  3. Einsteigerfragen
  4. Installation
  5. Raspi hängt sich 2x täglich auf
Geplant Angeheftet Gesperrt Verschoben Installation
38 Beiträge 7 Kommentatoren 2.9k Aufrufe 5 Beobachtet
    Theophilus
    Moin, moin,
    ich habe iobroker jetzt erfolgreich auf meinem RaspberryPi 3 installiert. Es läuft auch alles fein, aber leider hängt er sich regelmäßig auf. Hier das Log von heute Nacht:
    2023-05-31 02:27:32.418 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
    2023-05-31 02:27:32.430 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-05-31 02:27:32.433 - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
    2023-05-31 02:27:32.434 - info: host.raspberrypi ip addresses: fe80::4d0d:5036:a3d5:2263
    2023-05-31 02:27:36.821 - info: host.raspberrypi connected to Objects and States
    2023-05-31 02:27:36.906 - info: host.raspberrypi added notifications configuration of host
    2023-05-31 02:27:37.933 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
    2023-05-31 02:27:37.947 - info: host.raspberrypi 8 instances found
    2023-05-31 02:27:37.983 - info: host.raspberrypi starting 8 instances
    2023-05-31 02:27:38.182 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
    2023-05-31 02:27:38.285 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 627
    2023-05-31 02:27:38.302 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
    2023-05-31 02:27:38.380 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
    2023-05-31 02:27:38.457 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
    2023-05-31 02:27:38.532 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
    2023-05-31 02:27:38.606 - info: host.raspberrypi Some obsolete host states deleted.
    2023-05-31 02:27:42.077 - info: host.raspberrypi instance system.adapter.history.0 started with pid 634
    2023-05-31 02:27:42.857 - error: admin.0 (627) admin.0 already running
    2023-05-31 02:27:42.867 - warn: admin.0 (627) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-05-31 02:27:43.522 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-05-31 02:27:43.524 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2023-05-31 02:27:45.452 - error: history.0 (634) history.0 already running
    2023-05-31 02:27:45.461 - warn: history.0 (634) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-05-31 02:27:46.082 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 649
    2023-05-31 02:27:46.126 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-05-31 02:27:46.129 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
    2023-05-31 02:27:50.084 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 656
    2023-05-31 02:27:53.471 - error: javascript.0 (649) javascript.0 already running
    2023-05-31 02:27:53.480 - warn: javascript.0 (649) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-05-31 02:27:53.677 - error: mqtt.0 (656) mqtt.0 already running
    2023-05-31 02:27:53.685 - warn: mqtt.0 (656) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2023-05-31 02:27:54.111 - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 671
    2023-05-31 02:27:54.162 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2023-05-31 02:27:54.164 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
    2023-05-31 06:57:59.959 - error: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_AL
    Das gleiche gestern um 14:17 Uhr und auch in der Nacht um 2:31 Uhr. Was treibt der Raspi da?
    • T Theophilus
      Moin, moin,
      arteckA Offline
      arteckA Offline
      arteck
      @theophilus sagte in Raspi hängt sich 2x täglich auf:
      steht doch da
      ich würde eher wissen wollen was du da treibst.. warum alles doppelt läuft
      • arteckA arteck
        steht doch da
        Theophilus
        schrieb am zuletzt editiert von Theophilus
        @arteck ich treibe gar nichts ... Das macht der Raspi ganz von alleine!
