  4. Backitup Restore fehler
    5.1k
60 Beiträge 7 Kommentatoren 9.0k Aufrufe 5 Beobachtet
    #41
    @glasfaser
    am besten direkt
    iob install iobroker.zwave2@3.0.5 --debug
      @glasfaser
      am besten direkt
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      #42
      Cannot download
      steht im Log
      aber --debug kann auch nicht schaden
      E 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        Cannot download
        steht im Log
        Esmax666
        #43
        @glasfaser hat funktionniert:
        ich glaube da ist jetzt alles installiert :)
        esmax@ubuntu:/opt/iobroker$ iob install iobroker.zwave2@3.0.5 --debug
        NPM version: 9.6.7
        npm install iobroker.zwave2@3.0.5 --unsafe-perm --prefix "/opt/iobroker" (System call)
        added 126 packages in 32s
        133 packages are looking for funding
          run `npm fund` for details
        host.ubuntu install adapter zwave2@3.0.5
        upload [18] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/zwave2.svg zwave2.svg image/svg+xml
        upload [17] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/tab_m.html tab_m.html text/html
        upload [16] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/style.css style.css text/css
        upload [15] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/script/d3.min.js script/d3.min.js application/javascript
        upload [14] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/log_window.html log_window.html text/html
        upload [13] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/index_m.html index_m.html text/html
        upload [12] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js.map build/tab.js.map application/json
        upload [11] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js build/tab.js application/javascript
        upload [10] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js.map build/log.js.map application/json
        upload [9] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js build/log.js application/javascript
        upload [8] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js.map build/index.js.map application/json
        upload [7] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js build/index.js application/javascript
        upload [6] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-O2LXFUUG.js.map build/chunk-O2LXFUUG.js.map application/json
        upload [5] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-O2LXFUUG.js build/chunk-O2LXFUUG.js application/javascript
        upload [4] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-JKKDWOF2.js.map build/chunk-JKKDWOF2.js.map application/json
        upload [3] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-JKKDWOF2.js build/chunk-JKKDWOF2.js application/javascript
        upload [2] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-6B3WJWGE.js.map build/chunk-6B3WJWGE.js.map application/json
        upload [1] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-6B3WJWGE.js build/chunk-6B3WJWGE.js application/javascript
        upload [0] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/.eslintrc.js .eslintrc.js application/javascript
        host.ubuntu object system.adapter.zwave2 created/updated
        Update "system.adapter.zwave2.0"
        • GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          #44
          @esmax666 sagte in Backitup Restore fehler:
          dann zeige mal
          iob diag
          in der Full Version
            dann zeige mal
            iob diag
            in der Full Version
            Esmax666
            #45
            @glasfaser said in Backitup Restore fehler:
            iob diag
            Copy text starting here:
            ======== Start marking the full check here =========
            Skript v.2023-06-20
            *** BASE SYSTEM ***
             Static hostname: ubuntu
                   Icon name: computer
                  Machine ID: 965a81734c8d402ab05ca26017c6e6a9
                     Boot ID: a39af5905d2248f68505f9914e186102
            Operating System: Ubuntu 23.04
                      Kernel: Linux 6.2.0-1004-raspi
                Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.4
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : arm64
            Systemuptime and Load:
             21:22:07 up  3:53,  2 users,  load average: 0.41, 0.34, 0.24
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            Other values than 0x0 hint to temperature/voltage problems
            temp=52.1'C
            volt=0.8820V
            The systems needs to be REBOOTED!
            *** Time and Time Zones ***
                           Local time: Wed 2023-09-27 21:22:07 CEST
                       Universal time: Wed 2023-09-27 19:22:07 UTC
                             RTC time: n/a
                            Time zone: Europe/Paris (CEST, +0200)
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            esmax
            /home/esmax
            esmax adm dialout cdrom sudo audio video plugdev games users input render netdev gpio spi i2c iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            8.2G        1.4G        1.7G        3.3M        5.4G        6.8G
            Swap:             0B          0B          0B
            Total:          8.2G        1.4G        1.7G
                     7809 M total memory
                     1290 M used memory
                     1197 M active memory
                     4363 M inactive memory
                     1647 M free memory
                      195 M buffer memory
                     4992 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            Raspberry only:
            oom events: 0
            lifetime oom required: 0 Mbytes
            total time in oom handler: 0 ms
            max time spent in oom handler: 0 ms
            *** FILESYSTEM ***
            Filesystem     Type   Size  Used Avail Use% Mounted on
            tmpfs          tmpfs  781M  3.2M  778M   1% /run
            /dev/mmcblk0p2 ext4    59G  5.2G   51G  10% /
            tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
            tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
            /dev/mmcblk0p1 vfat   253M  151M  102M  60% /boot/firmware
            tmpfs          tmpfs  781M  4.0K  781M   1% /run/user/1000
            [Wed Sep 27 17:28:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 dwc_otg.lpm_enable=0 console=tty1 root=LABEL=writable rootfstype=ext4 rootwait fixrtc quiet splash
            [Wed Sep 27 17:28:35 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
            [Wed Sep 27 17:28:35 2023] EXT4-fs (mmcblk0p2): mounted filesystem 25a83575-fd50-4dcc-85e0-e3a81c621aa2 with ordered data mode. Quota mode: none.
            [Wed Sep 27 17:28:37 2023] EXT4-fs (mmcblk0p2): re-mounted 25a83575-fd50-4dcc-85e0-e3a81c621aa2. Quota mode: none.
