  4. Backitup Restore fehler
    5.1k
60 Beiträge 7 Kommentatoren 9.0k Aufrufe 5 Beobachtet
  • GlasfaserG Glasfaser
    Cannot download
    steht im Log
    aber --debug kann auch nicht schaden
    Esmax666
    @glasfaser hat funktionniert:
    ich glaube da ist jetzt alles installiert :)
    esmax@ubuntu:/opt/iobroker$ iob install iobroker.zwave2@3.0.5 --debug
    NPM version: 9.6.7
    npm install iobroker.zwave2@3.0.5 --unsafe-perm --prefix "/opt/iobroker" (System call)
    added 126 packages in 32s
    133 packages are looking for funding
      run `npm fund` for details
    host.ubuntu install adapter zwave2@3.0.5
    upload [18] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/zwave2.svg zwave2.svg image/svg+xml
    upload [17] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/tab_m.html tab_m.html text/html
    upload [16] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/style.css style.css text/css
    upload [15] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/script/d3.min.js script/d3.min.js application/javascript
    upload [14] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/log_window.html log_window.html text/html
    upload [13] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/index_m.html index_m.html text/html
    upload [12] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js.map build/tab.js.map application/json
    upload [11] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js build/tab.js application/javascript
    upload [10] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js.map build/log.js.map application/json
    upload [9] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js build/log.js application/javascript
    upload [8] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js.map build/index.js.map application/json
    upload [7] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js build/index.js application/javascript
    upload [6] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-O2LXFUUG.js.map build/chunk-O2LXFUUG.js.map application/json
    upload [5] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-O2LXFUUG.js build/chunk-O2LXFUUG.js application/javascript
    upload [4] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-JKKDWOF2.js.map build/chunk-JKKDWOF2.js.map application/json
    upload [3] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-JKKDWOF2.js build/chunk-JKKDWOF2.js application/javascript
    upload [2] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-6B3WJWGE.js.map build/chunk-6B3WJWGE.js.map application/json
    upload [1] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-6B3WJWGE.js build/chunk-6B3WJWGE.js application/javascript
    upload [0] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/.eslintrc.js .eslintrc.js application/javascript
    host.ubuntu object system.adapter.zwave2 created/updated
    Update "system.adapter.zwave2.0"
    • GlasfaserG Offline
      GlasfaserG Offline
      @esmax666 sagte in Backitup Restore fehler:
      dann zeige mal
      iob diag
      in der Full Version
      E 1 Antwort Letzte Antwort
        dann zeige mal
        iob diag
        in der Full Version
        Esmax666
        @glasfaser said in Backitup Restore fehler:
        iob diag
        Copy text starting here:
        Skript v.2023-06-20
        *** BASE SYSTEM ***
         Static hostname: ubuntu
               Icon name: computer
              Machine ID: 965a81734c8d402ab05ca26017c6e6a9
                 Boot ID: a39af5905d2248f68505f9914e186102
        Operating System: Ubuntu 23.04
                  Kernel: Linux 6.2.0-1004-raspi
            Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         21:22:07 up  3:53,  2 users,  load average: 0.41, 0.34, 0.24
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=52.1'C
        volt=0.8820V
        The systems needs to be REBOOTED!
        *** Time and Time Zones ***
                       Local time: Wed 2023-09-27 21:22:07 CEST
                   Universal time: Wed 2023-09-27 19:22:07 UTC
                         RTC time: n/a
                        Time zone: Europe/Paris (CEST, +0200)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        esmax
        /home/esmax
        esmax adm dialout cdrom sudo audio video plugdev games users input render netdev gpio spi i2c iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            8.2G        1.4G        1.7G        3.3M        5.4G        6.8G
        Swap:             0B          0B          0B
        Total:          8.2G        1.4G        1.7G
                 7809 M total memory
                 1290 M used memory
                 1197 M active memory
                 4363 M inactive memory
                 1647 M free memory
                  195 M buffer memory
                 4992 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        Filesystem     Type   Size  Used Avail Use% Mounted on
        tmpfs          tmpfs  781M  3.2M  778M   1% /run
        /dev/mmcblk0p2 ext4    59G  5.2G   51G  10% /
        tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
        /dev/mmcblk0p1 vfat   253M  151M  102M  60% /boot/firmware
        tmpfs          tmpfs  781M  4.0K  781M   1% /run/user/1000
        [Wed Sep 27 17:28:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 dwc_otg.lpm_enable=0 console=tty1 root=LABEL=writable rootfstype=ext4 rootwait fixrtc quiet splash
        [Wed Sep 27 17:28:35 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
        [Wed Sep 27 17:28:35 2023] EXT4-fs (mmcblk0p2): mounted filesystem 25a83575-fd50-4dcc-85e0-e3a81c621aa2 with ordered data mode. Quota mode: none.
        [Wed Sep 27 17:28:37 2023] EXT4-fs (mmcblk0p2): re-mounted 25a83575-fd50-4dcc-85e0-e3a81c621aa2. Quota mode: none.
