  4. Instanz javascript - Fehler im log
errorjavascriptlog
7 Beiträge 2 Kommentatoren 503 Aufrufe 2 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    installiert ist js 7.0.3
    Bei start kommt im log:
    host.iobroker
    2023-06-25 10:10:35.640	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    2023-06-25 10:10:35.640	error	Caught by controller[0]: Node.js v18.16.1
    host.iobroker
    2023-06-25 10:10:35.640	error	Caught by controller[0]: }
    host.iobroker
    2023-06-25 10:10:35.640	error	Caught by controller[0]: requestPath: 'coffeescript'
    host.iobroker
    2023-06-25 10:10:35.639	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
    host.iobroker
    2023-06-25 10:10:35.639	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.iobroker
    2023-06-25 10:10:35.639	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) {
    host.iobroker
    2023-06-25 10:10:35.639	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    host.iobroker
    2023-06-25 10:10:35.639	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
    host.iobroker
    2023-06-25 10:10:35.638	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:23)
    host.iobroker
    2023-06-25 10:10:35.638	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
    host.iobroker
    2023-06-25 10:10:35.638	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
    host.iobroker
    2023-06-25 10:10:35.637	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
    host.iobroker
    2023-06-25 10:10:35.637	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
    host.iobroker
    2023-06-25 10:10:35.637	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:680:18)
    host.iobroker
    2023-06-25 10:10:35.637	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:438:19)
    host.iobroker
    2023-06-25 10:10:35.637	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
    host.iobroker
    2023-06-25 10:10:35.637	error	Caught by controller[0]: ^
    host.iobroker
    2023-06-25 10:10:35.636	error	Caught by controller[0]: throw err;
    host.iobroker
    2023-06-25 10:10:35.636	error	Caught by controller[0]: node:internal/modules/cjs/loader:446
    host.iobroker
    2023-06-25 10:10:35.150	info	instance system.adapter.javascript.0 started with pid 3790
    iob diag zeigt:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : kvm
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     09:49:16 up 1 min,  1 user,  load average: 3.56, 1.05, 0.37
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Sun 2023-06-25 09:49:17 CEST
               Universal time: Sun 2023-06-25 07:49:17 UTC
                     RTC time: Sun 2023-06-25 07:49:18
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    dieter
    /home/dieter
    dieter cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            5.9G        1.9G        3.7G        0.0K        376M        3.9G
    Swap:           974M          0B        974M
    Total:          6.9G        1.9G        4.7G
             5928 M total memory
             1854 M used memory
              140 M active memory
             1945 M inactive memory
             3698 M free memory
               49 M buffer memory
              327 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    *** FILESYSTEM ***
    Filesystem                Type      Size  Used Avail Use% Mounted on
    udev                      devtmpfs  2.9G     0  2.9G   0% /dev
    tmpfs                     tmpfs     593M  508K  593M   1% /run
    /dev/sda1                 ext4       31G  7.1G   22G  25% /
    tmpfs                     tmpfs     2.9G     0  2.9G   0% /dev/shm
    tmpfs                     tmpfs     5.0M     0  5.0M   0% /run/lock
    //192.168.243.100/1_Sound cifs      238G  128G  110G  54% /mnt
    tmpfs                     tmpfs     593M     0  593M   0% /run/user/1000
    [Sun Jun 25 09:47:48 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Jun 25 09:47:52 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    Show mounted filesystems (real ones only):
    TARGET SOURCE                    FSTYPE OPTIONS
    /      /dev/sda1                 ext4   rw,relatime,errors=remount-ro
    `-/mnt //192.168.243.100/1_Sound cifs   rw,relatime,vers=3.1.1,cache=strict,username=dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
    /var:
    860M    /var/
    371M    /var/cache
    364M    /var/cache/apt
    322M    /var/log
    305M    /var/log/journal/dd59139b4ae040898d227e04f86103f0
    Archived and active journals take up 56.0M in the file system.