            [Wed Sep 27 17:28:47 2023] EXT4-fs (mmcblk0p2): resizing filesystem from 979920 to 15526139 blocks
            [Wed Sep 27 17:28:48 2023] EXT4-fs (mmcblk0p2): resized filesystem to 15526139
            Show mounted filesystems (real ones only):
            TARGET              SOURCE         FSTYPE   OPTIONS
            /                   /dev/mmcblk0p2 ext4     rw,relatime,discard,errors=remount-ro,commit=30
            |-/snap/core22/611  /dev/loop1     squashfs ro,nodev,relatime,errors=continue,threads=single
            |-/snap/lxd/24646   /dev/loop0     squashfs ro,nodev,relatime,errors=continue,threads=single
            |-/snap/snapd/18600 /dev/loop2     squashfs ro,nodev,relatime,errors=continue,threads=single
            |-/boot/firmware    /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            |-/snap/lxd/25755   /dev/loop4     squashfs ro,nodev,relatime,errors=continue,threads=single
            `-/snap/core22/867  /dev/loop3     squashfs ro,nodev,relatime,errors=continue,threads=single
            /var:
            924M    /var/
            677M    /var/lib
            505M    /var/lib/snapd
            504M    /var/lib/snapd/snaps
            220M    /var/cache
            Archived and active journals take up 25.9M in the file system.
            /opt/iobroker/backups:
            4.5M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            110M    /opt/iobroker/iobroker-data/
            83M     /opt/iobroker/iobroker-data/files
            27M     /opt/iobroker/iobroker-data/files/javascript.admin
            15M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
            8.0M    /opt/iobroker/iobroker-data/objects.json.bak
            4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
            4.4M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/2.934fa7ad.chunk.js.map
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.17.1
            /usr/bin/node           v18.17.1
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Installed: 18.17.1-deb-1nodesource1
              Candidate: 18.17.1-deb-1nodesource1
              Version table:
             *** 18.17.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x lunar/main arm64 Packages
                    100 /var/lib/dpkg/status
                 18.13.0+dfsg1-1ubuntu2 500
                    500 http://ports.ubuntu.com/ubuntu-ports lunar/universe arm64 Packages
            No problems detected
            npm ERR! code ELSPROBLEMS
            npm ERR! extraneous: @abandonware/bluetooth-hci-socket@0.5.3-10 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
            npm ERR! extraneous: usb@1.9.2 /opt/iobroker/node_modules/usb
            npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/debug
            npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ms
            npm ERR! invalid: @types/node@12.20.55 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
            npm ERR! extraneous: node-addon-api@4.3.0 /opt/iobroker/node_modules/usb/node_modules/node-addon-api
            npm ERR! A complete log of this run can be found in: /home/esmax/.npm/_logs/2023-09-27T19_22_14_366Z-debug-0.log
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: file
            States  type: file
            No configuration change needed.
            Multihost discovery server: disabled
            Discovery authentication:   enabled
            Persistent activation:      disabled
            Objects:                    file on 127.0.0.1
            States:                     file on 127.0.0.1
            Core adapters versions
            js-controller:  3.3.22
            admin:          5.2.1
            javascript:     5.2.13
            Adapters from github:   0
            Adapter State
            + system.adapter.admin.0                  : admin                 : ubuntu                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.alexa2.0                 : alexa2                : ubuntu                                   - disabled
            + system.adapter.backitup.0               : backitup              : ubuntu                                   -  enabled
              system.adapter.cloud.0                  : cloud                 : ubuntu                                   - disabled
              system.adapter.discovery.0              : discovery             : ubuntu                                   - disabled
              system.adapter.flot.0                   : flot                  : ubuntu                                   - disabled
            + system.adapter.heatingcontrol.0         : heatingcontrol        : ubuntu                                   -  enabled
            + system.adapter.history.0                : history               : ubuntu                                   -  enabled
              system.adapter.ical.0                   : ical                  : ubuntu                                   -  enabled
              system.adapter.info.0                   : info                  : ubuntu                                   - disabled
              system.adapter.iot.0                    : iot                   : ubuntu                                   - disabled
            + system.adapter.javascript.0             : javascript            : ubuntu                                   -  enabled
              system.adapter.linkeddevices.0          : linkeddevices         : ubuntu                                   - disabled
              system.adapter.mobile.0                 : mobile                : ubuntu                                   - disabled
              system.adapter.radar2.0                 : radar2                : ubuntu                                   - disabled
              system.adapter.rpi2.0                   : rpi2                  : ubuntu                                   - disabled
            + system.adapter.shuttercontrol.0         : shuttercontrol        : ubuntu                                   -  enabled
              system.adapter.socketio.0               : socketio              : ubuntu                                   - disabled, port: 8084, bind: 0.0.0.0, run as: admin
              system.adapter.telegram.0               : telegram              : ubuntu                                   - disabled, port: 8443, bind: 0.0.0.0
              system.adapter.text2command.0           : text2command          : ubuntu                                   - disabled
              system.adapter.tr-064.0                 : tr-064                : ubuntu                                   - disabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : ubuntu                                   - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ubuntu                                   - disabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ubuntu                                   - disabled