        [Wed Sep 27 17:28:47 2023] EXT4-fs (mmcblk0p2): resizing filesystem from 979920 to 15526139 blocks
        [Wed Sep 27 17:28:48 2023] EXT4-fs (mmcblk0p2): resized filesystem to 15526139
        TARGET              SOURCE         FSTYPE   OPTIONS
        /                   /dev/mmcblk0p2 ext4     rw,relatime,discard,errors=remount-ro,commit=30
        |-/snap/core22/611  /dev/loop1     squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/lxd/24646   /dev/loop0     squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/snapd/18600 /dev/loop2     squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/boot/firmware    /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        |-/snap/lxd/25755   /dev/loop4     squashfs ro,nodev,relatime,errors=continue,threads=single
        `-/snap/core22/867  /dev/loop3     squashfs ro,nodev,relatime,errors=continue,threads=single
        /var:
        924M    /var/
        677M    /var/lib
        505M    /var/lib/snapd
        504M    /var/lib/snapd/snaps
        220M    /var/cache
        Archived and active journals take up 25.9M in the file system.
        /opt/iobroker/backups:
        4.5M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        110M    /opt/iobroker/iobroker-data/
        83M     /opt/iobroker/iobroker-data/files
        27M     /opt/iobroker/iobroker-data/files/javascript.admin
        15M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
        8.0M    /opt/iobroker/iobroker-data/objects.json.bak
        4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
        4.4M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/2.934fa7ad.chunk.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x lunar/main arm64 Packages
             18.13.0+dfsg1-1ubuntu2 500
                500 http://ports.ubuntu.com/ubuntu-ports lunar/universe arm64 Packages
        No problems detected
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @abandonware/bluetooth-hci-socket@0.5.3-10 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
        npm ERR! extraneous: usb@1.9.2 /opt/iobroker/node_modules/usb
        npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/debug
        npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/ms
        npm ERR! invalid: @types/node@12.20.55 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
        npm ERR! extraneous: node-addon-api@4.3.0 /opt/iobroker/node_modules/usb/node_modules/node-addon-api
        npm ERR! A complete log of this run can be found in: /home/esmax/.npm/_logs/2023-09-27T19_22_14_366Z-debug-0.log
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: file
        States  type: file
        No configuration change needed.
        Multihost discovery server: disabled
        Discovery authentication:   enabled
        Persistent activation:      disabled
        Objects:                    file on 127.0.0.1
        States:                     file on 127.0.0.1
        Core adapters versions
        js-controller:  3.3.22
        admin:          5.2.1
        javascript:     5.2.13
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : ubuntu                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                 : alexa2                : ubuntu                                   - disabled
        + system.adapter.backitup.0               : backitup              : ubuntu                                   -  enabled
          system.adapter.cloud.0                  : cloud                 : ubuntu                                   - disabled
          system.adapter.discovery.0              : discovery             : ubuntu                                   - disabled
          system.adapter.flot.0                   : flot                  : ubuntu                                   - disabled
        + system.adapter.heatingcontrol.0         : heatingcontrol        : ubuntu                                   -  enabled
        + system.adapter.history.0                : history               : ubuntu                                   -  enabled
          system.adapter.ical.0                   : ical                  : ubuntu                                   -  enabled
          system.adapter.info.0                   : info                  : ubuntu                                   - disabled
          system.adapter.iot.0                    : iot                   : ubuntu                                   - disabled
        + system.adapter.javascript.0             : javascript            : ubuntu                                   -  enabled
          system.adapter.linkeddevices.0          : linkeddevices         : ubuntu                                   - disabled
          system.adapter.mobile.0                 : mobile                : ubuntu                                   - disabled
          system.adapter.radar2.0                 : radar2                : ubuntu                                   - disabled
          system.adapter.rpi2.0                   : rpi2                  : ubuntu                                   - disabled
        + system.adapter.shuttercontrol.0         : shuttercontrol        : ubuntu                                   -  enabled
          system.adapter.socketio.0               : socketio              : ubuntu                                   - disabled, port: 8084, bind: 0.0.0.0, run as: admin
          system.adapter.telegram.0               : telegram              : ubuntu                                   - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.text2command.0           : text2command          : ubuntu                                   - disabled
          system.adapter.tr-064.0                 : tr-064                : ubuntu                                   - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : ubuntu                                   - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ubuntu                                   - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ubuntu                                   - disabled
          system.adapter.vis-metro.0              : vis-metro             : ubuntu                                   - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ubuntu                                   - disabled
          system.adapter.vis.0                    : vis                   : ubuntu                                   - disabled
        + system.adapter.web.0                    : web                   : ubuntu                                   -  enabled, port: 443, bind: 0.0.0.0, run as: admin
