  4. Adapter update/installation nicht mehr möglich *gelöst*
    5.4k
30 Beiträge 3 Kommentatoren 2.9k Aufrufe 3 Beobachtet
  • Pepsi1183P Offline
    Pepsi1183P Offline
    Pepsi1183
    schrieb am zuletzt editiert von Pepsi1183
    ich habe die tage nach Anleitung nodejs auf 18 aktualisiert und heute versucht einen neuen Adapter zu installieren, aber leider bricht die installation ab und ich kann mit den log nachrichten nicht sehr viel anfangen.
    Ggf. kann mir hier jemand weiterhelfen?
    $ iobroker add semp auto --host ioBrokerVM --debug
    NPM version: 9.5.0
    Installing iobroker.semp@0.1.0... (System call)
    npm WARN tarball tarball data for iobroker.type-detector@file:iobroker.type-detector (null) seems to be corrupted. Trying again.
    npm WARN tarball tarball data for iobroker.objects-redis@file:iobroker.objects-redis (null) seems to be corrupted. Trying again.
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated cryptiles@0.2.2: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated boom@0.4.2: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
    npm WARN deprecated sntp@0.2.4: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    npm WARN deprecated hoek@0.9.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
    npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
    npm WARN deprecated request@2.44.0: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated hawk@1.1.1: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
    npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
    npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
    npm WARN deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀 @niftylettuce
    npm WARN deprecated protobuf-typescript@6.8.8: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
    npm ERR! code ENOENT
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-04-04T19_44_50_925Z-debug-0.log
    host.ioBrokerVM Cannot install iobroker.semp@0.1.0: 254
    ERROR: Process exited with code 25
    Log:
    10384 timing command:install Completed in 137210ms
    10385 verbose stack Error: ENOENT: no such file or directory, open '/opt/iobroker/iobroker.type-detector/package.json'
    10386 verbose cwd /opt/iobroker
    10387 verbose Linux 5.10.0-21-amd64
    10388 verbose node v18.15.0
    10389 verbose npm  v9.5.0
    10390 error code ENOENT
    10391 error syscall open
    10392 error path /opt/iobroker/iobroker.type-detector/package.json
    10393 error errno -2
    10394 error enoent ENOENT: no such file or directory, open '/opt/iobroker/iobroker.type-detector/package.json'
    10395 error enoent This is related to npm not being able to find a file.
    10395 error enoent
    10396 verbose exit -2
    10397 timing npm Completed in 137252ms
    10398 verbose unfinished npm timer reify 1680637490966
    10399 verbose unfinished npm timer reify:unpack 1680637597476
    10400 verbose unfinished npm timer reifyNode:node_modules/iobroker.type-detector 1680637597524
    10401 verbose unfinished npm timer reifyNode:node_modules/iobroker.objects-redis 1680637597524
    10402 verbose code -2
    10403 error A complete log of this run can be found in:
    10403 error     /home/iobroker/.npm/_logs/2023-04-04T19_44_50_925Z-debug-0.log
    christoph@ioBrokerVM:~$ type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    /usr/bin/npx
    v18.15.0
    v18.15.0
    9.5.0
    9.5.0
    ```[/s]
    Update:
    Problem wurde mit einer neuinstallation des Systems gelöst.
    sigi234S Thomas BraunT 2 Antworten Letzte Antwort
    • Pepsi1183P Pepsi1183
      NPM version: 9.5.0
      Log:
      10395 error enoent
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      /usr/bin/npx
      v18.15.0
      v18.15.0
      9.5.0
      9.5.0
      ```[/s]
      Update:
      sigi234S Online
      sigi234S Online
      sigi234
      @pepsi1183
      https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update
      Immer Daten sichern!
        NPM version: 9.5.0
        Log:
        10395 error enoent
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        /usr/bin/npx
        v18.15.0
        v18.15.0
        9.5.0
        9.5.0
        ```[/s]
        Update:
        @pepsi1183 sagte in Adapter update/installation nach Nodejs nicht mehr möglich:
        Das dürfte kein Fehler von semp sein, sondern da stimmt was mit dem iobroker.type-detector nicht.
        cd /opt/iobroker
        npm ls iobroker.type-detector
        sagt?
        Die Meldung
        ist jedenfalls vollkommen korrekt, der wohnt nämlich da nicht sondern ein Haus/Verzeichnis weiter:
        echad@chet:/opt/iobroker $ locate iobroker.type-detector
        /opt/iobroker/node_modules/iobroker.type-detector
        /opt/iobroker/node_modules/iobroker.type-detector/LICENSE
        /opt/iobroker/node_modules/iobroker.type-detector/README.md
        /opt/iobroker/node_modules/iobroker.type-detector/index.js
        /opt/iobroker/node_modules/iobroker.type-detector/package.json
        Pepsi1183P 1 Antwort Letzte Antwort
          cd /opt/iobroker
          sagt?
          Die Meldung
          Pepsi1183P Offline
          Pepsi1183P Offline
          Pepsi1183
          Also npm ls iobroker.type-detector gibt bei mir folgendes aus:
          [sudo] Passwort für christoph:
          npm ERR! code ELSPROBLEMS
          npm ERR! invalid: iobroker.type-detector@ /opt/iobroker/node_modules/iobroker.type-detector
          iobroker.inst@2.0.2 /opt/iobroker
          ├─┬ iobroker.iot@1.14.2
          │ └── iobroker.type-detector@1.1.1
          └── iobroker.type-detector@ invalid: "file:node_modules/iobroker.type-detector" from the root project
          npm ERR!     /home/iobroker/.npm/_logs/2023-04-04T20_19_09_492Z-debug-0.log
          Hilft mir irgendwie nicht wirklich weiter!? Oder zumindest stehe ich gerade voll auf dem Schlauch.....
