  3. Off Topic
  4. Homekit-controller lässt sich nicht installieren
    6.0k
28 Beiträge 7 Kommentatoren 3.2k Aufrufe 7 Beobachtet
    SirDrinsAlot
    Moin
    Hatte versucht den iobroker von raspberry auf einen Intel zu migrieren, aber egal ob unter windows oder linux, kann weder Homekit-controller noch vis installieren.
    Das bringt er als Fehler:
    code_text
    NPM version: 9.6.7
    Installing iobroker.homekit-controller@0.5.8... (System call)
    npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:66232) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_00_49_922Z-debug-0.log
    host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
    ERROR: Process exited with code 25
    DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
    • S SirDrinsAlot
      Moin
      code_text
      NPM version: 9.6.7
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @sirdrinsalot
      https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update
      Lehrling seit 1975 !!!
      • S SirDrinsAlot
        Moin
        code_text
        NPM version: 9.6.7
        @sirdrinsalot sagte in Homekit-controller lässt sich nicht installieren:
        Was steht da drin?
          SirDrinsAlot
          Der Error 25 Befehl ändert leider nix und das /home/iobroker/ Verzeichnis ist leer.
          • S SirDrinsAlot
            Nein, ist es nicht.
            Dateien und Verzeichnisse, die mit einem Punkt beginnen sind ausgeblendet.
            ls -lAh /home/iobroker
            zeigt auch diese Dateien.
              SirDrinsAlot
              Stimmt, sry bin eher windows user.
              0 verbose cli /usr/bin/node /usr/bin/npm
              1 info using npm@9.6.7
              2 info using node@v18.17.1
              3 timing npm:load:whichnode Completed in 1ms
              4 timing config:load:defaults Completed in 1ms
              5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 0ms
              6 timing config:load:builtin Completed in 0ms
              7 timing config:load:cli Completed in 2ms
              8 timing config:load:env Completed in 0ms
              9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
              10 timing config:load:project Completed in 2ms
              11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
              12 timing config:load:user Completed in 0ms
              13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
              14 timing config:load:global Completed in 0ms
              15 timing config:load:setEnvs Completed in 1ms
              16 timing config:load Completed in 8ms
              17 timing npm:load:configload Completed in 8ms
              18 timing npm:load:mkdirpcache Completed in 1ms
              19 timing npm:load:mkdirplogs Completed in 0ms
              20 verbose title npm install iobroker.homekit-controller@0.5.8
              21 verbose argv "install" "--save-exact" "--loglevel" "error" "iobroker.homekit-controller@0.5.8"
              22 timing npm:load:setTitle Completed in 1ms
              23 timing config:load:flatten Completed in 2ms
              24 timing npm:load:display Completed in 3ms
              25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-
              26 verbose logfile /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log
              27 timing npm:load:logFile Completed in 7ms
              28 timing npm:load:timers Completed in 0ms
              29 timing npm:load:configScope Completed in 0ms
              30 timing npm:load Completed in 21ms
              31 timing arborist:ctor Completed in 0ms
              32 silly logfile start cleaning logs, removing 2 files
              33 silly logfile done cleaning log files
              34 timing idealTree:init Completed in 1269ms
              35 timing idealTree:userRequests Completed in 2ms
              36 silly idealTree buildDeps
              37 silly fetch manifest iobroker.homekit-controller@0.5.8
              38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
              39 http fetch GET 200 https://registry.npmjs.org/iobroker.homekit-controller 1537ms (cache revalidated)
              40 silly placeDep ROOT iobroker.homekit-controller@0.5.8 OK for: iobroker.inst@3.0.0 want: 0.5.8
              41 silly fetch manifest @iobroker/adapter-core@^2.6.7
              42 silly fetch manifest debug@^4.3.4
              43 silly fetch manifest hap-controller@^0.9.3
              44 silly fetch manifest @esm2cjs/p-queue@^7.3.0
              45 http fetch GET 200 https://registry.npmjs.org/debug 101ms (cache revalidated)
              46 http fetch GET 200 https://registry.npmjs.org/@iobroker%2fadapter-core 596ms (cache revalidated)
              47 http fetch GET 200 https://registry.npmjs.org/@esm2cjs%2fp-queue 1428ms (cache revalidated)
              48 http fetch GET 200 https://registry.npmjs.org/hap-controller 1609ms (cache revalidated)
              49 timing idealTree:#root Completed in 3167ms
              50 silly placeDep ROOT @esm2cjs/p-queue@7.3.0 OK for: iobroker.homekit-controller@0.5.8 want: ^7.3.0
              51 silly fetch manifest @esm2cjs/p-timeout@^5.0.2
              52 silly fetch manifest eventemitter3@^4.0.7
              53 silly placeDep node_modules/iobroker.homekit-controller @iobroker/adapter-core@2.6.8 OK for: iobroker.homekit-controller@0.5.8 want: ^2.6.7
              54 silly placeDep node_modules/iobroker.homekit-controller debug@4.3.4 OK for: iobroker.homekit-controller@0.5.8 want: ^4.3.4
              55 silly fetch manifest ms@2.1.2
              56 silly placeDep ROOT hap-controller@0.9.3 OK for: iobroker.homekit-controller@0.5.8 want: ^0.9.3
              57 silly fetch manifest @abandonware/noble@1.9.2-20
              58 silly fetch manifest dnssd@^0.4.1
              59 silly fetch manifest fast-srp-hap@^2.0.4
              60 silly fetch manifest http-parser-js@^0.5.8
              61 silly fetch manifest libsodium-wrappers@^0.7.11
              62 silly fetch manifest node-hkdf-sync@^1.0.0
              63 http fetch GET 200 https://registry.npmjs.org/http-parser-js 90ms (cache revalidated)
              64 http fetch GET 200 https://registry.npmjs.org/eventemitter3 407ms (cache revalidated)
              65 http fetch GET 200 https://registry.npmjs.org/ms 606ms (cache revalidated)
              66 http fetch GET 200 https://registry.npmjs.org/@abandonware%2fnoble 603ms (cache revalidated)
              67 http fetch GET 200 https://registry.npmjs.org/libsodium-wrappers 778ms (cache revalidated)
              68 http fetch GET 200 https://registry.npmjs.org/node-hkdf-sync 1094ms (cache revalidated)
              69 http fetch GET 200 https://registry.npmjs.org/fast-srp-hap 1214ms (cache revalidated)
              70 http fetch GET 200 https://registry.npmjs.org/@esm2cjs%2fp-timeout 1532ms (cache revalidated)
              71 http fetch GET 200 https://registry.npmjs.org/dnssd 1934ms (cache revalidated)
              72 timing idealTree:node_modules/iobroker.homekit-controller Completed in 1950ms
