  4. Fehler MQTT-Adapter
Fehler MQTT-Adapter
5 Beiträge 3 Kommentatoren 1.3k Aufrufe
    AndyUM61
    mein MQTT-Adapter startet leider nicht mehr:(!
    Folgender Fehler im LOG:
    mqtt.0	2017-07-16 19:38:00.649	error	at Connection.Duplexify._write (C:\Program Files\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\node_modules\duplexify\index.js:201:22)
    mqtt.0	2017-07-16 19:38:00.649	error	at Writable.write (_stream_writable.js:214:11)
    mqtt.0	2017-07-16 19:38:00.649	error	at doWrite (_stream_writable.js:300:12)
    mqtt.0	2017-07-16 19:38:00.649	error	at Writable.write [as _write] (C:\Program Files\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\lib\writeToStream.js:10:9)
    mqtt.0	2017-07-16 19:38:00.649	error	at generate (C:\Program Files\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\node_modules\mqtt-packet\writeToStream.js:22:14)
    mqtt.0	2017-07-16 19:38:00.649	error	at Function.Buffer.concat (buffer.js:281:24)
    mqtt.0	2017-07-16 19:37:25.988	error	at Connection.Duplexify._write (C:\Program Files\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\node_modules\duplexify\index.js:201:22)
    mqtt.0	2017-07-16 19:37:25.988	error	at Writable.write (_stream_writable.js:214:11)
    mqtt.0	2017-07-16 19:37:25.988	error	at doWrite (_stream_writable.js:300:12)
    mqtt.0	2017-07-16 19:37:25.988	error	at Writable.write [as _write] (C:\Program Files\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\lib\writeToStream.js:10:9)
    mqtt.0	2017-07-16 19:37:25.988	error	at generate (C:\Program Files\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\node_modules\mqtt-packet\writeToStream.js:32:14)
    mqtt.0	2017-07-16 19:37:25.988	error	at Function.Buffer.concat (buffer.js:281:24)
    Internette Grüße
    Andy
    RaspberryMatic (Raspberry Pi3), CUxD, ioBroker (Synology/ Docker)
    • apollon77A Offline
      Hast du irgendwas gemacht? Systemupdates oder so?
        AndyUM61
        nein, nichts am ioBroker-System.
        Ich habe nur die FritzBox neu gestartet, und dann war das Problem da.
        Ist aber auch schon wieder erledigt.
        Ich habe erst versucht den Adapter noch einmal über zu installieren - erfolglos,
        dann habe ich in den Einstellungen "Benutze Pathch für Chunking:" deaktiviert, und jetzt läuft es wieder Fehlerfrei.
        Tja, was auch immer das war…???
        P.S. Da fällt mir gerade auf, dass da ein Schreibfehler in den Einstellungen ist: "Pat<u>h</u>ch";)
        Internette Grüße
        Andy
          @AndyUM61:
          P.S. Da fällt mir gerade auf, dass da ein Schreibfehler in den Einstellungen ist: "Pat<u>h</u>ch";) `
          Fixed auf Github. mache dafür aber keine eigene neue Version :-)
          • chucky666C Offline
            chucky666C Offline
            chucky666
            Hallo zusammen
            Bei mir stützt der Mqtt ab und zu ab ,
            Leider verbindet er sich nicht selbstständig neu .
            Kann man das irgendwie einbauen ?
            Ich starte die Instanz regelmäßig neu , ich hoffe das gibt keine neuen Probleme
            Gesendet von iPad mit Tapatalk Pro