              system.adapter.vis-metro.0              : vis-metro             : ubuntu                                   - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : ubuntu                                   - disabled
              system.adapter.vis.0                    : vis                   : ubuntu                                   - disabled
            + system.adapter.web.0                    : web                   : ubuntu                                   -  enabled, port: 443, bind: 0.0.0.0, run as: admin
            + system.adapter.zwave2.0                 : zwave2                : ubuntu                                   -  enabled
            + instance is alive
            ioBroker-Repositories
            stable      : http://download.iobroker.net/sources-dist.json
            beta        : http://download.iobroker.net/sources-dist-latest.json
            Active repo: stable
            Installed ioBroker-Instances
            Used repository: stable
            hash unchanged, use cached sources
            update done
            Adapter    "admin"         : 6.10.1   , installed 5.2.1 [Updateable]
            Adapter    "alexa2"        : 3.25.2   , installed 3.9.3 [Updateable]
            Adapter    "backitup"      : 2.8.1    , installed 2.2.2 [Updateable]
            Adapter    "cloud"         : 4.4.1    , installed 4.1.0 [Updateable]
            Adapter    "discovery"     : 3.1.0    , installed 3.1.0
            Adapter    "flot"          : 1.12.0   , installed 1.10.6 [Updateable]
            Adapter    "heatingcontrol": 2.11.1   , installed 2.7.2 [Updateable]
            Adapter    "history"       : 2.2.6    , installed 1.9.14 [Updateable]
            Adapter    "ical"          : 1.13.3   , installed 1.11.4 [Updateable]
            Adapter    "info"          : 1.9.26   , installed 1.9.8 [Updateable]
            Adapter    "iot"           : 1.14.5   , installed 1.8.22 [Updateable]
            Adapter    "javascript"    : 7.1.4    , installed 5.2.13 [Updateable]
            Controller "js-controller" : 5.0.12   , installed 3.3.22 [Updateable]
            Adapter    "linkeddevices" : 1.5.5    , installed 1.4.3 [Updateable]
            Adapter    "mobile"        : 1.0.1    , installed 1.0.1
            Adapter    "radar2"        : 2.0.7    , installed 2.0.3 [Updateable]
            Adapter    "rpi2"          : 1.3.2    , installed 1.3.1 [Updateable]
            Adapter    "shuttercontrol": 1.6.2    , installed 1.2.1 [Updateable]
            Adapter    "simple-api"    : 2.7.2    , installed 2.7.2
            Adapter    "socketio"      : 6.5.5    , installed 3.1.4 [Updateable]
            Adapter    "telegram"      : 1.16.0   , installed 1.10.0 [Updateable]
            Adapter    "text2command"  : 3.0.2    , installed 2.1.1 [Updateable]
            Adapter    "tr-064"        : 4.2.18   , installed 4.2.14 [Updateable]
            Adapter    "vis"           : 1.4.16   , installed 1.4.5 [Updateable]
            Adapter    "vis-colorpicker": 2.0.3   , installed 1.2.0 [Updateable]
            Adapter    "vis-hqwidgets" : 1.4.0    , installed 1.1.7 [Updateable]
            Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
            Adapter    "vis-metro"     : 1.2.0    , installed 1.1.2 [Updateable]
            Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
            Adapter    "web"           : 6.1.2    , installed 3.4.9 [Updateable]
            Adapter    "zwave2"        : 3.0.5    , installed 3.0.5
            Objects and States
            Objects:        1829
            States:         3260
            Hit:1 http://ports.ubuntu.com/ubuntu-ports lunar InRelease
            Hit:2 http://ports.ubuntu.com/ubuntu-ports lunar-updates InRelease
            Hit:3 http://ports.ubuntu.com/ubuntu-ports lunar-backports InRelease
            Hit:4 http://ports.ubuntu.com/ubuntu-ports lunar-security InRelease
            Hit:5 https://deb.nodesource.com/node_18.x lunar InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          78134      1/systemd
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        37558      13668/systemd-resol
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       86098      46034/iobroker.js-c
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       86091      46034/iobroker.js-c
            tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        37560      13668/systemd-resol
            tcp6       0      0 :::22                   :::*                    LISTEN      0          39954      1/systemd
            tcp6       0      0 :::111                  :::*                    LISTEN      0          78136      1/systemd
            tcp6       0      0 :::443                  :::*                    LISTEN      1001       90857      49322/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       84702      46059/io.admin.0
            udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        37559      13668/systemd-resol
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        37557      13668/systemd-resol
            udp        0      0 192.168.178.54:68       0.0.0.0:*                           998        52189      37786/systemd-netwo
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          76543      1/systemd
            udp6       0      0 :::111                  :::*                                0          76545      1/systemd
            udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                998        52209      37786/systemd-netwo
            2023-09-27 21:07:59.781  - info: host.ubuntu instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
            2023-09-27 21:08:09.427  - info: host.ubuntu "system.adapter.ical.0" disabled
            2023-09-27 21:08:09.428  - info: host.ubuntu stopInstance system.adapter.ical.0 (force=false, process=false)
            2023-09-27 21:08:09.430  - info: host.ubuntu stopInstance canceled schedule system.adapter.ical.0
            2023-09-27 21:08:14.720  - info: host.ubuntu "system.adapter.ical.0" enabled
            2023-09-27 21:08:14.723  - info: host.ubuntu stopInstance system.adapter.ical.0 (force=false, process=false)
            2023-09-27 21:08:17.803  - info: host.ubuntu instance scheduled system.adapter.ical.0 0,30 * * * *
            2023-09-27 21:08:17.841  - info: host.ubuntu instance system.adapter.ical.0 started with pid 49431
            2023-09-27 21:08:19.974  - info: ical.0 (49431) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            2023-09-27 21:08:19.991  - info: ical.0 (49431) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 3.3.22
            2023-09-27 21:08:20.611  - info: ical.0 (49431) processing URL: calendar1 https://63ea0ab88b/basic.ics
            2023-09-27 21:08:25.685  - info: ical.0 (49431) Terminated (NO_ERROR): Without reason
            2023-09-27 21:08:26.285  - info: host.ubuntu instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
            2023-09-27 21:10:00.025  - debug: shuttercontrol.0 (49337) calculate astrodata ...