          @sigi234 :
          Danke, aber da steht, das es seit gestern im iob fix drin ist, aber auch der hat mir nicht geholfen.....
            @sigi234 :
            cd /opt/iobroker
            npm uninstall iobroker.type-detector
              @sigi234 :
              Weil das nicht dein Problem ist...
                cd /opt/iobroker
                Pepsi1183P Offline
                Pepsi1183P Offline
                Pepsi1183
                Der wirft mir auch ne menge Meldungen die ich nicht verstehe....
                Muss ich dafür iob stoppen? restarten?
                /opt/iobroker$ npm uninstall iobroker.type-detector
                npm ERR! syscall open
                npm ERR! path /opt/iobroker/iobroker.objects-redis/package.json
                npm ERR! errno -2
                npm ERR! enoent ENOENT: no such file or directory, open '/opt/iobroker/iobroker.objects-redis/package.json'
                npm ERR! enoent This is related to npm not being able to find a file.
                npm ERR! enoent
                npm ERR!     /home/iobroker/.npm/_logs/2023-04-04T20_38_33_932Z-debug-0.log
                christoph@ioBrokerVM:/opt/iobroker$
                ```[/s]
                  npm ERR! errno -2
                  npm ERR! enoent
                  ```[/s]
                  Auch das dürfte 'daneben' liegen. Da scheint mal irgendwas manuell in das falsche Verzeichnis geworfen worden zu sein.
                  cd /opt/iobroker
                  npm ls
                    cd /opt/iobroker
                    npm ls
                    Pepsi1183P Offline
                    Pepsi1183P Offline
                    Pepsi1183
                    npm ls
                    npm ERR! extraneous: @azure/ms-rest-azure-env@1.1.2 /opt/iobroker/node_modules/@azure/ms-rest-azure-env
                    npm ERR! extraneous: @azure/ms-rest-js@1.8.15 /opt/iobroker/node_modules/@azure/ms-rest-js
                    npm ERR! extraneous: @azure/ms-rest-nodeauth@2.0.2 /opt/iobroker/node_modules/@azure/ms-rest-nodeauth
                    npm ERR! extraneous: @babel/generator@7.9.5 /opt/iobroker/node_modules/@babel/generator
                    npm ERR! extraneous: @babel/helper-function-name@7.9.5 /opt/iobroker/node_modules/@babel/helper-function-name
                    npm ERR! extraneous: @babel/helper-get-function-arity@7.8.3 /opt/iobroker/node_modules/@babel/helper-get-function-arity
                    npm ERR! extraneous: @babel/helper-split-export-declaration@7.8.3 /opt/iobroker/node_modules/@babel/helper-split-export-declaration
                    npm ERR! extraneous: @babel/helper-validator-identifier@7.9.5 /opt/iobroker/node_modules/@babel/helper-validator-identifier
                    npm ERR! extraneous: @babel/parser@7.9.4 /opt/iobroker/node_modules/@babel/parser
                    npm ERR! extraneous: @babel/template@7.8.6 /opt/iobroker/node_modules/@babel/template
                    npm ERR! extraneous: @babel/traverse@7.9.5 /opt/iobroker/node_modules/@babel/traverse
                    npm ERR! extraneous: @babel/types@7.9.5 /opt/iobroker/node_modules/@babel/types
                    npm ERR! extraneous: @cospired/i18n-iso-languages@3.1.1 /opt/iobroker/node_modules/@cospired/i18n-iso-languages
                    npm ERR! extraneous: @firebase/analytics-types@0.3.1 /opt/iobroker/node_modules/@firebase/analytics-types
                    npm ERR! extraneous: @firebase/analytics@0.3.8 /opt/iobroker/node_modules/@firebase/analytics
                    npm ERR! extraneous: @firebase/app-types@0.6.1 /opt/iobroker/node_modules/@firebase/app-types
                    npm ERR! extraneous: @firebase/app@0.6.7 /opt/iobroker/node_modules/@firebase/app
                    npm ERR! extraneous: @firebase/auth-interop-types@0.1.5 /opt/iobroker/node_modules/@firebase/auth-interop-types
                    npm ERR! extraneous: @firebase/auth-types@0.10.1 /opt/iobroker/node_modules/@firebase/auth-types
                    npm ERR! extraneous: @firebase/auth@0.14.7 /opt/iobroker/node_modules/@firebase/auth
                    npm ERR! extraneous: @firebase/component@0.1.15 /opt/iobroker/node_modules/@firebase/component
                    npm ERR! extraneous: @firebase/database-types@0.5.1 /opt/iobroker/node_modules/@firebase/database-types
                    npm ERR! extraneous: @firebase/database@0.6.6 /opt/iobroker/node_modules/@firebase/database
                    npm ERR! extraneous: @firebase/firestore-types@1.11.0 /opt/iobroker/node_modules/@firebase/firestore-types
                    npm ERR! extraneous: @firebase/firestore@1.15.5 /opt/iobroker/node_modules/@firebase/firestore
                    npm ERR! extraneous: @firebase/functions-types@0.3.17 /opt/iobroker/node_modules/@firebase/functions-types
                    npm ERR! extraneous: @firebase/functions@0.4.47 /opt/iobroker/node_modules/@firebase/functions
                    npm ERR! extraneous: @firebase/installations-types@0.3.4 /opt/iobroker/node_modules/@firebase/installations-types
