  4. Neuer Adapter für Roborock-Staubsauger
    6.7k
1.1k Beiträge 155 Kommentatoren 482.6k Aufrufe 138 Beobachtet
  • E Offline
    elochso
    #741
    Jetzt kommt immer folgender Fehler:
    Failed to execute get_map_v1 on robot 1opZH9d8PAaIcMMhNO0u9u (roborock.vacuum.a51): Error: Failed to convert JavaScript value Undefined into rust type String at /opt/iobroker/node_modules/iobroker.roborock/lib/mapCreator.js:647:29 at Array.forEach (<anonymous>) at MapCreator.canvasMap (/opt/iobroker/node_modules/iobroker.roborock/lib/mapCreator.js:624:30) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:84:46)
    • C Offline
      createch2
      #742
      Hab eben erst den Adapter installiert.
      Ich habe absichtlich keinerlei Kartenerzeugung angewählt, bekomme aber im Log File: "Failed to map rooms. You need to name your rooms via the mobile app on your phone."
      Gibts da Abhilfe ausser in der Mobile App tätig zu werden ?
        Adri525
        #743
        ich habe den QRevo Slim und bekomme folgende Fehlermeldungen:
        Unsupported attribute: kct of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a21
        2025-01-05 16:25:22.073	warn	State "roborock.0.Devices.52nkyxg5GRqLBvhDnBr6nw.consumables.dust_collection_work_times" has no existing object, this might lead to an error in future versions
        roborock.0
        2025-01-05 16:25:22.070 warn State "roborock.0.Devices.52nkyxg5GRqLBvhDnBr6nw.consumables.sensor_dirty_time" has no existing object, this might lead to an error in future versions
        roborock.0
        2025-01-05 16:25:22.070 warn State "roborock.0.Devices.52nkyxg5GRqLBvhDnBr6nw.consumables.filter_element_work_time" has no existing object, this might lead to an error in future versions
        roborock.0
        2025-01-05 16:25:22.070 warn State "roborock.0.Devices.52nkyxg5GRqLBvhDnBr6nw.consumables.filter_work_time" has no existing object, this might lead to an error in future versions
        roborock.0
        2025-01-05 16:25:22.068 warn State "roborock.0.Devices.52nkyxg5GRqLBvhDnBr6nw.consumables.side_brush_work_time" has no existing object, this might lead to an error in future versions
        roborock.0
        2025-01-05 16:25:22.067 warn State "roborock.0.Devices.52nkyxg5GRqLBvhDnBr6nw.consumables.main_brush_work_time" has no existing object, this might lead to an error in future versions
        roborock.0
        2025-01-05 16:25:02.479 warn Unsupported attribute: kct of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a21
        roborock.0
        2025-01-05 16:25:01.496 warn Unsupported attribute: in_warmup of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a21
        roborock.0
        2025-01-05 16:25:01.143 warn Unsupported attribute: monitor_status of get_status with value 0. Please contact the dev to add the newly found attribute of your robot. Model: roborock.vacuum.a21
        roborock.0
        2025-01-05 16:24:22.101 warn State "roborock.0.Devices.52nkyxg5GRqLBvhDnBr6nw.consumables.dust_collection_work_times" has no existing object, this might lead to an error in future versions
        roborock.0
        2025-01-05 16:24:22.101 warn State "roborock.0.Devices.52nkyxg5GRqLBvhDnBr6nw.consumables.sensor_dirty_time" has no existing object, this might lead to an error in future versions
        roborock.0
        2025-01-05 16:24:22.100 warn State "roborock.0.Devices.52nkyxg5GRqLBvhDnBr6nw.consumables.filter_element_work_time" has no existing object, this might lead to an error in future versions
        roborock.0
        2025-01-05 16:24:22.100 warn State "roborock.0.Devices.52nkyxg5GRqLBvhDnBr6nw.consumables.filter_work_time" has no existing object, this might lead to an error in future versions
        roborock.0
        2025-01-05 16:24:22.097 warn State "roborock.0.Devices.52nkyxg5GRqLBvhDnBr6nw.consumables.side_brush_work_time" has no existing object, this might lead to an error in future versions
        roborock.0
        2025-01-05 16:24:22.096 warn State "roborock.0.Devices.52nkyxg5GRqLBvhDnBr6nw.consumables.main_brush_work_time" has no existing object, this might lead to an error in future versions
        Liegt es daran dass der Slim noch nicht kompatibel ist?
        Falls ja, kann dieser über ein Update mit aufgenommen werden :)?