            2023-09-27 21:10:00.026  - debug: shuttercontrol.0 (49337) Sun Azimut: 293.5°
            2023-09-27 21:10:00.027  - debug: shuttercontrol.0 (49337) Sun Elevation: -20.7°
            2023-09-27 21:15:00.023  - debug: shuttercontrol.0 (49337) calculate astrodata ...
            2023-09-27 21:15:00.024  - debug: shuttercontrol.0 (49337) Sun Azimut: 294.5°
            2023-09-27 21:15:00.024  - debug: shuttercontrol.0 (49337) Sun Elevation: -21.5°
            2023-09-27 21:17:03.503  - debug: zwave2.0 (49299) Node 34: value updated: value_electric_kwh_consumed => 1.02
            2023-09-27 21:20:00.024  - debug: shuttercontrol.0 (49337) calculate astrodata ...
            2023-09-27 21:20:00.024  - debug: shuttercontrol.0 (49337) Sun Azimut: 295.6°
            2023-09-27 21:20:00.025  - debug: shuttercontrol.0 (49337) Sun Elevation: -22.2°
            2023-09-27 21:21:53.141  - debug: zwave2.0 (49299) Node 5: metadata updated: airTemperature
            2023-09-27 21:21:53.143  - debug: zwave2.0 (49299) Node 5: value updated: airTemperature => 17.79
            iob diag has finished.
            Press any key for a summary
                                 v.2023-06-20
                   Icon name: computer
                Architecture: arm64
            Installation:           native
            Kernel:                 aarch64
            Userland:               arm64
            Timezone:               Europe/Paris (CEST, +0200)
            User-ID:                1000
            X-Server:               false
            Pending OS-Updates:     0
            Pending iob updates:    26
            Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
            Recommended versions are nodejs 18.x.y and npm 9.x.y
            MEMORY:
            Mem:            8.2G        1.6G        1.5G        3.3M        5.4G        6.6G
            Swap:             0B          0B          0B
            Total:          8.2G        1.6G        1.5G
            Active iob-Instances:   9
            Active repo: stable
            ioBroker Core:          js-controller           3.3.22
                                    admin                   5.2.1
            Objects type: file
            States  type: file
            Objects:                1829
            States:                 3261
            Size of iob-Database:
            3.7M    /opt/iobroker/iobroker-data/objects.jsonl
            832K    /opt/iobroker/iobroker-data/states.json.bak
            44K     /opt/iobroker/iobroker-data/states.jsonl
            === Mark text until here for copying ===
            GlasfaserG Thomas BraunT simatecS 3 Antworten Letzte Antwort
            • E Esmax666
              iob diag
              Skript v.2023-06-20
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              temp=52.1'C
              volt=0.8820V
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              esmax
              /home/esmax
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:             0B          0B          0B
                       7809 M total memory
                       1290 M used memory
                       1647 M free memory
                        195 M buffer memory
                       4992 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              924M    /var/
              677M    /var/lib
              505M    /var/lib/snapd
              220M    /var/cache
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              nodejs:
                Version table:
              ioBroker Status
              Objects type: file
              States  type: file
              admin:          5.2.1
              javascript:     5.2.13
              Adapter State
              + instance is alive
              Active repo: stable
              update done
              Objects and States
              Objects:        1829
              States:         3260
              Pending Updates: 0
                                   v.2023-06-20
                     Icon name: computer
                  Architecture: arm64
              Kernel:                 aarch64
              Userland:               arm64
              User-ID:                1000
              X-Server:               false
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
              MEMORY:
              Swap:             0B          0B          0B
              Active repo: stable
                                      admin                   5.2.1
              Objects type: file
              States  type: file
              Objects:                1829
              States:                 3261
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              #46
              @esmax666
              sieht sehr gut aus .. hast alles gemacht wie beschrieben !
              jetzt weiter machen , nach der Liste !
              EDIT
              aber fange mit dem
              an !
              • E Esmax666
                iob diag
                Skript v.2023-06-20
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                temp=52.1'C
                volt=0.8820V
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                esmax
                /home/esmax
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:             0B          0B          0B
                         7809 M total memory
                         1290 M used memory
                         1647 M free memory
                          195 M buffer memory
                         4992 M swap cache
                            0 M total swap
                            0 M used swap
                            0 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                924M    /var/
                677M    /var/lib
                505M    /var/lib/snapd
                220M    /var/cache
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: file
                States  type: file
                admin:          5.2.1
                javascript:     5.2.13
                Adapter State
                + instance is alive
                Active repo: stable
                update done
                Objects and States
                Objects:        1829
                States:         3260
                Pending Updates: 0
                                     v.2023-06-20
                       Icon name: computer
                    Architecture: arm64
                Kernel:                 aarch64
                Userland:               arm64
                User-ID:                1000
                X-Server:               false
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                MEMORY:
                Swap:             0B          0B          0B
                Active repo: stable
                                        admin                   5.2.1
                Objects type: file
                States  type: file
                Objects:                1829
                States:                 3261
                #47
                Meine Gedanken zu dem System, kannst du umsetzen wenn der ioBroker wieder rennt.
                Ungünstige Wahl für einen längeren Betrieb. Diese Interimsversionen von ubuntu leben nur 9 Monate. Besser ein Debian/Raspberry OS auf die Kiste werfen.
                Keine Deko, das sollte man tun.
                Du sitzt in Frankreich?
