  4. Kein Adapter Update nach NodeJS 18 Update
    5.2k
nodejsadapter update probleme
14 Beiträge 4 Kommentatoren 1.7k Aufrufe 2 Beobachtet
    BruderBleistift
    nach einem NodeJS Update kann ich keine Adapter mehr updaten.
    Ich habe bereits alle Tipps aus dem Forum umgesetzt. NodeJS nach @Thomas-Braun Anleitung neu installiert, seinen Einzeiler zum Löschen von unnötigen Ordnern und auch den iob Fix.
    -> iob upgrade admin --debug
    Would you like to upgrade admin from @6.3.5 to @6.8.0 now? [(y)es, (n)o]: y
    Update admin from @6.3.5 to @6.8.0
    NPM version: 9.6.7
    Installing iobroker.admin@6.8.0... (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/pcap
    npm ERR! dest /opt/iobroker/node_modules/.pcap-xkmgBhAF
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/pcap' -> '/opt/iobroker/node_modules/.pcap-xkmgBhAF'
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-29T20_24_24_645Z-debug-0.log
    host.iobroker Cannot install iobroker.admin@6.8.0: 217
    anschließend:
    paul@iobroker:~$ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%/}; done
    und erneut -> iob upgrade admin --debug
    NPM version: 9.6.7
    npm WARN skipping integrity check for git dependency ssh://git@github.com/nobl/ioBroker.tesla-wallconnector3.git
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN cleanup Failed to remove some directories [
    npm WARN cleanup   [
    npm WARN cleanup     '/opt/iobroker/node_modules/unix-dgram',
    npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/unix-dgram'] {
    npm WARN cleanup       errno: -39,
    npm WARN cleanup       code: 'ENOTEMPTY',
    npm WARN cleanup       syscall: 'rmdir',
    npm WARN cleanup       path: '/opt/iobroker/node_modules/unix-dgram'
    npm WARN cleanup     }
    npm WARN cleanup   ],
    npm WARN cleanup   [
    npm WARN cleanup     '/opt/iobroker/node_modules/pcap',
    npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/pcap'] {
    npm WARN cleanup       path: '/opt/iobroker/node_modules/pcap'
    npm WARN cleanup     }
    npm WARN cleanup   ],
    npm WARN cleanup   [
    npm WARN cleanup     }
    npm WARN cleanup   ]
    npm WARN cleanup ]
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/openzwave-shared
    npm ERR! command failed
    npm ERR! command sh -c node-gyp rebuild
    npm ERR! make: Entering directory '/opt/iobroker/node_modules/openzwave-shared/build'
    npm ERR!   CXX(target) Release/obj.target/openzwave_shared/src/callbacks.o
    npm ERR! make: Leaving directory '/opt/iobroker/node_modules/openzwave-shared/build'
    npm ERR! gyp info it worked if it ends with ok
    npm ERR! gyp info using node-gyp@9.3.1
    npm ERR! gyp info using node@18.17.1 | linux | x64
    npm ERR! gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3"
    npm ERR! gyp info spawn /usr/bin/python3
    npm ERR! gyp info spawn args [
    npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
    npm ERR! gyp info spawn args   'binding.gyp',
    npm ERR! gyp info spawn args   '-f',
    npm ERR! gyp info spawn args   'make',
    npm ERR! gyp info spawn args   '-I',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/openzwave-shared/build/config.gypi',
    npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
    npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.17.1/include/node/common.gypi',
    npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
    npm ERR! gyp info spawn args   '-Dvisibility=default',
    npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.17.1',
    npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
    npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.17.1/<(target_arch)/node.lib',
    npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/openzwave-shared',
    npm ERR! gyp info spawn args   '-Dnode_engine=v8',
    npm ERR! gyp info spawn args   '--depth=.',
    npm ERR! gyp info spawn args   '--no-parallel',
    npm ERR! gyp info spawn args   '--generator-output',
    npm ERR! gyp info spawn args   'build',
    npm ERR! gyp info spawn args   '-Goutput_dir=.'
    npm ERR! gyp info spawn args ]
    npm ERR! gyp info spawn make
    npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-local-handle.h:12,
    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-array-buffer.h:12,
    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8.h:24,
    npm ERR!                  from ../src/openzwave.hpp:27,
    npm ERR!                  from ../src/callbacks.cc:18:
    npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-internal.h: In function ‘void v8::internal::PerformCastCheck(T*)’:
    npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-internal.h:646:38: error: ‘remove_cv_t’ is not a member of ‘std’; did you mean ‘remove_cv’?
