  4. Kann keine Adapter mehr installieren npm
    5.3k
7 Beiträge 4 Kommentatoren 609 Aufrufe 3 Beobachtet
    Pino72
    schrieb am zuletzt editiert von Pino72
    Plattform: Windows
    Betriebssystem: win32
    Architektur: x64
    CPUs: 4
    Geschwindigkeit: 1498 MHz
    Modell: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
    RAM: 7.8 GB
    System-Betriebszeit: 23:36:51
    Node.js: v18.17.0
    time: 1689936652605
    timeOffset: -120
    Adapter-Anzahl: 481
    Datenträgergröße: 222.9 GB
    Freier Festplattenspeicher: 154.5 GB
    Betriebszeit: 23:33:19
    Aktive Instanzen: 16
    Pfad: C:\Program Files\iobroker\SmartHome\
    aktiv:
    $ iobroker add info auto --host NUC(SmartHome2) --debug
    C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\lib\cli.js:35 throw err ^ TypeError: Class extends value undefined is not a constructor or null at Object.<anonymous> (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\fs-minipass\lib\index.js:136:4) at Module._compile (node:internal/modules/cjs/loader:1256:14) at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) at Module.load (node:internal/modules/cjs/loader:1119:32) at Module._load (node:internal/modules/cjs/loader:960:12) at Module.require (node:internal/modules/cjs/loader:1143:19) at require (node:internal/modules/cjs/helpers:110:18) at Object.<anonymous> (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\cacache\lib\content\read.js:4:13) at Module._compile (node:internal/modules/cjs/loader:1256:14) at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) Node.js v18.17.0 C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\lib\cli.js:35 throw err ^ TypeError: Class extends value undefined is not a constructor or null at Object.<anonymous> (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\fs-minipass\lib\index.js:136:4) at Module._compile (node:internal/modules/cjs/loader:1256:14) at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) at Module.load (node:internal/modules/cjs/loader:1119:32) at Module._load (node:internal/modules/cjs/loader:960:12) at Module.require (node:internal/modules/cjs/loader:1143:19) at require (node:internal/modules/cjs/helpers:110:18) at Object.<anonymous> (C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\cacache\lib\content\read.js:4:13) at Module._compile (node:internal/modules/cjs/loader:1256:14) at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) Node.js v18.17.0
    Aborting install because the npm version could not be checked!Please check that npm is installed correctly.Use "npm install -g npm@4" or "npm install -g npm@latest" to install a supported version.You need to make sure to repeat this step after installing an update to NodeJS and/or npm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    ERROR: Process exited with code 30
    Habe nodejs und npm geupdated und einen npm rebuild gemacht...ledier kann ich zb. den INfo adapter nicht mehr installieren....und auch andere adapter nicht. Er findet die npm Version nicht!?
    mpn -v spuckt 9.8.1 aus
    Danke für Eure hilfe!
    LG
    HomoranH sigi234S 2 Antworten Letzte Antwort
    • P Pino72
      Plattform: Windows
      Architektur: x64
      CPUs: 4
      RAM: 7.8 GB
      Node.js: v18.17.0
      time: 1689936652605
      timeOffset: -120
      Adapter-Anzahl: 481
      aktiv:
      LG
      @pino72 sagte in Kann keine Adapter mehr installieren npm:
      dann zeig mal die komplette Ausgabe von iob diag
      EDIT:
      ist ja anscheinend Windoof :-( ich weiss nicht ob diag das versteht
        EDIT:
        @homoran sagte in Kann keine Adapter mehr installieren npm:
        Nein, iob diag ist ein bash skript und auch da weitgehend auf Debian und Konsorten abgestellt.
          @thomas-braun und which npm ?
            Alles linuxisch.
            • P Pino72
              Plattform: Windows
              Architektur: x64
              CPUs: 4
              RAM: 7.8 GB
              Node.js: v18.17.0
              time: 1689936652605
              timeOffset: -120
              Adapter-Anzahl: 481
              aktiv:
              LG
              sigi234S Online
              sigi234S Online
              sigi234
              @pino72
              https://forum.iobroker.net/topic/63610/test-iobroker-unter-windows-installieren-2023-edition?_=1689944197945
              Immer Daten sichern!
              P 1 Antwort Letzte Antwort
              • sigi234S sigi234
                @pino72
                Pino72
                @sigi234
                Danke den neuen installer kenne ich, aber dann muss ich ja alles neu aufsetzen oder kann ich einfach meine alte iobroker config sichern (oder den Data Ordner) und wieder zurückspielen inkl. alles Scripte und Einstellungen jedes Adapters etc?