                    npm ERR! extraneous: @firebase/installations@0.4.13 /opt/iobroker/node_modules/@firebase/installations
                    npm ERR! extraneous: @firebase/logger@0.2.5 /opt/iobroker/node_modules/@firebase/logger
                    npm ERR! extraneous: @firebase/messaging-types@0.4.5 /opt/iobroker/node_modules/@firebase/messaging-types
                    npm ERR! extraneous: @firebase/messaging@0.6.19 /opt/iobroker/node_modules/@firebase/messaging
                    npm ERR! extraneous: @firebase/performance-types@0.0.13 /opt/iobroker/node_modules/@firebase/performance-types
                    npm ERR! extraneous: @firebase/performance@0.3.8 /opt/iobroker/node_modules/@firebase/performance
                    npm ERR! extraneous: @firebase/polyfill@0.3.36 /opt/iobroker/node_modules/@firebase/polyfill
                    npm ERR! extraneous: @firebase/remote-config-types@0.1.9 /opt/iobroker/node_modules/@firebase/remote-config-types
                    npm ERR! extraneous: @firebase/remote-config@0.1.24 /opt/iobroker/node_modules/@firebase/remote-config
                    npm ERR! extraneous: @firebase/storage-types@0.3.12 /opt/iobroker/node_modules/@firebase/storage-types
                    npm ERR! extraneous: @firebase/storage@0.3.37 /opt/iobroker/node_modules/@firebase/storage
                    npm ERR! extraneous: @firebase/util@0.2.50 /opt/iobroker/node_modules/@firebase/util
                    npm ERR! extraneous: @firebase/webchannel-wrapper@0.2.41 /opt/iobroker/node_modules/@firebase/webchannel-wrapper
                    npm ERR! extraneous: @grpc/grpc-js@1.1.1 /opt/iobroker/node_modules/@grpc/grpc-js
                    npm ERR! extraneous: @grpc/proto-loader@0.5.4 /opt/iobroker/node_modules/@grpc/proto-loader
                    npm ERR! extraneous: @serialport/bindings@8.0.7 /opt/iobroker/node_modules/@serialport/bindings
                    npm ERR! extraneous: @types/readable-stream@2.3.15 /opt/iobroker/node_modules/@types/readable-stream
                    npm ERR! extraneous: @types/tunnel@0.0.0 /opt/iobroker/node_modules/@types/tunnel
                    npm ERR! extraneous: adal-node@0.1.28 /opt/iobroker/node_modules/adal-node
                    npm ERR! extraneous: are-we-there-yet@1.1.7 /opt/iobroker/node_modules/are-we-there-yet
                    npm ERR! extraneous: argf@0.0.1 /opt/iobroker/node_modules/argf
                    npm ERR! extraneous: babel-eslint@10.1.0 /opt/iobroker/node_modules/babel-eslint
                    npm ERR! extraneous: better-sqlite3@8.0.1 /opt/iobroker/node_modules/better-sqlite3
                    npm ERR! extraneous: binary@0.3.0 /opt/iobroker/node_modules/binary
                    npm ERR! extraneous: binrpc@0.1.3 /opt/iobroker/node_modules/binrpc
                    npm ERR! extraneous: block-stream@0.0.9 /opt/iobroker/node_modules/block-stream
                    npm ERR! extraneous: buffer-writer@2.0.0 /opt/iobroker/node_modules/buffer-writer
                    npm ERR! extraneous: buffers@0.1.1 /opt/iobroker/node_modules/buffers
                    npm ERR! extraneous: chainsaw@0.1.0 /opt/iobroker/node_modules/chainsaw
                    npm ERR! missing: colors@^1.3.3, required by iobroker.inst@2.0.2
                    npm ERR! extraneous: core-js@3.6.5 /opt/iobroker/node_modules/core-js
                    npm ERR! extraneous: date-utils@1.2.21 /opt/iobroker/node_modules/date-utils
                    npm ERR! extraneous: dom-storage@2.1.0 /opt/iobroker/node_modules/dom-storage
                    npm ERR! extraneous: eslint-visitor-keys@1.1.0 /opt/iobroker/node_modules/eslint-visitor-keys
                    npm ERR! extraneous: eufy-security-client@1.4.0 /opt/iobroker/node_modules/eufy-security-client
                    npm ERR! extraneous: faye-websocket@0.11.3 /opt/iobroker/node_modules/faye-websocket
                    npm ERR! extraneous: firebase@7.15.5 /opt/iobroker/node_modules/firebase
                    npm ERR! missing: fs-extra@^7.0.1, required by iobroker.inst@2.0.2
                    npm ERR! extraneous: fstream@1.0.12 /opt/iobroker/node_modules/fstream
                    npm ERR! extraneous: gauge@2.7.4 /opt/iobroker/node_modules/gauge
                    npm ERR! extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
                    npm ERR! extraneous: globals@11.12.0 /opt/iobroker/node_modules/globals
                    npm ERR! extraneous: homematic-manager@1.0.14 /opt/iobroker/node_modules/homematic-manager
                    npm ERR! extraneous: homematic-xmlrpc@1.0.2 /opt/iobroker/node_modules/homematic-xmlrpc
                    npm ERR! extraneous: http-parser-js@0.5.2 /opt/iobroker/node_modules/http-parser-js
                    npm ERR! extraneous: i18n-iso-countries@7.1.0 /opt/iobroker/node_modules/i18n-iso-countries
                    npm ERR! extraneous: idb@3.0.2 /opt/iobroker/node_modules/idb