              73 silly placeDep ROOT @esm2cjs/p-timeout@5.1.0 OK for: @esm2cjs/p-queue@7.3.0 want: ^5.0.2
              74 silly placeDep node_modules/@esm2cjs/p-queue eventemitter3@4.0.7 OK for: @esm2cjs/p-queue@7.3.0 want: ^4.0.7
              75 timing idealTree:node_modules/@esm2cjs/p-queue Completed in 9ms
              76 timing idealTree:node_modules/@esm2cjs/p-timeout Completed in 0ms
              77 silly placeDep node_modules/hap-controller @abandonware/noble@1.9.2-20 OK for: hap-controller@0.9.3 want: 1.9.2-20
              78 silly fetch manifest node-addon-api@^4.3.0
              79 silly placeDep node_modules/hap-controller debug@4.3.4 OK for: hap-controller@0.9.3 want: ^4.3.4
              80 silly placeDep ROOT dnssd@0.4.1 OK for: hap-controller@0.9.3 want: ^0.4.1
              81 silly placeDep ROOT fast-srp-hap@2.0.4 OK for: hap-controller@0.9.3 want: ^2.0.4
              82 silly placeDep ROOT http-parser-js@0.5.8 OK for: hap-controller@0.9.3 want: ^0.5.8
              83 silly placeDep ROOT libsodium-wrappers@0.7.13 OK for: hap-controller@0.9.3 want: ^0.7.11
              84 silly fetch manifest libsodium@^0.7.13
              85 silly placeDep ROOT node-hkdf-sync@1.0.0 OK for: hap-controller@0.9.3 want: ^1.0.0
              86 silly fetch manifest vows@0.5.13
              87 http fetch GET 200 https://registry.npmjs.org/node-addon-api 88ms (cache revalidated)
              88 http fetch GET 200 https://registry.npmjs.org/libsodium 398ms (cache revalidated)
              89 http fetch GET 200 https://registry.npmjs.org/vows 1387ms (cache revalidated)
              90 timing idealTree:node_modules/hap-controller Completed in 1405ms
              91 timing idealTree:node_modules/dnssd Completed in 0ms
              92 timing idealTree:node_modules/fast-srp-hap Completed in 0ms
              93 timing idealTree:node_modules/http-parser-js Completed in 0ms
              94 silly placeDep ROOT libsodium@0.7.13 OK for: libsodium-wrappers@0.7.13 want: ^0.7.13
              95 timing idealTree:node_modules/libsodium-wrappers Completed in 4ms
              96 timing idealTree:node_modules/libsodium Completed in 0ms
              97 silly placeDep ROOT vows@0.5.13 OK for: node-hkdf-sync@1.0.0 want: 0.5.13
              98 timing idealTree:node_modules/node-hkdf-sync Completed in 4ms
              99 timing idealTree:node_modules/vows Completed in 0ms
              100 timing idealTree:node_modules/@esm2cjs/p-queue/node_modules/eventemitter3 Completed in 0ms
              101 silly placeDep node_modules/hap-controller node-addon-api@4.3.0 OK for: @abandonware/noble@1.9.2-20 want: ^4.3.0
              102 timing idealTree:node_modules/hap-controller/node_modules/@abandonware/noble Completed in 3ms
              103 silly placeDep node_modules/hap-controller ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
              104 timing idealTree:node_modules/hap-controller/node_modules/debug Completed in 1ms
              105 timing idealTree:node_modules/hap-controller/node_modules/ms Completed in 0ms
              106 timing idealTree:node_modules/hap-controller/node_modules/node-addon-api Completed in 0ms
              107 timing idealTree:node_modules/iobroker.homekit-controller/node_modules/@iobroker/adapter-core Completed in 0ms
              108 silly placeDep node_modules/iobroker.homekit-controller ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
              109 timing idealTree:node_modules/iobroker.homekit-controller/node_modules/debug Completed in 1ms
              110 timing idealTree:node_modules/iobroker.homekit-controller/node_modules/ms Completed in 0ms
              111 timing idealTree:buildDeps Completed in 6549ms
              112 timing idealTree:fixDepFlags Completed in 13ms
              113 timing idealTree Completed in 7847ms
              114 timing reify:loadTrees Completed in 7848ms
              115 timing reify:diffTrees Completed in 40ms
              116 silly reify moves {}
              117 timing reify:retireShallow Completed in 0ms
              118 timing reify:createSparse Completed in 2ms
              119 timing reify:loadBundles Completed in 0ms
              120 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
              121 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
              122 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
              123 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
              124 timing reifyNode:node_modules/osx-temperature-sensor Completed in 9ms
              125 timing reifyNode:node_modules/fsevents Completed in 10ms
              126 timing reifyNode:node_modules/mdns/node_modules/bindings Completed in 168ms
              127 timing reifyNode:node_modules/authenticate-pam Completed in 168ms
              128 timing reifyNode:node_modules/hap-controller/node_modules/ms Completed in 170ms
              129 timing reifyNode:node_modules/iobroker.homekit-controller/node_modules/ms Completed in 170ms
              130 timing reifyNode:node_modules/node-gyp/node_modules/strip-ansi Completed in 170ms
              131 timing reifyNode:node_modules/node-gyp/node_modules/string-width Completed in 170ms
              132 timing reifyNode:node_modules/node-gyp/node_modules/is-fullwidth-code-point Completed in 171ms
              133 timing reifyNode:node_modules/node-gyp/node_modules/brace-expansion Completed in 171ms
              134 timing reifyNode:node_modules/node-gyp/node_modules/ansi-regex Completed in 171ms
              135 timing reifyNode:node_modules/node-gyp/node_modules/aproba Completed in 171ms
              136 timing reifyNode:node_modules/@abandonware/noble/node_modules/ms Completed in 171ms
              137 timing reifyNode:node_modules/http-parser-js Completed in 173ms
              138 timing reifyNode:node_modules/node-gyp/node_modules/string_decoder Completed in 177ms
              139 timing reifyNode:node_modules/node-gyp/node_modules/npmlog Completed in 177ms
              140 timing reifyNode:node_modules/node-gyp/node_modules/minimatch Completed in 178ms
              141 timing reifyNode:node_modules/hap-controller/node_modules/debug Completed in 181ms
              142 timing reifyNode:node_modules/iobroker.homekit-controller/node_modules/debug Completed in 180ms
              143 timing reifyNode:node_modules/@abandonware/noble/node_modules/debug Completed in 180ms
              144 timing reifyNode:node_modules/node-hkdf-sync Completed in 182ms
              145 timing reifyNode:node_modules/usocket Completed in 182ms
              146 timing reifyNode:node_modules/node-gyp/node_modules/are-we-there-yet Completed in 183ms
              147 timing reifyNode:node_modules/node-gyp/node_modules/glob Completed in 184ms
              148 timing reifyNode:node_modules/libsodium-wrappers Completed in 186ms
              149 timing reifyNode:node_modules/@esm2cjs/p-queue/node_modules/eventemitter3 Completed in 188ms