        + system.adapter.zwave2.0                 : zwave2                : ubuntu                                   -  enabled
        + instance is alive
        ioBroker-Repositories
        stable      : http://download.iobroker.net/sources-dist.json
        beta        : http://download.iobroker.net/sources-dist-latest.json
        Active repo: stable
        Installed ioBroker-Instances
        Used repository: stable
        hash unchanged, use cached sources
        update done
        Adapter    "admin"         : 6.10.1   , installed 5.2.1 [Updateable]
        Adapter    "alexa2"        : 3.25.2   , installed 3.9.3 [Updateable]
        Adapter    "backitup"      : 2.8.1    , installed 2.2.2 [Updateable]
        Adapter    "cloud"         : 4.4.1    , installed 4.1.0 [Updateable]
        Adapter    "discovery"     : 3.1.0    , installed 3.1.0
        Adapter    "flot"          : 1.12.0   , installed 1.10.6 [Updateable]
        Adapter    "heatingcontrol": 2.11.1   , installed 2.7.2 [Updateable]
        Adapter    "history"       : 2.2.6    , installed 1.9.14 [Updateable]
        Adapter    "ical"          : 1.13.3   , installed 1.11.4 [Updateable]
        Adapter    "info"          : 1.9.26   , installed 1.9.8 [Updateable]
        Adapter    "iot"           : 1.14.5   , installed 1.8.22 [Updateable]
        Adapter    "javascript"    : 7.1.4    , installed 5.2.13 [Updateable]
        Controller "js-controller" : 5.0.12   , installed 3.3.22 [Updateable]
        Adapter    "linkeddevices" : 1.5.5    , installed 1.4.3 [Updateable]
        Adapter    "mobile"        : 1.0.1    , installed 1.0.1
        Adapter    "radar2"        : 2.0.7    , installed 2.0.3 [Updateable]
        Adapter    "rpi2"          : 1.3.2    , installed 1.3.1 [Updateable]
        Adapter    "shuttercontrol": 1.6.2    , installed 1.2.1 [Updateable]
        Adapter    "simple-api"    : 2.7.2    , installed 2.7.2
        Adapter    "socketio"      : 6.5.5    , installed 3.1.4 [Updateable]
        Adapter    "telegram"      : 1.16.0   , installed 1.10.0 [Updateable]
        Adapter    "text2command"  : 3.0.2    , installed 2.1.1 [Updateable]
        Adapter    "tr-064"        : 4.2.18   , installed 4.2.14 [Updateable]
        Adapter    "vis"           : 1.4.16   , installed 1.4.5 [Updateable]
        Adapter    "vis-colorpicker": 2.0.3   , installed 1.2.0 [Updateable]
        Adapter    "vis-hqwidgets" : 1.4.0    , installed 1.1.7 [Updateable]
        Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
        Adapter    "vis-metro"     : 1.2.0    , installed 1.1.2 [Updateable]
        Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
        Adapter    "web"           : 6.1.2    , installed 3.4.9 [Updateable]
        Adapter    "zwave2"        : 3.0.5    , installed 3.0.5
        Objects and States
        Objects:        1829
        States:         3260
        Hit:1 http://ports.ubuntu.com/ubuntu-ports lunar InRelease
        Hit:2 http://ports.ubuntu.com/ubuntu-ports lunar-updates InRelease
        Hit:3 http://ports.ubuntu.com/ubuntu-ports lunar-backports InRelease
        Hit:4 http://ports.ubuntu.com/ubuntu-ports lunar-security InRelease
        Hit:5 https://deb.nodesource.com/node_18.x lunar InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          78134      1/systemd
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        37558      13668/systemd-resol
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       86098      46034/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       86091      46034/iobroker.js-c
        tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        37560      13668/systemd-resol
        tcp6       0      0 :::22                   :::*                    LISTEN      0          39954      1/systemd
        tcp6       0      0 :::111                  :::*                    LISTEN      0          78136      1/systemd
        tcp6       0      0 :::443                  :::*                    LISTEN      1001       90857      49322/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       84702      46059/io.admin.0
        udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        37559      13668/systemd-resol
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        37557      13668/systemd-resol
        udp        0      0 192.168.178.54:68       0.0.0.0:*                           998        52189      37786/systemd-netwo
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          76543      1/systemd
        udp6       0      0 :::111                  :::*                                0          76545      1/systemd
        udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                998        52209      37786/systemd-netwo
        2023-09-27 21:07:59.781  - info: host.ubuntu instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2023-09-27 21:08:09.427  - info: host.ubuntu "system.adapter.ical.0" disabled
        2023-09-27 21:08:09.428  - info: host.ubuntu stopInstance system.adapter.ical.0 (force=false, process=false)
        2023-09-27 21:08:09.430  - info: host.ubuntu stopInstance canceled schedule system.adapter.ical.0
        2023-09-27 21:08:14.720  - info: host.ubuntu "system.adapter.ical.0" enabled
        2023-09-27 21:08:14.723  - info: host.ubuntu stopInstance system.adapter.ical.0 (force=false, process=false)
        2023-09-27 21:08:17.803  - info: host.ubuntu instance scheduled system.adapter.ical.0 0,30 * * * *
        2023-09-27 21:08:17.841  - info: host.ubuntu instance system.adapter.ical.0 started with pid 49431
        2023-09-27 21:08:19.974  - info: ical.0 (49431) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2023-09-27 21:08:19.991  - info: ical.0 (49431) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v18.17.1, js-controller: 3.3.22
        2023-09-27 21:08:20.611  - info: ical.0 (49431) processing URL: calendar1 https://63ea0ab88b/basic.ics
        2023-09-27 21:08:25.685  - info: ical.0 (49431) Terminated (NO_ERROR): Without reason
        2023-09-27 21:08:26.285  - info: host.ubuntu instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2023-09-27 21:10:00.025  - debug: shuttercontrol.0 (49337) calculate astrodata ...
        2023-09-27 21:10:00.026  - debug: shuttercontrol.0 (49337) Sun Azimut: 293.5°
        2023-09-27 21:10:00.027  - debug: shuttercontrol.0 (49337) Sun Elevation: -20.7°
        2023-09-27 21:15:00.023  - debug: shuttercontrol.0 (49337) calculate astrodata ...