                Du hast das System nicht sauber heruntergefahren. IMMER tun.
                Nicht falsch, aber nicht aktuell. Stell auf das neue nodesource-Repo um.
                Installier iobroker.javascript nochmal drüber.
                • E Esmax666
                  iob diag
                  Skript v.2023-06-20
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  temp=52.1'C
                  volt=0.8820V
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  esmax
                  /home/esmax
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:             0B          0B          0B
                           7809 M total memory
                           1290 M used memory
                           1647 M free memory
                            195 M buffer memory
                           4992 M swap cache
                              0 M total swap
                              0 M used swap
                              0 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  924M    /var/
                  677M    /var/lib
                  505M    /var/lib/snapd
                  220M    /var/cache
                  /usr/bin/npm            9.6.7
                  /usr/bin/npx            9.6.7
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: file
                  States  type: file
                  admin:          5.2.1
                  javascript:     5.2.13
                  Adapter State
                  + instance is alive
                  Active repo: stable
                  update done
                  Objects and States
                  Objects:        1829
                  States:         3260
                  Pending Updates: 0
                                       v.2023-06-20
                         Icon name: computer
                      Architecture: arm64
                  Kernel:                 aarch64
                  Userland:               arm64
                  User-ID:                1000
                  X-Server:               false
                                          /usr/bin/npm            9.6.7
                                          /usr/bin/npx            9.6.7
                  MEMORY:
                  Swap:             0B          0B          0B
                  Active repo: stable
                                          admin                   5.2.1
                  Objects type: file
                  States  type: file
                  Objects:                1829
                  States:                 3261
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #48
                  @esmax666 wenn alles fertig installiert ist und läuft, dann mache ein Upgrade aller Adapter und vorher js-controller updaten
                  iobroker stop
                  iobroker update
                  iobroker upgrade self
                  iobroker upgrade -y
                  iobroker fix
                  iobroker start
                  • Besuche meine Github Seite
                  • HowTo Restore ioBroker
                  • simatecS Offline
                    simatecS Offline
                    simatec
                    schrieb am zuletzt editiert von simatec
                    #49
                    @Esmax666
                    Danach richte Backitup ein, damit du jede Nacht ein Backup machst.
                    Am besten auf ein NAS oder wenn du dass nicht hast, nutze einen Clouddienst, den Backitup unterstützt.
                    Im Anschluss noch einen Kalendereintrag, der sich jeden Monat wiederholt, in dem du dein System auf Stand bringst.
                    Immer das System und den iobroker aktuell halten
                      @esmax666
                      EDIT
                      aber fange mit dem
                      an !
                      Esmax666
                      #50
                      @glasfaser
                      also jscontroler ist jetzt aktualisiert 5.0.12
                      ich kann jetzt weiter weitermachen oder ? weboberfläche geht aber nicht mehr
                      Skript v.2023-06-20
                      *** BASE SYSTEM ***
                             Icon name: computer
                               Boot ID: 0c59d3c9640b486fadab37c9e124b76a
                                Kernel: Linux 6.2.0-1013-raspi
                          Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                       23:16:45 up 8 min,  2 users,  load average: 3.57, 1.61, 0.67
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x0
                      temp=68.6'C
                      volt=0.9260V
                                     Local time: Wed 2023-09-27 23:16:46 CEST
                                 Universal time: Wed 2023-09-27 21:16:46 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      esmax
                      /home/esmax
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            8.2G        1.4G        6.4G        3.2M        602M        6.8G
                      Swap:             0B          0B          0B
                      Total:          8.2G        1.4G        6.4G
                               7809 M total memory
                               1352 M used memory
                                283 M active memory
                               1153 M inactive memory
                               6148 M free memory
                                 59 M buffer memory
                                515 M swap cache
                                  0 M total swap
                                  0 M used swap
                                  0 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      tmpfs          tmpfs  781M  3.1M  778M   1% /run
                      [Wed Sep 27 23:08:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 dwc_otg.lpm_enable=0 console=tty1 root=LABEL=writable rootfstype=ext4 rootwait fixrtc quiet splash
                      [Wed Sep 27 23:08:29 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                      [Wed Sep 27 23:08:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem 25a83575-fd50-4dcc-85e0-e3a81c621aa2 with ordered data mode. Quota mode: none.
                      [Wed Sep 27 23:08:31 2023] EXT4-fs (mmcblk0p2): re-mounted 25a83575-fd50-4dcc-85e0-e3a81c621aa2. Quota mode: none.
                      |-/snap/core22/611  /dev/loop0     squashfs ro,nodev,relatime,errors=continue,threads=single
                      |-/snap/core22/867  /dev/loop1     squashfs ro,nodev,relatime,errors=continue,threads=single
                      |-/snap/lxd/24646   /dev/loop2     squashfs ro,nodev,relatime,errors=continue,threads=single
                      |-/snap/lxd/25755   /dev/loop3     squashfs ro,nodev,relatime,errors=continue,threads=single
                      |-/snap/snapd/18600 /dev/loop4     squashfs ro,nodev,relatime,errors=continue,threads=single
                      `-/boot/firmware    /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      943M    /var/
                      677M    /var/lib
                      505M    /var/lib/snapd
                      222M    /var/cache
                      Archived and active journals take up 43.0M in the file system.