              150 timing reifyNode:node_modules/@esm2cjs/p-timeout Completed in 188ms
              151 timing reifyNode:node_modules/napi-thread-safe-callback Completed in 188ms
              152 timing reifyNode:node_modules/net-ping Completed in 195ms
              153 timing reifyNode:node_modules/buildcheck Completed in 195ms
              154 timing reifyNode:node_modules/raw-socket Completed in 201ms
              155 timing reifyNode:node_modules/node-gyp/node_modules/gauge Completed in 201ms
              156 timing reifyNode:node_modules/fast-srp-hap Completed in 203ms
              157 timing reifyNode:node_modules/iobroker.homekit-controller/node_modules/@iobroker/adapter-core Completed in 207ms
              158 timing reifyNode:node_modules/node-gyp/node_modules/readable-stream Completed in 211ms
              159 timing reifyNode:node_modules/libsodium Completed in 212ms
              160 timing reifyNode:node_modules/@esm2cjs/p-queue Completed in 214ms
              161 timing reifyNode:node_modules/hap-controller/node_modules/node-addon-api Completed in 222ms
              162 timing reifyNode:node_modules/@abandonware/noble/node_modules/node-addon-api Completed in 221ms
              163 timing reifyNode:node_modules/vows Completed in 231ms
              164 timing reifyNode:node_modules/raw-socket/node_modules/nan Completed in 248ms
              165 timing reifyNode:node_modules/mdns Completed in 253ms
              166 timing reifyNode:node_modules/hap-controller Completed in 282ms
              167 timing reifyNode:node_modules/cpu-features Completed in 300ms
              168 timing reifyNode:node_modules/dnssd Completed in 302ms
              169 timing reifyNode:node_modules/hap-controller/node_modules/@abandonware/noble Completed in 302ms
              170 timing reifyNode:node_modules/@abandonware/noble Completed in 300ms
              171 timing reifyNode:node_modules/node-gyp Completed in 307ms
              172 timing reifyNode:node_modules/iobroker.homekit-controller Completed in 329ms
              173 timing reify:unpack Completed in 331ms
              174 timing reify:unretire Completed in 0ms
              175 timing build:queue Completed in 3ms
              176 timing build:link:node_modules/dnssd Completed in 1ms
              177 timing build:link:node_modules/node-gyp Completed in 0ms
              178 timing build:link:node_modules/vows Completed in 0ms
              179 timing build:link Completed in 1ms
              180 info run @abandonware/noble@1.9.2-19 install node_modules/@abandonware/noble node-gyp-build
              181 info run authenticate-pam@1.0.5 install node_modules/authenticate-pam node-gyp rebuild
              182 info run cpu-features@0.0.9 install node_modules/cpu-features node buildcheck.js > buildcheck.gypi && node-gyp rebuild
              183 info run mdns@2.7.2 install node_modules/mdns node-gyp rebuild
              184 info run mdns@2.7.2 install { code: 1, signal: null }
              185 verbose reify failed optional dependency /opt/iobroker/node_modules/mdns
              186 silly reify mark deleted [ '/opt/iobroker/node_modules/mdns' ]
              187 verbose reify failed optional dependency /opt/iobroker/node_modules/mdns/node_modules/bindings
              188 silly reify mark deleted [ '/opt/iobroker/node_modules/mdns/node_modules/bindings' ]
              189 timing build:run:install:node_modules/mdns Completed in 551ms
              190 info run raw-socket@1.7.0 install node_modules/raw-socket node-gyp rebuild
              191 info run authenticate-pam@1.0.5 install { code: 1, signal: null }
              192 verbose reify failed optional dependency /opt/iobroker/node_modules/authenticate-pam
              193 silly reify mark deleted [ '/opt/iobroker/node_modules/authenticate-pam' ]
              194 timing build:run:install:node_modules/authenticate-pam Completed in 590ms
              195 info run usocket@0.3.0 install node_modules/usocket node-gyp rebuild
              196 info run cpu-features@0.0.9 install { code: 1, signal: null }
              197 verbose reify failed optional dependency /opt/iobroker/node_modules/cpu-features
              198 silly reify mark deleted [ '/opt/iobroker/node_modules/cpu-features' ]
              199 verbose reify failed optional dependency /opt/iobroker/node_modules/buildcheck
              200 silly reify mark deleted [ '/opt/iobroker/node_modules/buildcheck' ]
              201 timing build:run:install:node_modules/cpu-features Completed in 648ms
              202 info run @abandonware/noble@1.9.2-20 install node_modules/hap-controller/node_modules/@abandonware/noble node-gyp-build
              203 info run @abandonware/noble@1.9.2-19 install { code: 1, signal: null }
              204 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble
              205 silly reify mark deleted [ '/opt/iobroker/node_modules/@abandonware/noble' ]
              206 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble/node_modules/debug
              207 silly reify mark deleted [ '/opt/iobroker/node_modules/@abandonware/noble/node_modules/debug' ]
              208 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble/node_modules/node-addon-api
              209 silly reify mark deleted [
              209 silly reify   '/opt/iobroker/node_modules/@abandonware/noble/node_modules/node-addon-api'
              209 silly reify ]
              210 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble/node_modules/ms
              211 silly reify mark deleted [ '/opt/iobroker/node_modules/@abandonware/noble/node_modules/ms' ]
              212 timing build:run:install:node_modules/@abandonware/noble Completed in 685ms
              213 info run raw-socket@1.7.0 install { code: 1, signal: null }
              214 verbose reify failed optional dependency /opt/iobroker/node_modules/raw-socket
              215 silly reify mark deleted [ '/opt/iobroker/node_modules/raw-socket' ]
              216 verbose reify failed optional dependency /opt/iobroker/node_modules/net-ping
              217 silly reify mark deleted [ '/opt/iobroker/node_modules/net-ping' ]
              218 verbose reify failed optional dependency /opt/iobroker/node_modules/raw-socket/node_modules/nan
              219 silly reify mark deleted [ '/opt/iobroker/node_modules/raw-socket/node_modules/nan' ]
              220 timing build:run:install:node_modules/raw-socket Completed in 433ms
              221 info run usocket@0.3.0 install { code: 1, signal: null }
              222 verbose reify failed optional dependency /opt/iobroker/node_modules/usocket
              223 silly reify mark deleted [ '/opt/iobroker/node_modules/usocket' ]
              224 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp
              225 silly reify mark deleted [
              225 silly reify   '/opt/iobroker/node_modules/node-gyp',
              225 silly reify   '/opt/iobroker/node_modules/.bin/node-gyp'