                    npm ERR! invalid: iobroker.broadlink2@2.1.5 /opt/iobroker/node_modules/iobroker.broadlink2
                    npm ERR! extraneous: iobroker.eufy-security@0.7.5 /opt/iobroker/node_modules/iobroker.eufy-security
                    npm ERR! missing: iobroker.kodi@^2.0.1, required by iobroker.inst@2.0.2
                    npm ERR! invalid: iobroker.objects-redis@ /opt/iobroker/node_modules/iobroker.objects-redis
                    npm ERR! extraneous: iobroker.sbfspot@4.1.3 /opt/iobroker/node_modules/iobroker.sbfspot
                    npm ERR! missing: iobroker.sql@^1.15.2, required by iobroker.inst@2.0.2
                    npm ERR! invalid: iobroker.vis-materialdesign@0.3.8 /opt/iobroker/node_modules/iobroker.vis-materialdesign
                    npm ERR! missing: iobroker.yr@^2.0.3, required by iobroker.inst@2.0.2
                    npm ERR! missing: iobroker@^2.0.2, required by iobroker.inst@2.0.2
                    npm ERR! extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
                    npm ERR! extraneous: isomorphic-fetch@2.2.1 /opt/iobroker/node_modules/isomorphic-fetch
                    npm ERR! extraneous: jrpc-schema@2.1.0 /opt/iobroker/node_modules/jrpc-schema
                    npm ERR! extraneous: jsbi@3.1.3 /opt/iobroker/node_modules/jsbi
                    npm ERR! extraneous: jsesc@2.5.2 /opt/iobroker/node_modules/jsesc
                    npm ERR! extraneous: kodi-ws@2.4.0 /opt/iobroker/node_modules/kodi-ws
                    npm ERR! extraneous: lodash.camelcase@4.3.0 /opt/iobroker/node_modules/lodash.camelcase
                    npm ERR! extraneous: mqtt-connection@4.0.0 /opt/iobroker/node_modules/mqtt-connection
                    npm ERR! extraneous: mssql@6.2.1 /opt/iobroker/node_modules/mssql
                    npm ERR! extraneous: mysql@2.18.1 /opt/iobroker/node_modules/mysql
                    npm ERR! extraneous: mysql2@3.1.0 /opt/iobroker/node_modules/mysql2
                    npm ERR! extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
                    npm ERR! extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
                    npm ERR! extraneous: nice-try@1.0.5 /opt/iobroker/node_modules/nice-try
                    npm ERR! extraneous: node-gyp@3.8.0 /opt/iobroker/node_modules/node-gyp
                    npm ERR! extraneous: npm-bundled@1.1.2 /opt/iobroker/node_modules/npm-bundled
                    npm ERR! extraneous: npm-normalize-package-bin@1.0.1 /opt/iobroker/node_modules/npm-normalize-package-bin
                    npm ERR! extraneous: npm-run-path@2.0.2 /opt/iobroker/node_modules/npm-run-path
                    npm ERR! extraneous: npmlog@4.1.2 /opt/iobroker/node_modules/npmlog
                    npm ERR! extraneous: ohash@1.0.0 /opt/iobroker/node_modules/ohash
                    npm ERR! extraneous: os-homedir@1.0.2 /opt/iobroker/node_modules/os-homedir
                    npm ERR! extraneous: osenv@0.1.5 /opt/iobroker/node_modules/osenv
                    npm ERR! extraneous: p-is-promise@2.1.0 /opt/iobroker/node_modules/p-is-promise
                    npm ERR! extraneous: packet-reader@1.0.0 /opt/iobroker/node_modules/packet-reader
                    npm ERR! extraneous: path-key@2.0.1 /opt/iobroker/node_modules/path-key
                    npm ERR! extraneous: pg-connection-string@2.3.0 /opt/iobroker/node_modules/pg-connection-string
                    npm ERR! extraneous: pg-int8@1.0.1 /opt/iobroker/node_modules/pg-int8
                    npm ERR! extraneous: pg-pool@3.2.1 /opt/iobroker/node_modules/pg-pool
                    npm ERR! extraneous: pg-protocol@1.2.5 /opt/iobroker/node_modules/pg-protocol
                    npm ERR! extraneous: pg-types@2.2.0 /opt/iobroker/node_modules/pg-types
                    npm ERR! extraneous: pg@8.3.0 /opt/iobroker/node_modules/pg
                    npm ERR! extraneous: pgpass@1.0.2 /opt/iobroker/node_modules/pgpass
                    npm ERR! extraneous: platform@1.3.6 /opt/iobroker/node_modules/platform
                    npm ERR! extraneous: postgres-array@2.0.0 /opt/iobroker/node_modules/postgres-array
                    npm ERR! extraneous: postgres-bytea@1.0.0 /opt/iobroker/node_modules/postgres-bytea
                    npm ERR! extraneous: postgres-date@1.0.5 /opt/iobroker/node_modules/postgres-date
                    npm ERR! extraneous: postgres-interval@1.2.0 /opt/iobroker/node_modules/postgres-interval
                    npm ERR! extraneous: promise-polyfill@8.1.3 /opt/iobroker/node_modules/promise-polyfill
                    npm ERR! extraneous: request-promise@4.2.6 /opt/iobroker/node_modules/request-promise
                    npm ERR! extraneous: rimraf@2.7.1 /opt/iobroker/node_modules/rimraf
                    npm ERR! extraneous: rrule@2.6.9 /opt/iobroker/node_modules/rrule
                    npm ERR! extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
                    npm ERR! extraneous: shebang-command@1.2.0 /opt/iobroker/node_modules/shebang-command
