  3. Off Topic
  4. (Gelöst)Mist gebaut beim entfernen von Pihole
    1.0k
    6.1k
142 Beiträge 14 Kommentatoren 22.4k Aufrufe 10 Beobachtet
  • Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    schrieb am zuletzt editiert von Damrak2022
    Ich habe mein Pihole runtergeworfen, da ich damit nicht so ganz klar kam.
    Also habe ich den Befehl "Pihole uninstall" genutzt und alle Abfragen mit Yes bestätigt, was wohl falsch war.
    Jetzt wollte ich mein wöchentliches Update machen - also iob stop, sudo apt update usw. und habe mir nun diese Fehler eingehandelt:
    pi@homebridge:~ $ iobroker stop
    pi@homebridge:~ $ sudo apt update
    OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:2 http://deb.debian.org/debian bullseye InRelease
    OK:3 http://deb.debian.org/debian bullseye-updates InRelease
    OK:4 http://security.debian.org/debian-security bullseye-security InRelease
    Fehl:5 https://download.docker.com/linux/debian bullseye InRelease
      Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2240:f400:3:db06:4200:93a1 443]
    Fehl:6 https://apt.grafana.com stable InRelease
      Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a04:4e42:8d::729 443]
    Fehl:7 https://repos.influxdata.com/debian stable InRelease
      Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2057:ca00:11:fe8d:7d40:93a1 443]
    Fehl:8 https://deb.nodesource.com/node_16.x bullseye InRelease
      Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a02:26f0:280:3::213:788d 443]
    Fehl:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
      Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:1f1c:2e5:6900:6b28:6a2f:3ff1:92e4 443]
    Alle Pakete sind aktuell.
    W: https://repos.influxdata.com/debian/dists/stable/InRelease: No system certificates available. Try installing ca-certificates.
    W: https://download.docker.com/linux/debian/dists/bullseye/InRelease: No system certificates available. Try installing ca-certificates.
    W: https://apt.grafana.com/dists/stable/InRelease: No system certificates available. Try installing ca-certificates.
    W: https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease: No system certificates available. Try installing ca-certificates.
    W: https://packagecloud.io/ookla/speedtest-cli/debian/dists/bullseye/InRelease: No system certificates available. Try installing ca-certificates.
    W: Fehlschlag beim Holen von https://download.docker.com/linux/debian/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2240:f400:3:db06:4200:93a1 443]
    W: Fehlschlag beim Holen von https://apt.grafana.com/dists/stable/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a04:4e42:8d::729 443]
    W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/stable/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2057:ca00:11:fe8d:7d40:93a1 443]
    W: Fehlschlag beim Holen von https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a02:26f0:280:3::213:788d 443]
    W: Fehlschlag beim Holen von https://packagecloud.io/ookla/speedtest-cli/debian/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:1f1c:2e5:6900:6b28:6a2f:3ff1:92e4 443]
    W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
    Wie bekomme ich das wieder hin?
    Mit besten Grüßen
    Andy
    haselchenH OliverIOO 2 Antworten Letzte Antwort
    • Damrak2022D Damrak2022
      haselchenH Offline
      haselchenH Offline
      haselchen
      @damrak2022
      Hattest du in deinem Router die Einträge für den DNS Server verändert ?
      • haselchenH haselchen
        @damrak2022
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        @haselchen Ja, aber ich bin der Meinung das es danach noch ging. Aber ich werde in Zukunft die Finger von solchen Experimenten wie PiHole lassen. da fehlt mir einfach das Hintergrundwissen. Hauptsachen ich bekomme meine normale Installation mal wieder so hin, das alles sauber läuft.
        Mit besten Grüßen
        Andy
          haselchenH Offline
          haselchenH Offline
          haselchen
          @damrak2022
          Hatte auch ähnliche Probleme nach der Deinstallation. Hat mir alles zerschossen danach .
          Deshalb habe ich auch Pihole ad acta gelegt .
            @damrak2022
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            @haselchen Hast Du eine Ahnung wie ich das wieder hinbekomme?
            Mit besten Grüßen
            Andy
              haselchenH Offline
              haselchenH Offline
              haselchen
              @damrak2022
              Ich hatte einige IP in den DNS Server Einstellungen geändert .
              Hab das auf die Router IP geändert und Router neugestartet. Ich meine , dann war alles wieder okay.
