  4. VIS Adaper, kein update, löschen oder install möglich
    5.4k
45 Beiträge 7 Kommentatoren 5.0k Aufrufe 5 Beobachtet
  • L lustig29
    @glasfaser Oh, wie mache ich das rückgänig?
    GlasfaserG Offline
    GlasfaserG Offline
    @lustig29
    iobroker upgrade web@4.3.0
    • L lustig29
      @glasfaser
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       16:19:50 up 21:08,  3 users,  load average: 1.89, 2.08, 1.99
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=37.9'C
      volt=0.8688V
      *** Time and Time Zones ***
                     Local time: Sun 2023-04-16 16:19:50 CEST
                 Universal time: Sun 2023-04-16 14:19:50 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      lustig29
      /home/lustig29
      lustig29 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        2.3G        528M         35M        987M        1.6G
      Swap:            99M          0B         99M
      Total:          3.9G        2.3G        628M
               3793 M total memory
               2277 M used memory
               2508 M active memory
                475 M inactive memory
                528 M free memory
                 79 M buffer memory
                907 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      220G  6.3G  205G   3% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     759M  1.2M  758M   1% /run
      /dev/sda1      vfat      255M   51M  205M  20% /boot
      tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
      [Sat Apr 15 19:11:48 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:73:5F:A3 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=3fd05b5c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sat Apr 15 19:11:50 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Apr 15 19:11:50 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sat Apr 15 19:11:52 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      396M    /var/
      123M    /var/lib
      121M    /var/cache
      114M    /var/cache/apt
      68M     /var/lib/apt/lists
      Archived and active journals take up 48.0M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      548M    /opt/iobroker/iobroker-data/
      387M    /opt/iobroker/iobroker-data/files
      62M     /opt/iobroker/iobroker-data/backup-objects
      56M     /opt/iobroker/iobroker-data/files/vis
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      50M     /opt/iobroker/iobroker-data/states.jsonl
      41M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
      19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.9cfa27d8.js.map
      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v16.19.1
      /usr/bin/node           v16.19.1
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Installed: 16.19.1-deb-1nodesource1
        Candidate: 16.19.1-deb-1nodesource1
        Version table:
       *** 16.19.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
           12.22.12~dfsg-1~deb11u3 500
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   14
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : Iobroker        -  enabled
      + system.adapter.admin.0                  : admin                 : Iobroker        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
      + system.adapter.alexa2.0                 : alexa2                : Iobroker        -  enabled
        system.adapter.alias-manager.0          : alias-manager         : Iobroker        - disabled
        system.adapter.apple-find-me.0          : apple-find-me         : Iobroker        - disabled
      + system.adapter.backitup.0               : backitup              : Iobroker        -  enabled
        system.adapter.birthdays.0              : birthdays             : Iobroker        -  enabled
        system.adapter.bluelink.0               : bluelink              : Iobroker        - disabled
      + system.adapter.bring.0                  : bring                 : Iobroker        -  enabled
      + system.adapter.cloud.0                  : cloud                 : Iobroker        -  enabled
        system.adapter.daswetter.0              : daswetter             : Iobroker        -  enabled
      + system.adapter.denon.0                  : denon                 : Iobroker        -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : Iobroker        -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : Iobroker        -  enabled
        system.adapter.devices.0                : devices               : Iobroker        - disabled
        system.adapter.discovery.0              : discovery             : Iobroker        - disabled
        system.adapter.dwd.0                    : dwd                   : Iobroker        -  enabled
      + system.adapter.eusec.0                  : eusec                 : Iobroker        -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : Iobroker        -  enabled
        system.adapter.feiertage.0              : feiertage             : Iobroker        -  enabled
      + system.adapter.firetv.0                 : firetv                : Iobroker        -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : Iobroker        -  enabled
      + system.adapter.govee-app.0              : govee-app             : Iobroker        -  enabled
      + system.adapter.harmony.0                : harmony               : Iobroker        -  enabled
        system.adapter.heatingcontrol.0         : heatingcontrol        : Iobroker        - disabled
      + system.adapter.hmip.0                   : hmip                  : Iobroker        -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : Iobroker        -  enabled
      + system.adapter.homepilot20.0            : homepilot20           : Iobroker        -  enabled
        system.adapter.ical.0                   : ical                  : Iobroker        -  enabled
        system.adapter.ical.1                   : ical                  : Iobroker        -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : Iobroker        - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : Iobroker        - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : Iobroker        - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : Iobroker        - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Iobroker        - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : Iobroker        - disabled
      + system.adapter.info.0                   : info                  : Iobroker        -  enabled
      + system.adapter.iot.0                    : iot                   : Iobroker        -  enabled
      + system.adapter.javascript.0             : javascript            : Iobroker        -  enabled
      + system.adapter.lg-thinq.0               : lg-thinq              : Iobroker        -  enabled
      + system.adapter.linkeddevices.0          : linkeddevices         : Iobroker        -  enabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : Iobroker        - disabled, port: 54321
      + system.adapter.mqtt.0                   : mqtt                  : Iobroker        -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.openweathermap.0         : openweathermap        : Iobroker        -  enabled
      + system.adapter.parcel.0                 : parcel                : Iobroker        -  enabled
      + system.adapter.ping.0                   : ping                  : Iobroker        -  enabled
      + system.adapter.pushover.0               : pushover              : Iobroker        -  enabled
