (1162) Client [DVES_0D944D] subscribes on "Smarthome/OG/Laurenzsonoffs/cmnd/#" with regex /^Smarthome\.OG\.Laurenzsonoffs\.cmnd\..*/
                  2023-09-28 20:13:49.180  - info: mqtt.0 (1162) Client [DVES_0D944D] subscribes on "Smarthome/OG/Laurenzsonoffs/cmnd/#"  with regex /^mqtt\.0\.Smarthome\.OG\.Laurenzsonoffs\.cmnd\..*/
                  2023-09-28 20:13:49.182  - info: mqtt.0 (1162) Client [DVES_0D944D] subscribes on "cmnd/DVES_0D944D_fb/#" with regex /^cmnd\.DVES_0D944D_fb\..*/
                  2023-09-28 20:13:49.183  - info: mqtt.0 (1162) Client [DVES_0D944D] subscribes on "cmnd/DVES_0D944D_fb/#"  with regex /^mqtt\.0\.cmnd\.DVES_0D944D_fb\..*/
                  2023-09-28 20:13:49.378  - info: mqtt.0 (1162) Client [DVES_0D944D] publishOnSubscribe send all known states
                  2023-09-28 20:13:49.382  - info: mqtt.0 (1162) Client [DVES_0D944D] publishOnSubscribe send all known states
                  2023-09-28 20:13:49.384  - info: mqtt.0 (1162) Client [DVES_0D944D] publishOnSubscribe send all known states
                  2023-09-28 20:13:53.603  - info: renacidc.0 (1617) Adapter tries to retrieve data from the cloud
                  2023-09-28 20:13:56.773  - info: web.0 (1572) <== Disconnect system.user.admin from ::ffff:192.168.178.133
                  2023-09-28 20:13:56.867  - info: web.0 (1572) <== Disconnect system.user.admin from ::ffff:192.168.178.133 vis-2
                  2023-09-28 20:14:01.913  - info: web.0 (1572) ==> Connected system.user.admin from ::ffff:192.168.178.133
                  2023-09-28 20:14:02.132  - info: alexa2.0 (1087) No smart home devices to query
                  2023-09-28 20:14:06.739  - info: alexa2.0 (1087) Subscribing to states...
                  2023-09-28 20:14:06.751  - info: alexa2.0 (1087) Deleting the following states: ["Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84","Smart-Home-Devices.64ce6c05-678e-45c4-85e2-abdce053ca5d","Smart-Home-Devices.b6da0ecd-a0a0-4c77-a62c-850b5e6063ff","Smart-Home-Devices.db1f5767-8a29-4fb2-a89a-623c67fadb73","Smart-Home-Devices.74b879fd-8067-4ca9-b75b-36ed5d8b22b6","Smart-Home-Devices.be77b0e0-71d1-46e9-a9a1-7309c65b2373","Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c.#delete","Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c.#enabled","Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c.#query","Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c.Yeedi-Mode-mode","Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c.powerState","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84.#delete","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84.#enabled","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84.#query","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84.Blinds-Position-rangeValue","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84.connectivity","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84.connectivity-reason","Smart-Home-Devices.64ce6c05-678e-45c4-85e2-abdce053ca5d.#delete","Smart-Home-Devices.64ce6c05-678e-45c4-85e2-abdce053ca5d.#enabled","Smart-Home-Devices.64ce6c05-678e-45c4-85e2-abdce053ca5d.#query","Smart-Home-Devices.64ce6c05-678e-45c4-85e2-abdce053ca5d.Blinds-Position-rangeValue","Smart-Home-Devices.64ce6c05-678e-45c4-85e2-abdce053ca5d.connectivity","Smart-Home-Devices.64ce6c05-678e-45c4-85e2-abdce053ca5d.connectivity-reason","Smart-Home-Devices.b6da0ecd-a0a0-4c77-a62c-850b5e6063ff.#delete","Smart-Home-Devices.b6da0ecd-a0a0-4c77-a62c-850b5e6063ff.#enabled","Smart-Home-Devices.b6da0ecd-a0a0-4c77-a62c-850b5e6063ff.#query","Smart-Home-Devices.b6da0ecd-a0a0-4c77-a62c-850b5e6063ff.Blinds-Position-rangeValue","Smart-Home-Devices.b6da0ecd-a0a0-4c77-a62c-850b5e6063ff.connectivity","Smart-Home-Devices.b6da0ecd-a0a0-4c77-a62c-850b5e6063ff.connectivity-reason","Smart-Home-Devices.db1f5767-8a29-4fb2-a89a-623c67fadb73.#delete","Smart-Home-Devices.db1f5767-8a29-4fb2-a89a-623c67fadb73.#enabled","Smart-Home-Devices.287293af-2934-477a-b355-919eb74f9f84.#includeInAllQuery","Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c.VacuumCleaner-Charge-mode","Smart-Home-Devices.0a549d29-a62a-427f-b5e0-b67599e00c9c.#includeInAllQuery","Smart-Home-Devices.74b879fd-8067-4ca9-b75b-36ed5d8b22b6.#enabled","Smart-Home-Devices.74b879fd-8067-4ca9-b75b-36ed5d8b22b6.#delete","Smart-Home-Devices.be77b0e0-71d1-46e9-a9a1-7309c65b2373.#enabled","Smart-Home-Devices.be77b0e0-71d1-46e9-a9a1-7309c65b2373.#delete","Smart-Home-Devices.be77b0e0-71d1-46e9-a9a1-7309c65b2373.VacuumCleaner-Charge-mode","Smart-Home-Devices.be77b0e0-71d1-46e9-a9a1-7309c65b2373.powerState","Smart-Home-Devices.be77b0e0-71d1-46e9-a9a1-7309c65b2373.#query","Smart-Home-Devices.be77b0e0-71d1-46e9-a9a1-7309c65b2373.#includeInAllQuery"]
                  2023-09-28 20:14:06.785  - info: web.0 (1572) ==> Connected system.user.admin from ::ffff:192.168.178.133
                  2023-09-28 20:14:08.830  - info: alexa2.0 (1087) Alexa-Push-Connection (macDms = true) established. Disable Polling
                  2023-09-28 20:14:22.873  - info: alexa2.0 (1087) Initialization Done ...
