  4. Iobroker startet nach Stromausfall nicht mehr
55 Beiträge 9 Kommentatoren 7.1k Aufrufe 4 Beobachtet
  • Hardy 0H Hardy 0
    @wendy2702
    Das ist der Log.
    -----                  Step 1 of 5: Preparing container                   -----
    This is not the first run of this container. Skipping first run preparation.
    Installing additional packages is set by ENV.
    Checking the following Packages: ...
    Reading package lists...
    Building dependency tree...
    Reading state information...
    0 upgraded, 0 newly installed, 0 to remove and 33 not upgraded.
    Done.
    -----             Step 2 of 5: Detecting ioBroker installation             -----
    Existing installation of ioBroker detected in /opt/iobroker.
    -----             Step 3 of 5: Checking ioBroker installation              -----
    (Re)Setting folder permissions (This might take a while! Please be patient!)... Done.
    Fixing "sudo-bug" by replacing sudo in iobroker with gosu... Done.
    -----                Step 4 of 5: Applying special settings                -----
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
    Usb-device-support is activated by ENV.
    chown: cannot access '/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_fe07bd7d7029ec118b5a6c7840c9ce8d-if00-port0': No such file or directory
    chmod: cannot access '/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_fe07bd7d7029ec118b5a6c7840c9ce8d-if00-port0': No such file or directory
    Setting permissions for /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_fe07bd7d7029ec118b5a6c7840c9ce8d-if00-port0... Done.
    -----                    Step 5 of 5: ioBroker startup                     -----
    Starting ioBroker...
    host.b8818f500ddc check instance "system.adapter.admin.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.javascript.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.pushover.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.pushover.1" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.influxdb.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.influxdb.1" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.zigbee.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.alexa2.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.hm-rega.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.hm-rpc.1" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.sonoff.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.mqtt.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.ping.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.hm-rpc.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.ical.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.discovery.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.wled.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.accuweather.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.daswetter.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.device-reminder.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.device-reminder.1" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.easee.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.echarts.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.iot.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.text2command.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.unifi.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.web.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.vis.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.vis-bars.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.vis-canvas-gauges.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.vis-hqwidgets.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.vis-google-fonts.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.vis-material-advanced.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.vis-timeandweather.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.vis-inventwo.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.vis-lcars.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.trashschedule.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.gotify.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.gotify.1" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.habpanel.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.bluelink.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.youtube.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.kodi.0" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.gotify.2" for host "b8818f500ddc"
    host.b8818f500ddc check instance "system.adapter.gotify.3" for host "b8818f500ddc"
