  4. esphome - wird dies noch gepflegt?
    6.3k
44 Beiträge 9 Kommentatoren 9.0k Aufrufe 12 Beobachtet
    @tobiasp
    Dann bist hast nicht das beta-Repo aktiv.
    Der Adapter ist noch nicht in einer stabilen Version veröffentlicht worden.
    Davon abgesehen sagt
    iob diag
    was zu deinem System?
    tobiasp
    #41
    ====================== SUMMARY =======================
    v.2023-10-10
    Static hostname: raspberrypi
    Icon name: computer
    Operating System: Raspbian GNU/Linux 11 (bullseye)
    Kernel: Linux 6.1.21-v7l+
    Architecture: arm
    Installation: native
    Kernel: armv7l
    Userland: armhf
    Timezone: Europe/Berlin (CET, +0100)
    User-ID: 1000
    /home/iobroker/.diag.sh: line 469: [[: 1010
    2037: syntax error in expression (error token is "2037")
    X-Server: false
    Boot Target: graphical.target
    Pending OS-Updates: 0
    Pending iob updates: 13
    Nodejs-Installation: /usr/bin/nodejs v18.19.0
    /usr/bin/node v18.19.0
    /usr/bin/npm 10.2.3
    /usr/bin/npx 10.2.3
    /usr/bin/corepack 0.22.0
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    MEMORY:
    total used free shared buff/cache available
    Mem: 3.8G 2.1G 770M 35M 1.0G 1.6G
    Swap: 99M 0B 99M
    Total: 3.9G 2.1G 870M
    Active iob-Instances: 39
    Active repo(s): Beta (latest)
    ioBroker Core: js-controller 5.0.17
    admin 6.12.0
    ioBroker Status: iobroker is running on this host.
    Objects type: jsonl
    States type: redis
    • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 192.168.2.130, run as: admin
    • system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
    • system.adapter.web.1 : web : raspberrypi - enabled, port: 20002, bind: 0.0.0.0, run as: admin
    Objects: 20192
    States: 15783
    Size of iob-Database:
    43M /opt/iobroker/iobroker-data/objects.jsonl
    4.1M /opt/iobroker/iobroker-data/states.jsonl
    =================== END OF SUMMARY ==
    • T tobiasp
      v.2023-10-10
      Icon name: computer
      Architecture: arm
      Kernel: armv7l
      Userland: armhf
      User-ID: 1000
      X-Server: false
      /usr/bin/npm 10.2.3
      /usr/bin/npx 10.2.3
      MEMORY:
      Swap: 99M 0B 99M
      admin 6.12.0
      Objects type: jsonl
      States type: redis
      Objects: 20192
      States: 15783
      #42
      @tobiasp
      Die Langfassung.
      In CodeTags eingebettet.
        @tobiasp
        Die Langfassung.
        tobiasp
        #43
        @thomas-braun ```
        ======= Start marking the full check here =========
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Model		: Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         13:00:37 up 27 min,  2 users,  load average: 10.84, 6.09, 3.80
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sat 2024-01-13 13:00:37 CET
                   Universal time: Sat 2024-01-13 12:00:37 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        /home/iobroker/.diag.sh: line 200: [[: 1010
        X-Server: 	false
        Desktop: 	LXDE
        Terminal: 	x11
        *** MEMORY ***
        Mem:            3.8G        2.3G        325M         35M        1.2G        1.4G
        Swap:            99M          0B         99M
        Total:          3.9G        2.3G        425M
                 3839 M total memory
                 2296 M used memory
                  556 M active memory
                 2634 M inactive memory
                  325 M free memory
                  173 M buffer memory
                 1043 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        lifetime oom required: 0 Mbytes
        total time in oom handler: 0 ms
        max time spent in oom handler: 0 ms
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       29G   13G   16G  44% /
        devtmpfs       devtmpfs  1.9G     0  1.9G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     768M  1.2M  767M   1% /run
        /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
        tmpfs          tmpfs     384M   16K  384M   1% /run/user/1000
        [Sat Jan 13 12:33:30 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=480 bcm2708_fb.fbheight=320 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:84:C6:E5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=e83fc39a-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Sat Jan 13 12:33:32 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sat Jan 13 12:33:32 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sat Jan 13 12:33:34 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems \(real ones only\):
        TARGET                       SOURCE         FSTYPE            OPTIONS
        /                            /dev/mmcblk0p2 ext4              rw,noatime
        |-/boot                      /dev/mmcblk0p1 vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        `-/home/pi/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        /var:
        du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
        3.0G	/var/
        2.0G	/var/log/journal/930d3456bd0f4a518633913ebabe942b
        2.0G	/var/log
        642M	/var/lib
        Archived and active journals take up 1.9G in the file system.