                @damrak2022
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                @haselchen Nein, bei mir leider nicht, denn ich habe die Abfragen alle bestätigt beim entfernen vom Pihole.
                Mit besten Grüßen
                Andy
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @damrak2022
                  Steht da nicht schon die Lösung?
                  Das Paket ca-certificates enthält die wichtigsten Root Zertifikate für die ssl Kommunikation
                  Meine Adapter und Widgets
                  Links im Profil
                  • OliverIOO OliverIO
                    @damrak2022
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    @oliverio Eventuell, und wie mache ich das. Ja es war von mir eine blöde Idee pihole zu installieren. Wie kann ich das Paket installieren?
                    Mit besten Grüßen
                    Andy
                    OliverIOO Thomas BraunT 2 Antworten Letzte Antwort
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      @damrak2022
                      sudo apt-get update
                      sudo apt-get install ca-certificates
                      Probier das mal. Wenn es dann noch nicht geht evtl noch einen weiteren Befehl den ich gleich raussuche
                      Links im Profil
                        @damrak2022
                        sudo apt-get update
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        @oliverio sagte in Mist gebaut beim entfernen von Pihole:
                        Ich glaube das sieht schon ziemlich gut aus:
                        pi@homebridge:~ $ sudo apt-get update
                        OK:1 http://deb.debian.org/debian bullseye InRelease
                        OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                        Fehl:3 https://apt.grafana.com stable InRelease
                        OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                        OK:5 http://security.debian.org/debian-security bullseye-security InRelease
                        Fehl:6 https://download.docker.com/linux/debian bullseye InRelease
                          Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:236e:aa00:3:db06:4200:93a1 443]
                          Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2057:8600:11:fe8d:7d40:93a1 443]
                          Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a02:26f0:e600::687c:b29 443]
                          Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:1f1c:2e5:6901:8fe8:7515:8dd2:b18d 443]
                        W: Fehlschlag beim Holen von https://download.docker.com/linux/debian/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:236e:aa00:3:db06:4200:93a1 443]
                        W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/stable/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2057:8600:11:fe8d:7d40:93a1 443]
                        W: Fehlschlag beim Holen von https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a02:26f0:e600::687c:b29 443]
                        W: Fehlschlag beim Holen von https://packagecloud.io/ookla/speedtest-cli/debian/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:1f1c:2e5:6901:8fe8:7515:8dd2:b18d 443]
                        pi@homebridge:~ $ sudo apt-get install ca-certificates
                        Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                          alsa-topology-conf alsa-ucm-conf alsa-utils bluez bluez-firmware dos2unix git-man libasound2 libasound2-data libatopology2 liberror-perl libfftw3-single3 libsamplerate0
                          libsodium23 libxslt1.1 python3-distro python3-idna python3-six python3-toml python3-urllib3 raspinfo rfkill triggerhappy
                        Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                        Die folgenden NEUEN Pakete werden installiert:
                          ca-certificates
                        0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                        Es müssen 158 kB an Archiven heruntergeladen werden.
                        Nach dieser Operation werden 391 kB Plattenplatz zusätzlich benutzt.
                        Holen:1 http://deb.debian.org/debian bullseye/main arm64 ca-certificates all 20210119 [158 kB]
                        Es wurden 158 kB in 0 s geholt (1.696 kB/s).
                        Vorkonfiguration der Pakete ...
                        Vormals nicht ausgewähltes Paket ca-certificates wird gewählt.
                        (Lese Datenbank ... 53798 Dateien und Verzeichnisse sind derzeit installiert.)
                        Vorbereitung zum Entpacken von .../ca-certificates_20210119_all.deb ...
                        Entpacken von ca-certificates (20210119) ...
                        ca-certificates (20210119) wird eingerichtet ...
                        Updating certificates in /etc/ssl/certs...
                        129 added, 0 removed; done.
                        Trigger für man-db (2.9.4-2) werden verarbeitet ...
                        Trigger für ca-certificates (20210119) werden verarbeitet ...
                        0 added, 0 removed; done.
                        Running hooks in /etc/ca-certificates/update.d...
                        done.