        system.adapter.ring.0                   : ring                  : Iobroker        - disabled
        system.adapter.roborock.0               : roborock              : Iobroker        -  enabled
        system.adapter.sayit.0                  : sayit                 : Iobroker        - disabled, port: 0
      + system.adapter.scenes.0                 : scenes                : Iobroker        -  enabled
      + system.adapter.simple-api.0             : simple-api            : Iobroker        -  enabled, port: 8087, bind: 0.0.0.0, run as: admi        n
        system.adapter.smartcontrol.0           : smartcontrol          : Iobroker        - disabled
      + system.adapter.socketio.0               : socketio              : Iobroker        -  enabled, port: 8084, bind: 0.0.0.0, run as: admi        n
        system.adapter.sonoff.0                 : sonoff                : Iobroker        - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : Iobroker        -  enabled
        system.adapter.sourceanalytix.0         : sourceanalytix        : Iobroker        - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : Iobroker        -  enabled
        system.adapter.text2command.0           : text2command          : Iobroker        - disabled
      + system.adapter.tr-064.0                 : tr-064                : Iobroker        -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : Iobroker        -  enabled
      + system.adapter.tuya.0                   : tuya                  : Iobroker        -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : Iobroker        -  enabled
        system.adapter.vis-2-beta.0             : vis-2-beta            : Iobroker        - disabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : Iobroker        - disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : Iobroker        - disabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: Iobroker        - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : Iobroker        - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : Iobroker        - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Iobroker        - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : Iobroker        - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : Iobroker        - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Iobroker        - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : Iobroker        - disabled
        system.adapter.vis-map.0                : vis-map               : Iobroker        - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : Iobroker        -  enabled
        system.adapter.vis-owl.0                : vis-owl               : Iobroker        - disabled
        system.adapter.vis-players.0            : vis-players           : Iobroker        - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : Iobroker        - disabled
        system.adapter.vis-weather.0            : vis-weather           : Iobroker        - disabled
        system.adapter.vis.0                    : vis                   : Iobroker        -  enabled
      + system.adapter.web.0                    : web                   : Iobroker        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
      + system.adapter.wifilight.0              : wifilight             : Iobroker        -  enabled
        system.adapter.ws.0                     : ws                    : Iobroker        - disabled, port: 8085, bind: 0.0.0.0, run as: admi        n
        system.adapter.yahka.0                  : yahka                 : Iobroker        - disabled
      + system.adapter.zigbee.0                 : zigbee                : Iobroker        -  enabled, port: /dev/serial/by-id/usb-ITead_Sonof        f_Zigbee_3.0_USB_Dongle_Plus_3ca1ced350c9eb11b9d48b4f1d69213e-if00-port0
      + instance is alive
      ioBroker-Repositories
      live-stable   : http://iobroker.live/repo/sources-dist.json
      Active repo(s): beta, live-stable
      Installed ioBroker-Instances
      Used repositories: beta, live-stable
      Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "alias-manager": 1.2.4    , installed 1.2.6
      Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
      Adapter    "backitup"     : 2.6.16   , installed 2.6.16
      Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
      Adapter    "bluelink"     : 2.3.2    , installed 2.3.2
      Adapter    "bring"        : 1.8.1    , installed 1.8.1
      Adapter    "cloud"        : 4.3.0    , installed 4.3.0
      Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
      Adapter    "denon"        : 1.15.0   , installed 1.15.0
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "device-watcher": 2.6.1   , installed 2.6.1
      Adapter    "devices"      : 1.1.2    , installed 1.1.2
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "eusec"        : 0.9.9    , installed 0.9.10
      Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "firetv"       : 1.0.0    , installed 1.0.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "heatingcontrol": 2.10.6  , installed 2.10.6
      Adapter    "hmip"         : 1.20.0   , installed 1.20.0
      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.14.2   , installed 1.14.2
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "mihome-vacuum": 3.9.5    , installed 3.10.1
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "openweathermap": 0.3.3   , installed 0.3.3
      Adapter    "parcel"       : 0.0.27   , installed 0.0.27
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "ring"         : 3.2.2    , installed 3.3.0
      Adapter    "sayit"        : 1.12.3   , installed 1.12.3
      Adapter    "smartcontrol" : 1.3.2    , installed 1.3.2
      Adapter    "socketio"     : 4.2.0    , installed 6.3.5
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "sonos"        : 2.2.3    , installed 2.2.3
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "text2command" : 2.3.0    , installed 2.3.0
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.13.1   , installed 3.13.1
      Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
      Adapter    "vis-2-widgets-energy": 0.1.12, installed 0.1.12
      Adapter    "vis-2-widgets-gauges": 0.1.12, installed 0.1.12
      Adapter    "vis-2-widgets-material": 0.2.13, installed 0.2.13
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 4.3.0    , installed 6.0.1
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "ws"           : 1.3.0    , installed 2.3.6
      Adapter    "yahka"        : 0.17.0   , installed 0.17.0
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects:        23021
      States:         19702
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       36817      3546/io.mqtt.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13035      607/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          256317     14265/cupsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16957      575/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16705      575/iobroker.js-con
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       17260      1409/io.sonos.0
      tcp6       0      0 :::7906                 :::*                    LISTEN      1001       34685      3467/io.roborock.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28316      2969/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17160      1229/io.admin.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       25806      2210/io.simple-api.