        2023-09-27 21:15:00.024  - debug: shuttercontrol.0 (49337) Sun Azimut: 294.5°
        2023-09-27 21:15:00.024  - debug: shuttercontrol.0 (49337) Sun Elevation: -21.5°
        2023-09-27 21:17:03.503  - debug: zwave2.0 (49299) Node 34: value updated: value_electric_kwh_consumed => 1.02
        2023-09-27 21:20:00.024  - debug: shuttercontrol.0 (49337) calculate astrodata ...
        2023-09-27 21:20:00.024  - debug: shuttercontrol.0 (49337) Sun Azimut: 295.6°
        2023-09-27 21:20:00.025  - debug: shuttercontrol.0 (49337) Sun Elevation: -22.2°
        2023-09-27 21:21:53.141  - debug: zwave2.0 (49299) Node 5: metadata updated: airTemperature
        2023-09-27 21:21:53.143  - debug: zwave2.0 (49299) Node 5: value updated: airTemperature => 17.79
        iob diag has finished.
        Press any key for a summary
                             v.2023-06-20
               Icon name: computer
            Architecture: arm64
        Kernel:                 aarch64
        Userland:               arm64
        Timezone:               Europe/Paris (CEST, +0200)
        User-ID:                1000
        X-Server:               false
        Pending OS-Updates:     0
        Pending iob updates:    26
        Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:            8.2G        1.6G        1.5G        3.3M        5.4G        6.6G
        Swap:             0B          0B          0B
        Total:          8.2G        1.6G        1.5G
        Active iob-Instances:   9
        Active repo: stable
        ioBroker Core:          js-controller           3.3.22
                                admin                   5.2.1
        Objects type: file
        States  type: file
        Objects:                1829
        States:                 3261
        Size of iob-Database:
        3.7M    /opt/iobroker/iobroker-data/objects.jsonl
        832K    /opt/iobroker/iobroker-data/states.json.bak
        44K     /opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
        GlasfaserG Thomas BraunT simatecS 3 Antworten Letzte Antwort
        • E Esmax666
          iob diag
          Skript v.2023-06-20
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          temp=52.1'C
          volt=0.8820V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          esmax
          /home/esmax
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:             0B          0B          0B
                   7809 M total memory
                   1290 M used memory
                   1647 M free memory
                    195 M buffer memory
                   4992 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          924M    /var/
          677M    /var/lib
          505M    /var/lib/snapd
          220M    /var/cache
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: file
          States  type: file
          admin:          5.2.1
          javascript:     5.2.13
          Adapter State
          + instance is alive
          Active repo: stable
          update done
          Objects and States
          Objects:        1829
          States:         3260
          Pending Updates: 0
                               v.2023-06-20
                 Icon name: computer
              Architecture: arm64
          Kernel:                 aarch64
          Userland:               arm64
          User-ID:                1000
          X-Server:               false
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
          MEMORY:
          Swap:             0B          0B          0B
          Active repo: stable
                                  admin                   5.2.1
          Objects type: file
          States  type: file
          Objects:                1829
          States:                 3261
          GlasfaserG Offline
          GlasfaserG Offline
          @esmax666
          sieht sehr gut aus .. hast alles gemacht wie beschrieben !
          jetzt weiter machen , nach der Liste !
          EDIT
          aber fange mit dem
          an !
          • E Esmax666
            iob diag
            Skript v.2023-06-20
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            temp=52.1'C
            volt=0.8820V
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            esmax
            /home/esmax
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:             0B          0B          0B
                     7809 M total memory
                     1290 M used memory
                     1647 M free memory
                      195 M buffer memory
                     4992 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            924M    /var/
            677M    /var/lib
            505M    /var/lib/snapd
            220M    /var/cache
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Version table:
            ioBroker Status
            Objects type: file
            States  type: file
            admin:          5.2.1
            javascript:     5.2.13
            Adapter State
            + instance is alive
            Active repo: stable
            update done
            Objects and States
            Objects:        1829
            States:         3260
            Pending Updates: 0
                                 v.2023-06-20
                   Icon name: computer
                Architecture: arm64
            Kernel:                 aarch64
            Userland:               arm64
            User-ID:                1000
            X-Server:               false
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
            MEMORY:
            Swap:             0B          0B          0B
            Active repo: stable
                                    admin                   5.2.1
            Objects type: file
            States  type: file
            Objects:                1829
            States:                 3261
            Meine Gedanken zu dem System, kannst du umsetzen wenn der ioBroker wieder rennt.
            Ungünstige Wahl für einen längeren Betrieb. Diese Interimsversionen von ubuntu leben nur 9 Monate. Besser ein Debian/Raspberry OS auf die Kiste werfen.
            Keine Deko, das sollte man tun.
            Du sitzt in Frankreich?
            Du hast das System nicht sauber heruntergefahren. IMMER tun.
            Nicht falsch, aber nicht aktuell. Stell auf das neue nodesource-Repo um.
            Installier iobroker.javascript nochmal drüber.
