  4. Adapter update/installation nicht mehr möglich *gelöst*
    5.4k
30 Beiträge 3 Kommentatoren 2.9k Aufrufe 3 Beobachtet
  • Pepsi1183P Pepsi1183
    Der wirft mir auch ne menge Meldungen die ich nicht verstehe....
    Muss ich dafür iob stoppen? restarten?
    /opt/iobroker$ npm uninstall iobroker.type-detector
    [sudo] Passwort für christoph:
    npm WARN tarball tarball data for iobroker.objects-redis@file:iobroker.objects-redis (null) seems to be corrupted. Trying again.
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated cryptiles@0.2.2: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated boom@0.4.2: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
    npm WARN deprecated sntp@0.2.4: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated hoek@0.9.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
    npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
    npm WARN deprecated request@2.44.0: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated hawk@1.1.1: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
    npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
    npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
    npm WARN deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
    npm WARN deprecated protobuf-typescript@6.8.8: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
    npm ERR! code ENOENT
    npm ERR! syscall open
    npm ERR! path /opt/iobroker/iobroker.objects-redis/package.json
    npm ERR! errno -2
    npm ERR! enoent ENOENT: no such file or directory, open '/opt/iobroker/iobroker.objects-redis/package.json'
    npm ERR! enoent This is related to npm not being able to find a file.
    npm ERR! enoent
    npm ERR!     /home/iobroker/.npm/_logs/2023-04-04T20_38_33_932Z-debug-0.log
    christoph@ioBrokerVM:/opt/iobroker$
    ```[/s]
    @pepsi1183 sagte in Adapter update/installation nach Nodejs nicht mehr möglich:
    Auch das dürfte 'daneben' liegen. Da scheint mal irgendwas manuell in das falsche Verzeichnis geworfen worden zu sein.
    cd /opt/iobroker
    npm ls
    Pepsi1183P 1 Antwort Letzte Antwort
      cd /opt/iobroker
      npm ls
      Pepsi1183P Offline
      Pepsi1183P Offline
      Pepsi1183
      npm ls
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @azure/ms-rest-azure-env@1.1.2 /opt/iobroker/node_modules/@azure/ms-rest-azure-env
      npm ERR! extraneous: @azure/ms-rest-js@1.8.15 /opt/iobroker/node_modules/@azure/ms-rest-js
      npm ERR! extraneous: @azure/ms-rest-nodeauth@2.0.2 /opt/iobroker/node_modules/@azure/ms-rest-nodeauth
      npm ERR! extraneous: @babel/generator@7.9.5 /opt/iobroker/node_modules/@babel/generator
      npm ERR! extraneous: @babel/helper-function-name@7.9.5 /opt/iobroker/node_modules/@babel/helper-function-name
      npm ERR! extraneous: @babel/helper-get-function-arity@7.8.3 /opt/iobroker/node_modules/@babel/helper-get-function-arity
      npm ERR! extraneous: @babel/helper-split-export-declaration@7.8.3 /opt/iobroker/node_modules/@babel/helper-split-export-declaration
      npm ERR! extraneous: @babel/helper-validator-identifier@7.9.5 /opt/iobroker/node_modules/@babel/helper-validator-identifier
      npm ERR! extraneous: @babel/parser@7.9.4 /opt/iobroker/node_modules/@babel/parser
      npm ERR! extraneous: @babel/template@7.8.6 /opt/iobroker/node_modules/@babel/template
      npm ERR! extraneous: @babel/traverse@7.9.5 /opt/iobroker/node_modules/@babel/traverse
      npm ERR! extraneous: @babel/types@7.9.5 /opt/iobroker/node_modules/@babel/types
      npm ERR! extraneous: @cospired/i18n-iso-languages@3.1.1 /opt/iobroker/node_modules/@cospired/i18n-iso-languages
      npm ERR! extraneous: @firebase/analytics-types@0.3.1 /opt/iobroker/node_modules/@firebase/analytics-types
      npm ERR! extraneous: @firebase/analytics@0.3.8 /opt/iobroker/node_modules/@firebase/analytics
      npm ERR! extraneous: @firebase/app-types@0.6.1 /opt/iobroker/node_modules/@firebase/app-types
      npm ERR! extraneous: @firebase/app@0.6.7 /opt/iobroker/node_modules/@firebase/app
      npm ERR! extraneous: @firebase/auth-interop-types@0.1.5 /opt/iobroker/node_modules/@firebase/auth-interop-types
      npm ERR! extraneous: @firebase/auth-types@0.10.1 /opt/iobroker/node_modules/@firebase/auth-types
