  4. Raspi Installation läuft nicht durch
    5.7k
5 Beiträge 3 Kommentatoren 1.4k Aufrufe
  • E Offline
    EkkiB
    Weil das fertige Raspi-ioBroker Image auf dem Raspi 2B mit dem OWFS-Adapter nicht funktioniert, habe ich ein "frisches" Betriebssystem abgegriffen :
    2017-06-21-raspbian-jessie.img
    Node ausgetauscht zu :
    pi@ras2:~ $ node -v
    v8.1.3
    pi@ras2:~ $ npm -v
    5.0.3
    Das Kommando "$ sudo npm install iobroker –unsafe-perm" läuft ziemlich lange, um dann so abzustürzen :
    (bekannt ?)
    Write "./iobroker start" to start the ioBroker
    : No such file or directory
    Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
    iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
    mdns@2.3.3 install /opt/iobroker/node_modules/mdns
    node-gyp rebuild
    make: Entering directory '/opt/iobroker/node_modules/mdns/build'
    CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
    In file included from ../src/dns_sd.cpp:1:0:
    ../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
    #include <dns_sd.h>^
    compilation terminated.
    dns_sd_bindings.target.mk:150: recipe for target 'Release/obj.target/dns_sd_bindings/src/dns_sd.o' failed
    make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/mdns/build'
    gyp ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2
    gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:258:23)
    gyp ERR! stack at emitTwo (events.js:125:13)
    gyp ERR! stack at ChildProcess.emit (events.js:213:7)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:197:12)
    gyp ERR! System Linux 4.9.28-v7+
    gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/mdns
    gyp ERR! node -v v8.1.3
    gyp ERR! node-gyp -v v3.6.2
    gyp ERR! not ok
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
    npm WARN iobroker No description
    npm WARN iobroker No repository field.
    npm WARN iobroker No README data
    npm WARN iobroker No license field.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 (node_modules/mdns):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 install: node-gyp rebuild
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    • iobroker@1.0.0
    added 48 packages, removed 53 packages and updated 1 package in 765.723s
    pi@ras2:/opt/iobroker $</dns_sd.h>
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      Probier Mal mit node 6 und nicht 8!
      Send from mobile device
      • E Offline
        EkkiB
        Auf dem fertigen Image ist ja nodejs 6.10.0
        Und da funktioniert der OWFS Adapter nicht. Deswegen der Versuch mit einer neueren Node Version.
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          Dan besser da weiter troubleshooten, es ist bekannt dass node 8 noch einige Probleme verursacht node 6 ist ok für ioBroker und seine Adapter.
            tesso
            Mein System wurde mit node8 installiert und es läuft alles.
