  4. [gelöst] Fehler bei 'iobroker clean yes' - TypeError: undefi
6 Beiträge 2 Kommentatoren 2.0k Aufrufe
  • F Offline
    frankie
    beim Aufruf von
    iobroker clean yes
    gibt es folgende Fehlermeldung:
    root@raspberrypi:/opt/iobroker# iobroker clean
    Command "clean" clears all Objects and States. To execute it write "iobroker clean yes"
    root@raspberrypi:/opt/iobroker# iobroker clean yes
    /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1677
            objects.destroyDB(function () {
    TypeError: undefined is not a function
        at cleanDatabase (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1677:17)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:882:21
        at Object.States.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2284:70)
        at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/statesInMemClient.js:80:68)
        at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
        at Socket.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:129:10)
        at Socket.onconnect (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:308:8)
        at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:208:12)
        at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
    root@raspberrypi:/opt/iobroker#</anonymous></anonymous>
    Gibt es noch eine Einstellung, welche ich übersehen habe, oder handelt es sich um einen "echten" Fehler.
    Frank
    Raspberry Pi 2 - Raspbian 4.1.6-v7+
    node v0.12.7 (Installation nach http://nodered.org/docs/hardware/raspberrypi.html)
    mosquitto 1.4.3
    ioBroker.js-controller 0.7.12
    • BluefoxB Offline
      BluefoxB Offline
      Es ist ein echter Fehler. Muss schauen. Danke.
      • BluefoxB Offline
        BluefoxB Offline
        Falls du ioBroker vorher stoppst, dann kriegst diese Fehlermeldung nicht. Habe gefixt. Danke.
        • F Offline
          frankie
          @Bluefox:
          Falls du ioBroker vorher stoppst, dann kriegst diese Fehlermeldung nicht. Habe gefixt. Danke. `
          Super schnelle Antwort!!!!!!!!!!!!!!
          Wie komme ich denn Deinen Fix? Denn ich würde den Befehl "iobroker clean yes" gerne im Zusammenhang mit http://forum.iobroker.org/viewtopic.php?f=22&t=1129 testen wollen.
          mosquitto 1.4.3
          • BluefoxB Offline
            BluefoxB Offline
            cd /opt/iobroker
            npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
            Du kannst aber einfach /opt/iobroker/iobroker-data Verzeichnis löschen und dann
            cd /opt/iobroker
            iobroker setup
            aufrufen.
            • F Offline
              frankie
              Habe heute nach einem erfolgreichem Update die Funktion testen können.
              Stop ioBroker first!
              root@raspberrypi:/opt/iobroker# iobroker stop
              Stopping ioBroker controller daemon...
              ioBroker controller daemon stopped.
              Deleted 219 states
              Starting node restart.js
              Restarting ioBroker...
              mosquitto 1.4.3