                    npm ERR! extraneous: shebang-regex@1.0.0 /opt/iobroker/node_modules/shebang-regex
                    npm ERR! extraneous: skeemas-json-pointer@1.0.0 /opt/iobroker/node_modules/skeemas-json-pointer
                    npm ERR! extraneous: skeemas-json-refs@1.0.1 /opt/iobroker/node_modules/skeemas-json-refs
                    npm ERR! extraneous: skeemas@1.2.5 /opt/iobroker/node_modules/skeemas
                    npm ERR! extraneous: source-map@0.5.7 /opt/iobroker/node_modules/source-map
                    npm ERR! extraneous: sql-client@2.0.3 /opt/iobroker/node_modules/sql-client
                    npm ERR! extraneous: sqlite3@5.0.0 /opt/iobroker/node_modules/sqlite3
                    npm ERR! extraneous: sqlstring@2.3.1 /opt/iobroker/node_modules/sqlstring
                    npm ERR! extraneous: strip-eof@1.0.0 /opt/iobroker/node_modules/strip-eof
                    npm ERR! extraneous: tarn@1.1.5 /opt/iobroker/node_modules/tarn
                    npm ERR! extraneous: tedious@6.7.0 /opt/iobroker/node_modules/tedious
                    npm ERR! extraneous: to-fast-properties@2.0.0 /opt/iobroker/node_modules/to-fast-properties
                    npm ERR! extraneous: traverse@0.3.9 /opt/iobroker/node_modules/traverse
                    npm ERR! extraneous: ts-log@2.2.4 /opt/iobroker/node_modules/ts-log
                    npm ERR! extraneous: tunnel@0.0.6 /opt/iobroker/node_modules/tunnel
                    npm ERR! extraneous: websocket-driver@0.7.4 /opt/iobroker/node_modules/websocket-driver
                    npm ERR! extraneous: websocket-extensions@0.1.4 /opt/iobroker/node_modules/websocket-extensions
                    npm ERR! extraneous: whatwg-fetch@3.0.0 /opt/iobroker/node_modules/whatwg-fetch
                    npm ERR! extraneous: which@1.3.1 /opt/iobroker/node_modules/which
                    npm ERR! extraneous: xhr2@0.2.0 /opt/iobroker/node_modules/xhr2
                    npm ERR! extraneous: xmlhttprequest@1.8.0 /opt/iobroker/node_modules/xmlhttprequest
                    npm ERR! extraneous: xpath.js@1.1.0 /opt/iobroker/node_modules/xpath.js
                    npm ERR! extraneous: zigbee-herdsman-converters@12.0.47 /opt/iobroker/node_modules/zigbee-herdsman-converters
                    npm ERR! extraneous: zigbee-herdsman@0.12.57 /opt/iobroker/node_modules/zigbee-herdsman
                    ├── @azure/ms-rest-azure-env@1.1.2 extraneous
                    ├── @azure/ms-rest-js@1.8.15 extraneous
                    ├── @azure/ms-rest-nodeauth@2.0.2 extraneous
                    ├── @babel/generator@7.9.5 extraneous
                    ├── @babel/helper-function-name@7.9.5 extraneous
                    ├── @babel/helper-get-function-arity@7.8.3 extraneous
                    ├── @babel/helper-split-export-declaration@7.8.3 extraneous
                    ├── @babel/helper-validator-identifier@7.9.5 extraneous
                    ├── @babel/parser@7.9.4 extraneous
                    ├── @babel/template@7.8.6 extraneous
                    ├── @babel/traverse@7.9.5 extraneous
                    ├── @babel/types@7.9.5 extraneous
                    ├── @cospired/i18n-iso-languages@3.1.1 extraneous
                    ├── @firebase/analytics-types@0.3.1 extraneous
                    ├── @firebase/analytics@0.3.8 extraneous
                    ├── @firebase/app-types@0.6.1 extraneous
                    ├── @firebase/app@0.6.7 extraneous
                    ├── @firebase/auth-interop-types@0.1.5 extraneous
                    ├── @firebase/auth-types@0.10.1 extraneous
                    ├── @firebase/auth@0.14.7 extraneous
                    ├── @firebase/component@0.1.15 extraneous
                    ├── @firebase/database-types@0.5.1 extraneous
                    ├── @firebase/database@0.6.6 extraneous
                    ├── @firebase/firestore-types@1.11.0 extraneous
                    ├── @firebase/firestore@1.15.5 extraneous
                    ├── @firebase/functions-types@0.3.17 extraneous
                    ├── @firebase/functions@0.4.47 extraneous
                    ├── @firebase/installations-types@0.3.4 extraneous
                    ├── @firebase/installations@0.4.13 extraneous
                    ├── @firebase/logger@0.2.5 extraneous
                    ├── @firebase/messaging-types@0.4.5 extraneous
                    ├── @firebase/messaging@0.6.19 extraneous
                    ├── @firebase/performance-types@0.0.13 extraneous
                    ├── @firebase/performance@0.3.8 extraneous
                    ├── @firebase/polyfill@0.3.36 extraneous
                    ├── @firebase/remote-config-types@0.1.9 extraneous
                    ├── @firebase/remote-config@0.1.24 extraneous
                    ├── @firebase/storage-types@0.3.12 extraneous
                    ├── @firebase/storage@0.3.37 extraneous
                    ├── @firebase/util@0.2.50 extraneous
                    ├── @firebase/webchannel-wrapper@0.2.41 extraneous
