  4. Node-Red
  5. Variable in Node "influxdb in"
    6.4k
6 Beiträge 2 Kommentatoren 673 Aufrufe 2 Beobachtet
  • H Offline
    hinti
    Hallo!
    Ich verwende die Node "influxdb in" und habe ein Problem mit einer Variable.
    Bei
    SELECT sum("Pool_vom_Netz") / 120000 FROM "Bilanz" WHERE time > now() -31d
    funktioniert es. Ich möchte aber die (-31d) Tage in einer Variable verpacken.
    Das was ich im Netz gefunden habe funktioniert leider nicht.
    SELECT sum("Pool_vom_Netz") / 120000 FROM "Bilanz" WHERE time > now() '-${payload.Tage}d'
    Wie schaut die Variable richtig aus?
    Hier der Flow:
    "id": "c4adbc7357d003d1",
    "type": "tab",
    "label": "Flow 1",
    "disabled": false,
    "info": "",
    "env": []
    "id": "45b9ad6228447b62",
    "type": "inject",
    "z": "c4adbc7357d003d1",
    "name": "",
    "props": [
    "p": "payload"
    "p": "topic",
    "vt": "str"
    "repeat": "",
    "crontab": "",
    "once": false,
    "onceDelay": 0.1,
    "topic": "",
    "payload": "",
    "payloadType": "date",
    "x": 200,
    "y": 160,
    "wires": [
    "473b104681483dc8"
    "id": "473b104681483dc8",
    "type": "function",
    "name": "Monatstage",
    "func": "var msg = {};\n\n// ------------- Aktuellen Monat herausfinden -------------------------\nvar Tage;\nvar now = new Date();\nvar month = now.getMonth() + 1;\n\nif (month == 1) {Tage = 31}\nif (month == 2) { Tage = 28 }\nif (month == 3) { Tage = 31}\nif (month == 4) { Tage = 30 }\nif (month == 5) { Tage = 31}\nif (month == 6) { Tage = 30 }\nif (month == 7) { Tage = 31 }\nif (month == 8) { Tage = 31 }\nif (month == 9) { Tage = 30 }\nif (month == 10) { Tage = 31 }\nif (month == 11) { Tage = 30 }\nif (month == 12) { Tage = 31 }\n// --------------------------------------------------------------------\n\n\nmsg.payload =\n{\n Tage:Tage,\n}\nreturn [msg];",
    "outputs": 1,
    "noerr": 0,
    "initialize": "",
    "finalize": "",
    "libs": [],
    "x": 370,
    "y": 160,
    "wires": [
    "e73be277cb1cc425"
    "id": "e73be277cb1cc425",
    "type": "influxdb in",
    "influxdb": "655abc6ff1dd28f5",
    "name": "Abfrage Zählerst. Energie",
    "query": "SELECT sum("Pool_vom_Netz") / 120000 FROM "Bilanz" WHERE time > now() '-${payload.Tage}d'",
    "rawOutput": true,
    "precision": "",
    "retentionPolicy": "",
    "org": "",
    "x": 590,
    "y": 160,
    "wires": [
    "id": "655abc6ff1dd28f5",
    "type": "influxdb",
    "hostname": "10.1.1.113",
    "port": "8086",
    "protocol": "http",
    "database": "whirlpool",
    "name": "whirlpool",
    "usetls": false,
    "tls": "",
    "influxdbVersion": "1.x",
    "url": "http://localhost:8086",
    "rejectUnauthorized": true
    Danke.
    • H hinti
      Hallo!
      Bei
      Hier der Flow:
      "type": "tab",
      "label": "Flow 1",
      "disabled": false,
      "info": "",
      "env": []
      "type": "inject",
      "name": "",
      "props": [
      "p": "payload"
      "p": "topic",
      "vt": "str"
      "repeat": "",
      "crontab": "",
      "once": false,
      "onceDelay": 0.1,
      "topic": "",
      "payload": "",
      "x": 200,
      "y": 160,
      "wires": [
      "473b104681483dc8"
      "type": "function",
      "outputs": 1,
      "noerr": 0,
      "initialize": "",
      "finalize": "",
      "libs": [],
      "x": 370,
      "y": 160,
      "wires": [
      "e73be277cb1cc425"
      "rawOutput": true,
      "precision": "",
      "org": "",
      "x": 590,
      "y": 160,
      "wires": [
      "type": "influxdb",
      "port": "8086",
      "protocol": "http",
      "usetls": false,
      "tls": "",
      Danke.
      mickymM Offline
      mickymM Offline
      mickym
      Mit Deinem Flow kann man nichts anfangen weil Du das nicht in Code-Tags gepackt hast.
      Wenn Du das so reinkopierst interpretiert der Browser zeichen und man kann es nicht importieren.
      Du setzt einfach Deine komplette msg.query zusammen. Was heißt Variable ist es ein Eigenschaft des Nachrichtenobjektes oder nicht?