      npm ERR! extraneous: @firebase/auth@0.14.7 /opt/iobroker/node_modules/@firebase/auth
      npm ERR! extraneous: @firebase/component@0.1.15 /opt/iobroker/node_modules/@firebase/component
      npm ERR! extraneous: @firebase/database-types@0.5.1 /opt/iobroker/node_modules/@firebase/database-types
      npm ERR! extraneous: @firebase/database@0.6.6 /opt/iobroker/node_modules/@firebase/database
      npm ERR! extraneous: @firebase/firestore-types@1.11.0 /opt/iobroker/node_modules/@firebase/firestore-types
      npm ERR! extraneous: @firebase/firestore@1.15.5 /opt/iobroker/node_modules/@firebase/firestore
      npm ERR! extraneous: @firebase/functions-types@0.3.17 /opt/iobroker/node_modules/@firebase/functions-types
      npm ERR! extraneous: @firebase/functions@0.4.47 /opt/iobroker/node_modules/@firebase/functions
      npm ERR! extraneous: @firebase/installations-types@0.3.4 /opt/iobroker/node_modules/@firebase/installations-types
      npm ERR! extraneous: @firebase/installations@0.4.13 /opt/iobroker/node_modules/@firebase/installations
      npm ERR! extraneous: @firebase/logger@0.2.5 /opt/iobroker/node_modules/@firebase/logger
      npm ERR! extraneous: @firebase/messaging-types@0.4.5 /opt/iobroker/node_modules/@firebase/messaging-types
      npm ERR! extraneous: @firebase/messaging@0.6.19 /opt/iobroker/node_modules/@firebase/messaging
      npm ERR! extraneous: @firebase/performance-types@0.0.13 /opt/iobroker/node_modules/@firebase/performance-types
      npm ERR! extraneous: @firebase/performance@0.3.8 /opt/iobroker/node_modules/@firebase/performance
      npm ERR! extraneous: @firebase/polyfill@0.3.36 /opt/iobroker/node_modules/@firebase/polyfill
      npm ERR! extraneous: @firebase/remote-config-types@0.1.9 /opt/iobroker/node_modules/@firebase/remote-config-types
      npm ERR! extraneous: @firebase/remote-config@0.1.24 /opt/iobroker/node_modules/@firebase/remote-config
      npm ERR! extraneous: @firebase/storage-types@0.3.12 /opt/iobroker/node_modules/@firebase/storage-types
      npm ERR! extraneous: @firebase/storage@0.3.37 /opt/iobroker/node_modules/@firebase/storage
      npm ERR! extraneous: @firebase/util@0.2.50 /opt/iobroker/node_modules/@firebase/util
      npm ERR! extraneous: @firebase/webchannel-wrapper@0.2.41 /opt/iobroker/node_modules/@firebase/webchannel-wrapper
      npm ERR! extraneous: @grpc/grpc-js@1.1.1 /opt/iobroker/node_modules/@grpc/grpc-js
      npm ERR! extraneous: @grpc/proto-loader@0.5.4 /opt/iobroker/node_modules/@grpc/proto-loader
      npm ERR! extraneous: @serialport/bindings@8.0.7 /opt/iobroker/node_modules/@serialport/bindings
      npm ERR! extraneous: @types/readable-stream@2.3.15 /opt/iobroker/node_modules/@types/readable-stream
      npm ERR! extraneous: @types/tunnel@0.0.0 /opt/iobroker/node_modules/@types/tunnel
      npm ERR! extraneous: adal-node@0.1.28 /opt/iobroker/node_modules/adal-node
      npm ERR! extraneous: are-we-there-yet@1.1.7 /opt/iobroker/node_modules/are-we-there-yet
      npm ERR! extraneous: argf@0.0.1 /opt/iobroker/node_modules/argf
      npm ERR! extraneous: babel-eslint@10.1.0 /opt/iobroker/node_modules/babel-eslint
      npm ERR! extraneous: better-sqlite3@8.0.1 /opt/iobroker/node_modules/better-sqlite3
      npm ERR! extraneous: binary@0.3.0 /opt/iobroker/node_modules/binary
      npm ERR! extraneous: binrpc@0.1.3 /opt/iobroker/node_modules/binrpc
      npm ERR! extraneous: block-stream@0.0.9 /opt/iobroker/node_modules/block-stream
      npm ERR! extraneous: buffer-writer@2.0.0 /opt/iobroker/node_modules/buffer-writer
      npm ERR! extraneous: buffers@0.1.1 /opt/iobroker/node_modules/buffers
      npm ERR! extraneous: chainsaw@0.1.0 /opt/iobroker/node_modules/chainsaw
      npm ERR! missing: colors@^1.3.3, required by iobroker.inst@2.0.2
      npm ERR! extraneous: core-js@3.6.5 /opt/iobroker/node_modules/core-js
      npm ERR! extraneous: date-utils@1.2.21 /opt/iobroker/node_modules/date-utils
      npm ERR! extraneous: dom-storage@2.1.0 /opt/iobroker/node_modules/dom-storage
      npm ERR! extraneous: eslint-visitor-keys@1.1.0 /opt/iobroker/node_modules/eslint-visitor-keys
      npm ERR! extraneous: eufy-security-client@1.4.0 /opt/iobroker/node_modules/eufy-security-client
