  4. Restore auf Bookworm: VIS ohne Funktion
    2.4k
vis
23 Beiträge 4 Kommentatoren 2.3k Aufrufe 3 Beobachtet
    @robocop sagte in Restore auf Bookworm: VIS ohne Funktion:
    *** 18.13.0+dfsg1-1 500
    RoboCopR Offline
    RoboCopR Offline
    RoboCop
    @homoran und was sagt mir das?
    habe icxh doch gesagt ...geht nur 18.13.0
    ich kenne mich da nicht so aus damit
    • RoboCopR RoboCop
      @thomas-braun said in
      Die Langfassung bitte.
      Da ist aber nicht die nodesource-Version von nodejs installiert worden, die brächte nämlich npm und npx usw. mit.
      bitte schön:
      robocop0815@debian12:~$ iob diag
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the ``` characters at start and end.
      It helps us to help you!
      Press any key to continue
      ======== Start marking the full check here =========
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : microsoft
      Distributor ID: Debian
      Description:    Debian GNU/Linux 12 (bookworm)
      Release:        12
      Codename:       bookworm
      PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
      NAME="Debian GNU/Linux"
      VERSION_ID="12"
      VERSION="12 (bookworm)"
      VERSION_CODENAME=bookworm
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       17:41:49 up 6 min,  2 users,  load average: 1.75, 0.93, 0.44
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Wed 2023-08-30 17:41:49 CEST
                 Universal time: Wed 2023-08-30 15:41:49 UTC
                       RTC time: Wed 2023-08-30 15:41:48
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      robocop0815
      /home/robocop0815
      robocop0815 cdrom floppy sudo audio dip video plugdev users netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.1G        1.8G        2.2G        3.7M        292M        2.3G
      Swap:           1.0G          0B        1.0G
      Total:          5.1G        1.8G        3.2G
               3880 M total memory
               1702 M used memory
                113 M active memory
               1396 M inactive memory
               2117 M free memory
                 19 M buffer memory
                259 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     389M  556K  388M   1% /run
      /dev/sda1      ext4      124G  3.2G  115G   3% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
      [Wed Aug 30 17:35:42 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Aug 30 17:35:45 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      536M    /var/
      238M    /var/cache
      231M    /var/cache/apt
      177M    /var/lib
      155M    /var/cache/apt/archives
      Archived and active journals take up 39.3M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      113M    /opt/iobroker/iobroker-data/
      62M     /opt/iobroker/iobroker-data/files
      28M     /opt/iobroker/iobroker-data/files/vis.0
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      44M     /opt/iobroker/iobroker-data/objects.jsonl
      7.8M    /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
      6.6M    /opt/iobroker/iobroker-data/states.jsonl
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      4.7M    /opt/iobroker/iobroker-data/files/vis.0/Spiegel1/vis-views.json
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.13.0
      /usr/bin/node           v18.13.0
      /home/iobroker/.diag.sh: line 168: npm: command not found
      /home/iobroker/.diag.sh: line 169: npx: command not found
      /home/iobroker/.diag.sh: line 177: npm: command not found
      /home/iobroker/.diag.sh: line 178: npx: command not found
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 18.13.0+dfsg1-1
        Candidate: 18.13.0+dfsg1-1
        Version table:
              500 cdrom://[Debian GNU/Linux 12.1.0 _Bookworm_ - Official amd64 DVD Binary-1 with firmware 20230722-10:49] bookworm/main amd64 Packages
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
              100 /var/lib/dpkg/status
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.8.0
      javascript:     "javascript" not found
      /home/iobroker/.diag.sh: line 248: npm: command not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : debian12                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : debian12                                 -  enabled
      + system.adapter.backitup.0               : backitup              : debian12                                 -  enabled
      + system.adapter.backitup.1               : backitup              : IOB-Slave                                -  enabled
      + system.adapter.ble.0                    : ble                   : IOB-Slave                                -  enabled
        system.adapter.broadlink2.0             : broadlink2            : debian12                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : debian12                                 -  enabled
        system.adapter.device-reminder.0        : device-reminder       : debian12                                 -  enabled
      + system.adapter.discovery.0              : discovery             : debian12                                 -  enabled
        system.adapter.flot.0                   : flot                  : debian12                                 -  enabled
        system.adapter.harmony.0                : harmony               : debian12                                 -  enabled
        system.adapter.history.0                : history               : debian12                                 -  enabled
        system.adapter.hm-rega.0                : hm-rega               : debian12                                 -  enabled
        system.adapter.hm-rpc.0                 : hm-rpc                : debian12                                 -  enabled, port: 0
        system.adapter.hm-rpc.1                 : hm-rpc                : debian12                                 -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : debian12                                 -  enabled
        system.adapter.ical.1                   : ical                  : debian12                                 -  enabled
        system.adapter.ical.2                   : ical                  : debian12                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : debian12                                 -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : debian12                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : debian12                                 -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: debian12                                 -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : debian12                                 -  enabled
