  4. VIS Adaper, kein update, löschen oder install möglich
    5.4k
45 Beiträge 7 Kommentatoren 5.0k Aufrufe 5 Beobachtet
  • GlasfaserG Glasfaser
    @lustig29
    Was hast du da ,
    Adapter    "web"          : 4.3.0    , installed 6.0.1
    Das ist GITHUB ... nichts für dich !!!!
    lustig29
    @glasfaser Oh, wie mache ich das rückgänig?
    • L lustig29
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @lustig29
      iobroker upgrade web@4.3.0
      • L lustig29
        @glasfaser
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Architecture    : aarch64
        Docker          : false
        Virtualization  : none
        Distributor ID: Raspbian
        Description:    Raspbian GNU/Linux 11 (bullseye)
        Release:        11
        Codename:       bullseye
        PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
         16:19:50 up 21:08,  3 users,  load average: 1.89, 2.08, 1.99
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=37.9'C
        volt=0.8688V
        *** Time and Time Zones ***
                       Local time: Sun 2023-04-16 16:19:50 CEST
                   Universal time: Sun 2023-04-16 14:19:50 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        lustig29
        /home/lustig29
        lustig29 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.8G        2.3G        528M         35M        987M        1.6G
        Swap:            99M          0B         99M
        Total:          3.9G        2.3G        628M
                 3793 M total memory
                 2277 M used memory
                 2508 M active memory
                  475 M inactive memory
                  528 M free memory
                   79 M buffer memory
                  907 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        lifetime oom required: 0 Mbytes
        total time in oom handler: 0 ms
        max time spent in oom handler: 0 ms
        *** FILESYSTEM ***
        /dev/root      ext4      220G  6.3G  205G   3% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/sda1      vfat      255M   51M  205M  20% /boot
        tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
        [Sat Apr 15 19:11:48 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:73:5F:A3 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=3fd05b5c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Sat Apr 15 19:11:50 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sat Apr 15 19:11:50 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Sat Apr 15 19:11:52 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        396M    /var/
        123M    /var/lib
        121M    /var/cache
        114M    /var/cache/apt
        68M     /var/lib/apt/lists
        Archived and active journals take up 48.0M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        548M    /opt/iobroker/iobroker-data/
        387M    /opt/iobroker/iobroker-data/files
        62M     /opt/iobroker/iobroker-data/backup-objects
        56M     /opt/iobroker/iobroker-data/files/vis
        51M     /opt/iobroker/iobroker-data/files/javascript.admin
        50M     /opt/iobroker/iobroker-data/states.jsonl
        41M     /opt/iobroker/iobroker-data/objects.jsonl
        33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
        19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.9cfa27d8.js.map
        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v16.19.1
        /usr/bin/node           v16.19.1
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
        nodejs:
          Installed: 16.19.1-deb-1nodesource1
          Candidate: 16.19.1-deb-1nodesource1
          Version table:
         *** 16.19.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u3 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        MULTIHOSTSERVICE/enabled: false
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.3.5
        javascript:     6.1.4
        Adapters from github:   14
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : Iobroker        -  enabled
        + system.adapter.admin.0                  : admin                 : Iobroker        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
        + system.adapter.alexa2.0                 : alexa2                : Iobroker        -  enabled
          system.adapter.alias-manager.0          : alias-manager         : Iobroker        - disabled
          system.adapter.apple-find-me.0          : apple-find-me         : Iobroker        - disabled
        + system.adapter.backitup.0               : backitup              : Iobroker        -  enabled
          system.adapter.birthdays.0              : birthdays             : Iobroker        -  enabled
          system.adapter.bluelink.0               : bluelink              : Iobroker        - disabled
        + system.adapter.bring.0                  : bring                 : Iobroker        -  enabled
        + system.adapter.cloud.0                  : cloud                 : Iobroker        -  enabled
          system.adapter.daswetter.0              : daswetter             : Iobroker        -  enabled
        + system.adapter.denon.0                  : denon                 : Iobroker        -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : Iobroker        -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : Iobroker        -  enabled
          system.adapter.devices.0                : devices               : Iobroker        - disabled
          system.adapter.discovery.0              : discovery             : Iobroker        - disabled
          system.adapter.dwd.0                    : dwd                   : Iobroker        -  enabled