                    ├── @grpc/grpc-js@1.1.1 extraneous
                    ├── @grpc/proto-loader@0.5.4 extraneous
                    ├── @serialport/bindings@8.0.7 extraneous
                    ├── @types/readable-stream@2.3.15 extraneous
                    ├── @types/tunnel@0.0.0 extraneous
                    ├── adal-node@0.1.28 extraneous
                    ├── are-we-there-yet@1.1.7 extraneous
                    ├── argf@0.0.1 extraneous
                    ├── babel-eslint@10.1.0 extraneous
                    ├── better-sqlite3@8.0.1 extraneous
                    ├── binary@0.3.0 extraneous
                    ├── binrpc@0.1.3 extraneous
                    ├── block-stream@0.0.9 extraneous
                    ├── buffer-writer@2.0.0 extraneous
                    ├── buffers@0.1.1 extraneous
                    ├── chainsaw@0.1.0 extraneous
                    ├── UNMET DEPENDENCY colors@^1.3.3
                    ├── core-js@3.6.5 extraneous
                    ├── date-utils@1.2.21 extraneous
                    ├── dom-storage@2.1.0 extraneous
                    ├── eslint-visitor-keys@1.1.0 extraneous
                    ├── eufy-security-client@1.4.0 extraneous
                    ├── faye-websocket@0.11.3 extraneous
                    ├── firebase@7.15.5 extraneous
                    ├── UNMET DEPENDENCY fs-extra@^7.0.1
                    ├── fstream@1.0.12 extraneous
                    ├── gauge@2.7.4 extraneous
                    ├── generate-function@2.3.1 extraneous
                    ├── globals@11.12.0 extraneous
                    ├── homematic-manager@1.0.14 extraneous
                    ├── homematic-xmlrpc@1.0.2 extraneous
                    ├── http-parser-js@0.5.2 extraneous
                    ├── i18n-iso-countries@7.1.0 extraneous
                    ├── idb@3.0.2 extraneous
                    ├── iobroker.admin@6.3.5
                    ├── iobroker.alexa2@3.23.2
                    ├── iobroker.backitup@2.5.12
                    ├── iobroker.broadlink2@2.1.5 invalid: "github:frankjoke/ioBroker.broadlink2#master" from the root project
                    ├── iobroker.chromecast@3.0.3
                    ├── iobroker.cloud@4.3.0
                    ├── iobroker.daswetter@3.1.7
                    ├── iobroker.deconz@1.3.21
                    ├── iobroker.devices@1.1.2
                    ├── iobroker.discovery@3.1.0
                    ├── iobroker.eufy-security@0.7.5 extraneous
                    ├── iobroker.eusec@0.9.9
                    ├── iobroker.fb-checkpresence@1.1.25
                    ├── iobroker.fullcalendar@1.2.0
                    ├── iobroker.fullybrowser@2.1.2
                    ├── iobroker.habpanel@0.5.0
                    ├── iobroker.harmony@1.2.2
                    ├── iobroker.history@2.2.4
                    ├── iobroker.hue@3.7.1
                    ├── iobroker.ical@1.13.2
                    ├── iobroker.icons-icons8@0.0.1
                    ├── iobroker.icons-material-png@0.1.0
                    ├── iobroker.icons-material-svg@0.1.0
                    ├── iobroker.icons-mfd-svg@1.1.0
                    ├── iobroker.icons-open-icon-library-png@0.1.2
                    ├── iobroker.influxdb@3.2.0
                    ├── iobroker.info@1.9.19
                    ├── iobroker.iot@1.14.2
                    ├── iobroker.javascript@6.1.4
                    ├── iobroker.js-controller@4.0.24
                    ├── UNMET DEPENDENCY iobroker.kodi@^2.0.1
                    ├── iobroker.material@1.1.2
                    ├── iobroker.modbus@5.0.11
                    ├── iobroker.mqtt-client@1.6.3
                    ├── iobroker.mqtt@4.0.7
                    ├── iobroker.myenergi@0.0.3
                    ├── iobroker.net-tools@0.2.0
                    ├── iobroker.nina@0.0.25
                    ├── iobroker.node-red@4.0.0
                    ├── iobroker.objects-redis@ invalid: "file:node_modules/iobroker.objects-redis" from the root project
                    ├── iobroker.paw@0.3.2
                    ├── iobroker.pi-hole@1.3.4
                    ├── iobroker.ping@1.5.3
                    ├── iobroker.proxmox@1.3.4
                    ├── iobroker.pushbullet@0.0.11
                    ├── iobroker.rpi2@1.3.2
                    ├── iobroker.sbfspot@4.1.3 extraneous
                    ├── iobroker.scenes@2.3.9
                    ├── iobroker.shelly@6.3.1
                    ├── iobroker.simple-api@2.7.2
                    ├── iobroker.socketio@4.2.0
                    ├── iobroker.sonos@2.2.3
                    ├── UNMET DEPENDENCY iobroker.sql@^1.15.2
                    ├── iobroker.synology@2.1.13
                    ├── iobroker.tr-064@4.2.18
                    ├── iobroker.type-detector@ invalid: "file:node_modules/iobroker.type-detector" from the root project
                    ├── iobroker.vis-canvas-gauges@1.0.1
                    ├── iobroker.vis-colorpicker@1.2.0