              225 silly reify ]
              226 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/glob
              227 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/glob' ]
              228 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/npmlog
              229 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/npmlog' ]
              230 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/minimatch
              231 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/minimatch' ]
              232 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/are-we-there-yet
              233 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/are-we-there-yet' ]
              234 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/gauge
              235 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/gauge' ]
              236 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/brace-expansion
              237 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/brace-expansion' ]
              238 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/readable-stream
              239 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/readable-stream' ]
              240 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/aproba
              241 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/aproba' ]
              242 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/string-width
              243 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/string-width' ]
              244 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi
              245 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi' ]
              246 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/string_decoder
              247 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/string_decoder' ]
              248 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point
              249 silly reify mark deleted [
              249 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point'
              249 silly reify ]
              250 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/ansi-regex
              251 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/ansi-regex' ]
              252 timing build:run:install:node_modules/usocket Completed in 435ms
              253 info run @abandonware/noble@1.9.2-20 install { code: 1, signal: null }
              254 timing reify:rollback:createSparse Completed in 51ms
              255 timing reify:rollback:retireShallow Completed in 0ms
              256 timing command:install Completed in 9458ms
              257 verbose stack Error: command failed
              257 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
              257 verbose stack     at ChildProcess.emit (node:events:514:28)
              257 verbose stack     at maybeClose (node:internal/child_process:1091:16)
              257 verbose stack     at ChildProcess._handle.onexit (node:internal/child_process:302:5)
              258 verbose pkgid @abandonware/noble@1.9.2-20
              259 verbose cwd /opt/iobroker
              260 verbose Linux 6.1.0-12-amd64
              261 verbose node v18.17.1
              262 verbose npm  v9.6.7
              263 error code 1
              264 error path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noble
              265 error command failed
              266 error command sh -c node-gyp-build
              267 error (node:73159) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
              267 error (Use `node --trace-deprecation ...` to show where the warning was created)
              267 error Traceback (most recent call last):
              267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
              267 error     sys.exit(gyp.script_main())
              267 error              ^^^^^^^^^^^^^^^^^
              267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
              267 error     return main(sys.argv[1:])
              267 error            ^^^^^^^^^^^^^^^^^^
              267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
              267 error     return gyp_main(args)
              267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
              267 error     [generator, flat_list, targets, data] = Load(
              267 error                                             ^^^^^
              267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
              267 error     result = gyp.input.Load(
              267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
              267 error     LoadTargetBuildFile(
              267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
              267 error     build_file_data = LoadOneBuildFile(
              267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
              267 error     build_file_contents = open(build_file_path, "rU").read()
              267 error                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
              267 error ValueError: invalid mode: 'rU' while trying to load binding.gyp
              267 error gyp ERR! configure error
              267 error gyp ERR! stack Error: `gyp` failed with exit code: 1
              267 error gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
              267 error gyp ERR! stack     at ChildProcess.emit (node:events:514:28)
              267 error gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)
              267 error gyp ERR! System Linux 6.1.0-12-amd64
              267 error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
              267 error gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noble
              267 error gyp ERR! node -v v18.17.1
              267 error gyp ERR! node-gyp -v v7.1.2
              267 error gyp ERR! not ok
              268 verbose exit 1
              269 timing npm Completed in 9617ms
              270 verbose unfinished npm timer reify 1694784894962
              271 verbose unfinished npm timer reify:build 1694784903192
              272 verbose unfinished npm timer build 1694784903193
              273 verbose unfinished npm timer build:deps 1694784903193
              274 verbose unfinished npm timer build:run:install 1694784903197
              275 verbose unfinished npm timer build:run:install:node_modules/hap-controller/node_modules/@abandonware/noble 1694784903869
              276 verbose code 1
              277 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log
              • S SirDrinsAlot
                209 silly reify ]
                225 silly reify ]
                249 silly reify ]
                263 error code 1
                267 error                                             ^^^^^
                268 verbose exit 1
                276 verbose code 1
                @abandonware/noble
                Da kann @abandonware/noble nicht gebaut werden.
                build-environment am Start?
