  4. zigbee 1.8.17 bleibt rot
    6.7k
zigbee
19 Beiträge 7 Kommentatoren 1.5k Aufrufe 7 Beobachtet
  • amg_666A amg_666
    Nach Update kommt folgendes im Log
    host.iobroker
    	2023-07-15 22:02:17.930	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.iobroker
    	2023-07-15 22:02:17.930	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    	2023-07-15 22:02:17.930	error	Caught by controller[0]: Node.js v18.16.1
    host.iobroker
    	2023-07-15 22:02:17.930	error	Caught by controller[0]: at node:internal/main/run_main_module:23:47
    host.iobroker
    	2023-07-15 22:02:17.930	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    host.iobroker
    	2023-07-15 22:02:17.930	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
    host.iobroker
    	2023-07-15 22:02:17.930	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    host.iobroker
    	2023-07-15 22:02:17.929	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    host.iobroker
    	2023-07-15 22:02:17.929	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1220:27)
    host.iobroker
    	2023-07-15 22:02:17.929	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1178:20)
    host.iobroker
    	2023-07-15 22:02:17.929	error	Caught by controller[0]: at internalCompileFunction (node:internal/vm:73:18)
    host.iobroker
    	2023-07-15 22:02:17.929	error	Caught by controller[0]: SyntaxError: missing ) after argument list
    host.iobroker
    	2023-07-15 22:02:17.929	error	Caught by controller[0]: ^^^^^
    host.iobroker
    	2023-07-15 22:02:17.929	error	Caught by controller[0]: this.log.error(`Error ${error.code} on send command to ${payload.device}.` + ` Error: ${error.stack} ` + `Send command to ${payload.device} failed with ` + error;
    host.iobroker
    	2023-07-15 22:02:17.928	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/main.js:791
    host.iobroker
    	2023-07-15 22:02:17.559	info	instance system.adapter.zigbee.0 started with pid 23789
    Wechsel zurück auf 1.8.16 und alles ist wieder gut.
    iob auf nuc proxmox container, Debian 12, Beta Repository, node.js 18.16.1, npm 9.5.1
    @amg_666
    Gibt bereits ein Issue dazu.
    L DuffyD 2 Antworten Letzte Antwort
      @amg_666
      LarryXXL
      habe den Fehler auch. Adapter startet nicht mehr. zurück auf vorherige version alles ok.
      • L LarryXXL
        @larryxxl
        Ist in 1.8.18 gefixt.
          @larryxxl
          amg_666A Offline
          amg_666A Offline
          amg_666
          Die 18er Version von Github läuft, meckert aber beim Start fehlende icons (?) an:
          zigbee.0
          	2023-07-16 17:22:04.070	warn	DeviceAvailability:Failed to ping 0x84fd27fffecf6567 TS011F
          zigbee.0
          	2023-07-16 17:21:56.737	warn	DeviceAvailability:Failed to ping 0x00124b00234c6ba9 ZB-CL01
          zigbee.0
          	2023-07-16 17:21:56.408	warn	DeviceAvailability:Failed to ping 0x00124b00235279d6 ZB-CL01
          zigbee.0
          	2023-07-16 17:21:55.888	warn	DeviceAvailability:Failed to ping 0x00124b00234ca487 ZB-CL01
          zigbee.0
          	2023-07-16 17:21:28.946	info	debug devices set to []
          zigbee.0
          	2023-07-16 17:21:28.763	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
          zigbee.0
          	2023-07-16 17:21:28.759	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
          zigbee.0
          	2023-07-16 17:21:28.755	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
          zigbee.0
          	2023-07-16 17:21:28.752	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
          zigbee.0
          	2023-07-16 17:21:28.741	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
          zigbee.0
          	2023-07-16 17:21:28.737	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
          zigbee.0
          	2023-07-16 17:21:28.732	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
          zigbee.0
          	2023-07-16 17:21:28.714	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
          zigbee.0
          	2023-07-16 17:21:28.709	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
          zigbee.0
          	2023-07-16 17:21:28.705	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZB-RGBCW.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZB-RGBCW.png
          zigbee.0
          	2023-07-16 17:21:28.696	warn	download icon from https://www.zigbee2mqtt.io/images/devices/MCCGQ14LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/MCCGQ14LM.png
          zigbee.0
          	2023-07-16 17:21:28.681	warn	download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
          zigbee.0
          	2023-07-16 17:21:28.669	info	Zigbee started
          • amg_666A amg_666
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            @amg_666
            Die werden doch heruntergeladen?