                        pi@homebridge:~ $ iob stop
                        OK:3 http://security.debian.org/debian-security bullseye-security InRelease
                        OK:5 https://repos.influxdata.com/debian stable InRelease
                        OK:6 https://download.docker.com/linux/debian bullseye InRelease
                        OK:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                        OK:8 https://apt.grafana.com stable InRelease
                        OK:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                        pi@homebridge:~ $ sudo apt full-upgrade
                        Paketaktualisierung (Upgrade) wird berechnet… Fertig
                        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                        pi@homebridge:~ $
                        Mit besten Grüßen
                        Andy
                          @damrak2022
                          Betrifft nur ThirdParty-Repos, wenn ich das richtig sehe.
                          cat /etc/apt/sources.list.d/*
                          sagt?
                            @damrak2022
                            sagt?
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            @thomas-braun sagte in Mist gebaut beim entfernen von Pihole:
                            pi@homebridge:~ $ cat /etc/apt/sources.list.d/*
                            deb [arch=arm64 signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/debian bullseye stable
                            deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main
                            deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
                            deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                            deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                            # this file was generated by packagecloud.io for
                            # the repository at https://packagecloud.io/ookla/speedtest-cli
                            deb [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                            deb-src [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                            deb http://archive.raspberrypi.org/debian/ bullseye main
                            # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                            #deb-src http://archive.raspberrypi.org/debian/ bullseye main
                            Mit besten Grüßen
                            Andy
                              @damrak2022
                              Funktioniert ja wieder.
                              Damrak2022D 2 Antworten Letzte Antwort
                                  ca-certificates
                                done.
                                pi@homebridge:~ $
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                @damrak2022
                                Das letzt apt update hat ja fehlerfrei funktioniert.
                                Ich glaub aber nicht das es mit pihole zu tun hatte.
                                Evtl ist eines der root Zertifikate abgelaufen auf die einige basierten
                                Links im Profil
                                  @damrak2022
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  @thomas-braun Danke an Dich und die anderen. Ich denke mein Fehler war das ich bei dem Befehl "Phiole uninstall" alle Abfragen was er löschen soll, mit "ja" beantwortet habe. Somit waren wohl die Zertifikate weg.
                                  Geändert hat sich jetzt, das ich bei einem sudo apt update nochmal erneut mein Passwort eingeben muss, was ich ja vorher bei der Anmeldung via ssh schon eingegeben hatte. Kann ich das auch korrigieren?
                                  Mit besten Grüßen
                                  Andy
                                  OliverIOO QuarkmaxQ 2 Antworten Letzte Antwort
                                    OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    @damrak2022
                                    Du musst da dein Passwort nicht eingeben wegen neuer Anmeldung, sondern wegen Bestätigung, dass du auch sudo berechtigt bist
                                    Sudo merkt sich einige Zeit das Passwort und verlangt es dann erneut. Da gibt es eine time out Einstellungen aber die würde ich jetzt nicht verändern. Sudo ist ja kein alltäglicher Befehl
                                    Und man wird selbst darauf hingewiesen, dass man jetzt etwas macht, was ins System eingreift und etwas wichtiger Ist
                                    Links im Profil
                                    • DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      Prinzipiell sollte sich jeder selbst die Frage stellen WARUM man PiHole installiert...
                                      Ich selbst rein wegen den vielen, vielen Werbeteilen im Browser.
                                      Aber dazu stelle ich im Router ja nix um (!) sondern gebe halt meinen PCs den dementsprechenden Eintrag in den Netzwerkeinstellungen mit.
                                      PiHole ist für mich ein reiner WerbeBlocker in der GUI - nicht mehr und nicht weniger.
                                      Lehrling seit 1975 !!!
                                      OliverIOO Marc BergM 2 Antworten Letzte Antwort
                                        QuarkmaxQ Offline
                                        QuarkmaxQ Offline
                                        Quarkmax
                                        @damrak2022
                                        sudo visudo /etc/sudoers
                                        am Ende einfügen
                                        pi ALL=(ALL:ALL) NOPASSWD:ALL
                                        Thomas BraunT OliverIOO 2 Antworten Letzte Antwort
                                        • QuarkmaxQ Quarkmax
                                          @damrak2022
                                          am Ende einfügen
                                          @quarkmax
                                          Dafür gibt es die Datei
                                          /etc/sudoers.d/010_pi-nopasswd
                                          Da steht das drin:
                                          user_der_ausgenommen_ist ALL=(ALL) NOPASSWD: ALL