                  2023-09-28 20:14:53.603  - info: renacidc.0 (1617) Adapter tries to retrieve data from the cloud
                  2023-09-28 20:15:00.079  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 2132
                  2023-09-28 20:15:04.418  - info: dwd.0 (2132) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
                  2023-09-28 20:15:05.355  - info: dwd.0 (2132) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-09-28 20:15:05.902  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  Gruß Marcell
                  • K Kellerkind-86
                    so..nochmal
                    Skript v.2023-06-20
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    temp=77.4'C
                    volt=0.8563V
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:            99M          0B         99M
                             3794 M total memory
                             2270 M used memory
                              838 M free memory
                               53 M buffer memory
                              631 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    33G     /var/
                    /usr/bin/npm            9.6.7
                    /usr/bin/npx            9.6.7
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.10.1
                    javascript:     7.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        15736
                    States:         13238
                    Pending Updates: 0
                    @kellerkind-86
                    Ja, passt. Das nodesource-Repository musst du noch umstellen. Geht mit dem Skript aus meiner Signatur.
                      @kellerkind-86
                      Kellerkind-86
                      perfekt.. danke für die hilfe..
                      Nothing to do - Your installation is using the correct paths.
                      Nothing to do - Your version is the recommended one.
                      was könnte ich jetzt noch gegen das eigentliche problem tun ?
                      oder liegt es vielleicht an der hardware ?
                      hab mir was neues bestellt und wird morgen ankommen.
                      vielleicht behebt das ganze dann das eigentliche Problem.
                      muss mich jetzt nur noch schlau machen wie ich das ganze umziehen lasse, welches betriebsystem und welches containersystem ich nutzen soll....😕
                      danke für die unterstützung bis hier hin
                      Gruß Marcell
                      • O Offline
                        O Offline
                        Ostpower
                        schrieb am zuletzt editiert von Ostpower
                        Hallo Zusammen,
                        ich möchte mich mal hier auch dran hängen, da ich seit der vis-2.0 das selbe Problem mit Trashshedule widget habe.
                        Das Widget kann ich im Vis2 Editor bearbeiten und es wird mir auch angezeigt. Starte ich den Runtime ist das Widget mal da oder auch nicht. Es kommt oft wieder, wenn ich im Editor es nur kurz bewege. Das ganze hat in der VIS 1 ohne Probleme funktioniert.
                        Screenshot 2023-10-18 165020.pngRuntime oder Panel, sichtbar für ein paar Minuten
                        Screenshot 2023-10-18 164941.png Runtime oder Panel, nicht mehr sichtbar
                        Screenshot 2023-10-18 164900.png Vis-Editor.
                        Das selbe Problem habe ich mit dem "materialdesign Table widget", auch da kann ich z.B. die Json Tabelle vom Tankkönig einbinden, aber es verschwindet oft auf der Visu (Runtime bzw. Panel)
                        Hat jemand da vielleicht Eine Idee, was das sein könnte.
                        LG
                        • O Ostpower
                          Hallo Zusammen,
                          LG
                          schneidy76
                          @ostpower das Problem kann ich bestätigen, eine Lösung habe ich aber auch nicht
                          Raspberry Matic (RP3), LIVE PV Monitoring mit Smartmeter, Poolsteuerung mit NodeRed, KNX Ausbau (ersetzt stückweise HM & klassische Installation), ioBroker Multihost (RP4 &RP2), Visu mit VIS
                          • NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            dazu hat Mathias in GIT was geschrieben.
                            Er wird für VIS 2 ein neues Widget entwickeln.
                            https://github.com/klein0r/ioBroker.trashschedule/issues/193#issuecomment-1822283836
                            ° Fixer ---> iob fix
                            • NegaleinN Negalein
                              schneidy76
                              @negalein Ja, habe ein issue auf gemacht. Bin leider dazwischen nicht mehr ins Forum gekommen - die liebe Zeit.... ;-)