        /opt/iobroker/backups:
        338M	/opt/iobroker/backups/
        4.0K	/opt/iobroker/backups/redistmp
        /opt/iobroker/iobroker-data:
        2.7G	/opt/iobroker/iobroker-data/
        2.0G	/opt/iobroker/iobroker-data/history
        590M	/opt/iobroker/iobroker-data/files
        89M	/opt/iobroker/iobroker-data/files/echarts.admin
        78M	/opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        23M	/opt/iobroker/iobroker-data/objects.jsonl
        23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
        USB-Devices by-id:
        USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
        find: '/dev/serial/by-id/': No such file or directory
        *** NodeJS-Installation ***
        /usr/bin/npm 		10.2.3
        /usr/bin/npx 		10.2.3
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        Core adapters versions
        js-controller: 	5.0.17
        admin: 		6.12.0
        javascript: 	7.1.6
        Adapters from github: 	8
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.2.130, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
        + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        + system.adapter.countdown.0              : countdown             : raspberrypi                              -  enabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
          system.adapter.devices.0                : devices               : raspberrypi                              - disabled
        + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
        + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
        + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
        + system.adapter.energiefluss.1           : energiefluss          : raspberrypi                              -  enabled
          system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
        + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
          system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.iceroad.0                : iceroad               : raspberrypi                              - disabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              -  enabled
          system.adapter.meteoalarm.0             : meteoalarm            : raspberrypi                              -  enabled
          system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1884, bind: 192.168.2.130
        + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, port: 1888, bind: 192.168.2.130
        + system.adapter.mqtt.2                   : mqtt                  : raspberrypi                              -  enabled, port: 1896, bind: 0.0.0.0
          system.adapter.onkyo.0                  : onkyo                 : raspberrypi                              - disabled
        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
          system.adapter.ryd.0                    : ryd                   : raspberrypi                              -  enabled
        + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
          system.adapter.tvprogram.0              : tvprogram             : raspberrypi                              - disabled
        + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
          system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
          system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              - disabled
          system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
          system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
        + system.adapter.web.1                    : web                   : raspberrypi                              -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
          system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
        + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8095, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Installed ioBroker-Instances
        Used repository: Beta (latest)
        Adapter    "accuweather"  : 1.3.2    , installed 1.3.2
        Adapter    "admin"        : 6.13.15  , installed 6.12.0 [Updatable]
        Adapter    "alarm"        : 3.6.0    , installed 3.4.3  [Updatable]
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
        Adapter    "backitup"     : 2.10.1   , installed 2.9.8  [Updatable]
        Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
        Adapter    "countdown"    : 2.2.0    , installed 2.2.0
        Adapter    "daswetter"    : 3.1.13   , installed 3.1.11 [Updatable]
        Adapter    "devices"      : 1.1.5    , installed 1.1.5
        Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
        Adapter    "discovery"    : 4.2.0    , installed 4.2.0
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.14-alpha.4
        Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
        Adapter    "esphome"      : 0.5.0-beta.8, installed 0.5.0-beta.8
        Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.16.0   , installed 1.15.19 [Updatable]
        Adapter    "ical"         : 1.14.0   , installed 1.13.3 [Updatable]
        Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
        Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
        Adapter    "icons-material-png": 0.1.0, installed 0.1.1
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
        Adapter    "info"         : 2.0.0    , installed 2.0.0
        Adapter    "javascript"   : 7.6.3    , installed 7.1.6  [Updatable]
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
        Adapter    "meteoalarm"   : 2.3.7    , installed 2.3.7
        Adapter    "mqtt"         : 5.2.0    , installed 5.1.0  [Updatable]
        Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
        Adapter    "smartthings"  : 0.1.1    , installed 0.0.4  [Updatable]
        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
        Adapter    "trashschedule": 3.1.3    , installed 2.3.0  [Updatable]
        Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis"          : 1.5.4    , installed 1.5.4
        Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
        Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
        Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
        Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
        Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.6  [Updatable]
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.2.3    , installed 6.1.10 [Updatable]
        Adapter    "worx"         : 2.3.4    , installed 2.3.4
        Adapter    "ws"           : 2.5.10   , installed 2.5.8  [Updatable]
        Objects and States
        Objects: 	20170
        States: 	15747
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.2.130:8081      0.0.0.0:*               LISTEN      1001       102238     19610/io.admin.0
        tcp        0      0 192.168.2.130:2010      0.0.0.0:*               LISTEN      1001       104075     20130/io.hm-rpc.0