             "id": "a0f099e28f8b85fc",
             "type": "inject",
             "z": "5ad55a7b0d4580eb",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "{\"Tage\":31}",
             "payloadType": "json",
             "x": 340,
             "y": 2740,
             "wires": [
                     "2b43c618076c4c06",
                     "21b7ebf788d45e74"
             "id": "2b43c618076c4c06",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "query",
                     "pt": "msg",
                     "to": "'SELECT sum(\"Pool_vom_Netz\") / 120000 FROM \"Bilanz\" WHERE time > now() -' & payload.Tage & 'd'",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 540,
             "y": 2740,
             "wires": [
                     "5cdbd6f2567e8a20"
             "id": "21b7ebf788d45e74",
             "type": "debug",
             "name": "payload",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "payload",
             "targetType": "msg",
             "statusVal": "",
             "statusType": "auto",
             "x": 520,
             "y": 2680,
             "wires": []
             "id": "5cdbd6f2567e8a20",
             "type": "debug",
             "name": "query",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "query",
             "statusVal": "",
             "x": 730,
             "y": 2680,
             "wires": []
      Wie gesagt woher Deine Tage kommen - kann ich nicht sagen - da man Deinen Flow nicht importierten kann. Das Nachrichtenobjekt siehst Du ja - falls Du anderen Kontext nimmst, entweder in das Nachrichtenobjekt aufnehmen oder halt mit den entsprechenden Funktionen darauf zugreifen.
      H 1 Antwort Letzte Antwort
      • mickymM mickym
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "x": 340,
               "y": 2740,
               "wires": [
                       "2b43c618076c4c06",
                       "21b7ebf788d45e74"
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "query",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 540,
               "y": 2740,
               "wires": [
                       "5cdbd6f2567e8a20"
               "type": "debug",
               "name": "payload",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 520,
               "y": 2680,
               "wires": []
               "type": "debug",
               "name": "query",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 730,
               "y": 2680,
               "wires": []
        hinti
        @mickym
        Danke für die Antwort.
        Hier nochmals der Flow:
               "id": "72c36d015644d984",
               "type": "tab",
               "label": "Flow 2",
               "disabled": false,
               "info": "",
               "env": []
               "id": "8a88b6fdb45f100c",
               "type": "inject",
               "z": "72c36d015644d984",
               "name": "",
               "props": [
                       "p": "payload"
                       "p": "topic",
                       "vt": "str"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "",
               "x": 120,
               "y": 140,
               "wires": [
                       "a9316343deec6c53"
               "id": "a9316343deec6c53",
               "type": "function",
               "outputs": 1,
               "noerr": 0,
               "initialize": "",
               "finalize": "",
               "libs": [],
               "x": 290,
               "y": 140,
               "wires": [
                       "7e701c0656398ec3",
                       "1ea910c9a8ca6a24"
               "id": "7e701c0656398ec3",
               "query": "SELECT sum(\"Pool_vom_Netz\") / 120000 FROM \"Bilanz\" WHERE time > now() '-${payload.Tage}d'",
               "rawOutput": true,
               "precision": "",
               "org": "",
               "x": 510,
               "y": 140,
               "wires": [
                       "31afc62051488e86"
               "id": "31afc62051488e86",
               "type": "debug",
               "name": "payload",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 720,
               "y": 140,
               "wires": []
               "id": "1ea910c9a8ca6a24",
               "type": "debug",
               "name": "payload",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 460,
               "y": 80,
               "wires": []
               "type": "influxdb",
               "port": "8086",
               "protocol": "http",
               "usetls": false,
               "tls": "",
        Mit der Variable direkt im Query hab ich das Problem. Mit deiner Lösung mit dem Change Node funktioniert es jetzt
               "id": "f6bfa45d44848e0b",
               "type": "tab",
               "label": "Flow 3",
               "disabled": false,
               "info": "",
               "env": []
               "id": "d6218fe1418c8ae9",
               "type": "inject",
               "z": "f6bfa45d44848e0b",
               "name": "",
               "props": [
                       "p": "payload"
                       "p": "topic",
                       "vt": "str"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "",
               "x": 100,
               "y": 260,
               "wires": [
                       "2e25ecba20d95814"
               "id": "2e25ecba20d95814",
               "type": "function",
               "outputs": 1,
               "noerr": 0,
               "initialize": "",
               "finalize": "",
               "libs": [],
               "x": 270,
               "y": 260,
               "wires": [
                       "0374cab1d63834c4",
                       "42e42ac5275c90ae"
               "id": "42e42ac5275c90ae",
               "type": "debug",
               "name": "payload",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 440,
               "y": 220,
               "wires": []
               "id": "0374cab1d63834c4",
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "query",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 460,
               "y": 260,
               "wires": [
                       "9005b1ef0601da83",
                       "7e1adada9963614b"
               "id": "7e1adada9963614b",
               "type": "debug",
               "name": "query",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 630,
               "y": 220,
               "wires": []
               "id": "9005b1ef0601da83",
               "query": "msg.query",
               "rawOutput": true,
               "precision": "",
               "org": "",
               "x": 690,
               "y": 260,
               "wires": [
                       "af64830ef5a1d939",
                       "833e8db5cdba66d3"
               "id": "af64830ef5a1d939",
               "type": "debug",
               "name": "payload",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 840,
               "y": 220,
               "wires": []
               "id": "833e8db5cdba66d3",
               "type": "function",
               "name": "E_Whirlpool_Monat_v_Netz",
               "func": "var msg1 = {};\n\nvar Pool_vom_Netz = msg.payload.results[0].series[0].values[0][1];\n\n\nmsg1.payload =\n{\n\nPool_vom_Netz_Monat: parseFloat(Pool_vom_Netz.toFixed(2)),\n  \n\n}\n\n\nreturn [msg1];",
               "outputs": 1,
               "noerr": 0,
               "initialize": "",
               "finalize": "",
               "libs": [],
               "x": 940,
               "y": 260,
               "wires": [
                       "8014820292266bd7"
               "id": "8014820292266bd7",
               "type": "debug",
               "name": "payload",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1020,
               "y": 220,
               "wires": []
               "type": "influxdb",
               "port": "8086",
               "protocol": "http",
               "usetls": false,
               "tls": "",
        Kann man sich die change Node sparren, und die Variable direkt in die Query stecken?