      npm ERR! extraneous: faye-websocket@0.11.3 /opt/iobroker/node_modules/faye-websocket
      npm ERR! extraneous: firebase@7.15.5 /opt/iobroker/node_modules/firebase
      npm ERR! missing: fs-extra@^7.0.1, required by iobroker.inst@2.0.2
      npm ERR! extraneous: fstream@1.0.12 /opt/iobroker/node_modules/fstream
      npm ERR! extraneous: gauge@2.7.4 /opt/iobroker/node_modules/gauge
      npm ERR! extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
      npm ERR! extraneous: globals@11.12.0 /opt/iobroker/node_modules/globals
      npm ERR! extraneous: homematic-manager@1.0.14 /opt/iobroker/node_modules/homematic-manager
      npm ERR! extraneous: homematic-xmlrpc@1.0.2 /opt/iobroker/node_modules/homematic-xmlrpc
      npm ERR! extraneous: http-parser-js@0.5.2 /opt/iobroker/node_modules/http-parser-js
      npm ERR! extraneous: i18n-iso-countries@7.1.0 /opt/iobroker/node_modules/i18n-iso-countries
      npm ERR! extraneous: idb@3.0.2 /opt/iobroker/node_modules/idb
      npm ERR! invalid: iobroker.broadlink2@2.1.5 /opt/iobroker/node_modules/iobroker.broadlink2
      npm ERR! extraneous: iobroker.eufy-security@0.7.5 /opt/iobroker/node_modules/iobroker.eufy-security
      npm ERR! missing: iobroker.kodi@^2.0.1, required by iobroker.inst@2.0.2
      npm ERR! invalid: iobroker.objects-redis@ /opt/iobroker/node_modules/iobroker.objects-redis
      npm ERR! extraneous: iobroker.sbfspot@4.1.3 /opt/iobroker/node_modules/iobroker.sbfspot
      npm ERR! missing: iobroker.sql@^1.15.2, required by iobroker.inst@2.0.2
      npm ERR! invalid: iobroker.type-detector@ /opt/iobroker/node_modules/iobroker.type-detector
      npm ERR! invalid: iobroker.vis-materialdesign@0.3.8 /opt/iobroker/node_modules/iobroker.vis-materialdesign
      npm ERR! missing: iobroker.yr@^2.0.3, required by iobroker.inst@2.0.2
      npm ERR! missing: iobroker@^2.0.2, required by iobroker.inst@2.0.2
      npm ERR! extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
      npm ERR! extraneous: isomorphic-fetch@2.2.1 /opt/iobroker/node_modules/isomorphic-fetch
      npm ERR! extraneous: jrpc-schema@2.1.0 /opt/iobroker/node_modules/jrpc-schema
      npm ERR! extraneous: jsbi@3.1.3 /opt/iobroker/node_modules/jsbi
      npm ERR! extraneous: jsesc@2.5.2 /opt/iobroker/node_modules/jsesc
      npm ERR! extraneous: kodi-ws@2.4.0 /opt/iobroker/node_modules/kodi-ws
      npm ERR! extraneous: lodash.camelcase@4.3.0 /opt/iobroker/node_modules/lodash.camelcase
      npm ERR! extraneous: mqtt-connection@4.0.0 /opt/iobroker/node_modules/mqtt-connection
      npm ERR! extraneous: mssql@6.2.1 /opt/iobroker/node_modules/mssql
      npm ERR! extraneous: mysql@2.18.1 /opt/iobroker/node_modules/mysql
      npm ERR! extraneous: mysql2@3.1.0 /opt/iobroker/node_modules/mysql2
      npm ERR! extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
      npm ERR! extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
      npm ERR! extraneous: nice-try@1.0.5 /opt/iobroker/node_modules/nice-try
      npm ERR! extraneous: node-gyp@3.8.0 /opt/iobroker/node_modules/node-gyp
      npm ERR! extraneous: npm-bundled@1.1.2 /opt/iobroker/node_modules/npm-bundled
      npm ERR! extraneous: npm-normalize-package-bin@1.0.1 /opt/iobroker/node_modules/npm-normalize-package-bin
      npm ERR! extraneous: npm-run-path@2.0.2 /opt/iobroker/node_modules/npm-run-path
      npm ERR! extraneous: npmlog@4.1.2 /opt/iobroker/node_modules/npmlog
      npm ERR! extraneous: ohash@1.0.0 /opt/iobroker/node_modules/ohash
      npm ERR! extraneous: os-homedir@1.0.2 /opt/iobroker/node_modules/os-homedir
      npm ERR! extraneous: osenv@0.1.5 /opt/iobroker/node_modules/osenv
      npm ERR! extraneous: p-is-promise@2.1.0 /opt/iobroker/node_modules/p-is-promise
      npm ERR! extraneous: packet-reader@1.0.0 /opt/iobroker/node_modules/packet-reader
      npm ERR! extraneous: path-key@2.0.1 /opt/iobroker/node_modules/path-key
      npm ERR! extraneous: pg-connection-string@2.3.0 /opt/iobroker/node_modules/pg-connection-string
      npm ERR! extraneous: pg-int8@1.0.1 /opt/iobroker/node_modules/pg-int8
      npm ERR! extraneous: pg-pool@3.2.1 /opt/iobroker/node_modules/pg-pool