        system.adapter.info.0                   : info                  : debian12                                 -  enabled
        system.adapter.iot.0                    : iot                   : debian12                                 -  enabled
        system.adapter.javascript.0             : javascript            : debian12                                 -  enabled
        system.adapter.mclighting.0             : mclighting            : debian12                                 -  enabled, port: 81
        system.adapter.mihome.0                 : mihome                : debian12                                 -  enabled, port: 9898, bind: 0.0.0.0
        system.adapter.mqtt.0                   : mqtt                  : debian12                                 -  enabled, port: 1886, bind: 0.0.0.0
        system.adapter.nina.0                   : nina                  : debian12                                 -  enabled
        system.adapter.node-red.0               : node-red              : debian12                                 -  enabled, port: 1888, bind: 0.0.0.0
        system.adapter.octoprint.0              : octoprint             : debian12                                 -  enabled
        system.adapter.octoprint.1              : octoprint             : debian12                                 -  enabled
        system.adapter.octoprint.2              : octoprint             : debian12                                 -  enabled
        system.adapter.parcel.0                 : parcel                : debian12                                 -  enabled
        system.adapter.ping.0                   : ping                  : debian12                                 -  enabled
        system.adapter.plenticore.0             : plenticore            : debian12                                 -  enabled, port: 80
        system.adapter.pollenflug.0             : pollenflug            : debian12                                 -  enabled
        system.adapter.sayit.0                  : sayit                 : debian12                                 -  enabled
        system.adapter.scenes.0                 : scenes                : debian12                                 -  enabled
        system.adapter.shelly.0                 : shelly                : debian12                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.sonoff.0                 : sonoff                : debian12                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.statistics.0             : statistics            : debian12                                 -  enabled
        system.adapter.tankerkoenig.0           : tankerkoenig          : debian12                                 -  enabled
        system.adapter.tankerkoenig.1           : tankerkoenig          : debian12                                 -  enabled
        system.adapter.tankerkoenig.2           : tankerkoenig          : debian12                                 -  enabled
        system.adapter.telegram.0               : telegram              : debian12                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.telegram.1               : telegram              : debian12                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.terminal.0               : terminal              : debian12                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        system.adapter.text2command.0           : text2command          : debian12                                 -  enabled
        system.adapter.text2command.1           : text2command          : debian12                                 -  enabled
        system.adapter.tr-064.0                 : tr-064                : debian12                                 -  enabled
        system.adapter.trashschedule.0          : trashschedule         : debian12                                 -  enabled
        system.adapter.tuya.0                   : tuya                  : debian12                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : debian12                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : debian12                                 -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : debian12                                 -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : debian12                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian12                                 -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : debian12                                 -  enabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : debian12                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debian12                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : debian12                                 -  enabled
        system.adapter.vis-metro.0              : vis-metro             : debian12                                 -  enabled
        system.adapter.vis-owl.0                : vis-owl               : debian12                                 -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : debian12                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian12                                 -  enabled
        system.adapter.vis-weather.0            : vis-weather           : debian12                                 -  enabled
        system.adapter.vis.0                    : vis                   : debian12                                 -  enabled
      + system.adapter.web.0                    : web                   : debian12                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.worx.0                   : worx                  : debian12                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : IOB-Slave                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_64d0cc0f5286ec11ae4beb3719c2d21c-if00-port0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Adapter    "admin"        : 6.8.0    , installed 6.8.0
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "socketio"     : 4.2.0    , installed 4.2.0
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "web"          : 4.3.0    , installed 4.3.0
      Adapter    "ws"           : 1.3.0    , installed 1.3.0
      Objects and States
      Objects:        26246
      States:         22347
      E: The repository 'cdrom://[Debian GNU/Linux 12.1.0 _Bookworm_ - Official amd64 DVD Binary-1 with firmware 20230722-10:49] bookworm Release' does not have a Release file.
