  4. zigbee 1.8.17 bleibt rot
    6.7k
zigbee
19 Beiträge 7 Kommentatoren 1.5k Aufrufe 7 Beobachtet
  • amg_666A Offline
    amg_666A Offline
    amg_666
    schrieb am zuletzt editiert von amg_666
    Nach Update kommt folgendes im Log
    host.iobroker
    	2023-07-15 22:02:17.930	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.iobroker
    	2023-07-15 22:02:17.930	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    	2023-07-15 22:02:17.930	error	Caught by controller[0]: Node.js v18.16.1
    host.iobroker
    	2023-07-15 22:02:17.930	error	Caught by controller[0]: at node:internal/main/run_main_module:23:47
    host.iobroker
    	2023-07-15 22:02:17.930	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    host.iobroker
    	2023-07-15 22:02:17.930	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
    host.iobroker
    	2023-07-15 22:02:17.930	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    host.iobroker
    	2023-07-15 22:02:17.929	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    host.iobroker
    	2023-07-15 22:02:17.929	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1220:27)
    host.iobroker
    	2023-07-15 22:02:17.929	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1178:20)
    host.iobroker
    	2023-07-15 22:02:17.929	error	Caught by controller[0]: at internalCompileFunction (node:internal/vm:73:18)
    host.iobroker
    	2023-07-15 22:02:17.929	error	Caught by controller[0]: SyntaxError: missing ) after argument list
    host.iobroker
    	2023-07-15 22:02:17.929	error	Caught by controller[0]: ^^^^^
    host.iobroker
    	2023-07-15 22:02:17.929	error	Caught by controller[0]: this.log.error(`Error ${error.code} on send command to ${payload.device}.` + ` Error: ${error.stack} ` + `Send command to ${payload.device} failed with ` + error;
    host.iobroker
    	2023-07-15 22:02:17.928	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/main.js:791
    host.iobroker
    	2023-07-15 22:02:17.559	info	instance system.adapter.zigbee.0 started with pid 23789
    Wechsel zurück auf 1.8.16 und alles ist wieder gut.
    iob auf nuc proxmox container, Debian 12, Beta Repository, node.js 18.16.1, npm 9.5.1
    • amg_666A amg_666
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      @amg_666
      Gibt bereits ein Issue dazu.
      L DuffyD 2 Antworten Letzte Antwort
        @amg_666
        LarryXXL
        habe den Fehler auch. Adapter startet nicht mehr. zurück auf vorherige version alles ok.
        • L LarryXXL
          @larryxxl
          Ist in 1.8.18 gefixt.
            @larryxxl
            amg_666A Offline
            amg_666A Offline
            amg_666
            Die 18er Version von Github läuft, meckert aber beim Start fehlende icons (?) an:
            zigbee.0
            	2023-07-16 17:22:04.070	warn	DeviceAvailability:Failed to ping 0x84fd27fffecf6567 TS011F
            zigbee.0
            	2023-07-16 17:21:56.737	warn	DeviceAvailability:Failed to ping 0x00124b00234c6ba9 ZB-CL01
            zigbee.0
            	2023-07-16 17:21:56.408	warn	DeviceAvailability:Failed to ping 0x00124b00235279d6 ZB-CL01
            zigbee.0
            	2023-07-16 17:21:55.888	warn	DeviceAvailability:Failed to ping 0x00124b00234ca487 ZB-CL01
            zigbee.0
            	2023-07-16 17:21:28.946	info	debug devices set to []
            zigbee.0
            	2023-07-16 17:21:28.763	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
            zigbee.0
            	2023-07-16 17:21:28.759	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
            zigbee.0
            	2023-07-16 17:21:28.755	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
            zigbee.0
            	2023-07-16 17:21:28.752	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
            zigbee.0
            	2023-07-16 17:21:28.741	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
            zigbee.0
            	2023-07-16 17:21:28.737	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
            zigbee.0
            	2023-07-16 17:21:28.732	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
            zigbee.0
            	2023-07-16 17:21:28.714	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
            zigbee.0
            	2023-07-16 17:21:28.709	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
            zigbee.0
            	2023-07-16 17:21:28.705	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
            zigbee.0
            	2023-07-16 17:21:28.696	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
            zigbee.0
            	2023-07-16 17:21:28.681	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
            zigbee.0
            	2023-07-16 17:21:28.669	info	Zigbee started
            • amg_666A amg_666
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              @amg_666
              Die werden doch heruntergeladen?
