  3. Off Topic
  4. An error occurred during the signature verification [Gelöst]
    1.0k
    6.1k
11 Beiträge 2 Kommentatoren 2.3k Aufrufe 2 Beobachtet
  • N Naturfreund
    ich wollte heute ein update machen, folgendes spuckt die Konsole aus:
    pi@raspberrypi:~ $ sudo apt update
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,031 B]
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
    Err:5 https://repos.influxdata.com/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not av                                            ailable: NO_PUBKEY D8FF8E1F7DF8B07E
    Fetched 51.1 kB in 2s (26.9 kB/s)
    Reading package lists... Done
    20 packages can be upgraded. Run 'apt list --upgradable' to see them.
    W: An error occurred during the signature verification. The repository is not up                                            dated and the previous index files will be used. GPG error: https://repos.influx                                            data.com/debian bullseye InRelease: The following signatures couldn't be verifie                                            d because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease                                              The following signatures couldn't be verified because the public key is not ava                                            ilable: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used                                             instead.
    Wie kann ich denn die Signaturen aktualisieren?
    @naturfreund
    Leg das influx-Repository neu an.
    Alte .list-Datei in /etc/apt/sources.list.d zuvor löschen.
    Hier gibt's weiteres dazu:
    https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
    N 1 Antwort Letzte Antwort
      @naturfreund
      N Offline
      N Offline
      Naturfreund
      Hab die alten influx keys entfernt.
      Wie komme ich an die neuen ran?
      Die Adressen unten stimmen für influx sicher nicht ;-)
      sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
      echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
      • N Naturfreund
        @naturfreund sagte in An error occurred during the signature verification:
        Das Influx-Repo noch mal über deren Installer reinholen. Da kommen die Keys dann mit.
        Alternativ: Schau mal nach meinem Beitrag 'Phantastische Repos und wo sie zu finden sind'
        (Oder so ähnlich). Da steht es auch drin.
          N Offline
          N Offline
          Naturfreund
          schrieb am zuletzt editiert von Naturfreund
          Link auf phantastische-repositories-und-wo-sie-zu-finden-sind
          pi@raspberrypi:~ $ apt-key list | grep -i influx | wc -l
          Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
          Hit:7 https://apt.grafana.com stable InRelease
          Ign:8 https://repos.influxdata.com/debian $(lsb_release InRelease
          Err:9 https://repos.influxdata.com/debian $(lsb_release Release
            404  Not Found [IP: 99.84.88.81 443]
          E: The repository 'https://repos.influxdata.com/debian $(lsb_release Release' does not have a Release file.
          N: Updating from such a repository can't be done securely, and is therefore disabled by default.
          N: See apt-secure(8) manpage for repository creation and user configuration details.
          • N Naturfreund
            @naturfreund
            Der Eintrag
            Ist auch falsch. Da muss statt der Variable der entsprechende Release Name rein. Das passiert eigentlich automatisch wenn man das Skript bzw die Zeile ausführt und nicht einfach nur in die Datei kopiert.
              @naturfreund
              Der Eintrag
              N Offline
              N Offline
              Naturfreund
              pi@raspberrypi:~ $ sudo nano /etc/apt/sources.list.d/influxdb.list
              hab ich geändert auf:
              deb https://repos.influxdata.com/debian bullseye stable
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
              Get:7 https://repos.influxdata.com/debian bullseye InRelease [7,040 B]
              Hit:8 https://deb.nodesource.com/node_16.x bullseye InRelease
              Err:7 https://repos.influxdata.com/debian bullseye InRelease
                The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
              Fetched 7,040 B in 2s (3,499 B/s)
              W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
              W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
              Thomas BraunT 3 Antworten Letzte Antwort
              • N Naturfreund
                @naturfreund
                echad@chet:~ $ cat /etc/apt/sources.list.d/influxdata.list
                deb [signed-by=/etc/apt/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
                echad@chet:~ $
                Key muss natürlich in /etc/apt/keyrings deponiert sein.
                • N Naturfreund
                  @naturfreund
                  Lösch die influx*.list und dann diese vier Zeilen in dein Terminal kopieren:
                  sudo rm /etc/apt/sources.list.d/infl*
                  wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                  echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                  echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                  • N Naturfreund
                    @naturfreund
                    Und wenn das passt die 20 Updates auf das System schaufeln.
                      @naturfreund
                      N Offline
                      N Offline
                      Naturfreund
                      Danke @Thomas-Braun , ist alles sauber durchgelaufen
                      Hit:4 https://repos.influxdata.com/debian stable InRelease
                      Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                      All packages are up to date.