                  SirDrinsAlot
                  Wenn ich wüsste was das wäre... Linux ist nicht mein Gebiet.
                  • S SirDrinsAlot
                    @sirdrinsalot
                    Lass mal sehen wie du da womit unterwegs bist.
                    iob diag
                    Langfassung.
                      SirDrinsAlot
                      Ohje, is ne Menge.
                       *** BASE SYSTEM ***
                       Static hostname: iobrokerNUC
                             Icon name: computer-desktop
                               Chassis: desktop 🖥️
                            Machine ID: 5d7cb8cbe58a4a17a905354431cfbb8d
                               Boot ID: 200f822a21c448e884941fd698e54ca1
                                Kernel: Linux 6.1.0-12-amd64
                          Architecture: x86-64
                       Hardware Vendor: Default string
                        Hardware Model: Default string
                      Firmware Version: 5.27
                      model name      : Intel(R) N95
                      Docker          : false
                      Virtualization  : none
                      Kernel          : x86_64
                      Userland        : amd64
                      Systemuptime and Load:
                       16:48:21 up  3:32,  3 users,  load average: 0.43, 0.35, 0.26
                      CPU threads: 4
                      *** Time and Time Zones ***
                                     Local time: Fri 2023-09-15 16:48:21 CEST
                                 Universal time: Fri 2023-09-15 14:48:21 UTC
                                       RTC time: Fri 2023-09-15 14:48:21
                                    NTP service: active
                                RTC in local TZ: no
                      *** User and Groups ***
                      root
                      /root
                      root
                      *** X-Server-Setup ***
                      X-Server:       true
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:             16G        5.5G        4.6G        210M        7.0G         11G
                      Swap:           1.0G          0B        1.0G
                      Total:           17G        5.5G        5.6G
                              15767 M total memory
                               5258 M used memory
                               1133 M active memory
                               9391 M inactive memory
                               4349 M free memory
                                242 M buffer memory
                               6451 M swap cache
                                975 M total swap
                                  0 M used swap
                                975 M free swap
                      *** FILESYSTEM ***
                      udev           devtmpfs  7.7G     0  7.7G   0% /dev
                      tmpfs          tmpfs     1.6G  1.5M  1.6G   1% /run
                      /dev/sda2      ext4      467G  9.8G  434G   3% /
                      tmpfs          tmpfs     7.7G  792K  7.7G   1% /dev/shm
                      tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                      /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
                      tmpfs          tmpfs     1.6G  3.7M  1.6G   1% /run/user/1000
                      [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                      Show mounted filesystems (real ones only):
                      TARGET               SOURCE    FSTYPE      OPTIONS
                      /                    /dev/sda2 ext4        rw,relatime,errors=remount-ro
                      |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                      `-/boot/efi          /dev/sda1 vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
                      /var:
                      503M    /var/
                      231M    /var/cache
                      221M    /var/cache/apt
                      216M    /var/lib
                      145M    /var/cache/apt/archives
                      Archived and active journals take up 32.0M in the file system.
                      /opt/iobroker/backups:
                      71M     /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      784M    /opt/iobroker/iobroker-data/
                      698M    /opt/iobroker/iobroker-data/files
                      119M    /opt/iobroker/iobroker-data/files/vis-2
                      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                      71M     /opt/iobroker/iobroker-data/files/vis-2/static
                      73M     /opt/iobroker/iobroker-data/objects.jsonl
                      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.67295ba8.js.map
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v18.17.1
                      /usr/bin/node           v18.17.1
                      /usr/bin/npm            9.6.7
                      /usr/bin/npx            9.6.7
                      nodejs:
                        Installed: 18.17.1-deb-1nodesource1
                        Candidate: 18.17.1-deb-1nodesource1
                        Version table:
                       *** 18.17.1-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
                              100 /var/lib/dpkg/status
                           18.13.0+dfsg1-1 500
                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      No configuration change needed.