        • H hinti
          @mickym
                 "type": "tab",
                 "label": "Flow 2",
                 "disabled": false,
                 "info": "",
                 "env": []
                 "type": "inject",
                 "name": "",
                 "props": [
                         "p": "payload"
                         "p": "topic",
                         "vt": "str"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "payload": "",
                 "x": 120,
                 "y": 140,
                 "wires": [
                         "a9316343deec6c53"
                 "type": "function",
                 "outputs": 1,
                 "noerr": 0,
                 "initialize": "",
                 "finalize": "",
                 "libs": [],
                 "x": 290,
                 "y": 140,
                 "wires": [
                         "7e701c0656398ec3",
                         "1ea910c9a8ca6a24"
                 "rawOutput": true,
                 "precision": "",
                 "org": "",
                 "x": 510,
                 "y": 140,
                 "wires": [
                         "31afc62051488e86"
                 "type": "debug",
                 "name": "payload",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 720,
                 "y": 140,
                 "wires": []
                 "type": "debug",
                 "name": "payload",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 460,
                 "y": 80,
                 "wires": []
                 "type": "influxdb",
                 "port": "8086",
                 "protocol": "http",
                 "usetls": false,
                 "tls": "",
                 "type": "tab",
                 "label": "Flow 3",
                 "disabled": false,
                 "info": "",
                 "env": []
                 "type": "inject",
                 "name": "",
                 "props": [
                         "p": "payload"
                         "p": "topic",
                         "vt": "str"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "payload": "",
                 "x": 100,
                 "y": 260,
                 "wires": [
                         "2e25ecba20d95814"
                 "type": "function",
                 "outputs": 1,
                 "noerr": 0,
                 "initialize": "",
                 "finalize": "",
                 "libs": [],
                 "x": 270,
                 "y": 260,
                 "wires": [
                         "0374cab1d63834c4",
                         "42e42ac5275c90ae"
                 "type": "debug",
                 "name": "payload",
                 "active": false,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 440,
                 "y": 220,
                 "wires": []
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "query",
                         "pt": "msg",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 460,
                 "y": 260,
                 "wires": [
                         "9005b1ef0601da83",
                         "7e1adada9963614b"
                 "type": "debug",
                 "name": "query",
                 "active": false,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 630,
                 "y": 220,
                 "wires": []
                 "rawOutput": true,
                 "precision": "",
                 "org": "",
                 "x": 690,
                 "y": 260,
                 "wires": [
                         "af64830ef5a1d939",
                         "833e8db5cdba66d3"
                 "type": "debug",
                 "name": "payload",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 840,
                 "y": 220,
                 "wires": []
                 "type": "function",
                 "outputs": 1,
                 "noerr": 0,
                 "initialize": "",
                 "finalize": "",
                 "libs": [],
                 "x": 940,
                 "y": 260,
                 "wires": [
                         "8014820292266bd7"
                 "type": "debug",
                 "name": "payload",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 1020,
                 "y": 220,
                 "wires": []
                 "type": "influxdb",
                 "port": "8086",
                 "protocol": "http",
                 "usetls": false,
                 "tls": "",
          mickymM Offline
          mickymM Offline
          mickym
          @hinti Nein msg.query musst du vorher komplett zusammenbauen. Dafür ist es ja da. Ansonsten in der Node halt nur konstante Ausdrücke
          • mickymM mickym
            hinti
            @mickym
            OK, Super. Danke für deine Hilfe.
            • H hinti
              @mickym
              mickymM Offline
              mickymM Offline
              mickym
              @hinti wenn du mehrere Parameter hast, kannst du die msg.query auch mit einer Template Node zusammenbauen. Ist zwar nicht anders als mit einer Change-Node, vielleicht nur ein wenig übersichtlicher.