        Vielen Dank vorab!
        wolfi913W 1 Antwort Letzte Antwort
        • A Adri525
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          Vielen Dank vorab!
          wolfi913W Online
          wolfi913W Online
          wolfi913
          #744
          @adri525 sagte in Neuer Adapter für Roborock-Staubsauger:
          Kommt lt Issue ins nächste Update rein
          https://github.com/copystring/ioBroker.roborock/issues/738
          • wendy2702W Online
            wendy2702W Online
            wendy2702
            #745
            wie bekomme ich denn den Eintrag weg ohne den Adapter 0.6.18 deinstallieren zu müssen:
            Bei mir funktioniert der nämlich nicht.
            Und sieht das Debug log bei euch auch so aus, das geht so unendlich weiter.
            roborock.0
            	2025-01-23 14:21:18.343	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:17.342	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:16.341	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:15.340	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:14.880	debug	Client disconnected
            roborock.0
            	2025-01-23 14:21:14.879	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:13.878	debug	Websocket client connected
            roborock.0
            roborock.0
            	2025-01-23 14:21:13.340	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:12.339	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:11.337	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:10.337	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:09.336	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:08.335	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:07.332	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:06.329	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:05.328	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:04.327	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:03.327	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:02.882	debug	Client disconnected
            roborock.0
            	2025-01-23 14:21:02.881	debug	Client disconnected. Stopping interval.
            roborock.0
            	2025-01-23 14:21:02.441	debug	Size of message queue: 0
            roborock.0
            	2025-01-23 14:21:02.441	debug	Local message with protocol 4 and id 499 received. Result: [203]
            roborock.0
            	2025-01-23 14:21:02.440	debug	Chunk buffer data is complete. Processing...
            roborock.0
            	2025-01-23 14:21:02.439	debug	new chunk started
            roborock.0
            	2025-01-23 14:21:02.435	debug	Chunk buffer data is complete. Processing...
            roborock.0
            	2025-01-23 14:21:02.435	debug	new chunk started
            roborock.0
            	2025-01-23 14:21:02.431	debug	Sent payload for 5xxxxxmr with {"dps":{"4":"{\"id\":499,\"method\":\"get_water_box_custom_mode\",\"params\":[]}"},"t":1737638462} using local connection
            roborock.0
            	2025-01-23 14:21:02.326	debug	Size of message queue: 0
            roborock.0
            	2025-01-23 14:21:02.326	debug	Local message with protocol 4 and id 498 received. Result: [{"carpet_clean_mode":1}]
            roborock.0
            	2025-01-23 14:21:02.325	debug	Chunk buffer data is complete. Processing...
            roborock.0
            	2025-01-23 14:21:02.325	debug	new chunk started
            roborock.0
            	2025-01-23 14:21:02.324	debug	Chunk buffer data is complete. Processing...
            roborock.0
            	2025-01-23 14:21:02.323	debug	new chunk started
            • Walter WhiteW Offline
              Walter White
              #746
              Hallo, ich habe mehrmals am Tag eine rote Meldung, wie bekomme ich die weg?
              	Failed to get home details: Error [ERR_SOCKET_DGRAM_NOT_RUNNING]: Not running at healthCheck (node:dgram:922:11) at Socket.bind (node:dgram:242:3) at /opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:213:11 at new Promise (<anonymous>) at localConnector.getLocalDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:185:10) at Roborock.initializeHomeDetails (/opt/iobroker/node_modules/iobroker.roborock/main.js:197:56) at async /opt/iobroker/node_modules/iobroker.roborock/main.js:77:4
              VumerV 1 Antwort Letzte Antwort
              • Walter WhiteW Walter White
                VumerV Offline
                VumerV Offline
                Vumer
                schrieb am zuletzt editiert von Vumer
                #747
                @walter-white sagte in Neuer Adapter für Roborock-Staubsauger:
                ich auch, alle 3 St.
                roborock.0 2025-02-02 13:44:58.920	error	Failed to get home details: Error: Not running at healthCheck (node:dgram:922:11) at Socket.bind (node:dgram:242:3) at /opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:213:11 at new Promise (<anonymous>) at localConnector.getLocalDevices (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:185:10) at Roborock.initializeHomeDetails (/opt/iobroker/node_modules/iobroker.roborock/main.js:197:56) at /opt/iobroker/node_modules/iobroker.roborock/main.js:77:4
                Roborock Q7 Max
                  Manolo
                  #748
                  Bei mir die gleiche Fehlermeldung, auch alle paar Stunden.