    npm ERR!   646 |             !std::is_same<Data, std::remove_cv_t<T>>::value>::Perform(data);
    npm ERR!       |                                      ^~~~~~~~~~~
    npm ERR!       |                                      remove_cv
    npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-internal.h:646:50: error: template argument 2 is invalid
    npm ERR!       |                                                  ^
    npm ERR! /home/iobroker/.cache/node-gyp/18.17.1/include/node/v8-internal.h:646:63: error: ‘::Perform’ has not been declared
    npm ERR!       |                                                               ^~~~~~~
    npm ERR! make: *** [openzwave_shared.target.mk:150: Release/obj.target/openzwave_shared/src/callbacks.o] Error 1
    npm ERR! gyp ERR! build error
    npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
    npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23)
    npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)
    npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)
    npm ERR! gyp ERR! System Linux 5.15.0-82-generic
    npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
    npm ERR! gyp ERR! node -v v18.17.1
    npm ERR! gyp ERR! node-gyp -v v9.3.1
    npm ERR! gyp ERR! not ok
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-29T20_31_58_414Z-debug-0.log
    upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
    upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
    upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
    upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
    upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
    upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
    upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
    upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
    upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
    Der Vollständigkeit halber noch die folgenden Infos.
    paul@iobroker:~$ uname -m && type -P nodejs node npm npx corepack && nodejs -v && node -v && npm -v && npx -v && corepack -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
    x86_64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    /usr/bin/npx
    /usr/bin/corepack
    v18.17.1
    v18.17.1
    9.6.7
    9.6.7
    0.18.0
    4.0.24
    paul
    paul adm cdrom sudo dip plugdev lxd iobroker
    tty
    /home/paul
    OK:1 https://dl.yarnpkg.com/debian stable InRelease
    Holen:2 https://deb.nodesource.com/node_18.x jammy InRelease [4.563 B]
    OK:3 http://archive.ubuntu.com/ubuntu jammy InRelease
    OK:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    OK:5 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
    OK:6 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Es wurden 4.563 B in 2 s geholt (2.823 B/s).
    nodejs:
      Installiert:           18.17.1-deb-1nodesource1
      Installationskandidat: 18.17.1-deb-1nodesource1
      Versionstabelle:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
            100 /var/lib/dpkg/status
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    Ich hoffe mir kann irgendjemand weiterhelfen. Ich verzweifle langsam - mittlerweile kann ich den Admin auch nicht mehr öffnen.
    Vielen Dank im Voraus und Gruß,
    Paul
    • B BruderBleistift
      NPM version: 9.6.7
      npm ERR! errno -39
      anschließend:
      NPM version: 9.6.7
      npm WARN cleanup   [
      npm WARN cleanup     }
      npm WARN cleanup   ],
      npm WARN cleanup   [
      npm WARN cleanup     }
      npm WARN cleanup   ],
      npm WARN cleanup   [
      npm WARN cleanup     }
      npm WARN cleanup   ]
      npm WARN cleanup ]
      npm ERR! code 1
      npm ERR!       |                                                  ^
      npm ERR!       |                                                               ^~~~~~~
      x86_64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      /usr/bin/npx
      /usr/bin/corepack
      v18.17.1
      v18.17.1
      9.6.7
      9.6.7
      0.18.0
      4.0.24
      paul
      tty
      /home/paul
      nodejs:
        Versionstabelle:
      Paul
      @bruderbleistift sagte in Kein Adapter Update nach NodeJS 18 Update:
      Das klemmt da.
      cd /opt/iobroker/node_modules/openzwave-shared
      npm install --omit=dev
      mal probiert?
      B 1 Antwort Letzte Antwort
        Das klemmt da.
        mal probiert?
        BruderBleistift
        @thomas-braun sagte in Kein Adapter Update nach NodeJS 18 Update:
        mal probiert?
        Erst meckert er wieder /opt/iobroker/node_modules/pcap an, dann führte ich den Einzeiler zum Löschen aus und setzte deinen Befehl nochmal ab.
        Das Ergebnis:
        paul@iobroker:/opt/iobroker/node_modules/openzwave-shared$ npm install --omit=dev
        [sudo] password for paul:
        npm ERR! errno -39
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-29T21_39_48_786Z-debug-0.log
        paul@iobroker:/opt/iobroker/node_modules/openzwave-shared$ cd
        paul@iobroker:~$ cd /opt/iobroker/node_modules/openzwave-shared
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ]
        npm WARN cleanup ]
        npm ERR! code 1
        npm ERR!       |                                                  ^
        npm ERR!       |                                                               ^~~~~~~
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-29T21_44_57_811Z-debug-0.log
        • B BruderBleistift
          mal probiert?