                      119M    /opt/iobroker/iobroker-data/
                      8.1M    /opt/iobroker/iobroker-data/objects.jsonl
                      8.0M    /opt/iobroker/iobroker-data/objects.json.migrated
                      8.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                      /usr/bin/npm            9.6.7
                      /usr/bin/npx            9.6.7
                      nodejs:
                        Version table:
                      npm ERR! A complete log of this run can be found in: /home/esmax/.npm/_logs/2023-09-27T21_17_01_730Z-debug-0.log
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                    jsonl on 127.0.0.1
                      States:                     jsonl on 127.0.0.1
                      js-controller:  5.0.12
                      admin:          5.2.1
                      javascript:     5.2.13
                      Adapter State
                      + instance is alive
                      Active repo(s): stable
                      Adapter    "admin"        : 6.10.1   , installed 5.2.1  [Updatable]
                      Adapter    "alexa2"       : 3.25.2   , installed 3.9.3  [Updatable]
                      Adapter    "backitup"     : 2.8.1    , installed 2.2.2  [Updatable]
                      Adapter    "cloud"        : 4.4.1    , installed 4.1.0  [Updatable]
                      Adapter    "flot"         : 1.12.0   , installed 1.10.6 [Updatable]
                      Adapter    "heatingcontrol": 2.11.1  , installed 2.7.2  [Updatable]
                      Adapter    "history"      : 2.2.6    , installed 1.9.14 [Updatable]
                      Adapter    "ical"         : 1.13.3   , installed 1.11.4 [Updatable]
                      Adapter    "info"         : 1.9.26   , installed 1.9.8  [Updatable]
                      Adapter    "iot"          : 1.14.5   , installed 1.8.22 [Updatable]
                      Adapter    "javascript"   : 7.1.4    , installed 5.2.13 [Updatable]
                      Controller "js-controller": 5.0.12   , installed 5.0.12
                      Adapter    "linkeddevices": 1.5.5    , installed 1.4.3  [Updatable]
                      Adapter    "radar2"       : 2.0.7    , installed 2.0.3  [Updatable]
                      Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
                      Adapter    "shuttercontrol": 1.6.2   , installed 1.2.1  [Updatable]
                      Adapter    "socketio"     : 6.5.5    , installed 3.1.4  [Updatable]
                      Adapter    "telegram"     : 1.16.0   , installed 1.10.0 [Updatable]
                      Adapter    "text2command" : 3.0.2    , installed 2.1.1  [Updatable]
                      Adapter    "tr-064"       : 4.2.18   , installed 4.2.14 [Updatable]
                      Adapter    "vis"          : 1.4.16   , installed 1.4.5  [Updatable]
                      Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
                      Adapter    "vis-hqwidgets": 1.4.0    , installed 1.1.7  [Updatable]
                      Adapter    "vis-metro"    : 1.2.0    , installed 1.1.2  [Updatable]
                      Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
                      Adapter    "web"          : 6.1.2    , installed 3.4.9  [Updatable]
                      Objects and States
                      Objects:        4592
                      States:         3264
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17467      1/init
                      tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        22635      555/systemd-resolve
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       26995      2351/iobroker.js-co
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27002      2351/iobroker.js-co
                      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        22633      555/systemd-resolve
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          13962      1/init
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          23620      1/init
                      udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        22634      555/systemd-resolve
                      udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        22632      555/systemd-resolve
                      udp        0      0 192.168.178.54:68       0.0.0.0:*                           998        22809      812/systemd-network
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17468      1/init
                      udp6       0      0 :::111                  :::*                                0          16876      1/init
                      udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                998        22817      812/systemd-network
                      2023-09-27 23:17:33.462  - info: zwave2.0 (2938) Node 2: ready to use
                      2023-09-27 23:17:33.697  - info: zwave2.0 (2938) Node 2 is alive
                      2023-09-27 23:17:36.082  - info: zwave2.0 (2938) Node 3: ready to use
                      2023-09-27 23:17:36.179  - info: vis.0 (3029) Uploaded. 0
                      2023-09-27 23:17:36.436  - info: zwave2.0 (2938) Node 4: ready to use
                      2023-09-27 23:17:36.695  - info: vis.0 (3029) Terminated (NO_ERROR): Without reason
                      2023-09-27 23:17:37.940  - info: zwave2.0 (2938) Node 5: ready to use
                      2023-09-27 23:17:38.180  - info: zwave2.0 (2938) Node 5 is alive
                      2023-09-27 23:17:40.108  - info: zwave2.0 (2938) Node 7: ready to use
                      2023-09-27 23:17:40.256  - info: zwave2.0 (2938) Node 8: ready to use
                      2023-09-27 23:17:40.402  - info: zwave2.0 (2938) Node 9: ready to use
                      2023-09-27 23:17:41.185  - info: zwave2.0 (2938) Node 22: ready to use
                      2023-09-27 23:17:41.886  - info: zwave2.0 (2938) Node 25: ready to use
                      2023-09-27 23:17:59.738  - info: zwave2.0 (2938) Node 31: ready to use
                      2023-09-27 23:17:59.860  - info: zwave2.0 (2938) Node 31 is alive
                      2023-09-27 23:17:59.876  - info: zwave2.0 (2938) Node 32: ready to use
                      2023-09-27 23:17:59.988  - info: zwave2.0 (2938) Node 32 is alive
                      2023-09-27 23:18:00.067  - info: zwave2.0 (2938) Node 33: ready to use
                      2023-09-27 23:18:00.121  - info: zwave2.0 (2938) Node 34: ready to use
                      2023-09-27 23:18:00.169  - info: zwave2.0 (2938) Node 33 is alive
                      2023-09-27 23:18:00.183  - info: zwave2.0 (2938) Node 34 is alive
                      2023-09-27 23:18:00.390  - info: zwave2.0 (2938) Node 35: ready to use
                      2023-09-27 23:18:00.448  - info: zwave2.0 (2938) Node 35 is alive
                      2023-09-27 23:18:00.478  - info: zwave2.0 (2938) Node 38: ready to use
                      2023-09-27 23:18:00.526  - info: zwave2.0 (2938) Node 38 is alive
                      • E Esmax666
                        @glasfaser
                        Skript v.2023-06-20
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x0
                        temp=68.6'C
                        volt=0.9260V
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        esmax
                        /home/esmax
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:             0B          0B          0B
                                 7809 M total memory
                                 1352 M used memory
                                  283 M active memory
                                 6148 M free memory
                                   59 M buffer memory
                                  515 M swap cache
                                    0 M total swap
                                    0 M used swap
                                    0 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        943M    /var/
                        677M    /var/lib
                        505M    /var/lib/snapd
                        222M    /var/cache
                        /usr/bin/npm            9.6.7
                        /usr/bin/npx            9.6.7
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          5.2.1
                        javascript:     5.2.13
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        4592
                        States:         3264
                        Pending Updates: 0
                        #51
                        @esmax666
                        iob update
                        iob upgrade all -y
                        iob start admin
                          Esmax666
                          #52
                          @thomas-braun said in Backitup Restore fehler:
                          ich wollte ertmals probieren wie es früher war um weniger Problem zu bekommen :D
                          ich auch gemacht
                          JA
                          Seltsam ich habe nur gerade heute ubuntu / iobroker installiert ohne das Gerät auszuschalten
                          wie soll ich das machen ?