            • E Esmax666
              iob diag
              Skript v.2023-06-20
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              temp=52.1'C
              volt=0.8820V
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              esmax
              /home/esmax
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:             0B          0B          0B
                       7809 M total memory
                       1290 M used memory
                       1647 M free memory
                        195 M buffer memory
                       4992 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              924M    /var/
              677M    /var/lib
              505M    /var/lib/snapd
              220M    /var/cache
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              nodejs:
                Version table:
              ioBroker Status
              Objects type: file
              States  type: file
              admin:          5.2.1
              javascript:     5.2.13
              Adapter State
              + instance is alive
              Active repo: stable
              update done
              Objects and States
              Objects:        1829
              States:         3260
              Pending Updates: 0
                                   v.2023-06-20
                     Icon name: computer
                  Architecture: arm64
              Kernel:                 aarch64
              Userland:               arm64
              User-ID:                1000
              X-Server:               false
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
              MEMORY:
              Swap:             0B          0B          0B
              Active repo: stable
                                      admin                   5.2.1
              Objects type: file
              States  type: file
              Objects:                1829
              States:                 3261
              simatecS Offline
              simatecS Offline
              simatec
              @esmax666 wenn alles fertig installiert ist und läuft, dann mache ein Upgrade aller Adapter und vorher js-controller updaten
              iobroker stop
              iobroker update
              iobroker upgrade self
              iobroker upgrade -y
              iobroker fix
              iobroker start
              • Besuche meine Github Seite
              • HowTo Restore ioBroker
              • simatecS Offline
                simatecS Offline
                simatec
                @Esmax666
                Danach richte Backitup ein, damit du jede Nacht ein Backup machst.
                Am besten auf ein NAS oder wenn du dass nicht hast, nutze einen Clouddienst, den Backitup unterstützt.
                Im Anschluss noch einen Kalendereintrag, der sich jeden Monat wiederholt, in dem du dein System auf Stand bringst.
                Immer das System und den iobroker aktuell halten
                  @esmax666
                  EDIT
                  aber fange mit dem
                  an !
                  Esmax666
                  @glasfaser
                  also jscontroler ist jetzt aktualisiert 5.0.12
                  ich kann jetzt weiter weitermachen oder ? weboberfläche geht aber nicht mehr
                  Skript v.2023-06-20
                  *** BASE SYSTEM ***
                         Icon name: computer
                           Boot ID: 0c59d3c9640b486fadab37c9e124b76a
                            Kernel: Linux 6.2.0-1013-raspi
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                   23:16:45 up 8 min,  2 users,  load average: 3.57, 1.61, 0.67
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  temp=68.6'C
                  volt=0.9260V
                                 Local time: Wed 2023-09-27 23:16:46 CEST
                             Universal time: Wed 2023-09-27 21:16:46 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  esmax
                  /home/esmax
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            8.2G        1.4G        6.4G        3.2M        602M        6.8G
                  Swap:             0B          0B          0B
                  Total:          8.2G        1.4G        6.4G
                           7809 M total memory
                           1352 M used memory
                            283 M active memory
                           1153 M inactive memory
                           6148 M free memory
                             59 M buffer memory
                            515 M swap cache
                              0 M total swap
                              0 M used swap
                              0 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  tmpfs          tmpfs  781M  3.1M  778M   1% /run
                  [Wed Sep 27 23:08:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 dwc_otg.lpm_enable=0 console=tty1 root=LABEL=writable rootfstype=ext4 rootwait fixrtc quiet splash
                  [Wed Sep 27 23:08:29 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                  [Wed Sep 27 23:08:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem 25a83575-fd50-4dcc-85e0-e3a81c621aa2 with ordered data mode. Quota mode: none.
                  [Wed Sep 27 23:08:31 2023] EXT4-fs (mmcblk0p2): re-mounted 25a83575-fd50-4dcc-85e0-e3a81c621aa2. Quota mode: none.
                  |-/snap/core22/611  /dev/loop0     squashfs ro,nodev,relatime,errors=continue,threads=single
                  |-/snap/core22/867  /dev/loop1     squashfs ro,nodev,relatime,errors=continue,threads=single
                  |-/snap/lxd/24646   /dev/loop2     squashfs ro,nodev,relatime,errors=continue,threads=single
                  |-/snap/lxd/25755   /dev/loop3     squashfs ro,nodev,relatime,errors=continue,threads=single
                  |-/snap/snapd/18600 /dev/loop4     squashfs ro,nodev,relatime,errors=continue,threads=single
                  `-/boot/firmware    /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  943M    /var/
                  677M    /var/lib
                  505M    /var/lib/snapd
                  222M    /var/cache
                  Archived and active journals take up 43.0M in the file system.