        		     v.2023-04-16
        Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
        Kernel: 		6.1.21-v8+
        Installation: 		Native
        Timezone: 		Europe/Berlin (CEST, +0200)
        User-ID: 		1000
        X-Server: 		false
        Boot Target: 		multi-user.target
        Pending OS-Updates: 	0
        Pending iob updates: 	0
        Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.0
        			/usr/bin/node 		v18.16.0
        			/usr/bin/npm 		9.5.1
        			/usr/bin/npx 		9.5.1
        Recommended versions are nodejs 18.x.y and npm 9.x.y
        MEMORY:
        Mem:            909M        632M        120M        0.0K        156M        218M
        Swap:            99M         89M         10M
        Total:          1.0G        721M        131M
        Active iob-Instances: 	9
        Active repo(s): stable
        ioBroker Core: 		js-controller 		4.0.24
        			admin 			6.3.5
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        Objects: 		706
        States: 		628
        Size of iob-Database:
        40M	/opt/iobroker/iobroker-data/objects.jsonl
        6.7M	/opt/iobroker/iobroker-data/states.jsonl
        arteckA Thomas BraunT 2 Antworten Letzte Antwort
        • T Theophilus
          		     v.2023-04-16
          Kernel: 		6.1.21-v8+
          User-ID: 		1000
          X-Server: 		false
          			/usr/bin/npm 		9.5.1
          			/usr/bin/npx 		9.5.1
          MEMORY:
          Swap:            99M         89M         10M
          			admin 			6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects: 		706
          States: 		628
          arteckA Offline
          arteckA Offline
          arteck
          von alleine passiert erstmal nix..
          wie hast du den iobroker installiert ? und wir brauchen das LOG vor dem aufhängen nicht danach
          T 3 Antworten Letzte Antwort
          • arteckA arteck
            Theophilus
            @arteck nach der Anleitung hier im Forum
            • arteckA arteck
              Theophilus
              @arteck Davor ist erstmal 20 Minuten lang nix passiert:
              2023-05-31 00:00:00.056 - info: sourceanalytix.0 (811) Reset start values for : 0_userdata.0.Stromkasten.Verbrauch_Total
              2023-05-31 00:00:00.097 - info: sourceanalytix.0 (811) Memory values before reset : {"stateDetails":{"consumption":true,"deviceName":"0_userdata__0__Stromkasten__Verbrauch_Total","financialCategory":"earnings","headCategory":"delivered","meter_values":true,"stateType":"ElectricityDelivery","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1},"calcValues":{"cumulativeValue":11694.8968,"start_day":11678,"start_month":11389,"start_quarter":0,"start_week":11678,"start_year":9777,"valueAtDeviceReset":0,"valueAtDeviceInit":null},"prices":{"basicPrice":"15","unitPrice":"0.17"}}
              2023-05-31 00:00:00.149 - info: sourceanalytix.0 (811) Memory values after reset : {"stateDetails":{"consumption":true,"deviceName":"0_userdata__0__Stromkasten__Verbrauch_Total","financialCategory":"earnings","headCategory":"delivered","meter_values":true,"stateType":"ElectricityDelivery","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1},"calcValues":{"start_day":11694.8968,"start_month":11389,"start_quarter":0,"start_week":11678,"start_year":9777,"valueAtDeviceInit":null,"valueAtDeviceReset":0,"cumulativeValue":11694.8968},"prices":{"basicPrice":"15","unitPrice":"0.17"}}
              2023-05-31 00:00:00.150 - info: sourceanalytix.0 (811) Reset start values for : 0_userdata.0.Stromkasten.Einspeisung_Total
              2023-05-31 00:00:00.151 - info: sourceanalytix.0 (811) Memory values before reset : {"stateDetails":{"consumption":true,"deviceName":"0_userdata__0__Stromkasten__Einspeisung_Total","financialCategory":"earnings","headCategory":"delivered","meter_values":true,"stateType":"ElectricityDelivery","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1},"calcValues":{"cumulativeValue":103.0017,"start_day":101,"start_month":53,"start_quarter":16,"start_week":98,"start_year":0,"valueAtDeviceReset":0,"valueAtDeviceInit":null},"prices":{"basicPrice":"15","unitPrice":"0.17"}}
              2023-05-31 00:00:00.175 - info: sourceanalytix.0 (811) Memory values after reset : {"stateDetails":{"consumption":true,"deviceName":"0_userdata__0__Stromkasten__Einspeisung_Total","financialCategory":"earnings","headCategory":"delivered","meter_values":true,"stateType":"ElectricityDelivery","stateUnit":"kWh","useUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1},"calcValues":{"start_day":103.0017,"start_month":53,"start_quarter":16,"start_week":98,"start_year":0,"valueAtDeviceInit":null,"valueAtDeviceReset":0,"cumulativeValue":103.0017},"prices":{"basicPrice":"15","unitPrice":"0.17"}}
              2023-05-31 02:02:04.727 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (1): connection timed out
              2023-05-31 02:02:29.769 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (3): connection timed out
              2023-05-31 02:03:14.773 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (5): connection timed out
              2023-05-31 02:04:19.776 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (7): connection timed out
              2023-05-31 02:04:20.689 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Connect locally to device