                      Multihost discovery server: disabled
                      Discovery authentication:   enabled
                      Persistent activation:      disabled
                      Objects:                    jsonl on 127.0.0.1
                      States:                     jsonl on 127.0.0.1
                      Core adapters versions
                      js-controller:  5.0.12
                      admin:          6.10.1
                      javascript:     7.1.4
                      Adapters from github:   5
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : iobrokerNUC                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                        system.adapter.admin.1                  : admin                 : iobrokerNUC                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.alexa2.0                 : alexa2                : iobrokerNUC                              - disabled
                      + system.adapter.backitup.0               : backitup              : iobrokerNUC                              -  enabled
                        system.adapter.ble.0                    : ble                   : iobrokerNUC                              - disabled
                        system.adapter.broadlink2.0             : broadlink2            : iobrokerNUC                              - disabled
                        system.adapter.cameras.0                : cameras               : iobrokerNUC                              - disabled, port: 8200, bind: 0.0.0.0
                        system.adapter.chromecast.0             : chromecast            : iobrokerNUC                              - disabled
                        system.adapter.cloud.0                  : cloud                 : iobrokerNUC                              - disabled
                        system.adapter.daswetter.0              : daswetter             : iobrokerNUC                              - disabled
                        system.adapter.devices.0                : devices               : iobrokerNUC                              - disabled
                        system.adapter.discovery.0              : discovery             : iobrokerNUC                              - disabled
                        system.adapter.ecovacs-deebot.2         : ecovacs-deebot        : iobrokerNUC                              - disabled
                        system.adapter.ecovacs-deebot.3         : ecovacs-deebot        : iobrokerNUC                              - disabled
                        system.adapter.ecovacs-deebot.4         : ecovacs-deebot        : iobrokerNUC                              - disabled
                        system.adapter.energiefluss.0           : energiefluss          : iobrokerNUC                              - disabled
                        system.adapter.eusec.0                  : eusec                 : iobrokerNUC                              - disabled
                        system.adapter.feiertage.0              : feiertage             : iobrokerNUC                              - disabled
                        system.adapter.flot.0                   : flot                  : iobrokerNUC                              - disabled
                        system.adapter.fritzbox.0               : fritzbox              : iobrokerNUC                              - disabled
                        system.adapter.fritzdect.0              : fritzdect             : iobrokerNUC                              - disabled
                        system.adapter.fullcalendar.0           : fullcalendar          : iobrokerNUC                              - disabled
                        system.adapter.fullybrowser.0           : fullybrowser          : iobrokerNUC                              - disabled
                        system.adapter.govee-app.0              : govee-app             : iobrokerNUC                              - disabled
                        system.adapter.habpanel.0               : habpanel              : iobrokerNUC                              - disabled
                        system.adapter.history.0                : history               : iobrokerNUC                              - disabled
                        system.adapter.hm-rega.0                : hm-rega               : iobrokerNUC                              - disabled
                        system.adapter.hm-rpc.0                 : hm-rpc                : iobrokerNUC                              - disabled, port: 0
                        system.adapter.hm-rpc.1                 : hm-rpc                : iobrokerNUC                              - disabled, port: 0
                        system.adapter.homeconnect.0            : homeconnect           : iobrokerNUC                              - disabled
                        system.adapter.homekit-controller.0     : homekit-controller    : iobrokerNUC                              - disabled
                        system.adapter.homepilot20.0            : homepilot20           : iobrokerNUC                              - disabled
                        system.adapter.hue-extended.0           : hue-extended          : iobrokerNUC                              - disabled
                        system.adapter.hue.0                    : hue                   : iobrokerNUC                              - disabled, port: 443
                        system.adapter.ical.0                   : ical                  : iobrokerNUC                              - disabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobrokerNUC                              - disabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobrokerNUC                              - disabled
                        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobrokerNUC                              - disabled
                        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobrokerNUC                              - disabled
                        system.adapter.influxdb.0               : influxdb              : iobrokerNUC                              - disabled, port: 8090
                        system.adapter.info.0                   : info                  : iobrokerNUC                              - disabled
                        system.adapter.iot.0                    : iot                   : iobrokerNUC                              - disabled
                        system.adapter.javascript.0             : javascript            : iobrokerNUC                              - disabled
                        system.adapter.linux-control.0          : linux-control         : iobrokerNUC                              - disabled
                        system.adapter.material.0               : material              : iobrokerNUC                              - disabled
                        system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobrokerNUC                              - disabled, port: 54321
                        system.adapter.mihome.0                 : mihome                : iobrokerNUC                              - disabled, port: 9898, bind: 0.0.0.0
                        system.adapter.mobile.0                 : mobile                : iobrokerNUC                              - disabled
                        system.adapter.mqtt.0                   : mqtt                  : iobrokerNUC                              - disabled, port: 1888, bind: 0.0.0.0
                        system.adapter.musiccast.0              : musiccast             : iobrokerNUC                              - disabled
                        system.adapter.net-tools.0              : net-tools             : iobrokerNUC                              - disabled
                        system.adapter.netatmo.0                : netatmo               : iobrokerNUC                              - disabled
                        system.adapter.netatmo.1                : netatmo               : iobrokerNUC                              - disabled
                        system.adapter.node-red.0               : node-red              : iobrokerNUC                              - disabled, port: 1880, bind: 192.168.178.143
                        system.adapter.radar2.0                 : radar2                : iobrokerNUC                              - disabled
                        system.adapter.sayit.0                  : sayit                 : iobrokerNUC                              - disabled
                        system.adapter.scenes.0                 : scenes                : iobrokerNUC                              - disabled
                        system.adapter.shelly.0                 : shelly                : iobrokerNUC                              - disabled, port: 1886, bind: 0.0.0.0
                        system.adapter.simple-api.0             : simple-api            : iobrokerNUC                              - disabled, port: 8087, bind: 192.168.178.143, run as: admin
                        system.adapter.slideshow.0              : slideshow             : iobrokerNUC                              - disabled
                        system.adapter.smartthings.0            : smartthings           : iobrokerNUC                              - disabled
                        system.adapter.socketio.0               : socketio              : iobrokerNUC                              - disabled, port: 8085, bind: 0.0.0.0, run as: admin
                        system.adapter.sonoff.0                 : sonoff                : iobrokerNUC                              - disabled, port: 1883, bind: 192.168.178.143
                        system.adapter.sourceanalytix.0         : sourceanalytix        : iobrokerNUC                              - disabled
                        system.adapter.synology.0               : synology              : iobrokerNUC                              - disabled, port: 5000
                        system.adapter.telegram.0               : telegram              : iobrokerNUC                              - disabled, port: 8443, bind: 0.0.0.0
                        system.adapter.terminal.0               : terminal              : iobrokerNUC                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                        system.adapter.text2command.0           : text2command          : iobrokerNUC                              - disabled
                        system.adapter.tileboard.0              : tileboard             : iobrokerNUC                              - disabled
                        system.adapter.tr-064.0                 : tr-064                : iobrokerNUC                              - disabled