                    ├── iobroker.vis-fancyswitch@1.1.0
                    ├── iobroker.vis-google-fonts@1.0.4
                    ├── iobroker.vis-hqwidgets@1.3.0
                    ├── iobroker.vis-inventwo@3.3.1
                    ├── iobroker.vis-jqui-mfd@1.0.12
                    ├── iobroker.vis-material-advanced@1.7.2
                    ├── iobroker.vis-materialdesign@0.3.8 invalid: "https://github.com/Scrounger/ioBroker.vis-materialdesign/tarball/300a1ee9532b76baefd761732464b0f45c8a41a3" from the root project
                    ├── iobroker.vis-metro@1.2.0
                    ├── iobroker.vis-players@0.1.6
                    ├── iobroker.vis-timeandweather@1.2.2
                    ├── iobroker.vis-weather@2.5.6
                    ├── iobroker.vis@1.4.16
                    ├── iobroker.weatherunderground@3.4.2
                    ├── iobroker.web@4.3.0
                    ├── UNMET DEPENDENCY iobroker.yr@^2.0.3
                    ├── iobroker.zigbee@1.8.10
                    ├── UNMET DEPENDENCY iobroker@^2.0.2
                    ├── is-property@1.0.2 extraneous
                    ├── isomorphic-fetch@2.2.1 extraneous
                    ├── jrpc-schema@2.1.0 extraneous
                    ├── jsbi@3.1.3 extraneous
                    ├── jsesc@2.5.2 extraneous
                    ├── kodi-ws@2.4.0 extraneous
                    ├── lodash.camelcase@4.3.0 extraneous
                    ├── mqtt-connection@4.0.0 extraneous
                    ├── mssql@6.2.1 extraneous
                    ├── mysql@2.18.1 extraneous
                    ├── mysql2@3.1.0 extraneous
                    ├── named-placeholders@1.1.3 extraneous
                    ├── native-duplexpair@1.0.0 extraneous
                    ├── nice-try@1.0.5 extraneous
                    ├── node-gyp@3.8.0 extraneous
                    ├── npm-bundled@1.1.2 extraneous
                    ├── npm-normalize-package-bin@1.0.1 extraneous
                    ├── npm-run-path@2.0.2 extraneous
                    ├── npmlog@4.1.2 extraneous
                    ├── ohash@1.0.0 extraneous
                    ├── os-homedir@1.0.2 extraneous
                    ├── osenv@0.1.5 extraneous
                    ├── p-is-promise@2.1.0 extraneous
                    ├── packet-reader@1.0.0 extraneous
                    ├── path-key@2.0.1 extraneous
                    ├── pg-connection-string@2.3.0 extraneous
                    ├── pg-int8@1.0.1 extraneous
                    ├── pg-pool@3.2.1 extraneous
                    ├── pg-protocol@1.2.5 extraneous
                    ├── pg-types@2.2.0 extraneous
                    ├── pg@8.3.0 extraneous
                    ├── pgpass@1.0.2 extraneous
                    ├── platform@1.3.6 extraneous
                    ├── postgres-array@2.0.0 extraneous
                    ├── postgres-bytea@1.0.0 extraneous
                    ├── postgres-date@1.0.5 extraneous
                    ├── postgres-interval@1.2.0 extraneous
                    ├── promise-polyfill@8.1.3 extraneous
                    ├── request-promise@4.2.6 extraneous
                    ├── rimraf@2.7.1 extraneous
                    ├── rrule@2.6.9 extraneous
                    ├── seq-queue@0.0.5 extraneous
                    ├── shebang-command@1.2.0 extraneous
                    ├── shebang-regex@1.0.0 extraneous
                    ├── skeemas-json-pointer@1.0.0 extraneous
                    ├── skeemas-json-refs@1.0.1 extraneous
                    ├── skeemas@1.2.5 extraneous
                    ├── source-map@0.5.7 extraneous
                    ├── sql-client@2.0.3 extraneous
                    ├── sqlite3@5.0.0 extraneous
                    ├── sqlstring@2.3.1 extraneous
                    ├── strip-eof@1.0.0 extraneous
                    ├── tarn@1.1.5 extraneous
                    ├── tedious@6.7.0 extraneous
                    ├── to-fast-properties@2.0.0 extraneous
                    ├── traverse@0.3.9 extraneous
                    ├── ts-log@2.2.4 extraneous
                    ├── tunnel@0.0.6 extraneous
                    ├── websocket-driver@0.7.4 extraneous
                    ├── websocket-extensions@0.1.4 extraneous
                    ├── whatwg-fetch@3.0.0 extraneous
                    ├── which@1.3.1 extraneous
                    ├── xhr2@0.2.0 extraneous
                    ├── xmlhttprequest@1.8.0 extraneous
                    ├── xpath.js@1.1.0 extraneous
                    ├── zigbee-herdsman-converters@12.0.47 extraneous
                    └── zigbee-herdsman@0.12.57 extraneous
                    npm ERR!     /home/iobroker/.npm/_logs/2023-04-04T20_57_20_588Z-debug-0.log
                      npm ls
                      @pepsi1183
                      Bitte vollständig inkl. LogIn Prompt posten, damit man sieht wo du da herumstehst und ob/wo der Output komplett ist.
                        npm ls
                        @pepsi1183
                        Keine Ahnung was da alles schief ist bei dir.
