  4. Bewegungsmeldung mit Frigate
    6.6k
6 Beiträge 1 Kommentatoren 1.4k Aufrufe 4 Beobachtet
  • WalW Offline
    WalW Offline
    Wal
    schrieb am zuletzt editiert von Wal
    Nach der Idee aus diesem Thema habe ich das Skript angepasst um Bewegungen von Objekten zu erkennen.
    Es können so die Kameras die in Frigate integriert sind als Bewegungsmelder genutzt werden.
    Version 5:
    var filepath = '/srv/storage/frigate/clips/'; // Pfad zu den Frigate Clips
    var weburl= 'http://192.168.12.16:5000'; //Url zum Frigate Server
    function extractEventData(message) {
        const parsedMessage = JSON.parse(message);
        let extractedJSON = {};
        extractedJSON.eventtype = parsedMessage.type;
        extractedJSON.beforecamera = parsedMessage.before.camera;
        extractedJSON.beforelabel = parsedMessage.before.label;
        extractedJSON.afterid = parsedMessage.after.id;
        extractedJSON.aftertopscore = parsedMessage.after.top_score;
        extractedJSON.afterhasclip = parsedMessage.after.has_clip;
        extractedJSON.afterhassnapshot = parsedMessage.after.has_snapshot;
        return extractedJSON;
    on({id: [].concat(['mqtt.0.frigate.events']), change: "ne" }, function (obj) {
        const extractedJSON = extractEventData(obj.state.val);
        const beforecamera = extractedJSON.beforecamera;
        const beforelabel = extractedJSON.beforelabel;
        const afterid = extractedJSON.afterid;
        const topscore = extractedJSON.aftertopscore;
        const hasclip = extractedJSON.afterhasclip;
        const hassnapshot = extractedJSON.afterhassnapshot;
        const eventtype = extractedJSON.eventtype;
        let id0 = '0_userdata.0.frigate.event';
        let id1 = '0_userdata.0.frigate.' + beforecamera + '.event';
        let id2 = '0_userdata.0.frigate.' + beforecamera + '.objects.' + beforelabel;
        let snapfilename = filepath + beforecamera + '-' + afterid + '.jpg';
        let clipfilename = filepath + beforecamera + '-' + afterid + '-clean.png';
        let websnap = weburl + '//api/events/' + afterid + '/snapshot.jpg';
        let webclip = weburl + '//api/events/' + afterid + '/clip.mp4';
        if (eventtype == 'new') {
            //      Bewegung erkannt
            if(existsState(id0)) {
                setState(id0, true, true);
            } else {
                createState(id0, true, {
                    type:"boolean",
                    read:true,
                    write:false,
                    name:"Bewegung erkannt",
                    def: false
            //       Kamera erkannt
            if(existsState(id1)) {
                setState(id1, true, true);
            } else {
                createState(id1, true, {
                    type:"boolean",
                    read:true,
                    write:false,
                    name:"Kamera erkannt",
                    def: false
            //       Objekt erkannt
            if(existsState(id2 + '.event')) {
                setState(id2 + '.event', true, true);
            } else {
                createState(id2 + '.event', true, {
                    type:"boolean",
                    read:true,
                    write:false,
                    name:beforelabel + " erkannt",
                    def: false
        } else if (eventtype == 'end') {
            //         Event ID
            if(existsState(id2 + '.id')) {
                setState(id2 + '.id', afterid, true);
            } else {
                createState(id2 + '.id', afterid, {
                    type:"string",
                    read:true,
                    write:false,
                    role:"value",
                    def: ""
            //            Files
            if(existsState(id2 + '.filename.snap.snap_0')) {
                for (var i = 9; i>-1; i--)
                    if (i==0) {setState(id2 + '.filename.snap.snap_' + i.toString(), snapfilename, true)} else
                        setState(id2 + '.filename.snap.snap_' + i.toString(), getState(id2 + '.filename.snap.snap_' + (i-1).toString()), true);
            } else {
                for (var i = 0; i<10; i++)
                    let dummy = '';
                    if (i==0) dummy = snapfilename;
                    createState(id2 + '.filename.snap.snap_' + i.toString(), dummy, {
                        type:"string",
                        read:true,
                        write:false,
                        name:"Snapshot Filename " + i.toString(),
                        role:"value",
                        def: ""
            if(existsState(id2 + '.web.snap.snap_0')) {
                    if (i==0) {setState(id2 + '.web.snap.snap_' + i.toString(), websnap, true)} else
                        setState(id2 + '.web.snap.snap_' + i.toString(), getState(id2 + '.web.snap.snap_' + (i-1).toString()), true);
            } else {
                    let dummy = '';