        + system.adapter.eusec.0                  : eusec                 : Iobroker        -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : Iobroker        -  enabled
          system.adapter.feiertage.0              : feiertage             : Iobroker        -  enabled
        + system.adapter.firetv.0                 : firetv                : Iobroker        -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : Iobroker        -  enabled
        + system.adapter.govee-app.0              : govee-app             : Iobroker        -  enabled
        + system.adapter.harmony.0                : harmony               : Iobroker        -  enabled
          system.adapter.heatingcontrol.0         : heatingcontrol        : Iobroker        - disabled
        + system.adapter.hmip.0                   : hmip                  : Iobroker        -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : Iobroker        -  enabled
        + system.adapter.homepilot20.0            : homepilot20           : Iobroker        -  enabled
          system.adapter.ical.0                   : ical                  : Iobroker        -  enabled
          system.adapter.ical.1                   : ical                  : Iobroker        -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : Iobroker        - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : Iobroker        - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : Iobroker        - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : Iobroker        - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Iobroker        - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Iobroker        - disabled
        + system.adapter.info.0                   : info                  : Iobroker        -  enabled
        + system.adapter.iot.0                    : iot                   : Iobroker        -  enabled
        + system.adapter.javascript.0             : javascript            : Iobroker        -  enabled
        + system.adapter.lg-thinq.0               : lg-thinq              : Iobroker        -  enabled
        + system.adapter.linkeddevices.0          : linkeddevices         : Iobroker        -  enabled
          system.adapter.mihome-vacuum.0          : mihome-vacuum         : Iobroker        - disabled, port: 54321
        + system.adapter.mqtt.0                   : mqtt                  : Iobroker        -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.openweathermap.0         : openweathermap        : Iobroker        -  enabled
        + system.adapter.parcel.0                 : parcel                : Iobroker        -  enabled
        + system.adapter.ping.0                   : ping                  : Iobroker        -  enabled
        + system.adapter.pushover.0               : pushover              : Iobroker        -  enabled
          system.adapter.ring.0                   : ring                  : Iobroker        - disabled
          system.adapter.roborock.0               : roborock              : Iobroker        -  enabled
          system.adapter.sayit.0                  : sayit                 : Iobroker        - disabled, port: 0
        + system.adapter.scenes.0                 : scenes                : Iobroker        -  enabled
        + system.adapter.simple-api.0             : simple-api            : Iobroker        -  enabled, port: 8087, bind: 0.0.0.0, run as: admi        n
          system.adapter.smartcontrol.0           : smartcontrol          : Iobroker        - disabled
        + system.adapter.socketio.0               : socketio              : Iobroker        -  enabled, port: 8084, bind: 0.0.0.0, run as: admi        n
          system.adapter.sonoff.0                 : sonoff                : Iobroker        - disabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : Iobroker        -  enabled
          system.adapter.sourceanalytix.0         : sourceanalytix        : Iobroker        - disabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : Iobroker        -  enabled
          system.adapter.text2command.0           : text2command          : Iobroker        - disabled
        + system.adapter.tr-064.0                 : tr-064                : Iobroker        -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : Iobroker        -  enabled
        + system.adapter.tuya.0                   : tuya                  : Iobroker        -  enabled
          system.adapter.tvspielfilm.0            : tvspielfilm           : Iobroker        -  enabled
          system.adapter.vis-2-beta.0             : vis-2-beta            : Iobroker        - disabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : Iobroker        - disabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : Iobroker        - disabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: Iobroker        - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : Iobroker        - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : Iobroker        - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Iobroker        - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : Iobroker        - disabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : Iobroker        - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Iobroker        - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : Iobroker        - disabled
          system.adapter.vis-map.0                : vis-map               : Iobroker        - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : Iobroker        -  enabled