                @amg_666
                amg_666A Offline
                amg_666A Offline
                amg_666
                @thomas-braun Sorry, du hast recht, wer lesen kann ist klar im Vorteil :-) ich war über das Warning gestolpert, aber das bezieht sich wohl nur darauf, dass er fehlende Icons runterladen muss, das scheint auch geklappt zu haben, sieht alles sauber aus wenn ich auf die zigbee Übersicht gehe.
                • amg_666A amg_666
                  @amg_666
                  warning = Hinweis, nicht 'Warnung'
                    @amg_666
                    DuffyD Offline
                    DuffyD Offline
                    Duffy
                    Apropos icon, weisst du zufällig wo die icons hinterlegt sein müssen damit sie auch im Zigbee Adapter gezogen werden? Hatte mal icons hinterlegt die aber auf meinem Win PC lagen und dann natürlich kurz drauf wieder weg waren.
                    Es gibt ja schon auch einige Geräte die leider nicht hinterlegt sind.
                    Gruss Duffy
                    Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                    Node.js: v22.23.2
                    NPM: 10.9.4
                    js-controller 7.1.2
                    Linux: Trixie
                    Thomas BraunT WinniW arteckA 3 Antworten Letzte Antwort
                    • DuffyD Duffy
                      Gruss Duffy
                      @duffy
                      Nö.
                      • DuffyD Duffy
                        Gruss Duffy
                        WinniW Offline
                        WinniW Offline
                        Winni
                        @duffy ich denke das hier sollen sie sein:
                        opt/iobroker/iobroker-data/files/zigbee.admin/img
                        Es gibt nicht Gutes. Außer man tut es. Erich Kästner
                        • DuffyD Duffy
                          Gruss Duffy
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @duffy es sind ALLE hinterlegt.. und die die nicht da sind RTFM
                          DuffyD mcm1957M 2 Antworten Letzte Antwort
                          • arteckA arteck
                            DuffyD Offline
                            DuffyD Offline
                            Duffy
                            @arteck
                            Guten Morgen,
                            ich habe mich wahrscheinlich wieder schlecht ausgedrückt.
                            Ich meinte die Icons in den Objekten die bei mir teilweise fehlen.
                            Bekommt man die auch irgendwie da rein?
                            Gruß Duffy
                            Node.js: v22.23.2
                            NPM: 10.9.4
                            js-controller 7.1.2
                            Linux: Trixie
                            • DuffyD Duffy
                              @arteck
                              Guten Morgen,
                              Gruß Duffy
                              arteckA Offline
                              arteckA Offline
                              arteck
                              @duffy ok also nochmal RTFM
                              • DuffyD Offline
                                DuffyD Offline
                                Duffy
                                @arteck
                                Cool, mit
                                iob upload zigbee
                                hat es geklappt. Den nach oben zeigenden Pfeil beim Adapter gab es bei mir nicht.
                                Danke für den Tip
                                Gruß Duffy
                                Node.js: v22.23.2
                                NPM: 10.9.4
                                js-controller 7.1.2
                                Linux: Trixie
                                • DuffyD Duffy
                                  @arteck
                                  Cool, mit
                                  iob upload zigbee
                                  Danke für den Tip
                                  Gruß Duffy
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  @duffy sagte in zigbee 1.8.17 bleibt rot:
                                  dafür muss du den experten modus im admin einschalten
                                  DuffyD 1 Antwort Letzte Antwort
                                  • arteckA arteck
                                    DuffyD Offline
                                    DuffyD Offline
                                    Duffy
                                    @arteck
                                    ok, danke für den Hinweis.
                                    Node.js: v22.23.2
                                    NPM: 10.9.4
                                    js-controller 7.1.2
                                    Linux: Trixie
                                    • arteckA arteck
                                      mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      @arteck
                                      Warum werden die Icons nicht immer geuploaded?
                                      Oder gehts da um Update von Github ?
                                      Support Repositoryverwaltung.
                                      LESEN - gute Forenbeitrage
                                      • mcm1957M mcm1957
                                        @arteck
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        @mcm57 weil es technisch nicht geht..