                    if (i==0) dummy = websnap;
                    createState(id2 + '.web.snap.snap_' + i.toString(), dummy, {
                        type:"string",
                        read:true,
                        write:false,
                        name:"Snapshot WebUrl " + i.toString(),
                        role:"value",
                        def: ""
            if(existsState(id2 + '.web.clip.clip_0')) {
                    if (i==0) {setState(id2 + '.web.clip.clip_' + i.toString(), webclip, true)} else
                        setState(id2 + '.web.clip.clip_' + i.toString(), getState(id2 + '.web.clip.clip_' + (i-1).toString()), true);
            } else {
                    let dummy = '';
                    if (i==0) dummy = webclip;
                    createState(id2 + '.web.clip.clip_' + i.toString(), dummy, {
                        type:"string",
                        read:true,
                        write:false,
                        name:"Clip WebUrl " + i.toString(),
                        role:"value",
                        def: ""
            if(existsState(id2 + '.filename.clip.clip_0')) {
                    if (i==0) {setState(id2 + '.filename.clip.clip_0', clipfilename, true)} else
                        setState(id2 + '.filename.clip.clip_' + i.toString(), getState(id2 + '.filename.clip.clip_' + (i-1).toString()), true);
            } else {
                    let dummy = '';
                    if (i==0) dummy = clipfilename;
                    createState(id2 + '.filename.clip.clip_' + i.toString(), dummy, {
                        type:"string",
                        read:true,
                        write:false,
                        name:"Clip Filename " + i.toString(),
                        role:"value",
                        def: ""
            //       Erkennungsrate
            if(existsState(id2 + '.score')) {
                setState(id2 + '.score', Math.round(topscore*100), true);
            } else {
                createState(id2 + '.score', Math.round(topscore*100), {
                    type:"number",
                    read:true,
                    write:false,
                    role:"value.score",
                    unit:"%",
                    def: 0
            //       Clip vorhanden
            if(existsState(id2 + '.clip')) {
                setState(id2 + '.clip', hasclip, true);
            } else {
                createState(id2 + '.clip', hasclip, {
                    type:"boolean",
                    read:true,
                    write:false,
                    name:"Clip vorhanden",
                    def: false
            //      Snapshot vorhanden
            if(existsState(id2 + '.snapshot')) {
                setState(id2 + '.snapshot', hassnapshot, true);
            } else {
                createState(id2 + '.snapshot', hassnapshot, {
                    type:"boolean",
                    read:true,
                    write:false,
                    name:"Snapshot vorhanden",
                    def: false
            //      Reset Event States
            setState(id0, false, true);
            setState(id1, false, true);
            setState(id2 + '.event', false, true);
    Walter
    DoorIO-Adapter
    • WalW Offline
      WalW Offline
      Wal
      Version 2:
      Allgemeine Bewegung erkannt
      Bewegung an Kamera xxx erkannt
      Objekt (Person,Auto,Hund...) erkannt
      Walter
      DoorIO-Adapter
      • WalW Offline
        WalW Offline
        Wal
        Version 3:
        Erkennungsrate
        Clip vorhanden
        Snapshot vorhanden
        Walter
        DoorIO-Adapter
        • WalW Offline
          WalW Offline
          Wal
          Version 4:
          Pfade der letzten 10 Snapshots und Clips zur Verwendung in der Vis, E-Mail,Telegram u.s.w.
          Es funktioniert wie ein Ringpuffer, der aktuelle Pfad rückt auf die erste Stelle und der letzte Pfad fällt hinten raus.
          Der Frigate Ordner sollte unter ioBroker erreichbar sein.
          Ich nutze eine USB-Festplatte die in Proxmox eingebunden ist, diese mappe ich in den Frigate LXC und in den ioBroker LXC, dadurch habe ich die Bilder von Frigate direkt im ioBroker.
          Walter
          DoorIO-Adapter
          • WalW Offline
            WalW Offline
            Wal
            Version 5:
            Webadressen der Snapshots und Clips hinzugefügt.
            In der Vis ein Image hinzufügen und z.B.
            {0_userdata.0.frigate.deinkameranamen.objects.person.web.snap.snap_0}
            als Quelle einfügen.
            Die Clips sind die Videos zum Ereignis die man z.B. mit einem Link hinzufügen kann.
            Walter
            DoorIO-Adapter
            • WalW Offline
              WalW Offline
              Wal
              Da das Skript immer grösser wurde, habe ich alles in einen Adapter migriert.
              Walter
              DoorIO-Adapter