      npm ERR! extraneous: pg-protocol@1.2.5 /opt/iobroker/node_modules/pg-protocol
      npm ERR! extraneous: pg-types@2.2.0 /opt/iobroker/node_modules/pg-types
      npm ERR! extraneous: pg@8.3.0 /opt/iobroker/node_modules/pg
      npm ERR! extraneous: pgpass@1.0.2 /opt/iobroker/node_modules/pgpass
      npm ERR! extraneous: platform@1.3.6 /opt/iobroker/node_modules/platform
      npm ERR! extraneous: postgres-array@2.0.0 /opt/iobroker/node_modules/postgres-array
      npm ERR! extraneous: postgres-bytea@1.0.0 /opt/iobroker/node_modules/postgres-bytea
      npm ERR! extraneous: postgres-date@1.0.5 /opt/iobroker/node_modules/postgres-date
      npm ERR! extraneous: postgres-interval@1.2.0 /opt/iobroker/node_modules/postgres-interval
      npm ERR! extraneous: promise-polyfill@8.1.3 /opt/iobroker/node_modules/promise-polyfill
      npm ERR! extraneous: request-promise@4.2.6 /opt/iobroker/node_modules/request-promise
      npm ERR! extraneous: rimraf@2.7.1 /opt/iobroker/node_modules/rimraf
      npm ERR! extraneous: rrule@2.6.9 /opt/iobroker/node_modules/rrule
      npm ERR! extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
      npm ERR! extraneous: shebang-command@1.2.0 /opt/iobroker/node_modules/shebang-command
      npm ERR! extraneous: shebang-regex@1.0.0 /opt/iobroker/node_modules/shebang-regex
      npm ERR! extraneous: skeemas-json-pointer@1.0.0 /opt/iobroker/node_modules/skeemas-json-pointer
      npm ERR! extraneous: skeemas-json-refs@1.0.1 /opt/iobroker/node_modules/skeemas-json-refs
      npm ERR! extraneous: skeemas@1.2.5 /opt/iobroker/node_modules/skeemas
      npm ERR! extraneous: source-map@0.5.7 /opt/iobroker/node_modules/source-map
      npm ERR! extraneous: sql-client@2.0.3 /opt/iobroker/node_modules/sql-client
      npm ERR! extraneous: sqlite3@5.0.0 /opt/iobroker/node_modules/sqlite3
      npm ERR! extraneous: sqlstring@2.3.1 /opt/iobroker/node_modules/sqlstring
      npm ERR! extraneous: strip-eof@1.0.0 /opt/iobroker/node_modules/strip-eof
      npm ERR! extraneous: tarn@1.1.5 /opt/iobroker/node_modules/tarn
      npm ERR! extraneous: tedious@6.7.0 /opt/iobroker/node_modules/tedious
      npm ERR! extraneous: to-fast-properties@2.0.0 /opt/iobroker/node_modules/to-fast-properties
      npm ERR! extraneous: traverse@0.3.9 /opt/iobroker/node_modules/traverse
      npm ERR! extraneous: ts-log@2.2.4 /opt/iobroker/node_modules/ts-log
      npm ERR! extraneous: tunnel@0.0.6 /opt/iobroker/node_modules/tunnel
      npm ERR! extraneous: websocket-driver@0.7.4 /opt/iobroker/node_modules/websocket-driver
      npm ERR! extraneous: websocket-extensions@0.1.4 /opt/iobroker/node_modules/websocket-extensions
      npm ERR! extraneous: whatwg-fetch@3.0.0 /opt/iobroker/node_modules/whatwg-fetch
      npm ERR! extraneous: which@1.3.1 /opt/iobroker/node_modules/which
      npm ERR! extraneous: xhr2@0.2.0 /opt/iobroker/node_modules/xhr2
      npm ERR! extraneous: xmlhttprequest@1.8.0 /opt/iobroker/node_modules/xmlhttprequest
      npm ERR! extraneous: xpath.js@1.1.0 /opt/iobroker/node_modules/xpath.js
      npm ERR! extraneous: zigbee-herdsman-converters@12.0.47 /opt/iobroker/node_modules/zigbee-herdsman-converters
      npm ERR! extraneous: zigbee-herdsman@0.12.57 /opt/iobroker/node_modules/zigbee-herdsman
      iobroker.inst@2.0.2 /opt/iobroker
      ├── @azure/ms-rest-azure-env@1.1.2 extraneous
      ├── @azure/ms-rest-js@1.8.15 extraneous
      ├── @azure/ms-rest-nodeauth@2.0.2 extraneous
      ├── @babel/generator@7.9.5 extraneous
      ├── @babel/helper-function-name@7.9.5 extraneous
      ├── @babel/helper-get-function-arity@7.8.3 extraneous
      ├── @babel/helper-split-export-declaration@7.8.3 extraneous
      ├── @babel/helper-validator-identifier@7.9.5 extraneous
      ├── @babel/parser@7.9.4 extraneous
      ├── @babel/template@7.8.6 extraneous
      ├── @babel/traverse@7.9.5 extraneous
      ├── @babel/types@7.9.5 extraneous
      ├── @cospired/i18n-iso-languages@3.1.1 extraneous
      ├── @firebase/analytics-types@0.3.1 extraneous
      ├── @firebase/analytics@0.3.8 extraneous
      ├── @firebase/app-types@0.6.1 extraneous
      ├── @firebase/app@0.6.7 extraneous
      ├── @firebase/auth-interop-types@0.1.5 extraneous
      ├── @firebase/auth-types@0.10.1 extraneous