                          • E Esmax666
                            ich auch gemacht
                            JA
                            Esmax666
                            schrieb am zuletzt editiert von Esmax666
                            #53
                            update ist done,
                            ich glaube da läuft alles wieder richtig, dann mache schnell noch ein backup :D
                            Also das wäre noch eventuel zu machen ? Node.js: v18.17.1(18.18.0)
                            NPM: 9.6.7(9.8.1)
                            aber wie ?
                            Skript v.2023-06-20
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                             23:43:46 up 35 min,  2 users,  load average: 0.05, 0.65, 1.10
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            temp=53.0'C
                            volt=0.8600V
                                           Local time: Wed 2023-09-27 23:43:46 CEST
                                       Universal time: Wed 2023-09-27 21:43:46 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            esmax
                            /home/esmax
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            8.2G        1.3G        5.5G        3.3M        1.8G        6.9G
                            Swap:             0B          0B          0B
                            Total:          8.2G        1.3G        5.5G
                                     7809 M total memory
                                     1195 M used memory
                                      476 M active memory
                                     1755 M inactive memory
                                     5249 M free memory
                                       97 M buffer memory
                                     1576 M swap cache
                                        0 M total swap
                                        0 M used swap
                                        0 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /dev/mmcblk0p2 ext4    59G  5.5G   51G  10% /
                            /var:
                            944M    /var/
                            677M    /var/lib
                            505M    /var/lib/snapd
                            222M    /var/cache
                            7.6M    /opt/iobroker/backups/
                            229M    /opt/iobroker/iobroker-data/
                            192M    /opt/iobroker/iobroker-data/files
                            52M     /opt/iobroker/iobroker-data/files/javascript.admin
                            34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                            33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                            19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                            18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                            8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
                            8.2M    /opt/iobroker/iobroker-data/objects.jsonl
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.10.1
                            javascript:     7.1.4
                            Adapter State
                            + instance is alive
                            Adapter    "admin"        : 6.10.1   , installed 6.10.1
                            Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                            Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                            Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                            Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                            Adapter    "history"      : 2.2.6    , installed 2.2.6
                            Adapter    "ical"         : 1.13.3   , installed 1.13.3
                            Adapter    "info"         : 1.9.26   , installed 1.9.26
                            Adapter    "iot"          : 1.14.5   , installed 1.14.5
                            Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                            Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                            Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                            Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
                            Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                            Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                            Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                            Adapter    "text2command" : 3.0.2    , installed 3.0.2
                            Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
                            Adapter    "vis"          : 1.4.16   , installed 1.4.16
                            Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
                            Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
                            Adapter    "web"          : 6.1.2    , installed 6.1.2
                            Adapter    "ws"           : 2.5.5    , installed 2.5.5
                            Objects and States
                            Objects:        4615
                            States:         3306
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       47592      9892/iobroker.js-co
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50371      9892/iobroker.js-co
                            tcp6       0      0 :::443                  :::*                    LISTEN      1001       47776      10028/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       47619      9910/io.admin.0
                            2023-09-27 23:38:35.483  - info: zwave2.0 (10049) Node 4: ready to use
                            2023-09-27 23:38:35.521  - info: zwave2.0 (10049) Node 4 is alive
                            2023-09-27 23:38:37.047  - info: zwave2.0 (10049) Node 5: ready to use
                            2023-09-27 23:38:37.108  - info: zwave2.0 (10049) Node 5 is alive
                            2023-09-27 23:38:38.332  - info: zwave2.0 (10049) Node 22: ready to use
                            2023-09-27 23:38:38.362  - info: zwave2.0 (10049) Node 22 is alive
                            2023-09-27 23:38:56.528  - info: admin.0 (9910) ==> Connected system.user.admin from ::ffff:192.168.178.39
                            2023-09-27 23:38:58.724  - info: zwave2.0 (10049) Node 31: ready to use
                            2023-09-27 23:38:58.754  - info: zwave2.0 (10049) Node 31 is alive
                            2023-09-27 23:38:58.817  - info: zwave2.0 (10049) Node 32: ready to use
                            2023-09-27 23:38:58.865  - info: zwave2.0 (10049) Node 33: ready to use
                            2023-09-27 23:38:58.936  - info: zwave2.0 (10049) Node 34: ready to use
                            2023-09-27 23:38:58.970  - info: zwave2.0 (10049) Node 32 is alive
                            2023-09-27 23:38:58.990  - info: zwave2.0 (10049) Node 33 is alive
                            2023-09-27 23:38:59.014  - info: zwave2.0 (10049) Node 34 is alive
                            2023-09-27 23:38:59.204  - info: zwave2.0 (10049) Node 35: ready to use
                            2023-09-27 23:38:59.263  - info: zwave2.0 (10049) Node 35 is alive
                            2023-09-27 23:38:59.292  - info: zwave2.0 (10049) Node 38: ready to use
                            2023-09-27 23:38:59.322  - info: zwave2.0 (10049) Node 38 is alive
                            2023-09-27 23:40:00.027  - debug: shuttercontrol.0 (10013) calculate astrodata ...