              2023-05-31 02:04:20.690 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt Init with IP=192.168.178.122, Key=2149e76c6ae6295f, Version=3.3
              2023-05-31 02:04:25.698 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (1): connection timed out
              2023-05-31 02:04:50.700 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (3): connection timed out
              2023-05-31 02:05:35.704 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (5): connection timed out
              2023-05-31 02:06:40.708 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (7): connection timed out
              2023-05-31 02:06:45.642 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Connect locally to device
              2023-05-31 02:06:45.644 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt Init with IP=192.168.178.122, Key=2149e76c6ae6295f, Version=3.3
              2023-05-31 02:06:50.648 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (1): connection timed out
              2023-05-31 02:07:15.651 - info: tuya.0 (776) bf00d6e8fdadd39fd2bemt: Error on Reconnect (3): connection timed out
              T ? 2 Antworten Letzte Antwort
              • T Theophilus
                Theophilus
                @theophilus Gestern 14.17
                2023-05-30 13:29:30.562 - info: admin.0 (831) ==> Connected system.user.admin from ::ffff:192.168.178.42
                2023-05-30 13:42:55.653 - info: admin.0 (831) <== Disconnect system.user.admin from ::ffff:192.168.178.42 admin
                2023-05-30 14:18:26.657 - info: admin.0 (831) Request actual repository...
                2023-05-30 14:18:28.004 - info: host.raspberrypi Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                2023-05-30 14:17:14.307 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                2023-05-30 14:17:14.322 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2023-05-30 14:17:14.325 - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                2023-05-30 14:17:14.326 - info: host.raspberrypi ip addresses: fe80::4d0d:5036:a3d5:2263
                2023-05-30 14:17:17.489 - info: host.raspberrypi connected to Objects and States
                2023-05-30 14:17:17.566 - info: host.raspberrypi added notifications configuration of host
                2023-05-30 14:17:18.525 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
                2023-05-30 14:17:18.539 - info: host.raspberrypi 8 instances found
                2023-05-30 14:17:18.576 - info: host.raspberrypi starting 8 instances
                2023-05-30 14:17:18.695 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
                2023-05-30 14:17:18.724 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
                2023-05-30 14:17:18.761 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 626
                2023-05-30 14:17:18.847 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
                2023-05-30 14:17:18.920 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
                2023-05-30 14:17:18.994 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
                2023-05-30 14:17:19.066 - info: host.raspberrypi Some obsolete host states deleted.
                2023-05-30 14:17:22.683 - info: host.raspberrypi instance system.adapter.history.0 started with pid 633
                2023-05-30 14:17:23.253 - error: admin.0 (626) admin.0 already running
                2023-05-30 14:17:23.262 - warn: admin.0 (626) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2023-05-30 14:17:23.907 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2023-05-30 14:17:23.909 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
                2023-05-30 14:17:26.052 - error: history.0 (633) history.0 already running
                2023-05-30 14:17:26.061 - warn: history.0 (633) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2023-05-30 14:17:26.679 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 648
                2023-05-30 14:17:26.725 - error: host.raspberrypi instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2023-05-30 14:17:26.727 - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
                2023-05-30 14:17:30.698 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 655
                2023-05-30 14:17:34.002 - error: javascript.0 (648) javascript.0 already running
                2023-05-30 14:17:34.009 - warn: javascript.0 (648) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2023-05-30 14:17:34.213 - error: mqtt.0 (655) mqtt.0 already running
                2023-05-30 14:17:34.222 - warn: mqtt.0 (655) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2023-05-30 14:17:34.669 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2023-05-30 14:17:34.670 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
                2023-05-30 14:17:34.808 - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 670
                2023-05-30 14:17:34.855 - error: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2023-05-30 14:17:34.857 - info: host.raspberrypi Restart adapter system.adapter.mqtt.0 because enabled
                • T Theophilus
                  arteckA Offline
                  arteckA Offline
                  arteck
                  hier wird probiert alles nochmal zu starten...