      ├── @firebase/auth@0.14.7 extraneous
      ├── @firebase/component@0.1.15 extraneous
      ├── @firebase/database-types@0.5.1 extraneous
      ├── @firebase/database@0.6.6 extraneous
      ├── @firebase/firestore-types@1.11.0 extraneous
      ├── @firebase/firestore@1.15.5 extraneous
      ├── @firebase/functions-types@0.3.17 extraneous
      ├── @firebase/functions@0.4.47 extraneous
      ├── @firebase/installations-types@0.3.4 extraneous
      ├── @firebase/installations@0.4.13 extraneous
      ├── @firebase/logger@0.2.5 extraneous
      ├── @firebase/messaging-types@0.4.5 extraneous
      ├── @firebase/messaging@0.6.19 extraneous
      ├── @firebase/performance-types@0.0.13 extraneous
      ├── @firebase/performance@0.3.8 extraneous
      ├── @firebase/polyfill@0.3.36 extraneous
      ├── @firebase/remote-config-types@0.1.9 extraneous
      ├── @firebase/remote-config@0.1.24 extraneous
      ├── @firebase/storage-types@0.3.12 extraneous
      ├── @firebase/storage@0.3.37 extraneous
      ├── @firebase/util@0.2.50 extraneous
      ├── @firebase/webchannel-wrapper@0.2.41 extraneous
      ├── @grpc/grpc-js@1.1.1 extraneous
      ├── @grpc/proto-loader@0.5.4 extraneous
      ├── @serialport/bindings@8.0.7 extraneous
      ├── @types/readable-stream@2.3.15 extraneous
      ├── @types/tunnel@0.0.0 extraneous
      ├── adal-node@0.1.28 extraneous
      ├── are-we-there-yet@1.1.7 extraneous
      ├── argf@0.0.1 extraneous
      ├── babel-eslint@10.1.0 extraneous
      ├── better-sqlite3@8.0.1 extraneous
      ├── binary@0.3.0 extraneous
      ├── binrpc@0.1.3 extraneous
      ├── block-stream@0.0.9 extraneous
      ├── buffer-writer@2.0.0 extraneous
      ├── buffers@0.1.1 extraneous
      ├── chainsaw@0.1.0 extraneous
      ├── UNMET DEPENDENCY colors@^1.3.3
      ├── core-js@3.6.5 extraneous
      ├── date-utils@1.2.21 extraneous
      ├── dom-storage@2.1.0 extraneous
      ├── eslint-visitor-keys@1.1.0 extraneous
      ├── eufy-security-client@1.4.0 extraneous
      ├── faye-websocket@0.11.3 extraneous
      ├── firebase@7.15.5 extraneous
      ├── UNMET DEPENDENCY fs-extra@^7.0.1
      ├── fstream@1.0.12 extraneous
      ├── gauge@2.7.4 extraneous
      ├── generate-function@2.3.1 extraneous
      ├── globals@11.12.0 extraneous
      ├── homematic-manager@1.0.14 extraneous
      ├── homematic-xmlrpc@1.0.2 extraneous
      ├── http-parser-js@0.5.2 extraneous
      ├── i18n-iso-countries@7.1.0 extraneous
      ├── idb@3.0.2 extraneous
      ├── iobroker.admin@6.3.5
      ├── iobroker.alexa2@3.23.2
      ├── iobroker.backitup@2.5.12
      ├── iobroker.broadlink2@2.1.5 invalid: "github:frankjoke/ioBroker.broadlink2#master" from the root project
      ├── iobroker.chromecast@3.0.3
      ├── iobroker.cloud@4.3.0
      ├── iobroker.daswetter@3.1.7
      ├── iobroker.deconz@1.3.21
      ├── iobroker.devices@1.1.2
      ├── iobroker.discovery@3.1.0
      ├── iobroker.eufy-security@0.7.5 extraneous
      ├── iobroker.eusec@0.9.9
      ├── iobroker.fb-checkpresence@1.1.25
      ├── iobroker.fullcalendar@1.2.0
      ├── iobroker.fullybrowser@2.1.2
      ├── iobroker.habpanel@0.5.0
      ├── iobroker.harmony@1.2.2
      ├── iobroker.history@2.2.4
      ├── iobroker.hue@3.7.1
      ├── iobroker.ical@1.13.2
      ├── iobroker.icons-icons8@0.0.1
      ├── iobroker.icons-material-png@0.1.0
      ├── iobroker.icons-material-svg@0.1.0
      ├── iobroker.icons-mfd-svg@1.1.0
      ├── iobroker.icons-open-icon-library-png@0.1.2
      ├── iobroker.influxdb@3.2.0
      ├── iobroker.info@1.9.19
      ├── iobroker.iot@1.14.2
      ├── iobroker.javascript@6.1.4
      ├── iobroker.js-controller@4.0.24
      ├── UNMET DEPENDENCY iobroker.kodi@^2.0.1
      ├── iobroker.material@1.1.2
      ├── iobroker.modbus@5.0.11
      ├── iobroker.mqtt-client@1.6.3
      ├── iobroker.mqtt@4.0.7
      ├── iobroker.myenergi@0.0.3
      ├── iobroker.net-tools@0.2.0
      ├── iobroker.nina@0.0.25
      ├── iobroker.node-red@4.0.0
      ├── iobroker.objects-redis@ invalid: "file:node_modules/iobroker.objects-redis" from the root project
      ├── iobroker.paw@0.3.2
      ├── iobroker.pi-hole@1.3.4
      ├── iobroker.ping@1.5.3
      ├── iobroker.proxmox@1.3.4