    Send diag info: {"uuid":"1bfd457b-36fe-4c7b-ae7e-c539150694f2","language":"de","country":"Germany","hosts":[{"version":"4.0.24","platform":"Javascript/Node.js","type":"linux"}],"node":"v16.17.1","arch":"x64","docker":true,"adapters":{"admin":{"version":"6.3.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":"Javascript/Node.js"},"zigbee":{"version":"1.8.10","platform":"Javascript/Node.js"},"javascript":{"version":"6.1.4","platform":"Javascript/Node.js"},"wled":{"version":"0.6.7","platform":"Javascript/Node.js"},"accuweather":{"version":"1.2.1","platform":"Javascript/Node.js"},"alexa2":{"version":"3.23.2","platform":"Javascript/Node.js"},"daswetter":{"version":"3.1.7","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.15.16","platform":"Javascript/Node.js"},"hm-rega":{"version":"3.0.44","platform":"Javascript/Node.js"},"pushover":{"version":"3.0.3","platform":"Javascript/Node.js"},"sonoff":{"version":"2.5.1","platform":"Javascript/Node.js"},"device-reminder":{"version":"1.2.9","platform":"Javascript/Node.js"},"easee":{"version":"1.0.7","platform":"Javascript/Node.js"},"echarts":{"version":"1.0.12","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"iot":{"version":"1.14.2","platform":"Javascript/Node.js"},"text2command":{"version":"2.3.0","platform":"Javascript/Node.js"},"ical":{"version":"1.13.2","platform":"Javascript/Node.js"},"trashschedule":{"version":"2.2.0","platform":"Javascript/Node.js"},"unifi":{"version":"0.5.10","platform":"Javascript/Node.js"},"web":{"version":"4.3.0","platform":"Javascript/Node.js"},"vis":{"version":"1.4.15","platform":"Javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-canvas-gauges":{"version":"1.0.1","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.3.0","platform":"Javascript/Node.js"},"vis-google-fonts":{"version":"1.0.4","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.1.0","platform":"Javascript/Node.js"},"vis-material-advanced":{"version":"1.7.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.2.2","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"3.3.1","platform":"Javascript/Node.js"},"vis-lcars":{"version":"1.0.4","platform":"Javascript/Node.js"},"mqtt":{"version":"4.0.7","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"gotify":{"version":"0.0.1","platform":"Javascript/Node.js"},"habpanel":{"version":"0.5.0","platform":"Javascript/Node.js"},"devices":{"version":"1.1.2","platform":"Javascript/Node.js"},"bluelink":{"version":"2.2.5","platform":"Javascript/Node.js"},"chromecast":{"version":"2.3.1","platform":"Javascript/Node.js"},"youtube":{"version":"4.1.0","platform":"Javascript/Node.js"},"kodi":{"version":"2.0.8","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":47,"compactMode":false,"noCompactInstances":0,"model":"Common KVM processor","cpus":4,"mem":8343470080,"ostype":"Linux","city":"Teltow","vis":22}
    ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
    MOD EDIT: CODE TAGS KORRIGIERT
    Hardy 0H Offline
    Hardy 0H Offline
    Hardy 0
    schrieb am zuletzt editiert von Hardy 0
    #41
    @wendy2702 OK Danke - kann man da was erkennen?
    • wendy2702W Offline
      wendy2702W Offline
      wendy2702
      #42
      @hardy-0 Sehe da erstmal nichts negatives, betreibe selber IOB auch nicht im Docker.
      Ist das der Inhalt des IOB logs?
      /opt/iobroker/log/....
      Hardy 0H 1 Antwort Letzte Antwort
      • wendy2702W wendy2702
        Hardy 0H Offline
        Hardy 0H Offline
        Hardy 0
        #43
        @wendy2702 leider gibt es den Ordner nicht auf der VM....
        Gibt nur /opt/ mit z.b. nextcloud aber ibroker nicht...
        Oder muss ich woanders suchen?
        • Hardy 0H Hardy 0
          wendy2702W Offline
          wendy2702W Offline
          wendy2702
          #44
          @hardy-0 Ja, du musst im Container suchen.
            Hardy 0H Offline
            Hardy 0H Offline
            Hardy 0
            #45
            @wendy2702 Also daten sind im Ordner: /var/lib/docker/volumes/iobroker/_data vorhanden.
            wendy2702W Hardy 0H 2 Antworten Letzte Antwort
            • Hardy 0H Hardy 0
              wendy2702W Offline
              wendy2702W Offline
              wendy2702
              #46
              @hardy-0 Dann gibt es bestimmt auch ein Logfile im iobroker log ordner
              • Hardy 0H Hardy 0
                Hardy 0H Offline
                Hardy 0H Offline
                Hardy 0
                #47
                • Hardy 0H Hardy 0
                  wendy2702W Offline
                  wendy2702W Offline
                  wendy2702
                  #48
                  @hardy-0 Vielleicht im ersten Ordner von oben....
                  der "log" heisst
                    Hardy 0H Offline
                    Hardy 0H Offline
                    Hardy 0
                    #49
                    @wendy2702
                    2023-03-12 00:00:00.069  - info: host.b8818f500ddc instance system.adapter.daswetter.0 started with pid 24301
                    2023-03-12 00:00:01.365  - info: daswetter.0 (24301) starting. Version 3.1.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.17.1, js-controller: 4.0.24
                    2023-03-12 00:00:01.390  - info: daswetter.0 (24301) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                    2023-03-12 00:00:01.952  - info: daswetter.0 (24301) cleaned everything up...