                  Roborock S7 Pro Ultra
                  Roborock Qrevo Pro
                  ioBroker auf Beelink J45, Slave auf Beelink BT3pro, Unifi Controller auf Raspi Pi 3; 4x VIS Fully Browser auf 10" und 7" Tablet; piVCCU auf 2x Raspi Pi 3 Redundanzsystem, ca. 50 HM-Geräte; Unifi USG, Switch, AP-AC-LR
                    RISSN
                    #749
                    der Fehler kommt bei mir auch, aber es läuft alles ohne Probleme, Roborock S6 VMax
                    • G Offline
                      gutgut30
                      #750
                      Habe die Meldung ebenso. Hat schon jemand ein Issue auf Git dazu erstellt?
                      mickemupM 1 Antwort Letzte Antwort
                      • G gutgut30
                        mickemupM Online
                        mickemupM Online
                        mickemup
                        #751
                        @gutgut30
                        Ist schon ne Weile offen.
                        Aber es soll zur nächsten Version behoben sein :-)
                        https://github.com/copystring/ioBroker.roborock/issues/737
                        F 1 Antwort Letzte Antwort
                        • mickemupM mickemup
                          @gutgut30
                          Farmer-cb
                          schrieb am zuletzt editiert von Farmer-cb
                          #752
                          Hallo
                          was mach ich falsch, das die deviceStatusmeldungen etc immer erst zur vollen Minute aktualisiert werden??
                          kann ich da im Adapter bzw in meinem Roborock QRevo-Pro was falsch eingestellt haben???,
                          wenn ich eine Befehl sende geht das ja fast zeitgleich an den Roboter
                          mfg
                          Farmer
                          smartes Haus durch Digitalstrom, enocean, SPS S7-1215, Homematik, Shelly, Alexa, iobroker auf einem HP-mini mit Proxmox
                          • sunpower10S Offline
                            sunpower10S Offline
                            sunpower10
                            #753
                            eine Frage: Wenn ich folgendes Kommando über die beiden Varianten (simpleAPI) ausführe:
                            http://192.168.18.XXX:8087/setBulk/roborock.0.Devices.XXXXXXX.command?Wischintensität und Wassermenge=200
                            http://192.168.18.XXX:8087/set/roborock.0.Devices.XXXXXXX.commands.set_water_box_custom_mode?value=200
                            scheinen beide Befehle korrekt ausgeführt zu werden, nur bei ersterer Variante ändert sich der Wert in der ioBroker Ansicht nicht (?).
                            2.) Ist es ein Problem, wenn man nicht acknowledged? Auch z.B. bei der Floor Auswahl? Die Werte sind dann eben rot hinterlegt.
                            3.) Kann man den "Default" Wert für "set_water_box_custom_mode" und "set_custom_mode" über "def" einfach ändern? Weil bei mir ist auch in der App standardmäßig immer Saugen&Wischen eingestellt, hätte da lieber gerne immer Saugen. Wie funktioniert das über simpleAPI?
                            Vielen Dank.
                            • sunpower10S sunpower10
                              Vielen Dank.
                              wolfi913W Online
                              wolfi913W Online
                              wolfi913
                              #754
                              @sunpower10
                              Zu 1 kann ich Dir leider nichts brauchbares sagen.
                              Zu 2: Wenn Du Einstellungen in einem Adapter selber setzt sollten die eigentlich immer nicht acknowledged gemacht werden. Bei bspw. Blockly-Scripts somit immer mit dem Steuere-Block, nicht mit dem Aktualisiere
                              Zu 3: Bei der Reinigung von Räumen läuft das bei mir auch immer mit Saugen&Wischen. Irgendwo hier im Forum hab ich gelesen, dass das (derzeit ???) nicht anders geht.
                              Habe mir da mit folgendem Workaround beholfen:
                              Habe in der App für das Zimmer, welches nur gesaugt werden soll, ein "Programm" angelegt mit nur Saugen. Die werden dann (beim Adapter-Neustart) in den Bereich roborock.0.Devices.xxx.programs geladen.
                              Das baue ich dann per Blockly-Script vacuum.read_states.xml automatisch in einzeln ansprechbare Datenpunkte für jedes dieser Programme aus der App (sowie zusätzlich ein zusammengefasstes JSON) unter 0_userdata.0.vacuum um
                              die ich dann einfach direkt im ioBroker oder über ein DropDown (gefüllt mit den Inhalten des vorher erzeugten JSON) in der Visualisierung ansprechen kann.