      ├── iobroker.pushbullet@0.0.11
      ├── iobroker.rpi2@1.3.2
      ├── iobroker.sbfspot@4.1.3 extraneous
      ├── iobroker.scenes@2.3.9
      ├── iobroker.shelly@6.3.1
      ├── iobroker.simple-api@2.7.2
      ├── iobroker.socketio@4.2.0
      ├── iobroker.sonos@2.2.3
      ├── UNMET DEPENDENCY iobroker.sql@^1.15.2
      ├── iobroker.synology@2.1.13
      ├── iobroker.tr-064@4.2.18
      ├── iobroker.type-detector@ invalid: "file:node_modules/iobroker.type-detector" from the root project
      ├── iobroker.vis-canvas-gauges@1.0.1
      ├── iobroker.vis-colorpicker@1.2.0
      ├── iobroker.vis-fancyswitch@1.1.0
      ├── iobroker.vis-google-fonts@1.0.4
      ├── iobroker.vis-hqwidgets@1.3.0
      ├── iobroker.vis-inventwo@3.3.1
      ├── iobroker.vis-jqui-mfd@1.0.12
      ├── iobroker.vis-material-advanced@1.7.2
      ├── iobroker.vis-materialdesign@0.3.8 invalid: "https://github.com/Scrounger/ioBroker.vis-materialdesign/tarball/300a1ee9532b76baefd761732464b0f45c8a41a3" from the root project
      ├── iobroker.vis-metro@1.2.0
      ├── iobroker.vis-players@0.1.6
      ├── iobroker.vis-timeandweather@1.2.2
      ├── iobroker.vis-weather@2.5.6
      ├── iobroker.vis@1.4.16
      ├── iobroker.weatherunderground@3.4.2
      ├── iobroker.web@4.3.0
      ├── UNMET DEPENDENCY iobroker.yr@^2.0.3
      ├── iobroker.zigbee@1.8.10
      ├── UNMET DEPENDENCY iobroker@^2.0.2
      ├── is-property@1.0.2 extraneous
      ├── isomorphic-fetch@2.2.1 extraneous
      ├── jrpc-schema@2.1.0 extraneous
      ├── jsbi@3.1.3 extraneous
      ├── jsesc@2.5.2 extraneous
      ├── kodi-ws@2.4.0 extraneous
      ├── lodash.camelcase@4.3.0 extraneous
      ├── mqtt-connection@4.0.0 extraneous
      ├── mssql@6.2.1 extraneous
      ├── mysql@2.18.1 extraneous
      ├── mysql2@3.1.0 extraneous
      ├── named-placeholders@1.1.3 extraneous
      ├── native-duplexpair@1.0.0 extraneous
      ├── nice-try@1.0.5 extraneous
      ├── node-gyp@3.8.0 extraneous
      ├── npm-bundled@1.1.2 extraneous
      ├── npm-normalize-package-bin@1.0.1 extraneous
      ├── npm-run-path@2.0.2 extraneous
      ├── npmlog@4.1.2 extraneous
      ├── ohash@1.0.0 extraneous
      ├── os-homedir@1.0.2 extraneous
      ├── osenv@0.1.5 extraneous
      ├── p-is-promise@2.1.0 extraneous
      ├── packet-reader@1.0.0 extraneous
      ├── path-key@2.0.1 extraneous
      ├── pg-connection-string@2.3.0 extraneous
      ├── pg-int8@1.0.1 extraneous
      ├── pg-pool@3.2.1 extraneous
      ├── pg-protocol@1.2.5 extraneous
      ├── pg-types@2.2.0 extraneous
      ├── pg@8.3.0 extraneous
      ├── pgpass@1.0.2 extraneous
      ├── platform@1.3.6 extraneous
      ├── postgres-array@2.0.0 extraneous
      ├── postgres-bytea@1.0.0 extraneous
      ├── postgres-date@1.0.5 extraneous
      ├── postgres-interval@1.2.0 extraneous
      ├── promise-polyfill@8.1.3 extraneous
      ├── request-promise@4.2.6 extraneous
      ├── rimraf@2.7.1 extraneous
      ├── rrule@2.6.9 extraneous
      ├── seq-queue@0.0.5 extraneous
      ├── shebang-command@1.2.0 extraneous
      ├── shebang-regex@1.0.0 extraneous
      ├── skeemas-json-pointer@1.0.0 extraneous
      ├── skeemas-json-refs@1.0.1 extraneous
      ├── skeemas@1.2.5 extraneous
      ├── source-map@0.5.7 extraneous
      ├── sql-client@2.0.3 extraneous
      ├── sqlite3@5.0.0 extraneous
      ├── sqlstring@2.3.1 extraneous
      ├── strip-eof@1.0.0 extraneous
      ├── tarn@1.1.5 extraneous
      ├── tedious@6.7.0 extraneous
      ├── to-fast-properties@2.0.0 extraneous
      ├── traverse@0.3.9 extraneous
      ├── ts-log@2.2.4 extraneous
      ├── tunnel@0.0.6 extraneous
      ├── websocket-driver@0.7.4 extraneous
      ├── websocket-extensions@0.1.4 extraneous
      ├── whatwg-fetch@3.0.0 extraneous
      ├── which@1.3.1 extraneous
      ├── xhr2@0.2.0 extraneous
      ├── xmlhttprequest@1.8.0 extraneous
      ├── xpath.js@1.1.0 extraneous
      ├── zigbee-herdsman-converters@12.0.47 extraneous
      └── zigbee-herdsman@0.12.57 extraneous
      npm ERR!     /home/iobroker/.npm/_logs/2023-04-04T20_57_20_588Z-debug-0.log
        npm ls
        @pepsi1183
        Bitte vollständig inkl. LogIn Prompt posten, damit man sieht wo du da herumstehst und ob/wo der Output komplett ist.