          system.adapter.vis-owl.0                : vis-owl               : Iobroker        - disabled
          system.adapter.vis-players.0            : vis-players           : Iobroker        - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : Iobroker        - disabled
          system.adapter.vis-weather.0            : vis-weather           : Iobroker        - disabled
          system.adapter.vis.0                    : vis                   : Iobroker        -  enabled
        + system.adapter.web.0                    : web                   : Iobroker        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
        + system.adapter.wifilight.0              : wifilight             : Iobroker        -  enabled
          system.adapter.ws.0                     : ws                    : Iobroker        - disabled, port: 8085, bind: 0.0.0.0, run as: admi        n
          system.adapter.yahka.0                  : yahka                 : Iobroker        - disabled
        + system.adapter.zigbee.0                 : zigbee                : Iobroker        -  enabled, port: /dev/serial/by-id/usb-ITead_Sonof        f_Zigbee_3.0_USB_Dongle_Plus_3ca1ced350c9eb11b9d48b4f1d69213e-if00-port0
        + instance is alive
        ioBroker-Repositories
        live-stable   : http://iobroker.live/repo/sources-dist.json
        Active repo(s): beta, live-stable
        Installed ioBroker-Instances
        Used repositories: beta, live-stable
        Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
        Adapter    "admin"        : 6.3.5    , installed 6.3.5
        Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
        Adapter    "alias-manager": 1.2.4    , installed 1.2.6
        Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
        Adapter    "backitup"     : 2.6.16   , installed 2.6.16
        Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
        Adapter    "bluelink"     : 2.3.2    , installed 2.3.2
        Adapter    "bring"        : 1.8.1    , installed 1.8.1
        Adapter    "cloud"        : 4.3.0    , installed 4.3.0
        Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
        Adapter    "denon"        : 1.15.0   , installed 1.15.0
        Adapter    "device-reminder": 1.2.9  , installed 1.2.9
        Adapter    "device-watcher": 2.6.1   , installed 2.6.1
        Adapter    "devices"      : 1.1.2    , installed 1.1.2
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "eusec"        : 0.9.9    , installed 0.9.10
        Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "firetv"       : 1.0.0    , installed 1.0.0
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
        Adapter    "heatingcontrol": 2.10.6  , installed 2.10.6
        Adapter    "hmip"         : 1.20.0   , installed 1.20.0
        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
        Adapter    "ical"         : 1.13.2   , installed 1.13.2
        Adapter    "icons-material-png": 0.1.0, installed 0.1.0
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
        Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.14.2   , installed 1.14.2
        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "mihome-vacuum": 3.9.5    , installed 3.10.1
        Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
        Adapter    "openweathermap": 0.3.3   , installed 0.3.3
        Adapter    "parcel"       : 0.0.27   , installed 0.0.27
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
        Adapter    "ring"         : 3.2.2    , installed 3.3.0
        Adapter    "sayit"        : 1.12.3   , installed 1.12.3
        Adapter    "scenes"       : 2.3.9    , installed 2.3.9
        Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
        Adapter    "socketio"     : 4.2.0    , installed 6.3.5
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "sonos"        : 2.2.3    , installed 2.2.3
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
        Adapter    "text2command" : 2.3.0    , installed 2.3.0
        Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "tuya"         : 3.13.1   , installed 3.13.1
        Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-2-widgets-energy": 0.1.12, installed 0.1.12
        Adapter    "vis-2-widgets-gauges": 0.1.12, installed 0.1.12
        Adapter    "vis-2-widgets-material": 0.2.13, installed 0.2.13
        Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
        Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
        Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
        Adapter    "ws"           : 1.3.0    , installed 2.3.6
        Adapter    "yahka"        : 0.17.0   , installed 0.17.0
        Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
        Objects and States
        Objects:        23021
        States:         19702
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       36817      3546/io.mqtt.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13035      607/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          256317     14265/cupsd
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16957      575/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16705      575/iobroker.js-con
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       17260      1409/io.sonos.0
        tcp6       0      0 :::7906                 :::*                    LISTEN      1001       34685      3467/io.roborock.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28316      2969/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17160      1229/io.admin.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       25806      2210/io.simple-api.