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       24663      534/iobroker.js-con
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       2042       534/iobroker.js-con
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          903        1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          24092      596/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18215      625/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17362      1321/io.web.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          15388      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          24094      596/sshd: /usr/sbin
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          20381      1/init
      udp6       0      0 :::111                  :::*                                0          904        1/init
      2023-08-30 17:42:29.369  - error: host.debian12 iobroker npm-install: /bin/sh: 1: npm: not foundError trying to check npm version: Command failed: npm -v/bin/sh: 1: npm: not found!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Aborting install because the npm version could not be checked!Please check that npm is installed correctly.Use "npm install -g npm@4" or "npm install -g npm@latest" to install a supported version.You need to make sure to repeat this step after installing an update to NodeJS and/or npm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      2023-08-30 17:42:30.416  - info: host.debian12 iobroker npm-install: exit 30
      2023-08-30 17:42:30.416  - info: host.debian12 startInstance system.adapter.telegram.0: instance is disabled but should be started, re-enabling it
      2023-08-30 17:42:30.424  - info: host.debian12 instance "system.adapter.telegram.0" enabled via .alive
      2023-08-30 17:42:30.463  - info: host.debian12 "system.adapter.telegram.0" enabled
      2023-08-30 17:42:31.417  - warn: host.debian12 startInstance cannot find adapter "telegram@1.16.0". Try to install it... 1 attempt
      2023-08-30 17:42:31.417  - info: host.debian12 iobroker install telegram@1.16.0 using installedFrom
      2023-08-30 17:42:33.956  - info: host.debian12 iobroker npm-install: host.debian12 Adapter "system.adapter.telegram.0" is stopped.
      2023-08-30 17:42:34.044  - info: host.debian12 "system.adapter.telegram.0" disabled
      2023-08-30 17:42:34.066  - error: host.debian12 iobroker npm-install: /bin/sh: 1: npm: not found
      2023-08-30 17:42:34.067  - error: host.debian12 iobroker npm-install: Error trying to check npm version: Command failed: npm -v/bin/sh: 1: npm: not found!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      2023-08-30 17:42:34.068  - error: host.debian12 iobroker npm-install: Aborting install because the npm version could not be checked!Please check that npm is installed correctly.Use "npm install -g npm@4" or "npm install -g npm@latest" to install a supported version.You need to make sure to repeat this step after installing an update to NodeJS and/or npm
      2023-08-30 17:42:34.069  - error: host.debian12 iobroker npm-install: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      2023-08-30 17:42:35.094  - info: host.debian12 iobroker npm-install: exit 30
      2023-08-30 17:42:35.094  - info: host.debian12 startInstance system.adapter.telegram.1: instance is disabled but should be started, re-enabling it
      2023-08-30 17:42:35.106  - info: host.debian12 instance "system.adapter.telegram.1" enabled via .alive
      2023-08-30 17:42:35.125  - info: host.debian12 "system.adapter.telegram.1" enabled
      2023-08-30 17:42:36.345  - warn: host.debian12 startInstance cannot find adapter "alexa2@3.24.1". Try to install it... 1 attempt
      2023-08-30 17:42:36.345  - info: host.debian12 iobroker install alexa2@3.24.1 using installedFrom
      2023-08-30 17:42:38.842  - error: host.debian12 iobroker npm-install: /bin/sh: 1: npm: not found
      2023-08-30 17:42:38.844  - error: host.debian12 iobroker npm-install: Error trying to check npm version: Command failed: npm -v/bin/sh: 1: npm: not found
      2023-08-30 17:42:38.844  - error: host.debian12 iobroker npm-install: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Aborting install because the npm version could not be checked!Please check that npm is installed correctly.
      2023-08-30 17:42:38.845  - error: host.debian12 iobroker npm-install: Use "npm install -g npm@4" or "npm install -g npm@latest" to install a supported version.You need to make sure to repeat this step after installing an update to NodeJS and/or npm
      2023-08-30 17:42:38.846  - error: host.debian12 iobroker npm-install: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      2023-08-30 17:42:39.890  - info: host.debian12 iobroker npm-install: exit 30
      iob diag has finished.
      E: The repository 'cdrom://[Debian GNU/Linux 12.1.0 Bookworm - Official amd64 DVD Binary-1 with firmware 20230722-10:49] bookworm Release' does not have a Release file.
      Das kannst du löschen.
      Versuch mal den 'neusten heißen Shit aus dem Hause nodesource':
      sudo apt update
      sudo apt install -y ca-certificates curl gnupg
      curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
      NODE_MAJOR=18
      echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
      sudo apt update
      apt policy nodejs
      • RoboCopR RoboCop
        was sagt mir das?
        dass du node falsch installiert hast.
        bitte der Anleitung von @Thomas-Braun folgen und uns dann sagen wie du es gemacht hattest.
        83.2k
