  4. Multihost zusamen führen ** gelöst **
    2.6k
    4.5k
28 Beiträge 7 Kommentatoren 1.6k Aufrufe 5 Beobachtet
  • haselchenH haselchen
    Da beides unter iobroker.net läuft , woher soll ein , sagen wir Neuling , das dann unterscheiden?
    Wäre ja evtl.sinnvoll den alten Krams dann vom Netz zu nehmen.
    @haselchen sagte in Multihost zusamen führen:
    @Homoran
    • Horst BöttcherH Horst Böttcher
      @bahnuhr
      pi@PiMaster:~ $ sudo iobroker setup custom
      Current configuration:
      - Objects database:
       - Type: jsonl
       - Host/Unix Socket: 0.0.0.0
       - Port: 9001
      - States database:
       - Type: jsonl
       - Port: 9000
      - Data Directory: ../../iobroker-data/
      Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
      Host / Unix Socket of objects DB(jsonl), default[0.0.0.0]:
      Port of objects DB(jsonl), default[9001]:
      Type of states DB [(j)sonl, (f)file, (r)edis, ...], default [jsonl]:
      Host / Unix Socket of states DB (jsonl), default[0.0.0.0]:
      Port of states DB (jsonl), default[9000]:
      Data directory (file), default[../../iobroker-data/]:
      Host name of this machine [PiMaster]:
      updating conf/iobroker.json
      pi@PiMaster:~ $
      Slave
      pi@Slave1:/opt/iobroker $ sudo iobroker setup custom
      - Objects database:
        - Type: jsonl
        - Host/Unix Socket: 192.168.178.100
        - Port: 9001
      - States database:
        - Type: jsonl
        - Port: 9000
      Host / Unix Socket of objects DB(jsonl), default[192.168.178.100]: 192.168.178.100
      Host / Unix Socket of states DB (jsonl), default[192.168.178.100]: 192.168.178.100
      Host name of this machine [Slave1]: Slave1
      dann
      pi@PiMaster:~ $ iobroker multihost enable
      Multihost discovery server activated on this host. If iobroker is currently not running please start befeore trying to discover this host.
      Important: Multihost discovery works with UDP packets. Make sure they are routed correctly in your network. If you use Docker you also need to configure this correctly.
      Multihost discovery will be automatically deactivated after 15 minutes. If you want to activate it permanently use the --persist flag
      Discovery authentication activated.
      Enter secret phrase for connection:
      Repeat secret phrase for connection:
      Please check the binding of the configured jsonl server to allow remote connections.
      Please restart ioBroker for the changes to take effect: "iobroker restart"
      Multihost discovery server: enabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 0.0.0.0
      States:                     jsonl on 0.0.0.0
      ^C
      pi@PiMaster:~ $
      und iob restart
      beim Slave
      iobroker multihost browse
      ``` oder iobroker multihost browse
      und es kommt nix
      ich weiss nicht ob intressant log
      host.PiMaster
      2023-09-18 18:36:55.644	info	instance system.adapter.backitup.0 started with pid 17093
      host.PiMaster
      2023-09-18 18:36:51.364	info	instance system.adapter.discovery.0 started with pid 17075
      host.PiMaster
      2023-09-18 18:36:50.889	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      host.PiMaster
      2023-09-18 18:36:47.390	info	instance system.adapter.zigbee.0 started with pid 17052
      host.PiMaster
      2023-09-18 18:36:43.610	info	Some obsolete host states deleted.