                  119M    /opt/iobroker/iobroker-data/
                  8.1M    /opt/iobroker/iobroker-data/objects.jsonl
                  8.0M    /opt/iobroker/iobroker-data/objects.json.migrated
                  8.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                  /usr/bin/npm            9.6.7
                  /usr/bin/npx            9.6.7
                  nodejs:
                    Version table:
                  npm ERR! A complete log of this run can be found in: /home/esmax/.npm/_logs/2023-09-27T21_17_01_730Z-debug-0.log
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                    jsonl on 127.0.0.1
                  States:                     jsonl on 127.0.0.1
                  js-controller:  5.0.12
                  admin:          5.2.1
                  javascript:     5.2.13
                  Adapter State
                  + instance is alive
                  Active repo(s): stable
                  Adapter    "admin"        : 6.10.1   , installed 5.2.1  [Updatable]
                  Adapter    "alexa2"       : 3.25.2   , installed 3.9.3  [Updatable]
                  Adapter    "backitup"     : 2.8.1    , installed 2.2.2  [Updatable]
                  Adapter    "cloud"        : 4.4.1    , installed 4.1.0  [Updatable]
                  Adapter    "flot"         : 1.12.0   , installed 1.10.6 [Updatable]
                  Adapter    "heatingcontrol": 2.11.1  , installed 2.7.2  [Updatable]
                  Adapter    "history"      : 2.2.6    , installed 1.9.14 [Updatable]
                  Adapter    "ical"         : 1.13.3   , installed 1.11.4 [Updatable]
                  Adapter    "info"         : 1.9.26   , installed 1.9.8  [Updatable]
                  Adapter    "iot"          : 1.14.5   , installed 1.8.22 [Updatable]
                  Adapter    "javascript"   : 7.1.4    , installed 5.2.13 [Updatable]
                  Controller "js-controller": 5.0.12   , installed 5.0.12
                  Adapter    "linkeddevices": 1.5.5    , installed 1.4.3  [Updatable]
                  Adapter    "radar2"       : 2.0.7    , installed 2.0.3  [Updatable]
                  Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
                  Adapter    "shuttercontrol": 1.6.2   , installed 1.2.1  [Updatable]
                  Adapter    "socketio"     : 6.5.5    , installed 3.1.4  [Updatable]
                  Adapter    "telegram"     : 1.16.0   , installed 1.10.0 [Updatable]
                  Adapter    "text2command" : 3.0.2    , installed 2.1.1  [Updatable]
                  Adapter    "tr-064"       : 4.2.18   , installed 4.2.14 [Updatable]
                  Adapter    "vis"          : 1.4.16   , installed 1.4.5  [Updatable]
                  Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
                  Adapter    "vis-hqwidgets": 1.4.0    , installed 1.1.7  [Updatable]
                  Adapter    "vis-metro"    : 1.2.0    , installed 1.1.2  [Updatable]
                  Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
                  Adapter    "web"          : 6.1.2    , installed 3.4.9  [Updatable]
                  Objects and States
                  Objects:        4592
                  States:         3264
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17467      1/init
                  tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        22635      555/systemd-resolve
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       26995      2351/iobroker.js-co
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27002      2351/iobroker.js-co
                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        22633      555/systemd-resolve
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          13962      1/init
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          23620      1/init
                  udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        22634      555/systemd-resolve
                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        22632      555/systemd-resolve
                  udp        0      0 192.168.178.54:68       0.0.0.0:*                           998        22809      812/systemd-network
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17468      1/init
                  udp6       0      0 :::111                  :::*                                0          16876      1/init
                  udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                998        22817      812/systemd-network
                  2023-09-27 23:17:33.462  - info: zwave2.0 (2938) Node 2: ready to use
                  2023-09-27 23:17:33.697  - info: zwave2.0 (2938) Node 2 is alive
                  2023-09-27 23:17:36.082  - info: zwave2.0 (2938) Node 3: ready to use
                  2023-09-27 23:17:36.179  - info: vis.0 (3029) Uploaded. 0
                  2023-09-27 23:17:36.436  - info: zwave2.0 (2938) Node 4: ready to use
                  2023-09-27 23:17:36.695  - info: vis.0 (3029) Terminated (NO_ERROR): Without reason
                  2023-09-27 23:17:37.940  - info: zwave2.0 (2938) Node 5: ready to use
                  2023-09-27 23:17:38.180  - info: zwave2.0 (2938) Node 5 is alive
                  2023-09-27 23:17:40.108  - info: zwave2.0 (2938) Node 7: ready to use
                  2023-09-27 23:17:40.256  - info: zwave2.0 (2938) Node 8: ready to use
                  2023-09-27 23:17:40.402  - info: zwave2.0 (2938) Node 9: ready to use
                  2023-09-27 23:17:41.185  - info: zwave2.0 (2938) Node 22: ready to use
                  2023-09-27 23:17:41.886  - info: zwave2.0 (2938) Node 25: ready to use
                  2023-09-27 23:17:59.738  - info: zwave2.0 (2938) Node 31: ready to use
                  2023-09-27 23:17:59.860  - info: zwave2.0 (2938) Node 31 is alive
                  2023-09-27 23:17:59.876  - info: zwave2.0 (2938) Node 32: ready to use
                  2023-09-27 23:17:59.988  - info: zwave2.0 (2938) Node 32 is alive
                  2023-09-27 23:18:00.067  - info: zwave2.0 (2938) Node 33: ready to use
                  2023-09-27 23:18:00.121  - info: zwave2.0 (2938) Node 34: ready to use
                  2023-09-27 23:18:00.169  - info: zwave2.0 (2938) Node 33 is alive
                  2023-09-27 23:18:00.183  - info: zwave2.0 (2938) Node 34 is alive
                  2023-09-27 23:18:00.390  - info: zwave2.0 (2938) Node 35: ready to use
                  2023-09-27 23:18:00.448  - info: zwave2.0 (2938) Node 35 is alive
                  2023-09-27 23:18:00.478  - info: zwave2.0 (2938) Node 38: ready to use
                  2023-09-27 23:18:00.526  - info: zwave2.0 (2938) Node 38 is alive
                  • E Esmax666
                    @glasfaser
                    Skript v.2023-06-20
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    temp=68.6'C
                    volt=0.9260V
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    esmax
                    /home/esmax
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:             0B          0B          0B
                             7809 M total memory
                             1352 M used memory
                              283 M active memory
                             6148 M free memory
                               59 M buffer memory
                              515 M swap cache
                                0 M total swap
                                0 M used swap
                                0 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    943M    /var/
                    677M    /var/lib
                    505M    /var/lib/snapd
                    222M    /var/cache
                    /usr/bin/npm            9.6.7
                    /usr/bin/npx            9.6.7
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          5.2.1
                    javascript:     5.2.13
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        4592
                    States:         3264
                    Pending Updates: 0
                    @esmax666
                    iob update
                    iob upgrade all -y
                    iob start admin
                      Esmax666
                      @thomas-braun said in Backitup Restore fehler:
                      ich wollte ertmals probieren wie es früher war um weniger Problem zu bekommen :D
                      ich auch gemacht
                      JA
                      Seltsam ich habe nur gerade heute ubuntu / iobroker installiert ohne das Gerät auszuschalten
                      wie soll ich das machen ?