                              Die erzeugten Datenpunkte sollten dann vermutlich auch über simpleAPI ansprechbar sein.
                              Läuft unterm Strich dann auf die Ansteuerung dieses Datenpunktes hinaus
                              Ich hab für mich selber noch keine bessere Lösung gefunden. Ist zwar vermutlich nicht zu 100% das was Du suchst aber vielleicht hilft Dir das trotzdem etwas weiter.
                              sunpower10S 1 Antwort Letzte Antwort
                              • wolfi913W wolfi913
                                @sunpower10
                                sunpower10S Offline
                                sunpower10S Offline
                                sunpower10
                                #755
                                @wolfi913 Danke für deine Antwort, das ist schon mal sehr hilfreich.
                                Zu 3.) Ich habe gehofft, es geht einfacher, indem man den Wert für "def" ändert, welcher auch z.B. für das Kommando "set_water_box_custom_mode" hinterlegt ist. Glaubst du könnte das die Lösung sein, dann per Default z.B. "Saugen" festzulegen (auch in der App)? Weil von irgendwo muss das ja herkommen, dass die App standardmäßig immer auf "Saugen&Wischen" wechselt.
                                  wolfi913W Online
                                  wolfi913W Online
                                  wolfi913
                                  #756
                                  @sunpower10
                                  Habe bisher leider auch keine andere Möglichkeit gefunden, bei Steuerung über den Adapter, meinen Staubsauger dazu zu überreden nur zu saugen. Hatte einiges ausprobiert (kann aber leider nicht mehr sagen was alles) bis ich mir die obige Lösung zusammengebastelt habe. Komme damit aber bisher gut klar. Und das Anlegen von einzelnen Programmen in der App für die Anwendungsfälle geht ja auch recht zügig.
                                  Vielleicht hat hier ja jemand anderes eine (bessere) Möglichkeit gefunden.
                                  Aber als zusätzliches Feature im Adapter ist es ja scheinbar nicht geplant bzw. ist auch die Umsetzung gar nicht möglich.
                                    @sunpower10
                                    sunpower10S Offline
                                    sunpower10S Offline
                                    sunpower10
                                    schrieb am zuletzt editiert von sunpower10
                                    #757
                                    @wolfi913
                                    Also nur zu saugen über ioBroker einzustellen funktioniert, indem du "set_water_box_custom_mode" auf 200 und "set_custom_mode" auf z.B. 102 stellst. Mir ging es um die App, dies dort auch standardmäßig zu haben. Ich werde es die Tage mal über den "def" Wert versuchen, diesen bei "set_water_box_custom_mode" auf 200 und "set_custom_mode" auf 102 zu stellen. Vielleicht bleibt es dann in der App auch defaultmäßig auf "Saugen".
                                      @wolfi913
                                      wolfi913W Online
                                      wolfi913W Online
                                      wolfi913
                                      #758
                                      @sunpower10
                                      Aber (zumindest bei meinem Gerät) leider nicht beim Start über "commands.app_segment_clean" für die Einzelzimmerreinigung. Ich hatte es so aufgefasst, dass Du die Funktion meinst. Zumindest bei mir macht er da immer alles in einem kombinierten Saug&Wisch-Durchgang. Kann aber auch wieder abhängig vom Modell sein. Hab's jetzt gerade spaßeshalber nochmal mit 200/102 nochmal für den Flur ausprobiert. Der wurde aber trotz "commands.set_water_box_custom_mode = 200" wieder feucht gewischt.
                                      copystringC sunpower10S 2 Antworten Letzte Antwort
                                        @sunpower10
                                        copystringC Offline
                                        copystringC Offline
                                        copystring
                                        #759
                                        @wolfi913 def macht nichts anderes außer beim ersten starten des Adapters einen Standardwert auszuwählen. Andernfalls wäre das Feld einfach leer und kein Wert ausgewählt. Hat aber rein gar nichts mit dem Standardwert in der App zu tun.
                                        Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
                                        https://paypal.me/copystring
                                        wolfi913W sunpower10S 2 Antworten Letzte Antwort
                                        • copystringC copystring
                                          wolfi913W Online
                                          wolfi913W Online
                                          wolfi913
                                          #760
                                          @copystring sagte in Neuer Adapter für Roborock-Staubsauger:
                                          Dürfte eher @sunpower10 betreffen. Ich hab ja eine passende Lösung für mich.
                                          copystringC 1 Antwort Letzte Antwort