                    2023-03-12 00:00:02.022  - info: host.b8818f500ddc instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-03-12 00:00:02.360  - info: easee.0 (781) undefined is not a valid state value for id "easee.0.EH5ZAXPD.status.latestFirmware"
                    2023-03-12 00:00:04.131  - info: host.b8818f500ddc instance system.adapter.ical.0 started with pid 24330
                    2023-03-12 00:00:05.959  - info: ical.0 (24330) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v16.17.1, js-controller: 4.0.24
                    2023-03-12 00:00:07.475  - info: ical.0 (24330) processing URL: abfall https://apm.wastebox.gemos-management.de/Gemos/WasteBox/Frontend/TourSchedule/Raw/Name/2023/List/156279/1427,1429,1431,1433,1434,1435,1436,1437/180/Print/ics/Default/Abfuhrtermine.ics
                    2023-03-12 00:00:08.164  - info: host.b8818f500ddc instance system.adapter.youtube.0 started with pid 24345
                    2023-03-12 00:00:10.056  - info: youtube.0 (24345) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.youtube, node: v16.17.1, js-controller: 4.0.24
                    2023-03-12 00:00:10.720  - info: youtube.0 (24345) Terminated (NO_ERROR): Without reason
                    2023-03-12 00:00:11.259  - info: host.b8818f500ddc instance system.adapter.youtube.0 terminated with code 0 (NO_ERROR)
                    2023-03-12 00:00:12.792  - info: ical.0 (24330) Terminated (NO_ERROR): Without reason
                    2023-03-12 00:00:13.334  - info: host.b8818f500ddc instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                    • Hardy 0H Hardy 0
                      @wendy2702
                      wendy2702W Offline
                      wendy2702W Offline
                      wendy2702
                      #50
                      @hardy-0 sagte in Iobroker startet nach Stromausfall nicht mehr:
                      2023-03-12
                      das ist alt oder deine Time settings stimmen nicht
                        2023-03-12
                        Hardy 0H Offline
                        Hardy 0H Offline
                        Hardy 0
                        #51
                        @wendy2702 Habe die VM zurückgesetzt, ist vom 12.3.23...
                        • Hardy 0H Hardy 0
                          wendy2702W Offline
                          wendy2702W Offline
                          wendy2702
                          #52
                          @hardy-0 Wenn du die neu startest, sollte es ein log mit aktuellem Datum geben wenn das in der VM und im Container korrekt ist.
                          Ein Fehler ist in dem Schnipsel nicht zu sehen.
                            Hardy 0H Offline
                            Hardy 0H Offline
                            Hardy 0
                            #53
                            @wendy2702 Alles klar. Vielen dank für Deine Mühe... kann mir das überhaupt nicht erklären. Aber ich gebe nicht auf und suche weiter nach einer Lösung. LG Hardy
                              Hardy 0H Offline
                              Hardy 0H Offline
                              Hardy 0
                              #54
                              @wendy2702 Ich nochmal - habe mal portainer beendet, dann iob mit docker start iobroker versucht - Fehlermeldung war diese:
                              "root@docker:~# docker start iobroker
                              Error response from daemon: error gathering device information while adding custom device "/dev/serial/by-id/usb-ITead_Sonoff_Zigb ee_3.0_USB_Dongle_Plus_fe07bd7d7029ec118b5a6c7840c9ce8d-if00-port0": no such file or directory
                              Error: failed to start containers: iobroker
                              Hab dann in Portainer den Stick entfernt - den Container neu bauen lassen und was soll ich sagen... er läuft!
                              Lag also am durchgereichten zigbee-stick.
                              Hätte ich auch früher drauf kommen können...
                              • Hardy 0H Hardy 0
                                wendy2702W Offline
                                wendy2702W Offline
                                wendy2702
                                #55
                                @hardy-0 Sehr gut das es wieder funktioniert.
                                Etwas mit den Sticks oder dem Stick stand sogar im Log, wusste aber nicht das Docker dann nicht startet.
                                Ich würde mir an deiner Stelle aber mal Grundsätzlich gedanken über das Setup machen.
                                Proxmox --> VM --> Portainer --> Docker Container macht das handling unnötig aufwendig und kompliziert.
                                Warum nutzt du Proxmox wenn du eh darin alles in extra Docker Container verpackst?