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24511      2278/io.socketio.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13037      607/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          256316     14265/cupsd
        tcp6       0      0 :::61991                :::*                    LISTEN      1001       24748      1953/io.harmony.0
        tcp6       0      0 :::6824                 :::*                    LISTEN      1001       34684      3467/io.roborock.0
        udp        0      0 192.168.0.85:5353       0.0.0.0:*                           1001       20223      1429/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14968      427/avahi-daemon: r
        udp        0      0 0.0.0.0:38205           0.0.0.0:*                           108        14970      427/avahi-daemon: r
        udp        0      0 0.0.0.0:43028           0.0.0.0:*                           1001       20903      1858/io.eusec.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16513      498/dhcpcd
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       361243     19628/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       361244     19628/io.tuya.0
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       24749      1953/io.harmony.0
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          260571     14267/cups-browsed
        udp6       0      0 :::5353                 :::*                                108        14969      427/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          16665      498/dhcpcd
        udp6       0      0 :::39804                :::*                                108        14971      427/avahi-daemon: r
        2023-04-16 16:19:56.066  - info: vis.0 (23595) vis license is OK.
        2023-04-16 16:19:58.033  - info: vis.0 (23595) terminating
        2023-04-16 16:19:58.035  - info: vis.0 (23595) Terminated (NO_ERROR): Without reason
        2023-04-16 16:19:58.734  - info: host.Iobroker instance system.adapter.vis.0 terminated with code 0 (NO_ERROR)
        2023-04-16 16:19:58.735  - info: host.Iobroker Restart adapter system.adapter.vis.0 because enabled
        2023-04-16 16:20:00.085  - info: host.Iobroker instance system.adapter.tvspielfilm.0 started with pid 23670
        2023-04-16 16:20:04.158  - info: host.Iobroker instance system.adapter.dwd.0 started with pid 23691
        2023-04-16 16:20:04.248  - info: tvspielfilm.0 (23670) starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v16.19.1, js-controller: 4.0.24
        2023-04-16 16:20:06.381  - info: tvspielfilm.0 (23670) objects written
        2023-04-16 16:20:08.496  - info: dwd.0 (23691) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.1, js-controller: 4.0.24
        2023-04-16 16:20:09.458  - info: dwd.0 (23691) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-04-16 16:20:10.007  - info: host.Iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-04-16 16:20:16.891  - info: tvspielfilm.0 (23670) Terminated (NO_ERROR): Without reason
        2023-04-16 16:20:17.434  - info: host.Iobroker instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
        2023-04-16 16:20:26.946  - info: tuya.0 (19628) 2514114048551951601f: Error on Reconnect (1): connection timed out
        2023-04-16 16:20:28.961  - info: host.Iobroker instance system.adapter.vis.0 started with pid 23797
        2023-04-16 16:20:32.447  - info: vis.0 (23797) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
        2023-04-16 16:20:32.811  - info: vis.0 (23797) vis license is OK.
        2023-04-16 16:20:34.678  - info: vis.0 (23797) terminating
        2023-04-16 16:20:34.680  - info: vis.0 (23797) Terminated (NO_ERROR): Without reason
        2023-04-16 16:20:35.607  - info: host.Iobroker instance system.adapter.vis.0 terminated with code 0 (NO_ERROR)
        2023-04-16 16:20:35.608  - info: host.Iobroker Restart adapter system.adapter.vis.0 because enabled
        2023-04-16 16:20:51.948  - info: tuya.0 (19628) 2514114048551951601f: Error on Reconnect (3): connection timed out
        2023-04-16 16:21:05.825  - info: host.Iobroker instance system.adapter.vis.0 started with pid 24163
        2023-04-16 16:21:09.709  - info: vis.0 (24163) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
        iob diag has finished.
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        @lustig29 sagte in VIS Adaper, kein update, löschen oder install möglich:
        da ist ja noch ein teil von Beta !?
        Warum
        L 3 Antworten Letzte Antwort
          Warum
          lustig29
          @glasfaser Hatte wohl den Haken falsch gesetzt. Mache ich auch gleich wieder rückgängig.