    /opt/iobroker/backups:
    381M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    627M    /opt/iobroker/iobroker-data/files
    298M    /opt/iobroker/iobroker-data/files/vis.0
    248M    /opt/iobroker/iobroker-data/files/vis.0/wav
    235M    /opt/iobroker/iobroker-data/sqlite
    235M    /opt/iobroker/iobroker-data/sqlite/sqlite.db
    154M    /opt/iobroker/iobroker-data/files/vis.0/wav/starker-regen-mit-gewitter-im.wav
    36M     /opt/iobroker/iobroker-data/objects.jsonl
    34M     /opt/iobroker/iobroker-data/files/vis.0/wav/hagelschauer-im-sommer.wav
    31M     /opt/iobroker/iobroker-data/states.jsonl
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.1
    /usr/bin/node           v18.16.1
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.16.1-deb-1nodesource1
      Version table:
     *** 18.16.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    MULTIHOSTSERVICE/enabled: false
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   11
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.asterisk.0               : asterisk              : iobroker                                 -  enabled, port: 5038
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
      system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 - disabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.contact.0                : contact               : iobroker                                 -  enabled, port: 8096
    + system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.doorio.0                 : doorio                : iobroker                                 - disabled, port: 4444
    + system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
    + system.adapter.komoot.0                 : komoot                : iobroker                                 -  enabled
    + system.adapter.libre.0                  : libre                 : iobroker                                 -  enabled
      system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
    + system.adapter.mbus.0                   : mbus                  : Pi-Strom-Wasser                          -  enabled, port: 3493
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 192.168.243.12
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.musiccast.0              : musiccast             : iobroker                                 -  enabled
    + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
    + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
    + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
    + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
    + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
    + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled
      system.adapter.sayit.5                  : sayit                 : iobroker                                 - disabled, port: 0
      system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : Pi-Strom-Wasser                          -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : Pi-Strom-Wasser                          -  enabled
      system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
    + system.adapter.sql.1                    : sql                   : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.viessmann.0              : viessmann             : iobroker                                 -  enabled, port: 3002
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 - disabled, port: 5000
    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.243.114:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.3.5    , installed 6.3.5
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "bmw"          : 2.5.7    , installed 2.5.7
    Adapter    "bosch-ebike"  : 0.0.3    , installed 0.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "doorio"       : 2.1.4    , installed 2.1.4
    Adapter    "dwd"          : 2.8.3    , installed 2.8.5
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
    Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
    Adapter    "ical"         : 1.13.2   , installed 1.13.2
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "info"         : 1.9.26   , installed 1.9.26
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "libre"        : 0.0.4    , installed 0.0.5
    Adapter    "linux-control": 1.1.3    , installed 1.1.3
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "musiccast"    : 0.1.5    , installed 1.1.2
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "openligadb"   : 1.2.4    , installed 1.2.4
    Adapter    "parser"       : 1.3.2    , installed 1.3.2
    Adapter    "ping"         : 1.5.3    , installed 1.5.3
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
    Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "socketio"     : 4.2.0    , installed 6.3.5
    Adapter    "sql"          : 2.2.0    , installed 2.2.0
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "viessmann"    : 1.4.3    , installed 1.4.3
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 4.3.0    , installed 6.0.1
    Adapter    "wiobrowser"   : 2.0.1    , installed 2.0.1
    Adapter    "ws"           : 1.3.0    , installed 2.3.6
    Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        23819
    States:         19603
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       13637      406/iobroker.js-con
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       13628      406/iobroker.js-con
    tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      108        13608      403/asterisk
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          55         1/init
    tcp        0      0 192.168.243.15:2001     0.0.0.0:*               LISTEN      1001       15096      771/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11871      443/sshd: /usr/sbin
    tcp        0      0 192.168.243.15:2010     0.0.0.0:*               LISTEN      1001       15957      949/io.hm-rpc.2
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21822      1025/io.mqtt.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       19426      1031/io.mqtt.2
    tcp        0      0 192.168.243.15:8701     0.0.0.0:*               LISTEN      1001       16497      886/io.hm-rpc.1
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1232       1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13739      582/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20964      2595/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21774      2599/io.ws.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11873      443/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20152      2227/io.simple-api.
    udp        0      0 0.0.0.0:5060            0.0.0.0:*                           108        13622      403/asterisk
    udp        0      0 192.168.243.15:50249    0.0.0.0:*                           1001       23569      1093/io.yamaha.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       23570      1093/io.yamaha.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19402      1078/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19403      1078/io.tuya.0
    udp        0      0 0.0.0.0:36196           0.0.0.0:*                           108        14431      403/asterisk
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1425       371/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13276      1/init
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       17502      983/io.mihome-vacuu
    udp        0      0 0.0.0.0:4569            0.0.0.0:*                           108        13621      403/asterisk
    udp6       0      0 :::52485                :::*                                108        14432      403/asterisk
    udp6       0      0 :::111                  :::*                                0          13281      1/init
    2023-06-25 09:54:47.447  - info: mqtt.2 (1031) Client [Wemos_Philipp_Klima] publishOnSubscribe send all known states
    2023-06-25 09:54:47.590  - info: mqtt.2 (1031) Client [Wemos_Beamer-Wz] publishOnSubscribe send all known states
    2023-06-25 09:55:00.348  - info: host.iobroker instance system.adapter.dwd.0 started with pid 4197
    2023-06-25 09:55:08.710  - info: dwd.0 (4197) starting. Version 2.8.5 (non-npm: ioBroker/ioBroker.dwd) in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
    2023-06-25 09:55:09.473  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.0.diesel.feed, Alias=false, WriteNulls=false
    2023-06-25 09:55:17.239  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.1.diesel.feed, Alias=false, WriteNulls=false
    2023-06-25 09:55:22.539  - info: dwd.0 (4197) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-06-25 09:55:23.292  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-06-25 09:55:23.622  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.2.diesel.feed, Alias=false, WriteNulls=false
    2023-06-25 09:55:29.920  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.3.diesel.feed, Alias=false, WriteNulls=false
    2023-06-25 09:55:31.183  - info: octoprint.0 (1958) error EHOSTUNREACH from /api/version: connect EHOSTUNREACH 192.168.243.139:80
    2023-06-25 09:55:35.180  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.4.diesel.feed, Alias=false, WriteNulls=false
    2023-06-25 09:55:36.736  - error: daswetter.0 (1304) force terminate
    2023-06-25 09:55:36.740  - warn: daswetter.0 (1304) Terminated (UNKNOWN_ERROR): Without reason
    2023-06-25 09:55:37.264  - error: daswetter.0 (1304) exception in await insertIntoList [Error: DB closed]
    2023-06-25 09:55:37.287  - error: daswetter.0 (1304) exception in await insertIntoList [Error: DB closed]
    2023-06-25 09:55:37.292  - error: daswetter.0 (1304) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2.wind_value": Connection is closed.