        tcp        0      0 192.168.2.130:2001      0.0.0.0:*               LISTEN      1001       104098     20266/io.hm-rpc.1
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      111        1971       933/redis-server 12
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       105756     20520/io.sonoff.0
        tcp        0      0 192.168.2.130:1888      0.0.0.0:*               LISTEN      1001       104902     20418/io.mqtt.1
        tcp        0      0 0.0.0.0:1897            0.0.0.0:*               LISTEN      1001       105737     20458/io.mqtt.2
        tcp        0      0 0.0.0.0:1896            0.0.0.0:*               LISTEN      1001       105736     20458/io.mqtt.2
        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          13133      1027/dnsmasq
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       102004     19570/iobroker.js-c
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15415      968/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      0          131088     26215/nc
        tcp        0      0 192.168.2.130:9292      0.0.0.0:*               LISTEN      1001       105653     20403/io.hm-rpc.2
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       112465     21969/io.terminal.0
        tcp6       0      0 :::8095                 :::*                    LISTEN      1001       106247     21177/io.ws.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       108657     20889/io.web.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       108807     21162/io.simple-api
        tcp6       0      0 ::1:3350                :::*                    LISTEN      0          1916       959/xrdp-sesman
        tcp6       0      0 :::3389                 :::*                    LISTEN      116        14731      1012/xrdp
        tcp6       0      0 ::1:6379                :::*                    LISTEN      111        1972       933/redis-server 12
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15417      968/sshd: /usr/sbin
        tcp6       0      0 :::20002                :::*                    LISTEN      1001       116875     22117/io.web.1
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14097      401/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       117906     22757/io.upnp.0
        udp        0      0 0.0.0.0:58349           0.0.0.0:*                           108        14099      401/avahi-daemon: r
        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          13132      1027/dnsmasq
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          13129      1027/dnsmasq
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12884      812/dhclient
        udp        0      0 0.0.0.0:49274           0.0.0.0:*                           1001       116522     22757/io.upnp.0
        udp6       0      0 :::5353                 :::*                                108        14098      401/avahi-daemon: r
        udp6       0      0 :::39980                :::*                                108        14100      401/avahi-daemon: r
        2024-01-13 13:01:03.374  - info: energiefluss.1 (22735) Adapter started and listening to 5 States
        2024-01-13 13:01:04.706  - info: upnp.0 (22757) starting. Version 1.0.21 (non-npm: Jey-Cee/ioBroker.upnp#3c2a5fa39827e3615080e354eb75d6441ebfd5b3) in /opt/iobroker/node_modules/iobroker.upnp, node: v18.19.0, js-controller: 5.0.17
        2024-01-13 13:01:04.835  - info: upnp.0 (22757) Auto discover: true
        2024-01-13 13:01:08.076  - warn: upnp.0 (22757) Error: Error: Non-whitespace before first tag.
        Line: 0
        Column: 1
        Char: s
        2024-01-13 13:01:09.821  - info: ryd.0 (22037) Terminated (NO_ERROR): Without reason
        2024-01-13 13:01:09.843  - info: ryd.0 (22037) State value to set for "ryd.0.lastUpdate" has to be stringified but received type "object"
        2024-01-13 13:01:10.648  - info: host.raspberrypi instance system.adapter.ryd.0 terminated with code 0 (NO_ERROR)
        2024-01-13 13:01:12.858  - info: pollenflug.0 (21722) Next DWD pollen request starts on Sun Jan 14 2024 11:00:00 GMT+0100 (Central European Standard Time)
        2024-01-13 13:01:17.075  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-01-13 13:01:29.897  - info: fahrplan.0 (21586) Updated 2 routes, 2 enabled and 0 disabled
        2024-01-13 13:01:32.038  - info: fahrplan.0 (21586) Updated 1 departure timetables, 1 enabled and 0 disabled
        2024-01-13 13:01:32.796  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-01-13 13:01:48.907  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-01-13 13:01:49.905  - info: vis.0 (24342) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
        2024-01-13 13:01:52.364  - info: vis-google-fonts.0 (24382) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v18.19.0, js-controller: 5.0.17
        2024-01-13 13:01:53.411  - info: vis-google-fonts.0 (24382) Terminated (NO_ERROR): Without reason
        2024-01-13 13:01:54.799  - info: vis.0 (24342) Terminated (NO_ERROR): Without reason
        2024-01-13 13:02:04.803  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-01-13 13:02:05.759  - info: tankerkoenig.0 (21775) Start first request
        2024-01-13 13:02:20.153  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-01-13 13:02:35.279  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2024-01-13 13:02:50.813  - info: tr-064.0 (20802) forEachConfiguredDevice: in GetSpecificHostEntry 21(robotic-mower/98:D8:63:44:D8:D8) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        iob diag has finished.
        • T tobiasp
          @thomas-braun ```
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Docker          : false
          Kernel          : armv7l
          Userland        : armhf
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server: 	false
          Desktop: 	LXDE
          Terminal: 	x11
          *** MEMORY ***
          Swap:            99M          0B         99M
                   3839 M total memory
                   2296 M used memory
                    556 M active memory
                    325 M free memory
                    173 M buffer memory
                   1043 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          3.0G	/var/
          2.0G	/var/log
          642M	/var/lib
          USB-Devices by-id:
          /usr/bin/npm 		10.2.3
          /usr/bin/npx 		10.2.3
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: redis
          admin: 		6.12.0
          javascript: 	7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	20170
          States: 	15747
          Pending Updates: 0
          Line: 0
          Column: 1
          Char: s
          #44
          @tobiasp
          Das Ding ist komplett schief aufgesetzt.
          Installier da NEU ein 64Bit Raspberry OS Lite.