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24511      2278/io.socketio.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13037      607/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          256316     14265/cupsd
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       24748      1953/io.harmony.0
      tcp6       0      0 :::6824                 :::*                    LISTEN      1001       34684      3467/io.roborock.0
      udp        0      0 192.168.0.85:5353       0.0.0.0:*                           1001       20223      1429/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14968      427/avahi-daemon: r
      udp        0      0 0.0.0.0:38205           0.0.0.0:*                           108        14970      427/avahi-daemon: r
      udp        0      0 0.0.0.0:43028           0.0.0.0:*                           1001       20903      1858/io.eusec.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16513      498/dhcpcd
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       361243     19628/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       361244     19628/io.tuya.0
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       24749      1953/io.harmony.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          260571     14267/cups-browsed
      udp6       0      0 :::5353                 :::*                                108        14969      427/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          16665      498/dhcpcd
      udp6       0      0 :::39804                :::*                                108        14971      427/avahi-daemon: r
      2023-04-16 16:19:56.066  - info: vis.0 (23595) vis license is OK.
      2023-04-16 16:19:58.033  - info: vis.0 (23595) terminating
      2023-04-16 16:19:58.035  - info: vis.0 (23595) Terminated (NO_ERROR): Without reason
      2023-04-16 16:19:58.734  - info: host.Iobroker instance system.adapter.vis.0 terminated with code 0 (NO_ERROR)
      2023-04-16 16:19:58.735  - info: host.Iobroker Restart adapter system.adapter.vis.0 because enabled
      2023-04-16 16:20:00.085  - info: host.Iobroker instance system.adapter.tvspielfilm.0 started with pid 23670
      2023-04-16 16:20:04.158  - info: host.Iobroker instance system.adapter.dwd.0 started with pid 23691
      2023-04-16 16:20:04.248  - info: tvspielfilm.0 (23670) starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v16.19.1, js-controller: 4.0.24
      2023-04-16 16:20:06.381  - info: tvspielfilm.0 (23670) objects written
      2023-04-16 16:20:08.496  - info: dwd.0 (23691) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.1, js-controller: 4.0.24
      2023-04-16 16:20:09.458  - info: dwd.0 (23691) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-04-16 16:20:10.007  - info: host.Iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-04-16 16:20:16.891  - info: tvspielfilm.0 (23670) Terminated (NO_ERROR): Without reason
      2023-04-16 16:20:17.434  - info: host.Iobroker instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
      2023-04-16 16:20:26.946  - info: tuya.0 (19628) 2514114048551951601f: Error on Reconnect (1): connection timed out
      2023-04-16 16:20:28.961  - info: host.Iobroker instance system.adapter.vis.0 started with pid 23797
      2023-04-16 16:20:32.447  - info: vis.0 (23797) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
      2023-04-16 16:20:32.811  - info: vis.0 (23797) vis license is OK.
      2023-04-16 16:20:34.678  - info: vis.0 (23797) terminating
      2023-04-16 16:20:34.680  - info: vis.0 (23797) Terminated (NO_ERROR): Without reason
      2023-04-16 16:20:35.607  - info: host.Iobroker instance system.adapter.vis.0 terminated with code 0 (NO_ERROR)
      2023-04-16 16:20:35.608  - info: host.Iobroker Restart adapter system.adapter.vis.0 because enabled
      2023-04-16 16:20:51.948  - info: tuya.0 (19628) 2514114048551951601f: Error on Reconnect (3): connection timed out
      2023-04-16 16:21:05.825  - info: host.Iobroker instance system.adapter.vis.0 started with pid 24163
      2023-04-16 16:21:09.709  - info: vis.0 (24163) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
      iob diag has finished.