            Warum
            lustig29
            @glasfaser
            So, hoffe ich hab jetzt wieder alles rückgängig gemacht. Aber das mit dem VIs Adapter läuft immer noch nicht.
              Warum
              lustig29
              @glasfaser
              Der Adapter wird immer kurz grün und dann gleich wieder rot.
              • L lustig29
                @glasfaser
                welcher?
                Vis hat keine Ampel!
                L 1 Antwort Letzte Antwort
                  welcher?
                  lustig29
                  Bei mir schon. 😆
                  • L lustig29
                    Bei mir schon. 😆
                    @lustig29 dann hast du wild durcheinander installiert!
                    hast du mal Alpha Tester für vis2 gemacht?
                      lustig29
                      Ja, hatte ich mal probiert. Ist aber nie richtig gelaufen bei mir.
                      HomoranH GlasfaserG 2 Antworten Letzte Antwort
                      • L lustig29
                        und jetzt läuft vis auch nicht mehr!
                        was hast du denn da alles "versucht"?
                        • L Offline
                          lustig29
                          Ich wollte vis 2.0 eigentlich nur mal anschauen und testen. Das war wohl ein Fehler...
                            lustig29
                            Wie mache ich das denn am besten alles rückgänig?😬
                            • L lustig29
                              und weil du es wolltest, war vis2 plötzlich auf deinem Rechner, einfach so?
                                lustig29
                                Nein, ich hab es schon selber installiert, weil ich es mir mal anschauen wollte.:man-facepalming:
                                • L lustig29
                                  hilft auch nix!
                                  wenn hier jemand helfen soll muss er von dir schon die vollständige Antwort auf die Frage bekommen
                                  @homoran sagte in VIS Adaper, kein update, löschen oder install möglich:
                                    hilft auch nix!
                                    lustig29
                                    Habe alle Adapter gelöscht, die mit Vis2.0 zu tun haben. Leider wechselt mein Vis Adapter immer noch von grün auf rot.
                                    • L lustig29
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Glasfaser
                                      Ich krame ja nicht immer in den alter Thread bei dir herum !!
                                      aber warum machst du nicht eine Sache fertig und beginnst immer in neuen Thread´s , wie hier jetzt !
                                      so sehe ich kein Sinn ... den Fehler bei dir zu finden :
                                      https://forum.iobroker.net/topic/64458/vis-2-0-öffnet-sich-nicht
                                      https://forum.iobroker.net/post/974109
                                        lustig29
                                        schrieb am zuletzt editiert von lustig29
                                        @glasfaser
                                        Ja, da habe ich ja aufgegeben mit Vis 2.0 Adapter.
                                        Habe eingesehen, dass ich doch kein Beta Tester bin.
                                        Jetzt möchte ich einfach nur alles von Vis 2.0 löschen und das mein normaler Vis Adapter läuft.
                                          twebbs
                                          schrieb am zuletzt editiert von twebbs
                                          @crunchip
                                          Ich habe den manuellen install ausgeführt.
                                          npm install iobroker.vis@1.4.0
                                          Auch nach Neustart wurde der VIS Adapter in der Adapterliste weiterhin als nicht installiert angezeigt.
                                          In der Instanzliste war VIS gelistet, lies sich aber mit der gleichen Fehlermeldung (wie schon gepostet) nicht starten.
                                          Nun habe ich
                                          • ein jungfräuliches Raspi Image (32 bit, Rel 2023-02-21 mit Console) erstellt.
                                          • IObroker frisch aus dem Netz mit curl -sLf https://iobroker.net/install.sh | bash - installiert
                                          • WEB aus der Adapterliste installiert
                                          • VIS manuell mit npm install iobroker.vis@1.4.0 installiert . (bewusst die alte Version)
                                          • Backup eingespielt
                                          • reboot (zur Sicherheit)
                                          Der VIS Adapter startet nicht - Fehlermeldungen.
                                          Er läßt sich auch nicht auf den Stand 1.4.16 installieren. Update geht ja nicht, da er in der Adapterliste nicht zu sehen ist. (siehe Screenshot und log)
                                          2023-04-17T10_30_30_423Z-debug-0.log