    2023-06-25 09:55:37.309  - error: daswetter.0 (1304) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2.wind_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2.wind_value": Connection is closed.]
    2023-06-25 09:55:37.312  - error: daswetter.0 (1304) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2.windIconURL": Connection is closed.
    2023-06-25 09:55:37.319  - error: daswetter.0 (1304) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2.windIconURL: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2.windIconURL": Connection is closed.]
    2023-06-25 09:55:37.530  - error: host.iobroker instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
    2023-06-25 09:55:40.651  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.5.diesel.feed, Alias=false, WriteNulls=false
    2023-06-25 09:55:43.058  - info: octoprint.0 (1958) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
    2023-06-25 09:55:43.537  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.6.diesel.feed, Alias=false, WriteNulls=false
    2023-06-25 09:55:46.648  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.7.diesel.feed, Alias=false, WriteNulls=false
    iob diag has finished.
    Press any key for a summary
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 5.10.0-23-amd64
    Installation:           kvm
    Timezone:               Europe/Berlin (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            5.9G        3.3G        1.5G        0.0K        1.1G        2.4G
    Swap:           974M          0B        974M
    Total:          6.9G        3.3G        2.5G
    Active iob-Instances:   51
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                23819
    States:                 19601
    Size of iob-Database:
    37M     /opt/iobroker/iobroker-data/objects.jsonl
    38M     /opt/iobroker/iobroker-data/states.jsonl
    Danke.
    • bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      weiterhin kam im log:
      Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      Das habe ich ausprobiert im Verzeichnis: /opt/iobroker/node_modules/iobroker.javascript
      In der Konsole kommt:
      dieter@iobroker:/opt/iobroker/node_modules/iobroker.javascript$ npm install --production
      [sudo] Passwort für dieter:
      npm WARN config production Use `--omit=dev` instead.
      up to date, audited 169 packages in 5s
      9 packages are looking for funding
        run `npm fund` for details
      1 moderate severity vulnerability
      Some issues need review, and may require choosing
      a different dependency.
      Run `npm audit` for details.
      Gebracht hat es nichts. Weiterhin instance rot !
      Danke.
      • bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        So, habe javascript über npm neu drüber installiert.
        Instanz wird grün !
        Im log kommt aber noch sowas:
        javascript.0
        2023-06-25 10:24:50.847	error	WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        javascript.0
        2023-06-25 10:24:50.844	error	npm
        javascript.0
        2023-06-25 10:24:50.649	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
        javascript.0
        2023-06-25 10:24:50.647	error	npm
        javascript.0
        2023-06-25 10:24:50.263	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
        javascript.0
        2023-06-25 10:24:50.261	error	npm
        javascript.0
        2023-06-25 10:24:49.796	error	WARN deprecated har-validator@5.1.5: this library is no longer supported
        javascript.0
        2023-06-25 10:24:49.792	error	npm
        smartmeter.0
        2023-06-25 10:24:40.074	info	Received 7 values, 3 updated
        javascript.0
        2023-06-25 10:24:37.365	info	npm install basic-ftp --omit=dev (System call)
        javascript.0
        2023-06-25 10:24:37.295	info	starting. Version 7.0.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.16.1, js-controller: 4.0.24
        Danke.
        • bahnuhrB bahnuhr
          Instanz wird grün !
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          smartmeter.0
          javascript.0
          javascript.0
          crunchipC Abwesend
          crunchipC Abwesend
          @bahnuhr das kannst ignorieren
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            @crunchip sagte in Instanz javascript - Fehler im log:
            Ja, hab ich mir schon gedacht.
            Die Frage ist nur, warum kam der ursprüngliche Fehler mit dem "coffee"
            Vorher hatte ich mit update und upgrade alles aktualisiert.
            Und dann war js rot.
            Danke.
            • bahnuhrB bahnuhr
              crunchipC Abwesend
              crunchipC Abwesend
              @bahnuhr sagte in Instanz javascript - Fehler im log:
              kann ich dir nicht sagen, aber ich glaube mich zu erinnern, das du schon den ein oder anderen Thread eröffnet hattest, wegen diesem coffeescript
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                ja, aber danach hatte ich komplett neu aufgesetzt.
                Komisch.
                Danke.