          npm ls
          @pepsi1183
          Keine Ahnung was da alles schief ist bei dir.
          Ordentlich schaut das jedenfalls so aus:
          echad@chet:/opt/iobroker $ npm ls
          iobroker.inst@3.0.0 /opt/iobroker
          ├── iobroker.admin@6.4.3
          ├── iobroker.alias-manager@1.2.6
          ├── iobroker.backitup@2.6.16
          ├── iobroker.ble@0.13.3
          ├── iobroker.cloud@4.4.0
          ├── iobroker.echarts@1.4.13
          ├── iobroker.firetv@1.0.0
          ├── iobroker.followthesun@0.4.1
          ├── iobroker.govee-app@0.0.3 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#f7848a9817a15db547dd5fc7f332822752d9bed6)
          ├── iobroker.iceroad@1.2.0
          ├── iobroker.info@1.9.26
          ├── iobroker.iot@1.14.5 (git+ssh://git@github.com/ioBroker/ioBroker.iot.git#6735ac3c62352103ff3e9c98bf04b0e3f91d1a21)
          ├── iobroker.javascript@7.0.3
          ├── iobroker.js-controller@5.0.1-alpha.0-20230403-fd495c2e
          ├── iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#0d037c0c9a025b193546f881f747c8f998bfc724)
          ├── iobroker.mihome-cloud@0.0.5 (git+ssh://git@github.com/TA2k/ioBroker.mihome-cloud.git#e3bfab06b04163faacaa72edd7190f8e30252e60)
          ├── iobroker.mihome-vacuum@3.9.5
          ├── iobroker.mihome@1.4.0
          ├── iobroker.miio@0.0.13
          ├── iobroker.nuki-extended@2.6.5
          ├── iobroker.opendtu@0.1.4 (git+ssh://git@github.com/o0shojo0o/ioBroker.opendtu.git#f8836ab9b984b678eaa05f4efe92f2c7f95ddb58)
          ├── iobroker.parcel@0.0.25
          ├── iobroker.sainlogic@0.10.0
          ├── iobroker.socketio@6.3.5
          ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e)
          ├── iobroker.tado@0.4.6-alpha.2
          ├── iobroker.tankerkoenig@3.3.7
          ├── iobroker.tradfri@3.1.3
          ├── iobroker.trashschedule@2.2.0
          ├── iobroker.tuya@3.14.2
          ├── iobroker.web@5.5.3
          ├── iobroker.whatsapp-cmb@0.2.3
          └── iobroker.zigbee@1.8.10
            @pepsi1183
            Pepsi1183P Offline
            Pepsi1183P Offline
            Pepsi1183
            Ok,
            wie kann ich das denn reparieren?
            Übrigens hier nochmal von Anfang:
            /opt/iobroker$ npm ls
              Ok,
              Ich weiß es nicht. Da scheinen gleich mehrere Dinge schief zu sein.
                Pepsi1183P Offline
                Pepsi1183P Offline
                Pepsi1183
                Also gibt es kein "Konfig-File" das ich durchsuchen und korrigieren kann bzw. deinstallieren und neu installieren?
                  Im Zweifel gleich mehrere. Da sind vermutlich diverses package-lock.json und auch noch die versteckten Varianten derselben im Spiel.
                  find "/opt/iobroker/" -iname "*package-lock*"
                  sagt?
                    sagt?
