  3. Off Topic
  4. An error occurred during the signature verification [Gelöst]
    1.0k
    6.1k
11 Beiträge 2 Kommentatoren 2.3k Aufrufe 2 Beobachtet
  • N Offline
    N Offline
    Naturfreund
    schrieb am zuletzt editiert von Naturfreund
    ich wollte heute ein update machen, folgendes spuckt die Konsole aus:
    pi@raspberrypi:~ $ sudo apt update
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,031 B]
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
    Err:5 https://repos.influxdata.com/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not av                                            ailable: NO_PUBKEY D8FF8E1F7DF8B07E
    Fetched 51.1 kB in 2s (26.9 kB/s)
    Reading package lists... Done
    Building dependency tree... Done
    20 packages can be upgraded. Run 'apt list --upgradable' to see them.
    W: An error occurred during the signature verification. The repository is not up                                            dated and the previous index files will be used. GPG error: https://repos.influx                                            data.com/debian bullseye InRelease: The following signatures couldn't be verifie                                            d because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease                                              The following signatures couldn't be verified because the public key is not ava                                            ilable: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used                                             instead.
    Wie kann ich denn die Signaturen aktualisieren?
    • N Naturfreund
      @naturfreund
      Leg das influx-Repository neu an.
      Alte .list-Datei in /etc/apt/sources.list.d zuvor löschen.
      Hier gibt's weiteres dazu:
      https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
      N 1 Antwort Letzte Antwort
        @naturfreund
        N Offline
        N Offline
        Naturfreund
        Hab die alten influx keys entfernt.
        Wie komme ich an die neuen ran?
        Die Adressen unten stimmen für influx sicher nicht ;-)
        sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
        echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
        • N Naturfreund
          @naturfreund sagte in An error occurred during the signature verification:
          Das Influx-Repo noch mal über deren Installer reinholen. Da kommen die Keys dann mit.
          Alternativ: Schau mal nach meinem Beitrag 'Phantastische Repos und wo sie zu finden sind'
          (Oder so ähnlich). Da steht es auch drin.
            N Offline
            N Offline
            Naturfreund
            Link auf phantastische-repositories-und-wo-sie-zu-finden-sind
            pi@raspberrypi:~ $ apt-key list | grep -i influx | wc -l
            Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:5 https://repos.influxdata.com/debian stable InRelease
            Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
            Hit:7 https://apt.grafana.com stable InRelease
            Ign:8 https://repos.influxdata.com/debian $(lsb_release InRelease
            Err:9 https://repos.influxdata.com/debian $(lsb_release Release
              404  Not Found [IP: 99.84.88.81 443]
            E: The repository 'https://repos.influxdata.com/debian $(lsb_release Release' does not have a Release file.
            N: Updating from such a repository can't be done securely, and is therefore disabled by default.
            N: See apt-secure(8) manpage for repository creation and user configuration details.
            • N Naturfreund
              @naturfreund
              Der Eintrag
              Ist auch falsch. Da muss statt der Variable der entsprechende Release Name rein. Das passiert eigentlich automatisch wenn man das Skript bzw die Zeile ausführt und nicht einfach nur in die Datei kopiert.
                @naturfreund
                Der Eintrag
                N Offline
                N Offline
                Naturfreund
                pi@raspberrypi:~ $ sudo nano /etc/apt/sources.list.d/influxdb.list
                hab ich geändert auf:
                deb https://repos.influxdata.com/debian bullseye stable
                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:2 http://deb.debian.org/debian bullseye InRelease
                Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                Get:7 https://repos.influxdata.com/debian bullseye InRelease [7,040 B]
                Hit:8 https://deb.nodesource.com/node_16.x bullseye InRelease
                Err:7 https://repos.influxdata.com/debian bullseye InRelease
                  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                Fetched 7,040 B in 2s (3,499 B/s)
                W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                Thomas BraunT 3 Antworten Letzte Antwort
                • N Naturfreund
                  @naturfreund
                  echad@chet:~ $ cat /etc/apt/sources.list.d/influxdata.list
                  deb [signed-by=/etc/apt/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
                  echad@chet:~ $
                  Key muss natürlich in /etc/apt/keyrings deponiert sein.
                  • N Naturfreund
                    @naturfreund
                    Lösch die influx*.list und dann diese vier Zeilen in dein Terminal kopieren:
                    sudo rm /etc/apt/sources.list.d/infl*
                    wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                    echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                    echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                    • N Naturfreund
                      @naturfreund
                      Und wenn das passt die 20 Updates auf das System schaufeln.
                        @naturfreund
                        N Offline
                        N Offline
                        Naturfreund
                        Danke @Thomas-Braun , ist alles sauber durchgelaufen
                        Hit:4 https://repos.influxdata.com/debian stable InRelease
                        Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                        All packages are up to date.