                        system.adapter.tuya.0                   : tuya                  : iobrokerNUC                              - disabled
                        system.adapter.vis-2.0                  : vis-2                 : iobrokerNUC                              - disabled
                        system.adapter.vis-bars.0               : vis-bars              : iobrokerNUC                              - disabled
                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobrokerNUC                              - disabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokerNUC                              - disabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobrokerNUC                              - disabled
                        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobrokerNUC                              - disabled
                        system.adapter.vis-history.0            : vis-history           : iobrokerNUC                              - disabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobrokerNUC                              - disabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : iobrokerNUC                              - disabled
                        system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokerNUC                              - disabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokerNUC                              - disabled
                        system.adapter.vis-justgage.0           : vis-justgage          : iobrokerNUC                              - disabled
                        system.adapter.vis-keyboard.0           : vis-keyboard          : iobrokerNUC                              - disabled
                        system.adapter.vis-lcars.0              : vis-lcars             : iobrokerNUC                              - disabled
                        system.adapter.vis-map.0                : vis-map               : iobrokerNUC                              - disabled
                        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobrokerNUC                              - disabled
                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokerNUC                              - disabled
                        system.adapter.vis-metro.0              : vis-metro             : iobrokerNUC                              - disabled
                        system.adapter.vis-players.0            : vis-players           : iobrokerNUC                              - disabled
                        system.adapter.vis-plumb.0              : vis-plumb             : iobrokerNUC                              - disabled
                        system.adapter.vis-rgraph.0             : vis-rgraph            : iobrokerNUC                              - disabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokerNUC                              - disabled
                        system.adapter.vis-weather.0            : vis-weather           : iobrokerNUC                              - disabled
                        system.adapter.vis.0                    : vis                   : iobrokerNUC                              - disabled
                        system.adapter.web.0                    : web                   : iobrokerNUC                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobrokerNUC                              - disabled
                        system.adapter.wifilight.0              : wifilight             : iobrokerNUC                              - disabled
                        system.adapter.yeelight-2.0             : yeelight-2            : iobrokerNUC                              - disabled
                        system.adapter.yr.0                     : yr                    : iobrokerNUC                              - disabled
                        system.adapter.zigbee.0                 : zigbee                : iobrokerNUC                              - disabled, port: /dev/ttyUSB0
                        system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobrokerNUC                              - disabled
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Installed ioBroker-Instances
                      Used repository: stable
                      Adapter    "admin"        : 6.8.0    , installed 6.10.1
                      Adapter    "alexa2"       : 3.24.1   , installed 3.25.2
                      Adapter    "backitup"     : 2.6.23   , installed 2.8.1
                      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                      Adapter    "devices"      : 1.1.5    , installed 1.1.5
                      Adapter    "discovery"    : 3.1.0    , installed 4.0.0
                      Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                      Adapter    "eusec"        : 1.1.2    , installed 1.1.2
                      Adapter    "feiertage"    : 1.1.0    , installed 1.1.4
                      Adapter    "fritzbox"     : 0.2.1    , installed 0.5.0
                      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                      Adapter    "fullcalendar" : 1.2.0    , installed 2.2.6
                      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                      Adapter    "history"      : 2.2.6    , installed 2.2.6
                      Adapter    "hm-rega"      : 3.0.47   , installed 4.0.0
                      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                      Adapter    "hue"          : 3.9.5    , installed 3.10.0
                      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                      Adapter    "ical"         : 1.13.3   , installed 1.13.3
                      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                      Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
                      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                      Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
                      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                      Adapter    "info"         : 1.9.26   , installed 2.0.0
                      Adapter    "iot"          : 1.14.5   , installed 2.0.11
                      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                      Controller "js-controller": 5.0.12   , installed 5.0.12
                      Adapter    "linux-control": 1.1.5    , installed 1.1.5
                      Adapter    "material"     : 1.3.1    , installed 1.3.1
                      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                      Adapter    "mihome-vacuum": 3.11.0   , installed 4.0.0
                      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                      Adapter    "musiccast"    : 1.1.0    , installed 1.1.0
                      Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                      Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                      Adapter    "scenes"       : 2.3.9    , installed 2.3.9
                      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                      Adapter    "socketio"     : 6.5.5    , installed 6.5.3  [Updatable]
                      Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
                      Adapter    "synology"     : 2.1.13   , installed 3.0.0
                      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                      Adapter    "text2command" : 3.0.2    , installed 3.0.2
                      Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
                      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                      Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
                      Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
                      Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
                      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                      Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
                      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.4
                      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                      Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
                      Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
                      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                      Adapter    "web"          : 6.1.2    , installed 6.1.1  [Updatable]
                      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                      Adapter    "ws"           : 2.5.5    , installed 2.5.3  [Updatable]
                      Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                      Adapter    "yr"           : 5.3.0    , installed 5.3.0
                      Adapter    "zigbee"       : 1.8.23   , installed 1.8.24
                      Adapter    "zigbee2mqtt"  : 2.13.1   , installed 2.13.1
                      Objects and States
                      Objects:        37997
                      States:         31034
                      W: http://deb.anydesk.com/dists/all/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                      Hit:1 https://deb.nodesource.com/node_18.x bookworm InRelease
                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                      Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                      Hit:4 http://deb.anydesk.com all InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:37838           0.0.0.0:*               LISTEN      0          188418     28229/anydesk
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          21612      662/cupsd
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       212660     43636/iobroker.js-c
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       211792     43636/iobroker.js-c
                      tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          145110     28229/anydesk
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          166031     33594/sshd: /usr/sb
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          135901     1/init
                      tcp        0      0 127.0.0.1:4101          0.0.0.0:*               LISTEN      0          21672      544/brltty
                      tcp6       0      0 ::1:4101                :::*                    LISTEN      0          17962      544/brltty
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       211857     43667/io.admin.0
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          21611      662/cupsd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          166033     33594/sshd: /usr/sb