                    Pepsi1183P Offline
                    Pepsi1183P Offline
                    Pepsi1183
                    Sagt:
                    christoph@ioBrokerVM:/opt/iobroker$ find "/opt/iobroker/" -iname "package-lock*"
                    /opt/iobroker/node_modules/adal-node/package-lock.json
                    /opt/iobroker/node_modules/bower/packages/bower-config/package-lock.json
                    /opt/iobroker/node_modules/bower/packages/bower-json/package-lock.json
                    /opt/iobroker/node_modules/bower/lib/node_modules/bower-config/package-lock.json
                    /opt/iobroker/node_modules/bower/lib/node_modules/requireg/package-lock.json
                    /opt/iobroker/node_modules/bower/lib/node_modules/bower-json/package-lock.json
                    /opt/iobroker/node_modules/protobufjs/package-lock.json
                    /opt/iobroker/node_modules/eufy-security-client/node_modules/protobuf-typescript/package-lock.json
                    /opt/iobroker/node_modules/eufy-security-client/node_modules/protobuf-typescript/cli/package-lock.json
                    /opt/iobroker/node_modules/iobroker.eusec/node_modules/protobuf-typescript/package-lock.json
                    /opt/iobroker/node_modules/iobroker.eusec/node_modules/protobuf-typescript/cli/package-lock.json
                    /opt/iobroker/node_modules/iobroker.javascript/package-lock.json
                    /opt/iobroker/node_modules/iobroker.vis-materialdesign/package-lock.json
                    /opt/iobroker/node_modules/npm-normalize-package-bin/package-lock.json
                    /opt/iobroker/package-lock.json
                      Sagt:
                      @pepsi1183
                      Siehste.
                      Bei mir sind das nur 2 Dateien:
                      echad@chet:~ $ find "/opt/iobroker/" -iname "*package-lock*"
                      /opt/iobroker/node_modules/.package-lock.json
                        @pepsi1183
                        Siehste.
                        Pepsi1183P Offline
                        Pepsi1183P Offline
                        Pepsi1183
                        rest mal löschen? Verschieben?
                          rest mal löschen?
                          Kannst die alle löschen. Aber ich kann dir nicht versprechen das es damit getan ist. Oder der iobroker wieder auf die Beine kommt.
                          iob stop
                          find "/opt/iobroker/" -iname "*package-lock*" -exec rm "{}" \;
                          iob fix
                          iob start
                            rest mal löschen?
                            iob stop
                            iob fix
                            iob start
                            Pepsi1183P Offline
                            Pepsi1183P Offline
                            Pepsi1183
                            die Fehlermeldung beim installieren wird kürzer ;)
                             iobroker add semp auto --host ioBrokerVM --debug
                            NPM version: 9.5.0
                            Installing iobroker.semp@0.1.0... (System call)
                            npm WARN tarball tarball data for iobroker.type-detector@file:iobroker.type-detector (null) seems to be corrupted. Trying again.
                            npm WARN tarball tarball data for iobroker.type-detector@file:iobroker.type-detector (null) seems to be corrupted. Trying again.npm WARN tarball tarball data for iobroker.objects-redis@file:iobroker.objects-redis (null) seems to be corrupted. Trying again.
                            host.ioBrokerVM Cannot install iobroker.semp@0.1.0: 254
                            ERROR: Process exited with code 25
                              NPM version: 9.5.0
                              @pepsi1183
                              Lass die Finger von Installationen, solange der tree nicht sauber ist.
                              Wie schaut
                              cd /opt/iobroker
                              npm ls
                              nun aus?
                                @pepsi1183
                                Wie schaut
                                cd /opt/iobroker
                                npm ls
                                nun aus?
                                Pepsi1183P Offline
                                Pepsi1183P Offline
                                Pepsi1183
                                ok....
                                christoph@ioBrokerVM:/opt/iobroker$ npm ls
                                npm ERR!     /home/iobroker/.npm/_logs/2023-04-04T21_27_33_356Z-debug-0.log
                                  ok....
                                  @pepsi1183
                                  Immer noch zu strubbelig.
                                  npm prune
                                  führt zu welchem Bild?
                                    @pepsi1183
                                    npm prune
                                    Pepsi1183P Offline
                                    Pepsi1183P Offline
                                    Pepsi1183
                                    das hier:
                                    christoph@ioBrokerVM:/opt/iobroker$ npm prune
                                    npm ERR! path /opt/iobroker/iobroker.type-detector/package.json
                                    npm ERR! errno -2
                                    npm ERR! enoent ENOENT: no such file or directory, open '/opt/iobroker/iobroker.type-detector/package.json'
                                    npm ERR! enoent
                                    npm ERR!     /home/iobroker/.npm/_logs/2023-04-04T21_30_58_213Z-debug-0.log
                                      das hier:
                                      npm ERR! errno -2
                                      npm ERR! enoent
                                      @pepsi1183
                                      Ich weiß es nicht.
                                      Installier es ordentlich neu. Und hoffe, dass du die Knoten nicht schon in deinem Backup drin hast.
                                        @pepsi1183
                                        Ich weiß es nicht.
                                        Pepsi1183P Offline
                                        Pepsi1183P Offline
                                        Pepsi1183
                                        Ok, teste das morgen mal mit einer neuen VM von grund auf und spiele ein backup ein.....mal sehen was passiert.....
                                          Pepsi1183P Offline
                                          Pepsi1183P Offline
                                          Pepsi1183
                                          @Thomas-Braun
                                          Ähm, wie spiele ich am besten ein Backup ein? Bzw. wie erstelle ich eines?
                                          Backitup ?