                        Ordentlich schaut das jedenfalls so aus:
                        echad@chet:/opt/iobroker $ npm ls
                        iobroker.inst@3.0.0 /opt/iobroker
                        ├── iobroker.admin@6.4.3
                        ├── iobroker.alias-manager@1.2.6
                        ├── iobroker.backitup@2.6.16
                        ├── iobroker.ble@0.13.3
                        ├── iobroker.cloud@4.4.0
                        ├── iobroker.echarts@1.4.13
                        ├── iobroker.firetv@1.0.0
                        ├── iobroker.followthesun@0.4.1
                        ├── iobroker.govee-app@0.0.3 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#f7848a9817a15db547dd5fc7f332822752d9bed6)
                        ├── iobroker.iceroad@1.2.0
                        ├── iobroker.info@1.9.26
                        ├── iobroker.iot@1.14.5 (git+ssh://git@github.com/ioBroker/ioBroker.iot.git#6735ac3c62352103ff3e9c98bf04b0e3f91d1a21)
                        ├── iobroker.javascript@7.0.3
                        ├── iobroker.js-controller@5.0.1-alpha.0-20230403-fd495c2e
                        ├── iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#0d037c0c9a025b193546f881f747c8f998bfc724)
                        ├── iobroker.mihome-cloud@0.0.5 (git+ssh://git@github.com/TA2k/ioBroker.mihome-cloud.git#e3bfab06b04163faacaa72edd7190f8e30252e60)
                        ├── iobroker.mihome-vacuum@3.9.5
                        ├── iobroker.mihome@1.4.0
                        ├── iobroker.miio@0.0.13
                        ├── iobroker.nuki-extended@2.6.5
                        ├── iobroker.opendtu@0.1.4 (git+ssh://git@github.com/o0shojo0o/ioBroker.opendtu.git#f8836ab9b984b678eaa05f4efe92f2c7f95ddb58)
                        ├── iobroker.parcel@0.0.25
                        ├── iobroker.sainlogic@0.10.0
                        ├── iobroker.socketio@6.3.5
                        ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e)
                        ├── iobroker.tado@0.4.6-alpha.2
                        ├── iobroker.tankerkoenig@3.3.7
                        ├── iobroker.tradfri@3.1.3
                        ├── iobroker.trashschedule@2.2.0
                        ├── iobroker.tuya@3.14.2
                        ├── iobroker.web@5.5.3
                        ├── iobroker.whatsapp-cmb@0.2.3
                        └── iobroker.zigbee@1.8.10
                          @pepsi1183
                          Pepsi1183P Offline
                          Pepsi1183P Offline
                          Pepsi1183
                          Ok,
                          wie kann ich das denn reparieren?
                          Übrigens hier nochmal von Anfang:
                          /opt/iobroker$ npm ls
                            Ok,
                            Ich weiß es nicht. Da scheinen gleich mehrere Dinge schief zu sein.
                              Pepsi1183P Offline
                              Pepsi1183P Offline
                              Pepsi1183
                              Also gibt es kein "Konfig-File" das ich durchsuchen und korrigieren kann bzw. deinstallieren und neu installieren?
                                Im Zweifel gleich mehrere. Da sind vermutlich diverses package-lock.json und auch noch die versteckten Varianten derselben im Spiel.
                                find "/opt/iobroker/" -iname "*package-lock*"
                                sagt?
                                  sagt?
                                  Pepsi1183P Offline
                                  Pepsi1183P Offline
                                  Pepsi1183
                                  Sagt:
                                  christoph@ioBrokerVM:/opt/iobroker$ find "/opt/iobroker/" -iname "package-lock*"
                                  /opt/iobroker/node_modules/adal-node/package-lock.json
                                  /opt/iobroker/node_modules/bower/packages/bower-config/package-lock.json
                                  /opt/iobroker/node_modules/bower/packages/bower-json/package-lock.json
                                  /opt/iobroker/node_modules/bower/lib/node_modules/bower-config/package-lock.json
                                  /opt/iobroker/node_modules/bower/lib/node_modules/requireg/package-lock.json
                                  /opt/iobroker/node_modules/bower/lib/node_modules/bower-json/package-lock.json
                                  /opt/iobroker/node_modules/protobufjs/package-lock.json
                                  /opt/iobroker/node_modules/eufy-security-client/node_modules/protobuf-typescript/package-lock.json
                                  /opt/iobroker/node_modules/eufy-security-client/node_modules/protobuf-typescript/cli/package-lock.json
                                  /opt/iobroker/node_modules/iobroker.eusec/node_modules/protobuf-typescript/package-lock.json
                                  /opt/iobroker/node_modules/iobroker.eusec/node_modules/protobuf-typescript/cli/package-lock.json
                                  /opt/iobroker/node_modules/iobroker.javascript/package-lock.json
                                  /opt/iobroker/node_modules/iobroker.vis-materialdesign/package-lock.json
                                  /opt/iobroker/node_modules/npm-normalize-package-bin/package-lock.json
                                  /opt/iobroker/package-lock.json
                                    Sagt:
                                    @pepsi1183
                                    Siehste.
                                    Bei mir sind das nur 2 Dateien:
                                    echad@chet:~ $ find "/opt/iobroker/" -iname "*package-lock*"
                                    /opt/iobroker/node_modules/.package-lock.json
                                      @pepsi1183
                                      Siehste.
                                      Pepsi1183P Offline
                                      Pepsi1183P Offline
                                      Pepsi1183
                                      rest mal löschen? Verschieben?
                                        rest mal löschen?
                                        Kannst die alle löschen. Aber ich kann dir nicht versprechen das es damit getan ist. Oder der iobroker wieder auf die Beine kommt.
                                        iob stop
                                        find "/opt/iobroker/" -iname "*package-lock*" -exec rm "{}" \;
                                        iob fix
                                        iob start
                                          rest mal löschen?
                                          iob stop
                                          iob fix
                                          iob start
                                          Pepsi1183P Offline
                                          Pepsi1183P Offline
                                          Pepsi1183
                                          die Fehlermeldung beim installieren wird kürzer ;)
                                          NPM version: 9.5.0
                                          npm WARN tarball tarball data for iobroker.type-detector@file:iobroker.type-detector (null) seems to be corrupted. Trying again.npm WARN tarball tarball data for iobroker.objects-redis@file:iobroker.objects-redis (null) seems to be corrupted. Trying again.