                      • E Esmax666
                        ich auch gemacht
                        JA
                        Esmax666
                        schrieb am zuletzt editiert von Esmax666
                        update ist done,
                        ich glaube da läuft alles wieder richtig, dann mache schnell noch ein backup :D
                        Also das wäre noch eventuel zu machen ? Node.js: v18.17.1(18.18.0)
                        NPM: 9.6.7(9.8.1)
                        aber wie ?
                        Skript v.2023-06-20
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                         23:43:46 up 35 min,  2 users,  load average: 0.05, 0.65, 1.10
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x0
                        temp=53.0'C
                        volt=0.8600V
                                       Local time: Wed 2023-09-27 23:43:46 CEST
                                   Universal time: Wed 2023-09-27 21:43:46 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        esmax
                        /home/esmax
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            8.2G        1.3G        5.5G        3.3M        1.8G        6.9G
                        Swap:             0B          0B          0B
                        Total:          8.2G        1.3G        5.5G
                                 7809 M total memory
                                 1195 M used memory
                                  476 M active memory
                                 1755 M inactive memory
                                 5249 M free memory
                                   97 M buffer memory
                                 1576 M swap cache
                                    0 M total swap
                                    0 M used swap
                                    0 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /dev/mmcblk0p2 ext4    59G  5.5G   51G  10% /
                        /var:
                        944M    /var/
                        677M    /var/lib
                        505M    /var/lib/snapd
                        222M    /var/cache
                        7.6M    /opt/iobroker/backups/
                        229M    /opt/iobroker/iobroker-data/
                        192M    /opt/iobroker/iobroker-data/files
                        52M     /opt/iobroker/iobroker-data/files/javascript.admin
                        34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                        33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                        18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
                        8.2M    /opt/iobroker/iobroker-data/objects.jsonl
                        /usr/bin/npm            9.6.7
                        /usr/bin/npx            9.6.7
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.10.1
                        javascript:     7.1.4
                        Adapter State
                        + instance is alive
                        Adapter    "admin"        : 6.10.1   , installed 6.10.1
                        Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                        Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                        Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                        Adapter    "history"      : 2.2.6    , installed 2.2.6
                        Adapter    "ical"         : 1.13.3   , installed 1.13.3
                        Adapter    "iot"          : 1.14.5   , installed 1.14.5
                        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                        Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                        Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                        Adapter    "text2command" : 3.0.2    , installed 3.0.2
                        Adapter    "web"          : 6.1.2    , installed 6.1.2
                        Adapter    "ws"           : 2.5.5    , installed 2.5.5
                        Objects and States
                        Objects:        4615
                        States:         3306
                        Pending Updates: 0
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       47592      9892/iobroker.js-co
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50371      9892/iobroker.js-co
                        tcp6       0      0 :::443                  :::*                    LISTEN      1001       47776      10028/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       47619      9910/io.admin.0
                        2023-09-27 23:38:35.483  - info: zwave2.0 (10049) Node 4: ready to use
                        2023-09-27 23:38:35.521  - info: zwave2.0 (10049) Node 4 is alive
                        2023-09-27 23:38:37.047  - info: zwave2.0 (10049) Node 5: ready to use
                        2023-09-27 23:38:37.108  - info: zwave2.0 (10049) Node 5 is alive
                        2023-09-27 23:38:38.332  - info: zwave2.0 (10049) Node 22: ready to use
                        2023-09-27 23:38:38.362  - info: zwave2.0 (10049) Node 22 is alive
                        2023-09-27 23:38:56.528  - info: admin.0 (9910) ==> Connected system.user.admin from ::ffff:192.168.178.39
                        2023-09-27 23:38:58.724  - info: zwave2.0 (10049) Node 31: ready to use
                        2023-09-27 23:38:58.754  - info: zwave2.0 (10049) Node 31 is alive
                        2023-09-27 23:38:58.817  - info: zwave2.0 (10049) Node 32: ready to use
                        2023-09-27 23:38:58.865  - info: zwave2.0 (10049) Node 33: ready to use
                        2023-09-27 23:38:58.936  - info: zwave2.0 (10049) Node 34: ready to use
                        2023-09-27 23:38:58.970  - info: zwave2.0 (10049) Node 32 is alive
                        2023-09-27 23:38:58.990  - info: zwave2.0 (10049) Node 33 is alive
                        2023-09-27 23:38:59.014  - info: zwave2.0 (10049) Node 34 is alive
                        2023-09-27 23:38:59.204  - info: zwave2.0 (10049) Node 35: ready to use
                        2023-09-27 23:38:59.263  - info: zwave2.0 (10049) Node 35 is alive
                        2023-09-27 23:38:59.292  - info: zwave2.0 (10049) Node 38: ready to use
                        2023-09-27 23:38:59.322  - info: zwave2.0 (10049) Node 38 is alive
                        2023-09-27 23:40:00.027  - debug: shuttercontrol.0 (10013) calculate astrodata ...