                  machst du da backup vielleicht.. und das geht in die hose..
                  • T Theophilus
                    Moin,
                    ich ehe einfach mal davon aus, dass Dir der Speicher bei irgendeiner Aktion ausgeht und das System crasht.
                    MEMORY:
                    Swap:            99M         89M         10M
                    Wie viele Adapter hast Du denn installiert und wie viele sind aktiv?
                    Zeig doch mal die Langfassung von iob diag und aus dem journal die Einträge zur Zeit der Abstürze, hier mal Beispiele:
                    Vor 1 Stunde bis jetzt
                    $ journalctl --since "1 hour ago"
                    Von vor 2 Tagen bis jetzt
                    $ journalctl --since "2 days ago"
                    Zwischen zwei Zeiten*
                    $ journalctl --since "2015-06-26 23:15:00" --until "2015-06-26 23:20:00"
                    Oder schau mal, ob Du oom, kill im Log hast
                    $ journalctl | grep -iE 'oom|kill'
                    VG
                    Bernd
                    • T Theophilus
                      		     v.2023-04-16
                      Kernel: 		6.1.21-v8+
                      User-ID: 		1000
                      X-Server: 		false
                      			/usr/bin/npm 		9.5.1
                      			/usr/bin/npx 		9.5.1
                      MEMORY:
                      Swap:            99M         89M         10M
                      			admin 			6.3.5
                      Objects type: jsonl
                      States  type: jsonl
                      Objects: 		706
                      States: 		628
                      @theophilus
                      Gib mal die Langfassung von iob diag
                      Und schau zu den Zeiten in das Journal rein.
                      Edit: Zu langsam und zu ungenau gewesen... :-)
                        Moin,
                        MEMORY:
                        Swap:            99M         89M         10M
                        VG
                        Bernd
                        @dp20eic
                        Könnte für 1GB RAM schon zu viel sein.
                        ? T 2 Antworten Letzte Antwort
                        • arteckA arteck
                          Theophilus
                          @arteck sagte in Raspi hängt sich 2x täglich auf:
                          Das Log entstand unmittelbar vor dem Aufhängen. Es waren quasi seine letzten Lebenszeichen.
                            @dp20eic
                            @thomas-braun sagte in Raspi hängt sich 2x täglich auf:
                            Moin,
                            oh, danke, war wohl zu früh oder ich brauche doch eine Brille, wenn ich am Laptop arbeite :)
                            VG
                            Bernd
                            P.S.: also Betriebssystem, nodejs, iobroker, adapter, mir schwebt da eine Aussage vor den Augen, dass da so zwischen 60 - 100 MB pro Adapter zu veranschlagen ist, dann vielleicht noch Backup oder Scripte die da etwas machen, dann kann es eng werden.
                              @dp20eic
                              Theophilus
                              @thomas-braun Erweitern kann man beim Raspi nichts, oder?
                              • T Theophilus
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                RAM ? Natürlich nicht
                                Lehrling seit 1975 !!!
                                • DJMarc75D DJMarc75
                                  @djmarc75
                                  Der McGiver-Ansatz:
                                  https://www.pcgameshardware.de/Raspberry-Pi-Hardware-257637/News/4-RAM-Chip-16-GB-Upgrade-1418168/
                                    @djmarc75
                                    Der McGiver-Ansatz:
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    Der McGiver-Ansatz:
                                    ein Streicholz und ein Kaugummipapier 😂
                                    konnte damit schon viele LinuxProbleme lösen 😀 👍
                                      Der McGiver-Ansatz:
                                      @djmarc75
                                      Ja, die universell einsetzbaren libmatches und libbubblegum
                                        @djmarc75
                                        Theophilus
                                        Heute nachmittag hat er sich nicht aufgehängt. War wohl Zufall, dass es gestern 2 Uhr und 14 Uhr war.