          Das Ergebnis:
          npm ERR! errno -39
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ]
          npm WARN cleanup ]
          npm ERR! code 1
          npm ERR!       |                                                  ^
          npm ERR!       |                                                               ^~~~~~~
          @bruderbleistift
          Dann weiß ich auch nicht.
            @bruderbleistift
            BruderBleistift
            Könnte sich das mit einem BackUp das ioBroker und Neuaufsetzen beheben lassen, oder stellt er da den ganzen Müll wieder her?
            • B BruderBleistift
              crunchipC Offline
              crunchipC Offline
              @bruderbleistift sollte, außer es gibt ein generelles Problem mit einem Adapter
                BruderBleistift
                Nachdem ich alles neu aufgesetzt und das Backup wiederhergestellt habe, was auch noch ziemlich viel Kopfzerbrechen verursacht hat, läuft (fast) alles wieder.
                Danke euch für eure Hilfe. Hier kann dann zu.
                • B BruderBleistift
                  crunchipC Offline
                  crunchipC Offline
                  weshalb?
                  was läuft denn nicht?
                    weshalb?
                    BruderBleistift
                    @crunchip sagte in Kein Adapter Update nach NodeJS 18 Update:
                    weshalb?
                    • Der Admin ließ sich nach dem Einspielen des Backup nicht starten und es musste u.a. NodeJS und NPM neuinstalliert werden. Irgendwas musste noch gemacht werden, bekomme ich aber nicht mehr zusammen
                    • Auch VIS ließ sich nicht mehr installieren, weil die Lizenz angeblich ungültig ist, obwohl ich als Privatperson keine benötige. Die alten VIS Seiten mussten anschließend alle manuell wiederhergestellt werden, was aber auch nicht reibungslos funktioniert (siehe unten).
                    • Einige Javascripte verursachten Error ohne Ende -> war nach einer Neuanlage mit neuem Namen behoben.
                    • Vieles von dem oben genannten konnte ich die letzten Tage beheben. Mir fehlen aber noch einige VIS Seiten, die sich scheinbar aus dem Backup nicht wiederherstellen lassen.
                    Also alles in allem bin ich mit der BackUp Funktion ziemlich unzufrieden und bestätigt mich darin weiterhin die ganze VM mit Proxmox zu sichern. Das Wiederherstellen funktioniert absolut reibungslos.
                    Hat mir in dem Fall natürlich nicht weitergeholfen, weil scheinbar meine IOBroker Installation ein Ding weg hatte.
                    Also ein Tipp an alle was BackUps angeht: Immer schön zweigleisig fahren 👍 😀
                    • B BruderBleistift
                      weshalb?
                      Oder seine Installation nicht komplett auf Links drehen...
                      • B BruderBleistift
                        weshalb?
                        crunchipC Offline
                        crunchipC Offline
                        @bruderbleistift tja, ich kürz meine Antwort mal ab aufs wesentliche
                        backitup kann nichts für ein "verhautes System" was nicht gepflegt wird.
                        du kannst dir die VM tausend mal zurückspielen, bestehende Fehler schleifst du dadurch aber weiter mit
                          BruderBleistift
                          Und wie gehe ich da am besten vor?
                          Ich habe IOBroker nach Anleitung installiert.
                          Nach und nach sind Adapter hinzugekommen.
                          Für Admin Aktualisierungen wird ab und zu eine neue NodeJS Version benötigt, die ich ebenfalls nach den Anleitungen hier installiert hatte.
                          Nach der letzten Aktualisierung NodeJS Aktualisierung ließen sich dann aber keine Adapter mehr aktualisieren.
                          Das Ubuntu wurde ebenfalls regelmäßig auf dem aktuellen Stand gehalten.
                          Wie gesagt. In dem Fall hat das nichts gebracht, weswegen ich zweigleisig fahre.
                          Dass VIS mit BackItUp BackUps Probleme hat, scheint laut diesem Forum nicht neu zu sein und nicht nur mich zu betreffen. Aber ich gebe dir recht, da scheint BackItUp nicht schuld dran zu sein.
                          • B BruderBleistift
                            Ich weiß ja nicht genau was da bislang gemacht wurde.
                            Stimmt, der WorkAround ist vorab eine alte Version von vis zu installieren. Dann rutscht ein Backup da auch richtig rein. Ist aber zugegegebenermaßen eine blöde Situation.
                            • B BruderBleistift
                              nach welcher?