      GlasfaserG Offline
      GlasfaserG Offline
      @lustig29 sagte in VIS Adaper, kein update, löschen oder install möglich:
      da ist ja noch ein teil von Beta !?
      Warum
      L 3 Antworten Letzte Antwort
      • GlasfaserG Glasfaser
        Warum
        lustig29
        @glasfaser Hatte wohl den Haken falsch gesetzt. Mache ich auch gleich wieder rückgängig.
          Warum
          lustig29
          @glasfaser
          So, hoffe ich hab jetzt wieder alles rückgängig gemacht. Aber das mit dem VIs Adapter läuft immer noch nicht.
            Warum
            lustig29
            @glasfaser
            Der Adapter wird immer kurz grün und dann gleich wieder rot.
            • L lustig29
              @glasfaser
              welcher?
              Vis hat keine Ampel!
              L 1 Antwort Letzte Antwort
                welcher?
                lustig29
                Bei mir schon. 😆
                • L lustig29
                  Bei mir schon. 😆
                  @lustig29 dann hast du wild durcheinander installiert!
                  hast du mal Alpha Tester für vis2 gemacht?
                    lustig29
                    Ja, hatte ich mal probiert. Ist aber nie richtig gelaufen bei mir.
                    HomoranH GlasfaserG 2 Antworten Letzte Antwort
                    • L lustig29
                      und jetzt läuft vis auch nicht mehr!
                      was hast du denn da alles "versucht"?
                      • L Offline
                        lustig29
                        Ich wollte vis 2.0 eigentlich nur mal anschauen und testen. Das war wohl ein Fehler...
                          lustig29
                          Wie mache ich das denn am besten alles rückgänig?😬
                          • L lustig29
                            und weil du es wolltest, war vis2 plötzlich auf deinem Rechner, einfach so?
                              lustig29
                              Nein, ich hab es schon selber installiert, weil ich es mir mal anschauen wollte.:man-facepalming:
                              • L lustig29
                                hilft auch nix!
                                wenn hier jemand helfen soll muss er von dir schon die vollständige Antwort auf die Frage bekommen
                                @homoran sagte in VIS Adaper, kein update, löschen oder install möglich:
                                  hilft auch nix!
                                  lustig29
                                  Habe alle Adapter gelöscht, die mit Vis2.0 zu tun haben. Leider wechselt mein Vis Adapter immer noch von grün auf rot.
                                  • L lustig29
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Ich krame ja nicht immer in den alter Thread bei dir herum !!
                                    aber warum machst du nicht eine Sache fertig und beginnst immer in neuen Thread´s , wie hier jetzt !
                                    so sehe ich kein Sinn ... den Fehler bei dir zu finden :
                                    https://forum.iobroker.net/topic/64458/vis-2-0-öffnet-sich-nicht
                                    https://forum.iobroker.net/post/974109
                                      lustig29
                                      schrieb am zuletzt editiert von lustig29
                                      @glasfaser
                                      Ja, da habe ich ja aufgegeben mit Vis 2.0 Adapter.
                                      Habe eingesehen, dass ich doch kein Beta Tester bin.
                                      Jetzt möchte ich einfach nur alles von Vis 2.0 löschen und das mein normaler Vis Adapter läuft.
                                        twebbs
                                        schrieb am zuletzt editiert von twebbs
                                        @crunchip
                                        Ich habe den manuellen install ausgeführt.
                                        npm install iobroker.vis@1.4.0
                                        Auch nach Neustart wurde der VIS Adapter in der Adapterliste weiterhin als nicht installiert angezeigt.
                                        In der Instanzliste war VIS gelistet, lies sich aber mit der gleichen Fehlermeldung (wie schon gepostet) nicht starten.
                                        Nun habe ich
                                        • ein jungfräuliches Raspi Image (32 bit, Rel 2023-02-21 mit Console) erstellt.
                                        • IObroker frisch aus dem Netz mit curl -sLf https://iobroker.net/install.sh | bash - installiert
                                        • WEB aus der Adapterliste installiert
                                        • VIS manuell mit npm install iobroker.vis@1.4.0 installiert . (bewusst die alte Version)
                                        • Backup eingespielt
                                        • reboot (zur Sicherheit)
                                        Der VIS Adapter startet nicht - Fehlermeldungen.
                                        Er läßt sich auch nicht auf den Stand 1.4.16 installieren. Update geht ja nicht, da er in der Adapterliste nicht zu sehen ist. (siehe Screenshot und log)
                                        2023-04-17T10_30_30_423Z-debug-0.log
                                        • T twebbs
                                          @crunchip
                                          Nun habe ich
                                          @twebbs sagte in VIS Adaper, kein update, löschen oder install möglich:
                                          Auch im richtigen Verzeichnis?
                                          Besser per
                                          iobroker add vis --debug
                                          installieren.