                            2023-09-27 23:40:00.028  - debug: shuttercontrol.0 (10013) Sun Azimut: 331.9°
                            2023-09-27 23:40:00.029  - debug: shuttercontrol.0 (10013) Sun Elevation: -38.6°
                            2023-09-27 23:42:25.827  - debug: zwave2.0 (10049) Node 3: metadata updated: airTemperature
                            2023-09-27 23:42:25.830  - debug: zwave2.0 (10049) Node 3: value updated: airTemperature => 19.37
                            2023-09-27 23:43:32.756  - debug: zwave2.0 (10049) Node 32: value updated: value_electric_kwh_consumed => 0.5
                            • E Esmax666
                              update ist done,
                              NPM: 9.6.7(9.8.1)
                              aber wie ?
                              Skript v.2023-06-20
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : arm64
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x0
                              temp=53.0'C
                              volt=0.8600V
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              esmax
                              /home/esmax
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:             0B          0B          0B
                                       7809 M total memory
                                       1195 M used memory
                                        476 M active memory
                                       5249 M free memory
                                         97 M buffer memory
                                       1576 M swap cache
                                          0 M total swap
                                          0 M used swap
                                          0 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              944M    /var/
                              677M    /var/lib
                              505M    /var/lib/snapd
                              222M    /var/cache
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.10.1
                              javascript:     7.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        4615
                              States:         3306
                              Pending Updates: 0
                              #54
                              Schon wieder. Ich vermute dann, das deine SD-Karte krümelig ist.
                              Wenn du ansonsten das System sauber handelst.
                              • E Esmax666
                                update ist done,
                                NPM: 9.6.7(9.8.1)
                                aber wie ?
                                Skript v.2023-06-20
                                *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : arm64
                                CPU threads: 4
                                Raspberry only:
                                throttled=0x0
                                temp=53.0'C
                                volt=0.8600V
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                esmax
                                /home/esmax
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:             0B          0B          0B
                                         7809 M total memory
                                         1195 M used memory
                                          476 M active memory
                                         5249 M free memory
                                           97 M buffer memory
                                         1576 M swap cache
                                            0 M total swap
                                            0 M used swap
                                            0 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /var:
                                944M    /var/
                                677M    /var/lib
                                505M    /var/lib/snapd
                                222M    /var/cache
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.10.1
                                javascript:     7.1.4
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        4615
                                States:         3306
                                Pending Updates: 0
                                #55
                                aber wie ?
                                Schau in meiner Signatur nach dem node-fix-Skript.
                                  Esmax666
                                  #56
                                  krümelig
                                  Sag das nicht lol , ich habe gerade die karte gekauft (SANDISK Elite Extreme)
                                  Thomas BraunT ? 2 Antworten Letzte Antwort
                                  • E Esmax666
                                    krümelig
                                    #57
                                    @esmax666
                                    Die Meldung mit den orphans ist jedenfalls nicht normal. Kommt wenn dem System abrupt der Strom genommen wird und/oder bei defektem Datenträger.
                                      @esmax666
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #58
                                      @thomas-braun sagte in Backitup Restore fehler:
                                      @Esmax666 Trenne niemals deinen PI einfach vom Strom. Ein OS muss immer sauber heruntergefahren werden.
                                      • E Esmax666
                                        krümelig
                                        #59
                                        Moin,
                                        Mal einfach beschrieben
                                        ein Speichermedium verträgt nur eine gewisse Anzahl an defekten Sektoren/Inodes, da es eine bestimmte Anzahl an Sektoren/Inodes vor dem Benutzen versteckt und somit die Defekten ersetzen kann. Neigt sich dieser Vorrat dem Ende, dann kann man das Speichermedium entsorgen.
                                        Je größer ein Speichermedium, desto mehr Sektoren/Inodes stehen zur Reparatur zur Verfügung.
                                        Fehler und ihre Folgen
                                        Aber was viel schlimmer ist, wenn Informationen, die gerade durch, sagen wir mal, der Kernel hat seine Information aus Inode 101, 102,103 geladen und Du killst den Rechner durch Stromlos machen, sodass plötzlich Inode 102 nicht mehr gültig ist, dann kommt es beim nächsten Booten zu einem Kernel Panik und der Rechner startet nicht mehr.
                                        Im besten Fall kann, bei geeignetem Dateisystem, etwas repariert werden, im schlechtesten Fall, totaler Datenverlust.
                                        VG
                                        Bernd
                                        • simatecS simatec
                                          Esmax666
                                          #60
                                          @simatec said in Backitup Restore fehler:
                                          das habe ich auch nicht gemacht ( bin 99% sicher , aber das spät)