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          136579     1/init
                      udp        0      0 0.0.0.0:56190           0.0.0.0:*                           103        17893      594/avahi-daemon: r
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          137387     1/init
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23634      907/cups-browsed
                      udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          146842     28229/anydesk
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           103        17891      594/avahi-daemon: r
                      udp6       0      0 :::111                  :::*                                0          136581     1/init
                      udp6       0      0 :::52127                :::*                                103        17894      594/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                103        17892      594/avahi-daemon: r
                      2023-09-15 15:18:57.566  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                      2023-09-15 15:19:42.074  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:69843) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_18_57_748Z-debug-0.log
                      2023-09-15 15:19:42.074  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                      2023-09-15 15:19:43.092  - info: host.iobrokerNUC iobroker exit 25
                      2023-09-15 15:23:58.531  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
                      2023-09-15 15:23:59.537  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
                      2023-09-15 15:23:59.537  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                      2023-09-15 15:24:04.010  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:70887) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_23_59_740Z-debug-0.log
                      2023-09-15 15:24:04.011  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                      2023-09-15 15:24:05.036  - info: host.iobrokerNUC iobroker exit 25
                      2023-09-15 15:34:53.572  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
                      2023-09-15 15:34:54.600  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
                      2023-09-15 15:34:54.601  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                      2023-09-15 15:35:04.442  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:73159) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log
                      2023-09-15 15:35:04.443  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                      2023-09-15 15:35:05.468  - info: host.iobrokerNUC iobroker exit 25
                      2023-09-15 16:34:59.946  - info: admin.0 (43667) ==> Connected system.user.admin from ::ffff:192.168.178.105
                      2023-09-15 16:35:01.497  - info: host.iobrokerNUC Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                      2023-09-15 16:39:44.533  - info: admin.0 (43667) <== Disconnect system.user.admin from ::ffff:192.168.178.105
                      2023-09-15 16:39:53.534  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
                      2023-09-15 16:39:54.568  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
                      2023-09-15 16:39:54.569  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                      2023-09-15 16:40:03.838  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:85655) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T14_39_54_749Z-debug-0.log
                      2023-09-15 16:40:03.838  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                      2023-09-15 16:40:04.857  - info: host.iobrokerNUC iobroker exit 25
                                           v.2023-06-20
                               Chassis: desktop 🖥️
                      Installation:           native
                      Kernel:                 x86_64
                      Userland:               amd64
                      Timezone:               Europe/Berlin (CEST, +0200)
                      User-ID:                0
                      X-Server:               true
                      Pending OS-Updates:     0
                      • S SirDrinsAlot
                        Ohje, is ne Menge.
                         *** BASE SYSTEM ***
                                 Chassis: desktop 🖥️
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : amd64
                        CPU threads: 4
                                      NTP service: active
                                  RTC in local TZ: no
                        root
                        /root
                        root
                        X-Server:       true
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           1.0G          0B        1.0G
                                 5258 M used memory
                                 4349 M free memory
                                  242 M buffer memory
                                 6451 M swap cache
                                  975 M total swap
                                    0 M used swap
                                  975 M free swap
                        *** FILESYSTEM ***
                        /var:
                        503M    /var/
                        231M    /var/cache
                        221M    /var/cache/apt
                        216M    /var/lib
                        /usr/bin/npm            9.6.7
                        /usr/bin/npx            9.6.7
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.10.1
                        javascript:     7.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        37997
                        States:         31034
                        Pending Updates: 0
                                             v.2023-06-20
                                 Chassis: desktop 🖥️
                        Kernel:                 x86_64
                        Userland:               amd64
                        User-ID:                0
                        X-Server:               true
                        @sirdrinsalot
                        Statt spoiler die codetags verwenden.
                          SirDrinsAlot
                          HAt nicht funktioniert, kam Forbidden, sry.
                          • S SirDrinsAlot
                            Ohje, is ne Menge.
                             *** BASE SYSTEM ***
                                     Chassis: desktop 🖥️
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : amd64
                            CPU threads: 4
                                          NTP service: active
                                      RTC in local TZ: no
                            root
                            /root
                            root
                            X-Server:       true
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:           1.0G          0B        1.0G
                                     5258 M used memory
                                     4349 M free memory
                                      242 M buffer memory
                                     6451 M swap cache
                                      975 M total swap
                                        0 M used swap
                                      975 M free swap
                            *** FILESYSTEM ***
                            /var:
                            503M    /var/
                            231M    /var/cache
                            221M    /var/cache/apt
                            216M    /var/lib
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
                            nodejs:
                              Version table:
                                 18.13.0+dfsg1-1 500
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.10.1
                            javascript:     7.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        37997
                            States:         31034
                            Pending Updates: 0
                                                 v.2023-06-20
                                     Chassis: desktop 🖥️
                            Kernel:                 x86_64
                            Userland:               amd64
                            User-ID:                0
                            X-Server:               true
                            User-ID: 0
                            X-Server: true
                            Boot Target: graphical.target
                            Root und Desktop...
                            'nuff seen.
                            Schalt den Krampf aus und agier da als Standard-User.
                              @sirdrinsalot
                              @thomas-braun sagte in Homekit-controller lässt sich nicht installieren:
                              @sirdrinsalot
                              habs gefixt
                                @sirdrinsalot
                                habs gefixt
                                @homoran sagte in Homekit-controller lässt sich nicht installieren:
                                habs gefixt
                                Den Desktop und den root? Respekt!
                                  habs gefixt
                                  habs gefixt
                                  Natürlich!
                                  ist jetzt forbidden!
                                    SirDrinsAlot
                                    Mein Standarduser hat keine Rootrechte, hat mich nur im Nachhinein als root angemeldet für Reparaturversuche.
                                    Ohne root hats eben auch nicht funktioniert.
                                      habs gefixt
                                      Natürlich!
                                      Ja, das ohnehin. AnyDesk ist auch verboten.
                                      • S SirDrinsAlot
                                        @sirdrinsalot und root verbiegt noch die letzten Rechte vom user iobroker
                                        dann nimm jetzt den root und gib deinem user roottechte.
                                        melde dich dann als user an und mach
                                        iob stop
                                        iob fix
                                        iob start
                                        • S SirDrinsAlot
                                          Richtig, der sollte aber per sudo in die root-Rolle wechseln können. Man meldet sich niemals als root an. Schon gar nicht auf einem Desktop.