              @amg_666
              amg_666A Offline
              amg_666A Offline
              amg_666
              @thomas-braun Sorry, du hast recht, wer lesen kann ist klar im Vorteil :-) ich war über das Warning gestolpert, aber das bezieht sich wohl nur darauf, dass er fehlende Icons runterladen muss, das scheint auch geklappt zu haben, sieht alles sauber aus wenn ich auf die zigbee Übersicht gehe.
              • amg_666A amg_666
                @amg_666
                warning = Hinweis, nicht 'Warnung'
                  @amg_666
                  DuffyD Offline
                  DuffyD Offline
                  Duffy
                  Apropos icon, weisst du zufällig wo die icons hinterlegt sein müssen damit sie auch im Zigbee Adapter gezogen werden? Hatte mal icons hinterlegt die aber auf meinem Win PC lagen und dann natürlich kurz drauf wieder weg waren.
                  Es gibt ja schon auch einige Geräte die leider nicht hinterlegt sind.
                  Gruss Duffy
                  Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                  Node.js: v22.23.2
                  NPM: 10.9.4
                  js-controller 7.1.2
                  Linux: Trixie
                  Thomas BraunT WinniW arteckA 3 Antworten Letzte Antwort
                  • DuffyD Duffy
                    Gruss Duffy
                    @duffy
                    Nö.
                    • DuffyD Duffy
                      Gruss Duffy
                      WinniW Offline
                      WinniW Offline
                      Winni
                      @duffy ich denke das hier sollen sie sein:
                      opt/iobroker/iobroker-data/files/zigbee.admin/img
                      • DuffyD Duffy
                        Gruss Duffy
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @duffy es sind ALLE hinterlegt.. und die die nicht da sind RTFM
                        DuffyD mcm1957M 2 Antworten Letzte Antwort
                        • arteckA arteck
                          DuffyD Offline
                          DuffyD Offline
                          Duffy
                          @arteck
                          Guten Morgen,
                          ich habe mich wahrscheinlich wieder schlecht ausgedrückt.
                          Ich meinte die Icons in den Objekten die bei mir teilweise fehlen.
                          Bekommt man die auch irgendwie da rein?
                          Gruß Duffy
                          Node.js: v22.23.2
                          NPM: 10.9.4
                          js-controller 7.1.2
                          Linux: Trixie
                          • DuffyD Duffy
                            @arteck
                            Guten Morgen,
                            Gruß Duffy
                            arteckA Offline
                            arteckA Offline
                            arteck
                            @duffy ok also nochmal RTFM
                            • DuffyD Offline
                              DuffyD Offline
                              Duffy
                              @arteck
                              Cool, mit
                              iob upload zigbee
                              hat es geklappt. Den nach oben zeigenden Pfeil beim Adapter gab es bei mir nicht.
                              Danke für den Tip
                              Gruß Duffy
                              Node.js: v22.23.2
                              NPM: 10.9.4
                              js-controller 7.1.2
                              Linux: Trixie
                              • DuffyD Duffy
                                @arteck
                                Cool, mit
                                iob upload zigbee
                                Danke für den Tip
                                Gruß Duffy
                                arteckA Offline
                                arteckA Offline
                                arteck
                                @duffy sagte in zigbee 1.8.17 bleibt rot:
                                dafür muss du den experten modus im admin einschalten
                                DuffyD 1 Antwort Letzte Antwort
                                • arteckA arteck
                                  DuffyD Offline
                                  DuffyD Offline
                                  Duffy
                                  @arteck
                                  ok, danke für den Hinweis.
                                  Node.js: v22.23.2
                                  NPM: 10.9.4
                                  js-controller 7.1.2
                                  Linux: Trixie
                                  • arteckA arteck
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    @arteck
                                    Warum werden die Icons nicht immer geuploaded?
                                    Oder gehts da um Update von Github ?
                                    Support Repositoryverwaltung.
                                    LESEN - gute Forenbeitrage
                                    • mcm1957M mcm1957
                                      @arteck
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      @mcm57 weil es technisch nicht geht..