                                        • T Theophilus
                                          Theophilus
                                          @theophilus Er bleibt bei. Alles läuft super, dann kommt dieser ominöse Neustart und der Raspi hängt sich auf.
                                          2023-06-05 07:17:15.426 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                                          2023-06-05 07:17:15.439 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                          2023-06-05 07:17:15.441 - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                                          2023-06-05 07:17:15.443 - info: host.raspberrypi ip addresses: fe80::4d0d:5036:a3d5:2263
                                          2023-06-05 07:17:19.097 - info: host.raspberrypi connected to Objects and States
                                          2023-06-05 07:17:19.194 - info: host.raspberrypi added notifications configuration of host
                                          2023-06-05 07:17:20.208 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
                                          2023-06-05 07:17:20.221 - info: host.raspberrypi 9 instances found
                                          2023-06-05 07:17:20.262 - info: host.raspberrypi starting 9 instances
                                          2023-06-05 07:17:20.399 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
                                          2023-06-05 07:17:20.436 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
                                          2023-06-05 07:17:20.475 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 632
                                          2023-06-05 07:17:20.509 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
                                          2023-06-05 07:17:20.543 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
                                          2023-06-05 07:17:20.617 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
                                          2023-06-05 07:17:20.646 - info: host.raspberrypi Some obsolete host states deleted.
                                          2023-06-05 07:17:24.495 - info: host.raspberrypi instance system.adapter.history.0 started with pid 639
                                          2023-06-05 07:17:25.903 - info: admin.0 (632) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
                                          2023-06-05 07:17:26.028 - info: admin.0 (632) requesting all states
                                          2023-06-05 07:17:26.030 - info: admin.0 (632) requesting all objects
                                          2023-06-05 07:17:28.610 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 666
                                          2023-06-05 07:17:29.621 - info: admin.0 (632) received all objects
                                          2023-06-05 07:17:30.198 - info: history.0 (639) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.history, node: v18.16.0, js-controller: 4.0.24
                                          2023-06-05 07:17:30.369 - info: history.0 (639) enabled logging of 0_userdata.0.Solar.Solar_Aktuell (Count=1), Alias=false
                                          2023-06-05 07:17:30.372 - info: history.0 (639) enabled logging of 0_userdata.0.Stromkasten.Verbrauch_Aktuell (Count=2), Alias=false
                                          2023-06-05 07:17:30.375 - info: history.0 (639) enabled logging of 0_userdata.0.Stromkasten.Verbrauch_Total (Count=3), Alias=false
                                          2023-06-05 07:17:30.377 - info: history.0 (639) enabled logging of 0_userdata.0.Stromkasten.Einspeisung_Total (Count=4), Alias=false
                                          2023-06-05 07:17:31.502 - info: admin.0 (632) Request actual repository...
                                          2023-06-05 07:17:31.655 - info: admin.0 (632) http server listening on port 8081
                                          2023-06-05 07:17:31.658 - info: admin.0 (632) Use link "http://localhost:8081" to configure.
                                          2023-06-05 07:17:31.703 - info: admin.0 (632) socket.io server listening on port 8081
                                          2023-06-05 07:17:33.587 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                          2023-06-05 07:17:33.770 - info: host.raspberrypi instance system.adapter.mqtt.0 started with pid 681
                                          2023-06-05 07:17:35.155 - info: admin.0 (632) failed connection to socket.io from ::ffff:192.168.178.42: Passport was not initialized
                                          2023-06-05 07:17:35.438 - info: admin.0 (632) failed connection to socket.io from ::ffff:192.168.178.42: Passport was not initialized
                                          2023-06-05 07:17:36.396 - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 688