                        2023-09-27 23:40:00.028  - debug: shuttercontrol.0 (10013) Sun Azimut: 331.9°
                        2023-09-27 23:40:00.029  - debug: shuttercontrol.0 (10013) Sun Elevation: -38.6°
                        2023-09-27 23:42:25.827  - debug: zwave2.0 (10049) Node 3: metadata updated: airTemperature
                        2023-09-27 23:42:25.830  - debug: zwave2.0 (10049) Node 3: value updated: airTemperature => 19.37
                        2023-09-27 23:43:32.756  - debug: zwave2.0 (10049) Node 32: value updated: value_electric_kwh_consumed => 0.5
                        • E Esmax666
                          update ist done,
                          NPM: 9.6.7(9.8.1)
                          aber wie ?
                          Skript v.2023-06-20
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : arm64
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=53.0'C
                          volt=0.8600V
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          esmax
                          /home/esmax
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:             0B          0B          0B
                                   7809 M total memory
                                   1195 M used memory
                                    476 M active memory
                                   5249 M free memory
                                     97 M buffer memory
                                   1576 M swap cache
                                      0 M total swap
                                      0 M used swap
                                      0 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          944M    /var/
                          677M    /var/lib
                          505M    /var/lib/snapd
                          222M    /var/cache
                          /usr/bin/npm            9.6.7
                          /usr/bin/npx            9.6.7
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.10.1
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        4615
                          States:         3306
                          Pending Updates: 0
                          Schon wieder. Ich vermute dann, das deine SD-Karte krümelig ist.
                          Wenn du ansonsten das System sauber handelst.
                          • E Esmax666
                            update ist done,
                            NPM: 9.6.7(9.8.1)
                            aber wie ?
                            Skript v.2023-06-20
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            temp=53.0'C
                            volt=0.8600V
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            esmax
                            /home/esmax
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:             0B          0B          0B
                                     7809 M total memory
                                     1195 M used memory
                                      476 M active memory
                                     5249 M free memory
                                       97 M buffer memory
                                     1576 M swap cache
                                        0 M total swap
                                        0 M used swap
                                        0 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            944M    /var/
                            677M    /var/lib
                            505M    /var/lib/snapd
                            222M    /var/cache
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.10.1
                            javascript:     7.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        4615
                            States:         3306
                            Pending Updates: 0
                            aber wie ?
                            Schau in meiner Signatur nach dem node-fix-Skript.
                              Esmax666
                              krümelig
                              Sag das nicht lol , ich habe gerade die karte gekauft (SANDISK Elite Extreme)
                              Thomas BraunT ? 2 Antworten Letzte Antwort
                              • E Esmax666
                                krümelig
                                @esmax666
                                Die Meldung mit den orphans ist jedenfalls nicht normal. Kommt wenn dem System abrupt der Strom genommen wird und/oder bei defektem Datenträger.
                                  @esmax666
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  @thomas-braun sagte in Backitup Restore fehler:
                                  @Esmax666 Trenne niemals deinen PI einfach vom Strom. Ein OS muss immer sauber heruntergefahren werden.
                                  • E Esmax666
                                    krümelig
                                    Moin,
                                    Mal einfach beschrieben
                                    ein Speichermedium verträgt nur eine gewisse Anzahl an defekten Sektoren/Inodes, da es eine bestimmte Anzahl an Sektoren/Inodes vor dem Benutzen versteckt und somit die Defekten ersetzen kann. Neigt sich dieser Vorrat dem Ende, dann kann man das Speichermedium entsorgen.
                                    Je größer ein Speichermedium, desto mehr Sektoren/Inodes stehen zur Reparatur zur Verfügung.
                                    Fehler und ihre Folgen
                                    Aber was viel schlimmer ist, wenn Informationen, die gerade durch, sagen wir mal, der Kernel hat seine Information aus Inode 101, 102,103 geladen und Du killst den Rechner durch Stromlos machen, sodass plötzlich Inode 102 nicht mehr gültig ist, dann kommt es beim nächsten Booten zu einem Kernel Panik und der Rechner startet nicht mehr.
                                    Im besten Fall kann, bei geeignetem Dateisystem, etwas repariert werden, im schlechtesten Fall, totaler Datenverlust.
                                    Bernd
                                    • simatecS simatec
                                      Esmax666
                                      @simatec said in Backitup Restore fehler:
                                      das habe ich auch nicht gemacht ( bin 99% sicher , aber das spät)