      host.PiMaster
      2023-09-18 18:36:43.590	info	Delete state "system.host.PiMaster.versions.npmNewestNext"
      host.PiMaster
      2023-09-18 18:36:43.530	info	Delete state "system.host.PiMaster.versions.npmNewest"
      host.PiMaster
      2023-09-18 18:36:43.504	info	Delete state "system.host.PiMaster.versions.npmCurrent"
      host.PiMaster
      2023-09-18 18:36:43.483	info	instance system.adapter.admin.0 started with pid 17041
      host.PiMaster
      2023-09-18 18:36:43.440	info	Delete state "system.host.PiMaster.versions.nodeNewestNext"
      host.PiMaster
      2023-09-18 18:36:43.404	info	Delete state "system.host.PiMaster.versions.nodeNewest"
      host.PiMaster
      2023-09-18 18:36:43.303	info	starting 4 instances
      host.PiMaster
      2023-09-18 18:36:43.276	info	4 instances found
      host.PiMaster
      2023-09-18 18:36:43.250	info	Delete state "system.host.PiMaster.versions.nodeCurrent"
      host.PiMaster
      2023-09-18 18:36:42.278	info	added notifications configuration of host
      host.PiMaster
      2023-09-18 18:36:42.250	info	connected to Objects and States
      host.PiMaster
      2023-09-18 18:36:41.499	info	ip addresses: 192.168.178.100 2001:9e8:1ec:af00:d975:3f8a:fb83:7a0e fe80::b476:adb:eade:b907
      host.PiMaster
      2023-09-18 18:36:41.498	info	hostname: PiMaster, node: v18.17.1
      host.PiMaster
      2023-09-18 18:36:41.496	info	Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
      host.PiMaster
      2023-09-18 18:36:41.489	info	iobroker.js-controller version 5.0.12 js-controller starting
      host.PiMaster
      2023-09-18 18:36:36.948	info	terminated
      host.PiMaster
      2023-09-18 18:36:36.832	info	All instances are stopped.
      host.PiMaster
      2023-09-18 18:36:36.831	info	instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
      host.PiMaster
      2023-09-18 18:36:36.795	info	instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      host.PiMaster
      2023-09-18 18:36:36.781	info	instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      host.PiMaster
      2023-09-18 18:36:36.780	info	instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
      host.PiMaster
      2023-09-18 18:36:36.108	info	stopInstance system.adapter.backitup.0 send kill signal
      host.PiMaster
      2023-09-18 18:36:36.107	info	stopInstance system.adapter.discovery.0 send kill signal
      host.PiMaster
      2023-09-18 18:36:36.106	info	stopInstance system.adapter.zigbee.0 send kill signal
      host.PiMaster
      2023-09-18 18:36:36.103	info	stopInstance system.adapter.admin.0 send kill signal
      host.PiMaster
      2023-09-18 18:36:36.079	info	stopInstance system.adapter.backitup.0 (force=false, process=true)
      host.PiMaster
      2023-09-18 18:36:36.078	info	stopInstance system.adapter.discovery.0 (force=false, process=true)
      host.PiMaster
      2023-09-18 18:36:36.077	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
      host.PiMaster
      2023-09-18 18:36:36.063	info	stopInstance system.adapter.admin.0 (force=false, process=true)
      host.PiMaster
      2023-09-18 18:36:36.056	info	received SIGTERM
      host.PiMaster
      2023-09-18 18:15:06.462	info	Multihost discovery server stopped after 15 minutes, because only temporarily activated
      host.PiMaster
      2023-09-18 18:00:06.462	info	Multi-host discovery server: service started on 0.0.0.0:50005
      host.PiMaster
      2023-09-18 17:37:56.931	info	Multihost discovery server stopped after 15 minutes, because only temporarily activated
      host.PiMaster
      2023-09-18 17:22:56.932	info	Multi-host discovery server: service started on 0.0.0.0:50005
      @horst-böttcher sagte in Multihost zusamen führen:
      hast du das gemacht?
      Horst BöttcherH 1 Antwort Letzte Antwort
        das ist er seit 2018/20
          haselchenH Offline
          haselchenH Offline
          haselchen
          Hab doch gerade den Link gepostet?
          Die Seite ist aufrufbar und zu finden über Google.
            google vergisst nichts
            haselchenH Thomas BraunT 2 Antworten Letzte Antwort
              haselchenH Offline
              haselchenH Offline
              haselchen
              Wenn das noch in irgendeinem Cache steckt, dann ist es bestimmt möglich, anhand der URL, Google zum Löschen zu bewegen ?!
                @homoran sagte in Multihost zusamen führen:
                Und ChatGPT vergisst auch nix, erzählt aber dennoch belangloses Gebrabbel.
                  Horst BöttcherH Offline
                  Horst Böttcher
                  @homoran ja hab ich komisch jetzt ist er da
                  ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
